Like Tree247Likes
 Old 08-09-2011, 08:31 PM   #561
Trail of Fail
Dano's Avatar
Posts: 9,484   (View Stats)
Fortunately I lifted immediately (not a bad reaction time between recognition of problem and lifting or perhaps I just got lucky) without issue and found the following when I got home:
WOW! glad it didn't go badly.
phate (08-10-2011)
 Old 08-10-2011, 10:47 AM   #562
Eth Fiend
phate's Avatar
Posts: 6,947   (View Stats)
so phate when u gona reach in and fondle your INFP?
Possibly tonight. The pump is getting worse in a hurry. Unfortunately, my new place is outside of town, so I need my car on a daily basis :/ That access hole is getting opened up.
jracer (08-11-2011)
 Old 08-10-2011, 10:53 AM   #563
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
Phate, were you the original owner of your car?
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
 Old 08-10-2011, 11:00 AM   #564
Eth Fiend
phate's Avatar
No, I bought it with ~8k miles on it.
djuosnteisn (08-10-2011)
 Old 08-10-2011, 12:21 PM   #565
Eth Fiend
phate's Avatar
Going to drop the tank tonight, for sure. One of my friends is a Ford mech and is able to help me out. Hopefully things go smoothly.
djuosnteisn (08-10-2011), PapaSmurf (08-10-2011), silvapain (08-10-2011)
 Old 08-10-2011, 01:08 PM   #566
PapaSmurf's Avatar
Posts: 8,236   (View Stats)
goodluck!
860whp/677wtq
2.7 V6 Ecoboost
phate (08-11-2011)
 Old 08-10-2011, 04:04 PM   #567
bewsted's Avatar
Posts: 2,456   (View Stats)
bewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the world
Oh shutup mr.ihaveafullpagesigcauseimtightlikethat @MicaBlueMS3
I'm running the agressive timing as previously discussed now with a little lower on the top end and a little more boost....
On a 4th gear pull today I held 20 psi to 6000 rpms LOL!
PapaSmurf likes this.
EWG K04...GETSUM!
A journey to make people cry like babies when loosing to a wagon.
bewsted is offline   Reply With Quote
The Following 2 Users Say Thank You to bewsted For This Useful Post:
djuosnteisn (08-11-2011), phate (08-11-2011)
 Old 08-10-2011, 05:02 PM   #568
Eth/Meth Junkie
cld12pk2go's Avatar
Posts: 2,998   (View Stats)
I could only hold 20PSI to about 5200 RPMs today...poor K04 spinning at 11 billion RPMs...
 Old 08-10-2011, 11:56 PM   #569
bewsted's Avatar
Weather was rather perfect today as well...
Although this holding 20 psi is kind of a once in a while occasion...if that lil turd gets warm kiss that shit goodbye.
EWG K04...GETSUM!
The Following User Says Thank You to bewsted For This Useful Post:
phate (08-11-2011)
 Old 08-11-2011, 10:07 AM   #570
bewsted's Avatar
So @driver311 and @cld12pk2go what kind of afr are you guys targetting now days?
I just bumped upto 12.6 from 3500-rl......Next bump is 12.8
EWG K04...GETSUM!
The Following 3 Users Say Thank You to bewsted For This Useful Post:
Dano (08-11-2011), djuosnteisn (08-11-2011), phate (08-11-2011)
 Old 08-11-2011, 10:41 AM   #571
86AmishMs3's Avatar
Posts: 3,639   (View Stats)
Groans: 338
On a semi related note with the sludge, I'm noticing on my integra that pure e85 is drying out the gaskets and causing to become brittle when they go dry. But then again they are 150k miles and over 15 year old gaskets. Replaced them today when I switched back to stock injectors and gasoline was shooting everywhere. Sooo take that as you will.
Edit: fuel filter on my integra looked on par for 150k miles.
On my mazda, loves a 30% mix.
Current: N54 135i
DCI, DP's, Exhaust, FMIC
12.3@122
2009 Mazdaspeed 3:
GT3076 - Corkey tuned
390whp/400wtq
12.8@114
Sold
The Following User Says Thank You to 86AmishMs3 For This Useful Post:
phate (08-11-2011)
 Old 08-11-2011, 10:43 AM   #572
bewsted's Avatar
30% is your knock eliminator and gives a lil extra pep for sure.
EWG K04...GETSUM!
phate (08-11-2011)
 Old 08-11-2011, 12:59 PM   #573
so howd it go phate?
phate (08-11-2011)
 Old 08-11-2011, 02:20 PM   #574
Eth Fiend
phate's Avatar
So we dropped the tank, all went well. It only took a few hours. Everything in the pump assembly looked fine, except for the filter. The filter, which is a tiny POS on the inlet of the pump, was almost black with nasty dirt. It had so much sediment, it was very heavy compared to the one on my replacement pump. I am 99% sure it was the filter causing a huge restriction on the inlet of the ITFP.
But, I went ahead and replaced the entire pump assembly, only reusing the fuel level float. So we dissected the pump and regulator to look for anything odd. Every bit of it looked fine. All plastic pieces were intact, the pump motor spun freely, there wasn't buildup anywhere inside of the pump. The O-rings on the regulator looked brand new, and the rubber flapper valve was intact and functioning properly.
The filter material was still intact, and obviously doing its job. I am pretty confident in saying the ethanol is not eating anything in the fuel pump assembly. Though, it may be an indirect cause of the fuel filter clogging. I am unsure if this was 55k miles (total on car) worth of dirt, or 5k (total on e85) miles worth of dirt. In 5k or so miles, I'll re-inspect the new filter.
Aside from that, I have noticed significantly more buildup in the HPFP since the stock internals went back in and the ITFP started to die. It could be dirt getting past the ITFP filter, or it could be tied to cavitation in the HPFP due to lack of supply from the ITFP. I'm going to pull the HPFP tonight and clean everything. Hopefully I'll see this buildup subside from the current rate. I haven't been running the in-line filter for a few weeks, now, so I may put it back in.
On the positive side of increased buildup, I scraped together a good sample to send to Blackstone. I used a brand new razor blade to prevent cross contamination as much as I could. I'm going to compose a letter summarizing my entire experience. Hopefully they will be able to get some results. I'll post a copy of my letter here.
I have many pictures of the fuel pump assembly pieces. I don't have internet access at my new place, yet, but I should get it hooked up tonight. I'll post pictures of everything as soon as I can.
The Following 16 Users Say Thank You to phate For This Useful Post:
802MS3 (08-11-2011), bewsted (08-11-2011), Ckmazdaspeed3 (08-17-2011), cld12pk2go (08-11-2011), Dano (08-11-2011), djuosnteisn (08-11-2011), Enki (08-11-2011), jracer (08-12-2011), mr_mazda329 (08-28-2011), MSFer87 (08-12-2011), PapaSmurf (08-11-2011), ScarMS3 (08-11-2011), silvapain (08-16-2011), superskaterxes (08-11-2011), triplejumper18 (08-11-2011), wolly6973 (08-11-2011)
 Old 08-11-2011, 03:45 PM   #575
Eth Fiend
phate's Avatar
Letter to Blackstone, sent today with the residue sample, 8/11/2011
August 10, 2011
Dear Blackstone Labs,
What the heck is this? I recently spoke with Randy on the phone about this buildup I am seeing inside of my high pressure fuel pump. This is from a 2007 Mazdaspeed3 direct injection fuel pump. I recently switched the car to E85, and have been seeing this buildup ever since. I have been running E85 for almost three months, driving approximately 5,000 miles in that time.
Initially, I suspected it was dirt being dislodged by the ethanol. I put an in-line fuel filter in place, just before the direct injection pump, to no avail. The buildup continues. After 3,500 miles with the fuel filter in place, I dissected the filter to find not even a trace of sediment. I have found, however, that buildup occurs much more quickly without the in-line fuel filter in place. This leads me to believe it may be filtering some, but not all, of the contaminants.
Also, I recently had an issue with the in-tank filter getting clogged. All other in-tank pump components (pump/regulator/o-rings/rubber parts) looked unaffected. These two issues could be tied together, and I hope an analysis can point me in the right direction! Randy has already told me this is not in the normal realm for any Blackstone analysis. Please call to discuss possibilities - xxx-xxx-xxxx (cell phone).
Thank you,
phate - my client ID
PS - from what I can tell, after many hours searching through Google and online forum use that is bordering on obsession, I may be the only person running straight E85 in the Mazda MZR DISI engine. When the buildup isn’t causing a problem, the car runs better than it ever has. I, and the MazdaSpeed community, hope you can help us identify what this car will require to use E85 consistently, without the issues I am seeing.
The Following 11 Users Say Thank You to phate For This Useful Post:
802MS3 (08-12-2011), bewsted (08-11-2011), Ckmazdaspeed3 (08-17-2011), cld12pk2go (08-11-2011), Dano (08-11-2011), djuosnteisn (08-11-2011), Enki (08-11-2011), JacksonMS30 (08-11-2011), jracer (08-12-2011), mr_mazda329 (08-28-2011), wolly6973 (08-11-2011)
 Old 08-11-2011, 04:03 PM   #576
Eth/Meth Junkie
cld12pk2go's Avatar
12.5:1 from 1500-7000 RPMs.
The Following 6 Users Say Thank You to cld12pk2go For This Useful Post:
802MS3 (08-12-2011), bewsted (08-11-2011), Ckmazdaspeed3 (08-17-2011), Dano (08-11-2011), djuosnteisn (08-11-2011), phate (08-12-2011)
 Old 08-11-2011, 04:21 PM   #577
bewsted's Avatar
That's with 100% meth
tapa dat ass
EWG K04...GETSUM!
phate (08-12-2011)
 Old 08-11-2011, 07:50 PM   #578
on a similar note, @djuosnteisn/@socks/@SSinstaller , did you guys see any shitty buildup when you pulled your pumps?
Dano (08-11-2011), phate (08-12-2011)
 Old 08-11-2011, 07:55 PM   #579
driver311's Avatar
Posts: 1,769   (View Stats)
Im the same.
Mazdaspeed
The Following 3 Users Say Thank You to driver311 For This Useful Post:
bewsted (08-11-2011), Dano (08-11-2011), phate (08-12-2011)
 Old 08-11-2011, 08:05 PM   #580
bewsted's Avatar
I have been running @ 12.5 for a bit and tried 12.7 and kept getting nasty creep....
Guess 12.5 to 12.6 seems to be the "promise land" for me.
EWG K04...GETSUM!
phate (08-12-2011)
 Old 08-11-2011, 09:01 PM   #581
creep? on stock turbo? lol
phate (08-12-2011)
 Old 08-11-2011, 09:04 PM   #582
Trail of Fail
Dano's Avatar
@driver311 @superskaterxes and anyone else for that matter
what was the leanest AFR you were able to run on 93?
phate (08-12-2011)
 Old 08-11-2011, 09:08 PM   #583
bewsted's Avatar
lol....afr's running away.....excuse the terminology creep
EWG K04...GETSUM!
phate (08-12-2011)
 Old 08-11-2011, 09:26 PM   #584
with meth? i think ive been as high as 12.5-12.7 depending on AAT and boost level
Dano (08-12-2011), phate (08-12-2011)
 Old 08-11-2011, 09:28 PM   #585
driver311's Avatar
Back in the day when I was running mid to high 12s on just a few bolt ons I was running mid 12s for afr and car ripped. Now I run 12.0-12.2 on pump 93 when Its in my tank.
It all depends on how efficient of a setup you have and keeping the bats down.
Mazdaspeed
The Following 2 Users Say Thank You to driver311 For This Useful Post:
 Old 08-11-2011, 09:30 PM   #586
bewsted's Avatar
12.0-12.2 is farthest i've gone on 93 pumpzilla....
EWG K04...GETSUM!
 Old 08-12-2011, 08:51 AM   #587
Eth Fiend
phate's Avatar
I haz interweb
So I chopped the filter apart in layers:
The inside portion (pickup side) of the filter is dirty:
And a few other pieces:
Dano (08-12-2011), djuosnteisn (08-15-2011), JacksonMS30 (08-12-2011), jracer (08-12-2011), superskaterxes (08-12-2011), wolly6973 (08-12-2011)
 Old 08-12-2011, 09:14 AM   #588
Eth Fiend
phate's Avatar
Just found out my new HPFP internals will be here next week.
So we all know what that means...because I don't, as they say, 'fuck around'. [LOL]
DYNO TIME
Just sent an inquiry to schedule for Thursday or Friday.
The Following 8 Users Say Thank You to phate For This Useful Post:
bewsted (08-12-2011), Ckmazdaspeed3 (08-17-2011), Dano (08-12-2011), djuosnteisn (08-15-2011), Enki (08-12-2011), mr_mazda329 (08-28-2011), superskaterxes (08-12-2011), wolly6973 (08-12-2011)
 Old 08-12-2011, 09:45 AM   #589
Enki's Avatar
Posts: 7,541   (View Stats)
Enki has disabled reputation
Groans: 189
Looks like you might be just fine with a filter replacement and a good old fashioned scrubbing of the gas tank (if that's even possible). Maybe toss a gallon of methanol in there and swish it around for a few minutes to really get all the nasty shit out.
If you do that, take a pic of the result
Edit: New internals? What happened to the old ones?
 Old 08-12-2011, 09:47 AM   #590
Trail of Fail
Dano's Avatar
Excellent idea!!!
Tappin
 Old 08-12-2011, 09:55 AM   #591
Eth Fiend
phate's Avatar
The inside of the gas tank looked clean. There was a little bit of debris floating around, but nothing serious for 55k miles worth of fuel. Gas tank is back in the car with the new fuel pump assembly. It was definitely an issue with the ITFP, as I'm seeing 1900psi out of the stock pump when I get into boost a little bit. It can't supply enough fuel, of course, but I'm seeing way more pressure than I was before.
Internals were my first though, so I sent them in to KMD for warranty. Apparently they tested bad, as well, so I'm getting a new set.
Enki (08-12-2011), wolly6973 (08-12-2011)
 Old 08-12-2011, 09:57 AM   #592
Enki's Avatar
Groans: 189
Hmm...I'm wondering how they tested bad. Did they say? Hopefully they are actually still good, and KMD is just covering their bases and being awesome.
phate (08-12-2011)
 Old 08-12-2011, 09:59 AM   #593
Eth Fiend
phate's Avatar
You could be right. Before I sent them in, I was told they would be tested for approval/denial. They just sent an email saying my warranty claim was approved, without explanation. I sent in a letter explaining how I tested another set of internals and they held pressure, along with a graph of my pressure loss over the rpm range.
PS - while Ethanol is not much more corrosive than gas, methanol is more corrosive than both, AFAIK. I don't think I would ever attempt methanol in a stock fuel system.
 Old 08-12-2011, 10:22 AM   #594
Enki's Avatar
Groans: 189
Yes, I'm aware of how corrosive methanol is, and I would never suggest running it in the stock fuel system; which is why I suggested you flush the tank (alone) with it, which should eat away anything loose inside.
Ergh; Edit:
That is pretty strange behavior by KMD. If I were you, I'd grill them a bit further.
phate (08-12-2011)
 Old 08-12-2011, 12:25 PM   #595
Eth Fiend
phate's Avatar
Ugh, no time available at the closest dyno. I'm going to call around, but it may be after the dragon trip when I dyno. I need to switch back to gas for the labor day trip to make sure all is well with it.
 Old 08-12-2011, 12:49 PM   #596
Trail of Fail
Dano's Avatar
Don't they close the highway to let ppls run it?
phate (08-12-2011)
 Old 08-12-2011, 03:28 PM   #597
socks's Avatar
Posts: 3,250   (View Stats)
Groans: 125
I did notice buildup. it was significantly worse than in the pictures above.
i didnt cut my filter apart, all i noticed was on the outside.
The Following 2 Users Say Thank You to socks For This Useful Post:
phate (08-12-2011), superskaterxes (08-12-2011)
 Old 08-12-2011, 09:52 PM   #598
Eth Fiend
phate's Avatar
So, I just spent most of my Friday night cleaning my HPFP parts. Everything was pretty bad. The housing and spill valve (minus the spill valve solenoid) was caked worse than when I first started on this venture. I haven't cleaned everything like this for many miles - probably over 1,000, but the buildup got much worse in just the last couple hundred miles.
Hopefully I'll be able to see some difference in build up rate with the new ITFP assembly and ITFP filter. I'm a little skeptical of the new ITFP filter, as it seemed like there was much less filter material compared to the old one. It was a different design, just like a single layer of thin cloth material, whereas the old one had a thick layer plus the woven mesh layer on the outside. We'll see, I guess.
Dano (08-15-2011), Enki (08-12-2011)
 Old 08-15-2011, 09:24 AM   #599
Eth Fiend
phate's Avatar
I've got some dyno time this Friday up in Seneca, IL @ Snowdance Enterprises. For any of you Chicago folk, this shop only charges $100/hr!! It sounds like they don't have any sort of tuner, so you'll be on your own, there.
Edit: looks like internals should be here tomorrow.
Ckmazdaspeed3 (08-17-2011), djuosnteisn (08-15-2011), Enki (08-15-2011), PapaSmurf (08-15-2011)
 Old 08-15-2011, 12:29 PM   #600
Eth Fiend
phate's Avatar
I just realized they sent them to the wrong fucking address. WTF
Edit: Holy hell, I just realized this post is #601 in this thread!
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f567/e85-discussion-hpfp-lubrication-flow-issues-79030/
Anyone tried E85 yet? - Page 7 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum This thread Refback 05-10-2015 03:21 PM
E85 issues with injectors? - Page 3 - Scion FR-S Forum | Subaru BRZ Forum | Toyota 86 GT 86 Forum | AS1 Forum - FT86CLUB This thread Refback 09-12-2014 09:25 PM
Anyone tried E85 yet? - Page 7 - Focus Fanatics This thread Refback 07-04-2014 09:58 AM
Quel est le meilleur carburant? - Mazda 3 Quebec This thread Refback 05-26-2014 10:29 AM
DM E85 tune - VW GTI Forum / VW Rabbit Forum / VW R32 Forum / VW Golf Forum - Golfmkv.com This thread Refback 10-28-2013 11:10 AM
E85 Station in Alhambra? This thread Refback 03-04-2013 07:10 PM
E85 technical documentation This thread Refback 01-28-2013 05:28 AM
Tuner pre purchase questions - Page 4 This thread Refback 01-03-2013 01:32 PM
Ethanol Blending - Page 10 - VW GTI Forum / VW Rabbit Forum / VW R32 Forum / VW Golf Forum - Golfmkv.com This thread Refback 12-03-2012 10:54 AM
US vs AUS fuel This thread Pingback 11-30-2012 10:48 AM
E-85 users thread - Scion FR-S Forum | Subaru BRZ Forum | Toyota 86 GT 86 Forum | AS1 Forum - FT86CLUB This thread Refback 11-08-2012 01:05 PM
Ethanol Blending - Page 10 - VW GTI Forum / VW Rabbit Forum / VW R32 Forum / VW Golf Forum - Golfmkv.com This thread Refback 11-01-2012 01:40 PM
The Official Unofficial FAQ for Big Turbo FSI owners Pt2 - Page 42 - VW GTI Forum / VW Rabbit Forum / VW R32 Forum / VW Golf Forum - Golfmkv.com This thread Refback 11-01-2012 01:25 PM
Mazdaspeed3 thread (Welcome MSF) - Page 19 - Genesis Forum: GenCoupe Hyundai Genesis Forums This thread Refback 04-03-2012 10:19 PM
Mazdaspeed3 thread (Welcome MSF) - Page 20 - Genesis Forum: GenCoupe Hyundai Genesis Forums Post #781 Pingback 11-03-2011 02:23 PM
Anyone tried E85 yet ? This thread Refback 10-09-2011 01:21 PM
COBB AccessPORT OTS Beta Testing - *NEW* 2007-2009 MS3 Calibrations using BT Tuning! - Page 2 This thread Refback 08-01-2011 12:38 PM
AP's Injector Duty Cycle This thread Refback 06-26-2011 06:16 PM
COBB AccessPORT OTS Beta Testing - *NEW* 2007-2009 MS3 Calibrations using BT Tuning! This thread Refback 06-14-2011 09:05 AM
Gutted cat flow ~= SLP Loudmouth Resonator? Flow cant be hurt I dont think.. 08Anamoly MazdaSpeed 3 - Engine, Transmission & Driveline 6 03-04-2010 01:07 PM
Toyota ponders new pedals, lubrication as fixes in latest recall Haltech Automotive News 0 01-22-2010 10:10 PM
Any tuning issues when you delete vcts flaps, bypassing egr to flow clean cool air? Wenis Prinkle MazdaSpeed 3/6 - ECU Computer Tuning 6 07-27-2009 01:47 AM
HPFP flow mods, should support 550 WHP ptperformance Mazdaspeed3/6 General Discussion 20 01-04-2009 01:56 AM
Page generated in 0.60933 seconds with 31 queries
