Like Tree3Likes
  • 1 Post By WetzMS3
  • 1 Post By Code Monkey
 Old 01-21-2016, 04:09 PM   #1
Sir Phallsalot's Avatar
Posts: 19   (View Stats)
Sir Phallsalot has a spectacular aura aboutSir Phallsalot has a spectacular aura about
Default Bought a speed6 with a tune
Hey all. I bought a ms6 a couple months ago, and I've been enjoying the hell out of it. I was told when I bought the car that it had a tune on it, but the guy I bought it from didn't know what kind as it was the previous owner before him who tuned the car. After doing a little more research I think my car may actually have a 50/50 e85 tune on it, but I'm not actually sure. Is there any way to find out without having an AP?
A secondary question I would have is would I have any issues just running 93 through it if it does indeed have this e85 tune?
Thanks guys! Love being a mazdaspeed owner!
Sir Phallsalot is offline   Reply With Quote
 Old 01-21-2016, 04:49 PM   #2
MizzyMS3's Avatar
Posts: 511   (View Stats)
MizzyMS3 is the leader of the worldMizzyMS3 is the leader of the worldMizzyMS3 is the leader of the worldMizzyMS3 is the leader of the worldMizzyMS3 is the leader of the worldMizzyMS3 is the leader of the worldMizzyMS3 is the leader of the worldMizzyMS3 is the leader of the worldMizzyMS3 is the leader of the worldMizzyMS3 is the leader of the worldMizzyMS3 is the leader of the world
If there is actually a 50/50 E85 tune on it, you will have major problems due to the fact that when using E85, the timing is increased to get more power. Not sure how you would actually tell if there's a tune on it unless you bought an AP and tried to marry it to your car. But I would not go WOT if I were you until you knew for sure.
2012 CWP MS3 w/ Tech Package
Cobb AP V3 Purple Drank Tuned (E33 mix) | HTP 3.5' Intake | eBay Catless DP | UR CBE | CX-Racing FMIC | Autotechs | Turbosmart Dual Port BOV | JBR Short Throw Shifter | JBR Stage 2 SSP | JBR 88 duro RMM | RallyArmor Mudflaps | Eibach pro kit + Koni Yellows + SPC Camber Arms | NGK step colder
MizzyMS3 is offline   Reply With Quote
 Old 01-21-2016, 04:59 PM   #3
robbspeed's Avatar
Posts: 1,074   (View Stats)
robbspeed is the leader of the worldrobbspeed is the leader of the worldrobbspeed is the leader of the worldrobbspeed is the leader of the worldrobbspeed is the leader of the worldrobbspeed is the leader of the worldrobbspeed is the leader of the worldrobbspeed is the leader of the worldrobbspeed is the leader of the worldrobbspeed is the leader of the worldrobbspeed is the leader of the world
Groans: 50
I'm pretty sure you would be running insanely rich all the time if you had a 50/50 e85 tune. The stoichiometric rate of ethanol is like 9ish to 1 and gasoline is 14.7 to 1. So way more gasoline then is needed would be injected into the cylinder.
2011 Mazdaspeed3 w/ tech package
Totaled/ R.I.P.
robbspeed is offline   Reply With Quote
 Old 01-21-2016, 06:04 PM   #4
I am definitely running rich. That much I know.
The reason I suspected it was a 50/50 was because I think I found my car's previous owner on this site, and he listed it as one of the mods on the car. I haven't been able to get in contact with him yet though to find out if it really is my car's old owner.
I've been running 93 for 2 months now with no issues in timing(I don't think) so maybe it isn't tuned to e85, but I'd like to be sure.
 Old 01-21-2016, 06:10 PM   #5
robbspeed's Avatar
Groans: 50
How do you know you're running rich?
Totaled/ R.I.P.
 Old 01-21-2016, 06:21 PM   #6
Well I guess I should say that I'm assuming it is just by the smell, and gas mileage. I haven't checked plugs or anything yet.
 Old 01-21-2016, 06:23 PM   #7
robbspeed's Avatar
Groans: 50
You should do that soon. Are u planning on picking up an AP soon?
Totaled/ R.I.P.
 Old 01-21-2016, 06:30 PM   #8
Get an AP asap, the car is a ticking bomb without knowing exactly what you have. Post some car pictures, if the PO was a member here, someone will probably recognize the car.
CWP_MS3 (01-27-2016), robbspeed (01-21-2016), Vansquish (01-27-2016)
 Old 01-21-2016, 06:33 PM   #9
taf0422's Avatar
Posts: 4,689   (View Stats)
Groans: 192
Why don't you ask what was done if you think you found the previous owner? Worst he/she says is it wasnt theirs
[SIZE="1"]07 MS3 GT..
GTX3076r --- 479/412
S4-460/400
Highest HP BNR S3
BNR-S3 424/397
 Old 01-21-2016, 06:34 PM   #10
I'll see if I can't pull them out and check this weekend. I was planning on getting an AP, but probably not soon. I was trying to cool down my spending after the car purchase...
Yeah. I am trying to get in touch with the guy now. hopefully he'll respond soon.
Last edited by Sir Phallsalot; 01-21-2016 at 06:34 PM. Reason: MSF Database - Automerged Doublepost
 Old 01-21-2016, 06:42 PM   #11
By the way, thanks for all the help guys. It's nice to have good support in a car community. Here are some pictures of the car to see if someone recognizes it.
 Old 01-21-2016, 06:43 PM   #12
Won't buy an AP, but you're looking for "diffusers"?
Rear diffuser
You sir are a prime candidate for a block window mod.
 Old 01-21-2016, 06:45 PM   #13
I was looking to see if I could find some for cheap since mine are broken. I wasn't aware until just now that I may actually NEED an ap. Sorry if I did something wrong.
 Old 01-21-2016, 06:48 PM   #14
Ah......that is my bad man. There are often posts about aftermarket "diffusers". Often brownies. That was my assumption. You should specify in there the part you are looking for with pictures. Someone will know the part #.
monkey.bones.007 likes this.
robbspeed (01-22-2016)
 Old 01-21-2016, 06:52 PM   #15
Thanks man. I may end up putting that off until later now. They don't look too bad, but just cracked at the bottom of both exhaust holes. Maybe I'll just end up doing my own body work to clean em up some once the weather starts warming back up.
The Following User Says Thank You to Sir Phallsalot For This Useful Post:
WetzMS3 (01-21-2016)
 Old 01-21-2016, 06:55 PM   #16
robbspeed's Avatar
Groans: 50
Ok so you can spend another $650 or become v.i.p. by donating and find a used AP in the for sale section.
Totaled/ R.I.P.
The Following User Says Thank You to robbspeed For This Useful Post:
 Old 01-21-2016, 06:58 PM   #17
^ And perhaps rear diffusers, although they do not pop up for sale too often.
 Old 01-21-2016, 06:58 PM   #18
I know the exact part you're talking about. It ends up cracked on almost every 6. @Micha; or @xfeejayx; may remember the part number. Check the brackets for the tailpipe too and make sure they're intact.
About the tune. You need a way to monitor things at least. Preferably, get an AP asap and get logs to see what is going on there. If the PO had an AP and tune, when you talk to him, try to buy it off of him.
Micha (01-22-2016), xfeejayx (01-22-2016)
 Old 01-21-2016, 07:00 PM   #19
Becoming a vip here was always the plan. I'll likely wait for a response from the guy I think is the previous owner though. I do want to buy an AP but if it is necessary yet then I'd like to save my money a bit longer yet. Again, thanks so much for helping the new guy out.
 Old 01-21-2016, 07:03 PM   #20
The AP should have come with the car, hopefully the seller overlooked this. A married AP is useless to the seller, unless the guy is a douche and sold it to some unsuspecting soul.
WetzMS3 likes this.
The Following 4 Users Say Thank You to Code Monkey For This Useful Post:
Enki (01-22-2016), MD1032 (01-26-2016), Micha (01-22-2016), WetzMS3 (01-21-2016)
 Old 01-22-2016, 12:59 AM   #21
Enki's Avatar
Posts: 7,541   (View Stats)
Enki has disabled reputation
Groans: 189
If you are indeed running a 50/50 tune on pump gas, it should be close to 20% rich, in which case it should be popping a check engine light as well as damn near smoking and bucking and whatnot when you try to give it the go pedal.
More than likely, it is running a stock tune, but in that case, it's running rich because of the aftermarket intake.
Also, these cars tend to reek of fuel anyways, especially on the stock tune; though you shouldn't discount the possibility of a fuel leak if the engine bay smells of gas.
MD1032 (01-26-2016), robbspeed (01-22-2016), SofaKingAwesome (01-27-2016), Vansquish (01-27-2016)
 Old 01-22-2016, 06:35 AM   #22
xfeejayx's Avatar
Posts: 1,729   (View Stats)
Groans: 78
Still got the passenger side sitting in the basement. I'll make a for sale thread...someday.
WetzMS3 (01-22-2016)
 Old 01-22-2016, 07:26 AM   #23
aviator79's Avatar
Posts: 3,934   (View Stats)
Im sure your on a stock tune but the car should have been sold with the AP thou with CPE SRI I think its same as OEM diameter where the MAF is.
For OEM rear "bumper gaurds" I paid $220/side. Now $225 so $463.55 with $13 shipping at mazda-parts.com which is the cheapest place to buy them. I did insurance claim so they were free.
right
GP9A50360E
left
GP9A50370D
Put your location in your profile. Must be inland with no rust. Maybe some hillbilly on here will be located near you to help.
Last edited by aviator79; 01-22-2016 at 07:26 AM. Reason: MSF Database - Automerged Doublepost
 Old 01-26-2016, 06:39 PM   #24
MD1032's Avatar
Posts: 2,624   (View Stats)
Groans: 143
I have often wondered why our cars have this unique "scent" to the exhaust...especially pronounced at idle. One thing I have thought of is that maybe it's caused by the flow balance on the stock IM.
No way OP has a 50/50 tune on his car...it would be DTC after DTC followed by ZZB...
2007 Mazdaspeed3 GT
 Old 01-27-2016, 02:35 AM   #25
Enki's Avatar
Groans: 189
Probably not ZZB, because corn. You'd have to be way, way out of fueling range to pop on full corn. I ran a pass at 24 psi (~400 whp worth of air) and 14:1 AFR and it cost me a ringland on *one* cylinder.
 Old 01-27-2016, 04:58 AM   #26
hidin in yo bushes
CWP_MS3's Avatar
Groans: 122
But he's not running corn. lol He said he's been running 93.
The scariest thing about this all is it has changed hands 2x now, and the last owner didn't know shit about it either, and probably put pump in it as well.
Oh the joys of not knowing what map is on the car... lol I'd be terrified if I owned it.
Rich Tuned
330WHP and 363TQ
10-19-13 Moore Automotive
The Following 3 Users Say Thank You to CWP_MS3 For This Useful Post:
Enki (01-27-2016), MD1032 (01-27-2016), Vansquish (01-27-2016)
 Old 01-27-2016, 05:30 AM   #27
Hammology's Avatar
Posts: 540   (View Stats)
Groans: 36
Op should check his compression lol
Built motor
GTX3071
Meth
6th Port
The Following 4 Users Say Thank You to Hammology For This Useful Post:
CWP_MS3 (01-27-2016), MD1032 (01-27-2016), Vansquish (01-27-2016), WetzMS3 (01-27-2016)
 Old 01-27-2016, 05:41 AM   #28
Police - Grammarhead
Vansquish's Avatar
Who do you think is the previous owner?
 Old 01-27-2016, 10:22 AM   #29
COCKSTRONG
SofaKingAwesome's Avatar
Posts: 8,447   (View Stats)
Groans: 890
If no AP with the car, it's probably not tuned.
Unless it's with one of the older tuners, in which case you better get this sorted out ASAP.
Enki (01-27-2016)
 Old 01-27-2016, 10:30 AM   #30
hidin in yo bushes
CWP_MS3's Avatar
Groans: 122
You'd have to be a real ass hat to keep all of those easily unbolted mods on there, but take the AP.
If its unflashed at least its a 93 map, and not an E85 map with 19* of timing. lol
Rich Tuned
330WHP and 363TQ
 Old 01-27-2016, 11:12 AM   #31
blue speed's Avatar
Posts: 237   (View Stats)
blue speed has a reputation beyond reputeblue speed has a reputation beyond reputeblue speed has a reputation beyond reputeblue speed has a reputation beyond reputeblue speed has a reputation beyond reputeblue speed has a reputation beyond reputeblue speed has a reputation beyond reputeblue speed has a reputation beyond reputeblue speed has a reputation beyond reputeblue speed has a reputation beyond reputeblue speed has a reputation beyond repute
Groaned at 4 Times in 1 Post
If he cant afford a AP right now get a V-Link for $30 and a cell app for his phone so he can check on fuel pressure,temps & timing for now.
Cobb shifter weight, CBE, RSB, knob Corksport BPV, boost tubes, SRI, TIP ,Ex hangers,80 Duro RMM & TMM insert CP-E TMIC, UR test pipe & catted DP, Hypertech, Autotechs. JBR Coolant bypass, intake gasket, air filter & BP hose.Konig wheels. Sure, FSB bushings.
blue speed is offline   Reply With Quote
Just bought a speed6, and it now sounds awful KSUWildcatFan MazdaSpeed 6 - Engine, Transmission & Driveline 96 06-13-2014 10:00 AM
cobb ap: is safe tune quicker than stage 0 tune? Fusion_MS3 2010 MS3 - ECU Computer Tuning 14 12-16-2012 02:27 AM
Page generated in 0.49819 seconds with 35 queries
