> Gen2 MS3 General Discussion
 Old 10-08-2019, 05:59 PM   #1
AlanSpeed3's Avatar
Posts: 4   (View Stats)
AlanSpeed3 is an unknown quantity at this point
Default P0172
Hi, If anyone could help I'd appreciate it. I have a 13 Speed3 fully modded that is throwing a P0172 code. Lt and St trims are full negative at idle pulling back fuel. I can drive for 300 miles without a light, as long as I don't sit at a stop for more that 40 seconds. I have cleaned the MAF and throttle body, changed plugs,air filter, WB A/F sensor and O2 sensor, cleaned the injectors, pressure tested the induction system from MAF outlet the the intake manifold, changed otc maps from Stage 1, 2 and 3 and removed access port completely to revert back to factory software. I have also modified the throttle inlet snorkel to accept the MAF directly to eliminate the boost system completely. (I thought of this after Cobb T.S. insisted that i have a post cat leak) All these test and procedures still result in high negative trims at idle and a P0172 within 2 minutes of idling. Also, with my Autel scantool hooked up at cold start, all pids seem to be normal for the first 5 minutes of running time, with no cel setting. At around 5 minutes and 160 f. the Equivalency ratio, A/F ratio and fuel go full rich. I have included data logs. Thank you for your help.
AlanSpeed3 is offline   Reply With Quote
 Old 10-08-2019, 10:14 PM   #2
Posts: 2,826   (View Stats)
See my response to your other post.
AlanSpeed3 (10-15-2019)
Rich Trims P0172 AlanSpeed3 MazdaSpeed 3/6 - ECU Computer Tuning 1 10-08-2019 10:09 PM
P0172 issues Syrza 2010 MS3 - Troubleshoot/Diagnostics 2 01-15-2017 07:01 PM
2013 GEN PU CEL P0172 BadBish76 2010 MS3 - Troubleshoot/Diagnostics 6 09-08-2015 09:22 PM
Help p0172 code Speedster13 2010 MS3 - Troubleshoot/Diagnostics 10 10-22-2013 11:22 AM
P0172 - 3 Days Straight mkochjr CX-7 > Issues & Troubleshooting 9 02-15-2011 11:42 AM
Page generated in 0.22887 seconds with 22 queries
