| MazdaSpeed 3/6 - E85 Fueling Learn more about feeding your car corn |
![]() Join Date: Aug 2013 Location: Manitowoc, WI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,312
__________________ https://www.youtube.com/user/JustinBieberVEVO |
![]() Join Date: Jan 2011 Location: Jacksonville, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 311
| Not Ranked : 0 score Are you running an upgraded RV? Just wondering. If only we had E85 readily available here..
__________________ 08 MazdaSpeed3 | Cobb AP | MS Intake | CS TIP | CP-E FMIC | CNT Catless TBE | ITV22 | | AutoTech Internals | TurboSmart BOV | BC Racing Coilovers | CS RMM | CS TMM | | Black Powdercoated Stockers | Built Motor | | Mahle 88mm Pistons | Manley H-Beam Rods | |
(Thread Starter) | Not Ranked : 0 score Yup. PTP.
| The Following User Says Thank You to Gr8Speed For This Useful Post: | Jtaylor (09-24-2014) |
![]() Join Date: Aug 2012 Location: Ripon, CA
Rep Power: 2958 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,390
| Not Ranked : 0 score What was the brand of E you were using? Sent From a Galaxy, Far Far Away... |
(Thread Starter) | Not Ranked : 0 score Kwik Trip e85 with Kwik Trip 10% eth 89 octane- was also running Rotella. I am now running BP 93 octane (as of last week) and PP 5w30 (as of ~1-2 months and 2000 miles ago).
| Not Ranked : 0 score Yeah Rotella and e don't mix very well together. If you change oils to royal purple you will have better luck running a 50/50 mix. We are Woking on a pump mod so everyone can experience the joys of running any amounts of E desired whenever they want with any oil they want. We are still in the testing stages though. Sent From a Galaxy, Far Far Away... |
__________________ https://www.youtube.com/user/JustinBieberVEVO | |
| The Following User Says Thank You to Gr8Speed For This Useful Post: | chaser27 (09-24-2014) |
| Not Ranked : 0 score |
| The Following User Says Thank You to littleloogy For This Useful Post: | Gr8Speed (09-24-2014) |
Rep Power: 6573 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10,956
Groans: 122
| I've been running 50/50 with Pennzoil Platinum for almost 2 years, with only a month on 93 and haven't had any issues other than failing fuel level senders (because pu fail). I've definitely noticed a complaint pattern with Rotella.
__________________ CP-e S2 RMM // TurbineTech FMM // Ghetto SRI // 3" ATP MAF housing // Ultimate Racing CBE // Ebay Downpipe // Cobb AP // Autotechs // PG TIP // HKS V4 BOV // NGK Iridiums // ACT Street Disc // JBR Trans Mount Rich Tuned 330WHP and 363TQ 10-19-13 Moore Automotive ![]() |
| Not Ranked : 0 score But I thought Rotella was gods gift to lubrication?
Groans: 122
| Well is seems to do really well with our UOAs, but like anything with our cars, we can only have so much win without inevitable fail.
| The Following 3 Users Say Thank You to CWP_MS3 For This Useful Post: |
![]() Join Date: Jan 2012 Location: mars
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 454
| Not Ranked : 0 score is it the Pennzoil platinum 5w-30 full synthetic? i noticed the rottella pattern in diffrent threads as well, i'm switching it up next oil change
__________________ [SIGPIC][/SIGPIC] Corn Fed//Richtuned |
| Not Ranked : 0 score I ran Pennzoil Ultra and 50/50 for many moons without a problem. I just know from experience RP was the most resistant to death. Sent From a Galaxy, Far Far Away... |
| The Following User Says Thank You to littleloogy For This Useful Post: | Enki (09-24-2014) |
(Thread Starter) | Not Ranked : 0 score Yup. Seems to be a lot cleaner after 2k miles than the Rotella too, which is potentially positive or negative. My concern with it is that it doesn't have the detergent quality of Rotella.
| The Following User Says Thank You to Gr8Speed For This Useful Post: | darth_speeder (09-24-2014) |
Groans: 189
| Not Ranked : 0 score The most important question to ask here is how you do your 50/50 fills...
__________________ |
| The Following User Says Thank You to Enki For This Useful Post: | phate (09-25-2014) |
Groans: 122
| whatchumean?
Groans: 189
| Not Ranked : 0 score Anyone that is shooting for an exact mix and puts x amount in of either corn or pump then tops it off with the other is doing it very, very wrong.
| The Following User Says Thank You to Enki For This Useful Post: | Gr8Speed (09-25-2014) |
(Thread Starter) | Not Ranked : 0 score No. I never top off. 5/5 gallons usually. If I'm really empty I'll do 6/6.
| The Following User Says Thank You to Gr8Speed For This Useful Post: | Enki (09-25-2014) |
Groans: 122
But to say that its always perfect, would be untrue. So I don't think that has anything to do with your gunk of death or whatever you call it.
__________________ CP-e S2 RMM // TurbineTech FMM // Ghetto SRI // 3" ATP MAF housing // Ultimate Racing CBE // Ebay Downpipe // Cobb AP // Autotechs // PG TIP // HKS V4 BOV // NGK Iridiums // ACT Street Disc // JBR Trans Mount Rich Tuned 330WHP and 363TQ 10-19-13 Moore Automotive ![]() | |
![]() Join Date: Jul 2012 Location: Clifton Springs NY
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,398
Groans: 51
| Not Ranked : 0 score Is this driven by the fact you are at a 50/50 mix? Ive been on a 4 gal mix and now a 3 gal mix with the bt for about 12 - 15k and haven't had any issues yet. Key word --> "yet"
__________________ I used to go zoom zoom with my speed.... Now i drive a slow stockish Focus ST... |
Groans: 122
| Who is that question directed to? If its me, I'm not sure I understand what you're asking.
Groans: 51
| Not Ranked : 0 score More towards op. I'm just curious how much of a difference in the clear sticky we see when comparing a 25% mix too a 50% mix.
(Thread Starter) | Not Ranked : 0 score No clue honestly. I'm just reporting my experience on a 50% mix. I've never run 25%. From my understanding it's a non-issue on 25% and relatively rare on 50%, though I've seen more of it lately.
| The Following User Says Thank You to Gr8Speed For This Useful Post: | MazdaBoy2.3 (09-25-2014) |
![]() | | #24 | ![]() |
Groans: 51
| Not Ranked : 0 score I'd agree. Although, I think the increase is in part caused by the corn sauce being used by more of us. I'll Prob take a look at mine this winter.
| 50/50 e85 clear death?? | Ireland | MazdaSpeed 3/6 - E85 Fueling | 47 | 03-29-2014 02:04 AM |
| Chicago: 2014 Volkswagen Beetle GSR is black and yellow, black and yellow | Haltech | Automotive News | 0 | 02-07-2013 12:00 PM |
| Anybody have 3M clear bra? | mtlms3 | Mazdaspeed3/6 General Discussion | 8 | 07-14-2011 03:01 PM |
| clear bra? | iracer7 | MazdaSpeed 3/6 - Appearance | 6 | 07-23-2010 12:12 AM |
| Clear Bra | FastAttack | MazdaSpeed 3/6 - Appearance | 21 | 06-10-2008 11:47 AM |
