> Gen2 MS3 General Discussion
Like Tree3Likes
 Old 07-17-2012, 10:36 AM   #1
Sid3wayS's Avatar
Posts: 6,790   (View Stats)
Groans: 97
Sorry I wrote that late last night, its the other way around. No it closes when you are building boost to control the levels. At full Wot it should be fairly constant. This fully depends on your tune. For instance mine is set at 70% when at full boost. The reason we have bpv is because we have a recirc system, the air once sucked in is accounted for and a percentage of fuel is calculated for that metered air. ShoulD it be expelled from the system, a bov, that air is not missing and your afr now has to much fuel causing a rich condition which is the black smoke/backfire that people not tuned for bov get.
Msf bucks can be used to join raffles.
TEAM LUXURY
 Old 07-17-2012, 10:43 AM   #2
ANITIX87's Avatar
Posts: 1,394   (View Stats)
ANITIX87 is the leader of the worldANITIX87 is the leader of the worldANITIX87 is the leader of the worldANITIX87 is the leader of the worldANITIX87 is the leader of the worldANITIX87 is the leader of the worldANITIX87 is the leader of the worldANITIX87 is the leader of the worldANITIX87 is the leader of the worldANITIX87 is the leader of the worldANITIX87 is the leader of the world
Groans: 93
Groaned at 27 Times in 16 Posts
Thanks for the clarification. So both BPV and BOV will have this WGDC value, right? It's just a BPV sends the expelled air back to the turbo and a BOV vents to atmosphere?
Also, what about other parameters like:
EGT
Oil Temp
Coolant Temp
And any others anyone else thinks would be useful, whether Stock or Tuned...
TIS
TOTS
2012 Mazdaspeed3, CWP, Tech Package. COBB AccessPort V3, AUTOTECH HPFP Internals, JBR 3" Wide-path SRI+TIP, CP-E TMIC, UR 3" Test Pipe, CP-E Triton CBE, FORGE V2 BPV, DENSO ITV22 Plugs, JBR RMM 88a, JBR OCC, JBR RSB Kit, JBR Solid Shifter Bushings, CP-E Tow Plate, CorkSport ECU Relocation, TSW Nurburgring Bronze 18x7.5
alphasaur: "Fuck I just beat it to surprise tranny porn. Saw the dick right when I came fml"
ANITIX87 is offline   Reply With Quote
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f544/ultimate-guide-parameter-monitoring-119096/
It's been a minute: - DFW Mazdas This thread Refback 01-15-2015 11:05 PM
EGT monitoring shifter48 2010 MS3 - ECU Computer Tuning 2 01-18-2012 04:26 AM
Monitoring w/ AP AZSPEED3 MazdaSpeed 3/6 - ECU Computer Tuning 46 08-04-2010 05:15 PM
How to Change a Flat Tire: The Ultimate Guide Haltech Automotive News 0 06-14-2010 02:10 PM
Autoblog's Ultimate Toyota Recall Guide Haltech Automotive News 0 02-01-2010 10:20 AM
STOCK engine parameter recordings RocketScientist MazdaSpeed 3/6 - ECU Computer Tuning 0 12-29-2009 10:43 AM
Page generated in 0.25795 seconds with 22 queries
