| MazdaSpeed 3/6 - E85 Fueling Learn more about feeding your car corn |
| Banned ![]() Join Date: Jan 2016 Location: Fultondale, Alabama
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 0
(Thread Starter) | Not Ranked : 0 score "E85 ethanol is used in engines modified to accept higher concentrations of ethanol. Such FFV are designed to run on any mixture of gasoline or ethanol with up to 85% ethanol by volume. There are a few major differences between FFVs and non-FFVs. One is the elimination of bare magnesium, aluminum, and rubber parts in the fuel system. Another is that fuel pumps must be capable of operating with electrically conductive ethanol instead of non-conducting dielectric gasoline fuel. Fuel injection control systems have a wider range of pulse widths to inject approximately 34% more fuel. Stainless steel fuel lines, sometimes lined with plastic, and stainless-steel fuel tanks in place of terne fuel tanks are used. In some cases, FFVs use acid-neutralizing engine oil. For vehicles with fuel-tank-mounted fuel pumps, additional differences to prevent arcing, as well as flame arrestors positioned in the tank's fill pipe, are also sometimes used." So to kinda ignite the flames again. Mixes of 50/50 e85 and pump gas may be doing better because the mix isn't as conductive to charged electrons. Think about it. Our spill valve - electrically charged Our Hpfp - Grounded to spark plug harness Rotella T6 - Shit tons of magnesium & zinc In Tank Fuel Pump - Electrically charged and submerged in gasoline conductive fluid to heat but not electricity Our Fuel Rail - Pretty sure it aluminum ? When mazda developed these parts I don't believe insulation of the electrical components was a 100% must have or requirement and in some cases these components were used on purpose to ground out or discharge electrical current The term arcing means - An electric arc or arc discharge is an electrical breakdown of a gas that produces an ongoing plasma discharge, resulting from a current through normally nonconductive media such as air. Black Death is nothing but burnt plasma left behind and although we may have found a possible cure to prevent buildup over short term and for some even long term testing periods I don't think we have solved the issue. Possible fixes 1. Royal Purple works great! 2. Drown Spill valve in redline SI-1 is working so far. 3. Move the grounding of our spark plug harness to a different location ( possible ? ) 4. In tank fuel pump must be insulated in it's entirety to prevent electromagnetic charge of the fluids it pumps and is submerged in. ( anyone tried a pump like the wrx guys are using ? ) 5. All conductive super conductive metals be removed from the assembly and replaced with non conductive or less conductive materials ... table of conductive metals and their properties below. ( the hard part is our fuel rail. Teflon coating or special surface protectant ? ) 6. Deionization of the fuel and it's electrical conductors through filtration or purification before hitting the fuel pumps or injectors? I know this seems like a drastic change in the fueling assembly but as a community we have helped other platforms benefit from our research yet I think the one thing we failed to look at as the root cause being our pressurized fuel rail ( converts fuel into a gas ) and that fuel rail being electrically conductive ( Aluminum ) Somewhere in the fuel delivery process it is being exposed to electrical current causing the substance to thicken in our fuel systems and during the delivery process increasing duty cycles, flow , and incorrect amount to each combustion chamber. A link to various metals their resistance and conductive properties can be found at this link Lastly has anyone suggested a FSG sensor for auto scaling ATR fuel tables as a plug and play USB input or additional controller ? Theres a market for that ... and a big one once you taste a full partial or full corn diet with you car. https://en.wikipedia.org/wiki/Electr...d_conductivity Last edited by Xtrinsic1337; 03-21-2016 at 11:35 PM. |
| The Following User Says Thank You to Xtrinsic1337 For This Useful Post: | Mazdazilla6 (03-21-2016) |
| Not Ranked : 0 score Interesting stuff. I'm fairly sure it's already been concluded that RP by itself won't keep black death away though. The S1 has been pretty well proven to work just fine and it looks like the IE internals are also working just fine too. What is this pump that the WRX guys are using? Also, I'm not very familiar with electricity's effect on gasoline/ethanol but I'm not sure moving grounds around will really solve too much. It's definitely worth a shot to see if it changes anything though. Lastly, I think you'll have a tough time completely insulating the fuel from electricity since most of the engine is Al and it will conduct through just about all of it so it's kind of hard to separate the whole fuel system from electricity. I'd certainly be interested to see some results from testing OP.
Groans: 189
| Not Ranked : 0 score You must have missed the part where I boiled a ton of E85 in a stainless steel pot, got no reaction, then did the same with a couple drops of Rotella and got death formation very quickly. You've also missed the part where Redline and RP are required to be a long term resolution, not just one or the other. Redline doesn't work with Rotella.
__________________ |
![]() Join Date: Dec 2013 Location: Tampa, Florida
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 462
| Not Ranked : 0 score And as for the sensor, yes it is already being worked on.
__________________ The line up: 2013 G37 loaded...not stock for long 2013 MS3...stock to midturbo back to stock (traded) 2009 Nissan Frontier LE loaded...big stereo system (traded) 2009 Cadillac CTS sport package...stock (blown and traded piece of shit) 1994 Integra RS built all motor (sold) 1990 Civic EF nitrous turbo motor swapped beast (sold) 1987 Dodge pick up...jacked up (sold) |
![]() Join Date: Feb 2012 Location: Li ny
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,290
Groans: 74
The spark plugs must ground at the head where it is screwed in so no changing that. Also the high Voltage (low Current) of the spark plug coil will tend to make the Current to flow towards the surface of the motor and less in the middle where the pump internals are located. The motor is grounded for the sensors and spark plugs so after this the majority of the cars Current flows through the main ground near the DR side strut tower. As to isolating the HPFP the bolts can conduct as well as the timing chain, HPFP lobe, and follower which touches the internals directly. As I believe from reading the main issue is the type of oil used and the clearances of the oil seal on the internal it self coupled with high temps causeing the Black Death.
__________________ MECP 2012 BM PTE 5858 Vband .82ar // Tial EWG // CPE Mani // 3" Turboback // JBR Under route hot pipe // MD ST mani+spacer with PI // Siemens 60lb Injectors // Splitsecond inj controller // JBR 88 duro RMM/TMM // MD PMM // TWM Full replacement shifter // JBR CC // Autotech FP Internals // SP63 SB/Manley rods SP63 pro pistons // Treadstone FMIC TR824 // FoMoCo Tranny Jizz // South Bend Clutch Stage 3 enduro// GFB Respons // FJ 4" intake // WMI 100% VPM1 // Air Lift 1000 in rear // N2MB WOT BOX Rfinkle tune in progress The Brooklyn beater: 2005 1.8 Auto Sentra | |
![]() Join Date: Jul 2011 Location: Virginia Beach, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 473
| Not Ranked : 0 score Cleaned pump with S-1 for the first time on 10/12/2014 following an RP oil change. Pulled internals after 5k miles of full corn on 3/28/2015 just for pics and to verify. Since then, and hel if I know another 15K miles, zero startup issues aside from an occasional long crank, zero FP dips. Haven't pulled the internals since (autotechs) then, nor added any S-1 to the SV. 3 E-85 stations in NY, 1 in MD and 2 here in VA. Only thing done is another RP oil change in the meantime. Does it get more permanent than this?
__________________ Speed 6 Gone for 3+ years and still not happy about it 2007 Speed 3. JBR 3" WP. AP. Autotechs. Full Maize. CP-E Stage 2 RMM, Rubber Filled OEM TMM, Nator'd TP, Moog's and DM SSP Enki - "High mixes of corn = all the wastegate all the time for great justice." |
| The Following User Says Thank You to MSP6 For This Useful Post: | g00s3y (05-26-2016) |
Groans: 189
| Not Ranked : 0 score Not quite permanent permanent. At some point in the next year you'll need to flush the spill valve with redline.
| Not Ranked : 0 score 10 minutes of maintenance every 2+ years is as close to permanent as a Speed 3 will ever be! Spill valve, end links, PMM you name it... At least in my case.
| The Following 2 Users Say Thank You to MSP6 For This Useful Post: | g00s3y (05-26-2016), monkey.bones.007 (05-26-2016) |
![]() Join Date: May 2010 Location: SLC, Utah
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 15
| Not Ranked : 0 score I don't think this a correct assumption at all. I'm betting its purely a chemical reaction. Do RL & RP have some magic electrical/grounding formulation that other oils don't? No - they just have a different chemical composition.
__________________ 2009 MGM MS3 - / HTP 3"/ COBB AP, FMIC, RMM, & DP / AT Internals / Manley Rods & Pistons / ARP studs & bolts / Koyorad radiator / DM OCCs / ACT Clutch / Bilstein B16 / CS Camber Plates, Camber Arms, & Seals / JBR .125 RSB, BSD, 51R Battery Box & Raider's AD / StopTech Brakes |
| The Following User Says Thank You to shamie For This Useful Post: | Enki (05-26-2016) |
Groans: 189
| Not Ranked : 0 score Everything is grounded; there's no reason electricity should be a factor *at all,* considering at no point is the fuel not wrapped in metal that's not touching other metal that goes right back to the ground side of the battery. This thread gives me a headache.
| The Following 3 Users Say Thank You to Enki For This Useful Post: |
| Fuel pressure drop | derek13p | 2010 MS3 - ECU Computer Tuning | 32 | 05-27-2013 10:24 PM |
| Fuel Pressure Drop/Cut | Burton | MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection | 6 | 05-31-2012 07:43 PM |
| Fuel Pressure Drop after load of 2 | dpolseno41 | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 3 | 02-17-2012 07:37 PM |
| What causes pressure drop on inercoolers? | NinjaT1985 | 2010 MS3 - Turbo Induction | 11 | 11-17-2011 03:57 PM |
| Drop in Boost Pressure | Jujiro_Prodigy_31 | MazdaSpeed 3/6 - Turbo Induction | 4 | 01-12-2010 04:04 PM |
