![]() Join Date: Apr 2019
Rep Power: 0 ![]() Thanks: 0
![]() Join Date: Oct 2013 Location: Vermont
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 139
| Not Ranked : 0 score Does it go away or sound different if the clutch pedal is pressed to the floor? How many miles on the car? Sent from my SM-G975U using Tapatalk
__________________ 2012 Speed3 - Velocity Red Mica Current Mods JBR Solid Shifter Bushings: Corksport Stage II SRI/TIP: CP-E Stage II Rear Motor Mount: AutoTech Internals: Cobb AccessPort V3: UR Test Pipe: Cobb 3" Catback Exhaust: JBR Boost Tubes: ETS TMIC: Denso ITV22s: JBR EGR Block Off Kit: JBR RSB: TS Kompact BPV: Tuned by Rob |
![]() Join Date: Nov 2016 Location: AZ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 550
Groans: 105
| Not Ranked : 0 score zzb
__________________ Stockish |
(Thread Starter) | Not Ranked : 0 score Pressing clutch pedal doesn’t change anything. I can rev in neutral and it comes on with clutch depressed and in gear. But if your going on boost then out into neutral on highway the noise stops, but revving in neutral it comes back, in gear also. Basically only when you touch accelerator anytime it comes on.I have 52k miles no mods, been doing since 46k miles hasn’t gotten any louder since then. Took to a mechanic today he couldn’t source the issue, saying it was my turbo or it could be a pulley free spinning and needs to be replaced. But if it was my turbo how come I can hit full boost then neutral and it goes away wouldn’t it spool down and keep making the noise before I add any more engine load so it comes back? |
![]() Join Date: Sep 2011 Location: Jacksonville FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 127
Groaned at 12 Times in 7 Posts
| Not Ranked : 0 score I doubt it's the turbo. It's speed varies greatly compared to engine RPM...so any noise from it would be variable by comparison.
__________________ Traded in: 2012 MS3, CWP 2019 Dodge Charger Scat Pack 1986 Buick T-Type, square |
(Thread Starter) | Not Ranked : 0 score Found video of some guys speed3 from 6-9 seconds at start mine makes same metallic noise 24/7 when I drive. https://youtu.be/PuXtm8y9Yh0 I bought this car used is it just normal then? All of my friends and the mechanics I’ve seen say it’s not. |
| Not Ranked : 0 score I don't hear any strange noises in that video. Are you talking about the rush of air when he stabs the throttle?
![]() Join Date: Oct 2015 Location: Central Jerz
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 17
| Not Ranked : 0 score I didnt hear anything either, unless hes talking about the super faint rotating kinda sound after the 3rd rev.
__________________ 2010 MS3 - Tuned By Nishan Autotech Fuel Pump Internals OBX R Custom Exhaust Cobb SF Intake & TIH w. Blitz Filter CP-e TMIC Corksport Dual VTA BPV JBR 88 Duro RMM |
(Thread Starter) | Not Ranked : 0 score I’m not sure, I can hear a metal chain spinning sounds when he revs at start slowly with air sounds and engine sounds with it. I tried to get my own video of mine but it’s too hard to hear in the video. But that noise is closest that resembles my issue right now. I can only hear it in the video mainly from 6-9 seconds after that his car got to loud. Last edited by sandersjosh12; 04-19-2019 at 02:05 PM. |
(Thread Starter) | Not Ranked : 0 score Found this old thread too same issue I believe: annoying high pitch noise |
![]() Join Date: Sep 2013 Location: Ontario, Canada
Rep Power: 85 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2
| Not Ranked : 0 score That chain-like rotating noise is normal, I know exactly what you're describing. More noticeable when driving close to a wall like a drive thru for example. It probably has something to do with our HPFP, my car has made that sound since new. The Speed6 has an even louder "chain" sound. Engine shroud quiets it down, if you go FMIC or TMIC with no shroud it will get louder.
__________________ 2010 Black MS3 (autocross/track duty) Stratified tune, Accessport, Corksport HPFP, Corksport TMIC, Ultimate Racing test pipe, K&N intake, E-focus RMM, Corksport RSB, Corksport steering wheel + ebrake handle, solid shifter bushings, RE-71R tires 2007 Black Speed6 (daily driver) Freektune, Accessport, Autotech HPFP, CPE TMIC, Ultimate Racing test pipe, Cobb intake + TIP, Corksport rear diff mount, CPE xflex RMM, Corksport rear brake pads, Matt Damond rear caliper bushings, solid shifter bushings, X-ice3 / AS3+ tires |
| Metallic jangling in rear? | streetskater | MazdaSpeed 3/6 - Suspension & Brakes | 6 | 07-03-2017 07:57 AM |
| 07 MS6 macadamia metallic | iTygarin | MazdaSpeed 3/6 - Build Diaries | 78 | 09-05-2015 03:26 AM |
| Advan RS Dark Gun Metallic 18's | randyb559 | 2010 MS3 - Wheels & Tires | 61 | 11-03-2014 10:17 AM |
| Metallic Green Mazda2 | triplejumper18 | Car Detailing | 3 | 07-13-2012 01:43 PM |
| metallic black | Palms | Appearance - BLACK | 1 | 04-17-2010 07:46 PM |
