 Old 04-04-2016, 09:52 AM   #1
tokoam's Avatar
Posts: 199   (View Stats)
tokoam has a brilliant futuretokoam has a brilliant futuretokoam has a brilliant futuretokoam has a brilliant futuretokoam has a brilliant futuretokoam has a brilliant futuretokoam has a brilliant futuretokoam has a brilliant futuretokoam has a brilliant futuretokoam has a brilliant futuretokoam has a brilliant future
Groaned at 17 Times in 4 Posts
Default e85 bnr Powa?
would like some of you guys to elaborate on my 2 logs first log is of 93 on e85 mix with 4 gallons 2nd is with same but on e85 tune.Does this seem about right to you is it possiable to eek some more ?
tokoam is offline   Reply With Quote
 Old 04-04-2016, 10:03 AM   #2
Shwaykid's Avatar
Posts: 646   (View Stats)
I'd worry about smoothing out your boost curve and OL MAFCAL before trying to find more power...
2008 Mazdaspeed3 GT
Jet Black Wax (06/24/2017)
Shwaykid is offline   Reply With Quote
The Following User Says Thank You to Shwaykid For This Useful Post:
Enki (04-04-2016)
 Old 04-04-2016, 10:11 AM   #3
tokoam's Avatar
maf cal may look off cause of switching of map right after the other ? and whats wrong with my boost curve ?
 Old 04-04-2016, 10:26 AM   #4
Shwaykid's Avatar
Your second, 'blue' run actually isn't bad. That red one would have scared me. That's a pretty big drop after spool-up.
And from my understanding, your OL MAFCAL shouldn't take any miles or 'block-learn' When I tune my OL, I make the small adjustment, then go back out and do another pull.
What BNR are you on, btw?
2008 Mazdaspeed3 GT
Last edited by Shwaykid; 04-04-2016 at 10:26 AM. Reason: MSF Database - Automerged Doublepost
 Old 04-04-2016, 01:30 PM   #5
tokoam's Avatar
S3 I haven't done any of the tuning I'm not very good with software I just did the install of everything.Lex from stratified tuned me .I assume run 1 was skued due to the e85 mix ?
Sent from my SM-N920T using Tapatalk
1st gen, big powa mr.speedy3 MazdaSpeed 3/6 - Dyno Sheets/Discussions 7 08-21-2014 10:18 PM
Addin' Some Powa' to the DD jeoje 2010 MS3 - Build Diaries 45 06-03-2012 11:08 PM
I NEED MORE POWA!!!! Eazy Mazdaspeed3/6 General Discussion 8 01-27-2009 02:00 PM
Page generated in 0.25538 seconds with 22 queries
