| MazdaSpeed 3/6 - E85 Fueling Learn more about feeding your car corn |
![]() | | #81 | ![]() |
![]() Join Date: Feb 2012 Location: Gibsonville, NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 100
| Not Ranked : 0 score
__________________ [SIGPIC] [/SIGPIC] 2012 Black Mica W/Tech Cobb AP AutoTech Internals JBR 88DM RMMJBR Heavy Knob JBR 3" WP JBR Rear camber arms UR TP Ford MOFO Tranny juice Rotella T6 Self Tune - (Work in Process) NGK Step 1 colder 5/7 corn fed |
| The Following User Says Thank You to Printman For This Useful Post: | mrshoulders (04-21-2013) |
![]() | | #82 | ![]() |
Groans: 189
| Not Ranked : 0 score 3/9 mix isn't that much to be honest. Some cars don't even require a recal for it, depending on the seasonal blend you're on or the e content of the pump gas. @johnnyboy05gt; is getting hilariously bad mileage right now (less than 200 per tank on 50/50), and after his tune is done I'll do my current MPG tune changes and we will see what gain he gets from it.
__________________ |
| The Following User Says Thank You to Enki For This Useful Post: | Printman (05-06-2013) |
![]() | | #83 | ![]() |
![]() Join Date: Jul 2011 Location: davis monthan afb tucson az
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 30
| Not Ranked : 0 score Today i drove total of 25 miles and used 1/4 tank. on my way home i will be easy on it and use about another 1/8 tank. idk whats going on but i think my fuel line is hooked straight into my downpipe |
| The Following User Says Thank You to johnnyboy05gt For This Useful Post: | Enki (04-23-2013) |
![]() | | #84 | ![]() |
Groans: 189
| Not Ranked : 0 score Get me a log of a full trip. Turn everything on logging wise from within the AP logging menu.
| The Following User Says Thank You to Enki For This Useful Post: | ms3rick (04-23-2013) |
![]() | | #85 | ![]() |
| Banned ![]() Join Date: Sep 2012 Location: Arlington, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 271
| Not Ranked : 0 score Just an update: Going from E40 to E35 got me about 2mpg more, mixed mileage driving. I did my valves recently too, and altogether I'm getting about 3.5 or so more average mpg (2 from going to E35 and 1.5 from the valves). |
![]() | | #86 | ![]() |
![]() Join Date: Mar 2010 Location: Des Plaines, IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 297
Groaned at 7 Times in 4 Posts
| Not Ranked : 0 score Just saw this and thought it's some retarded propaganda ImageUploadedByTapatalk1368079294.831365.jpg
__________________ '06 Mazdaspeed6 Sport | LPM MODS: COBB SF | COBB TIP | SURE RMM | CXRacing FMIC | M2 DP | NGK Laser Iridiums | Magnaflow CB | COBB AP Stg 2 SF+TIH+IC 93 | Autotech FP Internals | JBR SSP, SSB, and Heavy Knob | EBC Ultimax Rotors | EBC Red Stuff Pads | Plastidipped Grill | 20% Tint all around 50% Windshield I'm SO stock it HURTS |
| The Following User Says Thank You to MS6 Sanchez For This Useful Post: | TheFlash (05-09-2013) |
![]() | | #87 | ![]() |
![]() Join Date: Jun 2012 Location: San Jose, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,963
Groans: 47
| Not Ranked : 0 score LOL @ that ad. They are so detailed...
__________________ 2006 Mazdaspeed6 FreekTune | 91 | JBR 3", PMM & RMM | CS Racepipe, TMIC & TMM Inserts | Autotechs ![]() |
![]() | | #88 | ![]() |
![]() Join Date: Jan 2013 Location: McKinney, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,778
| Not Ranked : 0 score 50/50 with a few single gear wot pulls and then highway cruising I got about 260miles before my light came on. My tires are also slightly taller than stock which hurts acceleration but keeps my rpms slightly lower at speed. Sent from my SAMSUNG-SGH-I777 using Tapatalk
__________________ 3rd rebuild on the way...maybe... |
![]() | | #89 | ![]() |
| Not Ranked : 0 score 286 miles on 50/50 and light didn't even come on. Pretty sure I could've gotten 300 on a tank and that was including 4th gear WOTs for logs and a/c usage. Sent from my SAMSUNG-SGH-I777 using Tapatalk
| The Following User Says Thank You to Cheapspeed For This Useful Post: | TheFlash (06-14-2014) |
![]() | | #90 | ![]() |
![]() Join Date: Apr 2012 Location: Minoa, NY
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,172
| Not Ranked : 0 score 267ish miles with my first fill up (base map) 33% mix
__________________ 2012 Black Mica Mods CS catless DP, CS RP Magnaflow CBE Autotech HPFP NGK Plugs CS RMM JBR PMM CS Short Shit Kit and Shifter Bushings Cobb SRI and TIP CS TMIC SU Boost Tubes JBR Reticulation Tube Cobb AP v2 H&R springs JBR Rear Sway Bar Self Built 3 Port EBCS maisonvi Shift Knob Tuned on 93 and corn [SIGPIC][/SIGPIC] |
![]() | | #91 | ![]() |
Groans: 438
| Not Ranked : 0 score Just got 253 miles out of my last tank, running full e85.
__________________ All good things must come to an end... |
![]() | | #92 | ![]() |
![]() Join Date: Feb 2014 Location: PHX, AZ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2
| Not Ranked : 0 score how big is the tank in the MS3? I get 275mi/tank in my 6, for an average of just under 20 mpg (mostly highway) on a stage 2+ tune with 91. sounds like I wouldn't see much if any hit by switching to E.
__________________ 2006 Liquid Platinum Metallic MS6 Sport 71 Nova LSx/T56 |
![]() | | #93 | ![]() |
Groans: 189
| Not Ranked : 0 score Genwon holds 14 IIRC. Hits E at 12 though.
![]() | | #94 | ![]() |
| Not Ranked : 0 score I tend to get ~260-270 miles per tank with 6 gal E85 per tank in mixed driving. ~21MPG is typical. I do get lots of smiles per mile though...
__________________ 08 MS3: ATP GTX3071 at 26PSI , AEM Dryflow 21-2147DK, CP-E 3.25'' MAF, CP-E Nviscid TIP, PG FMIC piping with Treadstone TR11 core, Cobb BPV, Ported IM, PG v1 manifold, CP-E catted DP, CNT CBE, KMD v2, Grimspeed EBCS, Alkycontrol Meth injection (M10 with 100% meth), E40 fuel, Cobb AP (ATR= WIN), ACT ZX4-HDSS, 3-Bar MAP, JBR RSB, and CP-E 60 Duro Engine Mount Set. (297.3WHP/366.9WTQ - on K04, 469.2WHP/420.7WTQ - on GTX3071) |
![]() | | #95 | ![]() |
![]() Join Date: Apr 2013 Location: Chattanooga, TN
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,760
Groans: 42
| Not Ranked : 0 score 0% mix of E I've gotten anywhere between 7 and 34 mpg for a tank.
__________________ Coming at ya with all 297/359 POWER: HTP 3" intake, Corksport BPV, Treadstone FMIC, Cobb EBCS, Autotech HPFP, CPE full catless DP ECU: self-tuned HANDLING: JBR RSB (Middle Setting) RICE: Stickers and stuff, mudflaps, floormats, Evil M, etc. RADAR: Passport Escort 9500ci |
| The Following User Says Thank You to chaser27 For This Useful Post: | Speed2006 (01-03-2018) |
![]() | | #96 | ![]() |
Groans: 189
| Not Ranked : 0 score Currently running full E85. Miles /// Gallons /// MPG 214 /// 11 /// 19.45 260 /// 12 /// 21.66 201 /// 10.5 /// 19.14 Mostly blue pic is my VVT configuration (no VVT during cruise/light accel) Other pic is my closed loop fueling: 1.1 = 16.17 AFR 1.05 = 15.435 AFR 1.025 = 15.067 AFR 1.0 = 14.7 AFR
| The Following 3 Users Say Thank You to Enki For This Useful Post: |
![]() | | #97 | ![]() |
Groans: 189
| Not Ranked : 0 score Just under 892 miles now; Last fillup: 216.6 miles on 10.45 gallons 20.72 MPG, with lots of WOT.
![]() | | #98 | ![]() |
![]() Join Date: Feb 2015 Location: Palmer, Iowa
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 152
| Not Ranked : 0 score that lean burn map looks good for highway driving, have any noticable temperature issues at 1.1?
__________________ 06 MS6 GT Titanium Gray II Metallic |
![]() | | #99 | ![]() |
Groans: 189
| Not Ranked : 0 score Nope.
![]() | | #100 | ![]() |
| Not Ranked : 0 score How many miles do you think you can achieve to a tank with mostly conservative driving? I just finished my e30 tune and im thinking about stepping up to e50 since the gas stations around here offer e30, e50 and e85. I havent seen any mpg loss at e30, still get about 380 miles to the tank. Sent from my SAMSUNG-SM-N910A using Tapatalk
![]() | | #101 | ![]() |
Groans: 189
| Not Ranked : 0 score On full E85, probably same as stock if not a hair better, assuming highway mpg @ 80.
![]() | | #102 | ![]() |
| Not Ranked : 0 score Thats good to know, so I shouldn't expect any loss from e50 then. Thanks for the info. Sent from my SAMSUNG-SM-N910A using Tapatalk
![]() | | #103 | ![]() |
Groans: 189
| Not Ranked : 0 score Assuming you drive conservative and have tuned for it yeah, you shouldn't. There's a video earlier in this thread I think that shows me getting 27/28 MPG per the AP on 50/50 mix at 75 MPH with the AC on.
![]() | | #104 | ![]() |
| Not Ranked : 0 score I live in the middle of nowhere, so i do all highway, very little if any city driving. I can do 4th gear logs less than a mile from my house so it makes the tuning process much quicker. How is your idc on e85? Sent from my SAMSUNG-SM-N910A using Tapatalk
![]() | | #105 | ![]() |
Groans: 189
| Not Ranked : 0 score Doing what? I'm big turbo and on aux fuel.
![]() | | #106 | ![]() |
| Not Ranked : 0 score Makes sense, I figured e85 would max idc on the k04. Sent from my SAMSUNG-SM-N910A using Tapatalk
![]() | | #107 | ![]() |
Groans: 189
| Not Ranked : 0 score Not usually, but it will get pretty close depending on elevation and targeted AFR.
![]() | | #108 | ![]() |
| Not Ranked : 0 score Have you run lean burn maps on mixes? Sent from my SAMSUNG-SM-N910A using Tapatalk
![]() | | #109 | ![]() |
Groans: 189
| Not Ranked : 0 score Yes. There are guys running pump gas on 17:1 targets for cruise, but IMO efficacy falls off sharply after 16:1.
![]() | | #110 | ![]() |
| Not Ranked : 0 score Thanks for the info, I want to give this a shot before i step up to e50. Sent from my SAMSUNG-SM-N910A using Tapatalk
![]() | | #111 | ![]() |
![]() Join Date: Sep 2014 Location: Gainesville, FL
Rep Power: 0 ![]() Thanks: 18
| Not Ranked : 0 score I generally get around 22 MPG running highway speeds (75mph). Around town, averaging about 15 mpg. This is in a Speed6 running a 50/50 mix
__________________ 2008 Mazdaspeed3 E48 fuel Cobb SF+TIH, CNT Catted DP, AP V3, Autotech HPFP Internals 369 WHP/ 410 WTQ 12/27/2017 |
![]() | | #112 | ![]() |
| Not Ranked : 0 score I get about 21 MPG on 6.5 gal E per tank here with 80% highway driving... MPG sucks, but my Smiles Per Mile (SPM) are pretty sweet.
| The Following User Says Thank You to cld12pk2go For This Useful Post: | Enki (01-11-2016) |
![]() | | #113 | ![]() |
| Not Ranked : 0 score I'm not sure if this is the best thread to put this in but it's relevant and I don't want to bump an old mpg thread. For all of those people concerned about lean cruise running hotter and possibly causing damage. That is a misconception and running a lean cruise will actually burn colder than running at stoich. It is possible to actually run lean enough to run into something called cold lean where the engine cannot combust the fuel properly (typically 18:1 or above) because there isn't enough fuel and the large amount of air will cool off the combustion chamber. The reason why cars run at stoich from the factory is because the catalytic converter will get ruined if the engine runs lean or rich for an extended period of time. So if you're catless there is no harm in running a lean cruise so long as you tune for it properly. THIS IS NOT THE SAME AS RUNNING LEAN AT WOT!
| The Following User Says Thank You to Mazdazilla6 For This Useful Post: | Cheapspeed (01-14-2016) |
![]() | | #114 | ![]() |
| Not Ranked : 0 score Along those same lines, I found something interesting with my highway cruising coolant temperatures. When I ran straight 93, I found that my coolant temp hovered between 180-190⁰F during normal highway speeds and an 85⁰F ambient temperature. Now, in those same conditions running 50/50 mix, I find that my vehicle reads between 165-175⁰F. I understand that alcohol fuels burn cooler, but I am not certain if my coolant temps should have dropped that much. Is that common? I just worry a tiny bit about the block being aluminum, and not having the temps be hot enough to maintain the tight tolerances.
![]() | | #115 | ![]() |
My car ran as cool as 155* cruising on the highway when it was fully open 20*F weather.
__________________ 3rd rebuild on the way...maybe... | |
| The Following User Says Thank You to Cheapspeed For This Useful Post: | Enki (01-14-2016) |
![]() | | #116 | ![]() |
![]() Join Date: Nov 2014 Location: La Porte, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 56
| Not Ranked : 0 score On the mileage note gen juan, freek E getting about 280-290 per 13 gallons on e33. only a 10 mile per tank diff from the 93 tune
__________________ Cobb AP JBR Tru-3.0 CNT Catted DP "Gutted" CNT Catback JBR 88 RMM DM PMM and TMM 3 port, Turbosmart dual port FReaktune E33 |
| The Following User Says Thank You to PurplFox For This Useful Post: | Enki (01-14-2016) |
![]() | | #117 | ![]() |
Groans: 189
| Not Ranked : 0 score He could go further if he wanted to, MPG wise. I was getting 28 on the highway on 50/50; grant it, aero and drafting had a bit to do with that but still.
![]() | | #118 | ![]() |
__________________ Built 5862: Shootin For The Stars 2006 Mazdaspeed6 GT Crystal White Pearl #07141 Damond Motorsports = PS Cooler - RMM - PMM - OCC VersaTuner = Versatune Clutchmasters = 850 Street Twindisk Corksport = RDM - CBE - RSB - TMM Insert Turbine Tech = Forward Diff Mount - FMM CP-e = Exhaust Manifold - Injector Seals PTE = JB 5862 JMF = Intake Manifold w/Custom PI Kozmic = Downpipe - 6th Port - EGR Delete Forge = V2 BPV Tial = 44mm WG Autotech = HPFP Internals HTP = 4" Intake - Battery Tray Bilstein = B6 Shocks w/Eibach springs Grimmspeed = EBCS Technafit = SS Brake Lines - SS Clutch Line Enkei = EVOX GSR 18x8.5 +38 - NT03+M 17x9.5 +38 Custom = FMIC w/TR1035 - Shifter Cables - Shifter Bushings | |
| The Following User Says Thank You to Mazdazilla6 For This Useful Post: | Enki (01-14-2016) |
