> Gen2 MS3 General Discussion
 Old 05-12-2012, 04:33 PM   #1
dspider's Avatar
Posts: 119   (View Stats)
dspider has much to be proud ofdspider has much to be proud ofdspider has much to be proud ofdspider has much to be proud ofdspider has much to be proud ofdspider has much to be proud ofdspider has much to be proud ofdspider has much to be proud ofdspider has much to be proud of
Default occ install question
so i finally installed my occ today and i noticed my afr at idle ac off is at 14.7 .as soon as i turn the ac on it starts jumping around between 14.7 and 15.2 .. is this normal ?
i double checked all the connections everything is nice and tight .
thanks
[SIGPIC][/SIGPIC][/SIGPIC]Just to be fair i hate everyone equally , so dont feel left out.
dspider is offline   Reply With Quote
 Old 05-12-2012, 05:40 PM   #2
helmetface's Avatar
Posts: 5,685   (View Stats)
Groans: 219
Only parameter that I can think of that the OCC would mess with directly are the vacuum/boost levels.
Monitor boost, make sure you're nearly 20psig in a vacuum and that you're boosting fully.
I had an issue with my hose trying to collapse- when heated and under a strong vacuum. You'd never know looking at it cold/parked.
 Old 05-12-2012, 05:44 PM   #3
vrspeed10's Avatar
Posts: 1,035   (View Stats)
vrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the world
Groaned at 25 Times in 10 Posts
What daft punk said^^^^^
If your not first your last.
03 Speed Protege.. SOLD
10 Speed3 BT and getting my DRANK on!!!
vrspeed10 is offline   Reply With Quote
 Old 05-12-2012, 05:55 PM   #4
dspider's Avatar
cool thanks i am going to take it out for a run now.i ahve no codes poppin and i hope it stays that way lol
 Old 05-12-2012, 06:00 PM   #5
helmetface's Avatar
Groans: 219
Couldn't think of a code that would pop..doesn't mean there aren't any, but again, I can't think of one.
Just watch that vacuum.
 Old 05-12-2012, 06:21 PM   #6
Sid3wayS's Avatar
Posts: 6,790   (View Stats)
Groans: 97
Does it change with the fan turning on and off? If so your good.
TEAM LUXURY
 Old 05-12-2012, 07:00 PM   #7
dspider's Avatar
if i turn the defrost for the windsheild on or anytime the ac compressor kicks on it bounces up and down between 14.7 and 15.2 and holds closer to 14.9
i just got back from a quick drive couldnt get her goin too fast due to traffic, i am getting about -12 or so vacum and it seems to be holding boost ..afr seems normal during driving so i am going to drive it for a few days and see if anything changes..
the hoses may shape themselves and seal better once they heat up enough (i hope)
as long as she doesnt lean out too much i should be good. if it dont settle down in a couple days i may pull the hoses off and start over ,not that i want too..
 Old 05-12-2012, 07:52 PM   #8
Sid3wayS's Avatar
Groans: 97
Your fine. When the compressor kick on and off it puts more strain on the crank and will change the fueling (afr). It will lean out a bit when it first kicks on and then adjust itself back to stoich. So long as it goes back to 14.7 when you turn it off then it is normal and there is no leak. Your vac, as long as the values you gave are in psi and not ingh. are where they should be. Go drive and have fun.
TEAM LUXURY
SLOWHATCH (05-12-2012)
 Old 05-12-2012, 08:13 PM   #9
helmetface's Avatar
Groans: 219
This is why you do not run your A/C when racing.
Secondly, I don't know what hose you're using- but I don't like mine flexing much when they heat up. Again, the issue I mentioned above, that causes the deep vacuums to misshapen them
Sid3wayS (05-12-2012)
 Old 05-12-2012, 10:11 PM   #10
dspider's Avatar
the occ kit has been sitting in my basement for about 9 months ( actually got it for my cx7)with the hose coiled up like a snake so it took a bit of bending ,twisting and alot of cursing to get it all straight and routed as per the install guide..
when i said the heat may help i kinda meant it would warm up the hose enough so it would not want to coil up anymore ..
thanks for the replies and educating me a little more.
SRI/ TIP question after install eternally_enduring 2010 MS3 - Troubleshoot/Diagnostics 22 10-28-2011 06:23 PM
CP-E CAI install question kpsoerensen MazdaSpeed 3/6 - Turbo Induction 8 04-14-2010 02:38 PM
install question Vinnie MazdaSpeed 3/6 - Turbo Induction 8 02-06-2010 02:33 PM
FSB install question speedster3_08.5 MazdaSpeed 3/6 - Suspension & Brakes 8 11-27-2008 02:19 AM
mbc install question det_ms3 MazdaSpeed 3/6 - Turbo Induction 30 06-04-2008 07:56 AM
Page generated in 0.29943 seconds with 23 queries
