![]() Join Date: Oct 2011
Rep Power: 0 ![]() Thanks: 0
Groaned at 51 Times in 12 Posts
(Thread Starter) | Not Ranked : 0 score when i owned my 2003 evo and ran catless test pipe, buschur racing had offered an o2 cheater. it was nothing more than this resister with a little light on it. fooled the ECU into thinking the cat was still there for emission purposes. anything like that in the ms3 world? now on my z06 i just have it tuned out in the ECU but wasnt sure that was possible or not. kinda a newb here. owned mostly german cars.
__________________ |
![]() Join Date: Mar 2011 Location: Boca Raton, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,500
Groans: 669
| Not Ranked : 0 score It's called a defouler Search here But you can also get a Cobb AccessPort and clear the code. Search the forum to get more answers.
__________________ Fast cars are for straight lines. Corners are for fast drivers. 2006 Corvette Z06 - AKA "El Zorro" Sold: 2012 Evolution X GSR - 394awhp / 378awtq Sold: 2011 MS3 Hypnotic Tuned @ 322whp/370tq |
| The Following User Says Thank You to adlpb For This Useful Post: | SLOWHATCH (11-10-2011) |
(Thread Starter) | Not Ranked : 0 score i know all about anti foulers but....sometimes they do not work. ive had them do both. the o2 cheater/resistor is a sure thing. and to my knowledge, the AP will only clear the code, not get rid of it completly.
Groans: 669
| Not Ranked : 0 score Well the Cobb AP is pretty much a necessary mod for a downpipe, so if you get it then you can just clear the CEL code using it.
(Thread Starter) | Not Ranked : 0 score ok maybe u dont get what im saying....... the Cobb AP will not completly fix the problem of not having a Cat, will only clear the codes. now this is not a fix, just a bandaid until the code comes back. an anti-fouler might work. but if someone makes an o2 cheater....thats a certain fix. unless you can ready the codes with the AP now am im unaware of this. not to mention the AP isnt out yet for the 2012's.
Groans: 669
This is the first time I've read the "02 cheater" term in this forum. I was under the impression that a defouler would have similar (if not the same) properties. But you would have to use a defouler and see if that works. Then just wait until the AP maps for the 2012's are out. This how-to states they are the same... http://forums.evolutionm.net/evo-how...ouler-how.html
__________________ Fast cars are for straight lines. Corners are for fast drivers. 2006 Corvette Z06 - AKA "El Zorro" Sold: 2012 Evolution X GSR - 394awhp / 378awtq Sold: 2011 MS3 Hypnotic Tuned @ 322whp/370tq | |
![]() Join Date: Jun 2010 Location: Wichita, KS
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 40,628
Groans: 386
| Not Ranked : 0 score This thread is a good read about the diode fix and how it affects us... Check Engine Light (P2098) The 2nd O2 isn't just there to make sure the cat is working on our cars, it also influences fuel trims. The diode screws that up and makes your fueling whacky. |
(Thread Starter) | Not Ranked : 0 score wow tha sucks! but the AP should be able to fix the code and keep the sensor working.
Groans: 386
| Not Ranked : 0 score Yes. Depending where you are that may be a problem for inspections if they plug in to your OBDII though. |
(Thread Starter) | Not Ranked : 0 score NY and we have everything besides a sniffer so its not easy to pass at all!
![]() Join Date: Oct 2011 Location: Jamaica Queens NY
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 93
new cars only check saftey!! youll be alright
__________________ Tuned by Phate. | |
![]() Join Date: May 2010 Location: Miramar,FL
Groaned at 7 Times in 5 Posts
| Not Ranked : 0 score i have an atp catless downpipe i have no issues with the o2 extended. |
![]() Join Date: Mar 2010 Location: STL, MO
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,038
Groans: 123
| Not Ranked : 0 score Find someone who will pass it. After being around cars and going to car meets you'll inevitably meet someone who knows a guy that can pass it. I'm completely catless, one of my O2's is not even present and the other O2 has a wideband in it lol
__________________ 2003 Evo VIII BUILD PLANS: LR 2.0/2.4, 6466, 800+whp. Shooting for 9s at full weight. Time is on my side, gonna take forever. Old: 2009 White MS3. Fully bolted and tuned. Sold |
![]() Join Date: Nov 2009 Location: PLAINEDGE, NY
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 364
| Not Ranked : 0 score catted DP will save you from all this hassle with minimal difference in power. just sayin.
__________________ 2010 Black Mica Mazdaspeed3 2009 Black Cherry CX-9 AWD 1997 Classic Red Miata [SIGPIC][/SIGPIC] |
Groans: 386
| Not Ranked : 0 score Not necessarily. A lot of people with catted dps still get the p0421 code. |
| Not Ranked : 0 score |
