| MazdaSpeed 3/6 - E85 Fueling Learn more about feeding your car corn |
Groans: 189
(Thread Starter) | Neutral : +1 score 12-4-2014 UPDATE: VersaTune cheatsheet added; it only uses FSG, at a higher rate to avoid having to do a scalar as well: For mixes below 10%, just use the 10% value. 5-21-2014 UPDATE: No more Google Docs version of the sheet. For the new, standalone HTML version, go here: Fuel mix cheat sheets New Seasonal Blends by Region table (easier to use): Seasonal Blends by Region - Mazdaspeed Forums Mazdaspeed 3/6 Wikispeedia END UPDATE Original Seasonal Blends by Region table: Seasonal Blends By Region For 70%, 75%, 80%, 85% seasonal blends of e85 (ethanol content by volume), also factoring in e10 pump gas. Please let me know if you guys want other blends of e85/e10 done up. E85 beta scalar cheat sheet: ***NOTE*** This cheat sheet is based on the percentage of ethanol in the tank, NOT the percentage of e85 in the tank (ethanol content by volume). See below sheets for actual %E for use in the above table. E70 mix cheat sheet: E75 mix cheat sheet: E80 mix cheat sheet: E85 mix cheat sheet: Actual spreadsheet (which can be modified for other seasonal blends and also has the scalar cheat sheet within it) is also attached now.
__________________ Last edited by Enki; 12-04-2014 at 04:01 PM. Reason: Update to OP for new links/information |
| The Following 69 Users Say Thank You to Enki For This Useful Post: | 86AmishMs3 (10-15-2012), Agent_Orange (01-19-2014), Arnie1229 (03-20-2015), Big sugaaakane1 (10-13-2015), Bigeasy (10-10-2013), Bob-o (01-16-2012), BobbleHead (07-23-2012), Boosted Beluga (02-28-2012), Boost_creep (01-17-2012), BrianB6 (02-18-2013), ChimmyChong (06-11-2013), cshunter (12-17-2012), CWP_MS3 (03-11-2013), Dahouse702 (07-02-2012), Dano (02-28-2012), davychronic (06-25-2015), dead-zone (04-10-2013), Decepticon (03-23-2012), djuosnteisn (04-14-2012), donjohnk (03-24-2014), dougefresh_ (01-16-2012), DSIT995 (01-13-2013), eljefe62 (12-30-2012), El_Diablo (07-08-2013), FistPump20fo7 (05-27-2013), galens47 (07-19-2012), GoSpeed3Go (01-16-2012), Gr8Speed (09-17-2014), GrumpyMPS (05-17-2014), harryclay (03-04-2012), JacksonMS30 (04-25-2012), JeffroMS3 (09-17-2013), JgamB (09-01-2015), Juyoung (05-10-2013), k_kid (08-12-2013), mazdaspeed916 (08-21-2012), Mfinlay04 (03-01-2015), Micha (07-01-2012), Mike@Stratified (05-09-2013), mr_mazda329 (08-17-2013), ms3bamf (01-16-2012), ms3blackmica (11-08-2012), msfastashell (08-20-2014), Nataphen (02-28-2012), phate (08-14-2012), Pseud0logik (05-09-2012), rfinkle2 (02-28-2012), Rich990 (06-28-2015), RichieRichness (03-20-2012), Rokusek (03-19-2014), rxtasy7 (03-02-2017), Scribbles (01-16-2012), seshomaru7 (06-12-2013), shadesofgray19 (06-22-2012), Sid3wayS (02-28-2012), simply_pandora (01-05-2013), slickety (02-26-2016), speedy308 (10-18-2012), superskaterxes (02-29-2012), taf0422 (10-25-2012), tegxsi (07-07-2015), the public enemy (08-19-2015), tMC (07-08-2015), Tres3 (09-15-2014), Twofer (02-18-2013), udntknw (01-08-2014), warlord (07-26-2012), WetzMS3 (10-07-2013), wolly6973 (03-01-2012) |
Groans: 189
(Thread Starter) | Not Ranked : 0 score The XLS for whomever wants more granularity, etc. Made in OpenOffice, not sure if it will have issues with Excel or whatnot. Edit: Use the XLS in the OP.
__________________ Last edited by Enki; 02-28-2012 at 12:52 PM. |
| The Following 5 Users Say Thank You to Enki For This Useful Post: | mr_mazda329 (05-06-2016), qkrthnu2 (08-05-2015), rfinkle2 (02-28-2012), RichieRichness (03-20-2012), Twofer (02-18-2013) |
![]() Join Date: Jun 2009 Location: placerville, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 52
Groaned at 27 Times in 8 Posts
| Not Ranked : 0 score cool man. was wondering where my 2/5 was.
__________________ https://www.facebook.com/NorCalTintZone instagram: sharpdetails |
Groans: 189
(Thread Starter) | Not Ranked : 0 score Looks like about 19% on winter blend.
__________________ |
| The Following User Says Thank You to Enki For This Useful Post: | rfinkle2 (02-28-2012) |
| Not Ranked : 0 score i dont think they switch in cali because of the mild weather.
Groans: 189
(Thread Starter) | Not Ranked : 0 score I Just realized I should probably post up my method for filling up; the rule of 3. MS3 has 14.5 gallon tank, but reads E at about 2 gallons; I figure each quarter tank is 3 gallons, making 50/50 mix 1.5 gallons per quarter tank or .75 gallons per 1/8th, with half a tank obviously being 3 each and 3/4 fill-up being 4.5. While you may not fill all the way up to the neck with this method, you are less likely to fuck up your mix when doing so.
| The Following 2 Users Say Thank You to Enki For This Useful Post: | Pseud0logik (05-09-2012), rfinkle2 (02-28-2012) |
Groans: 189
(Thread Starter) | Not Ranked : 0 score Added E85 beta scalar cheat sheet.
| The Following 4 Users Say Thank You to Enki For This Useful Post: |
Groans: 189
(Thread Starter) | Not Ranked : 0 score Everything now in the OP for ease of perusal.
| The Following User Says Thank You to Enki For This Useful Post: | Boosted Beluga (02-28-2012) |
![]() Join Date: Jun 2009 Location: Riverside, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 11,560
Groans: 50
| Not Ranked : 0 score Sweet thank you.
__________________ 08 Mazdaspeed 3 Fucking FREEK TUNED and shit |
| The Following User Says Thank You to Boosted Beluga For This Useful Post: | Hoyoman (03-31-2013) |
| Not Ranked : 0 score This should be stickied. thanks Enki!
__________________ ![]() 07 Red MS3 GT - E40 - Carrillo Rods - Wiseco Pistons - BSD - JBR 3.5 WidePath - ATP GTX3071 - Forge BPV - GA - Cobb v2 FMIC - CPE EM - CPE DP - CNT CBE - APv3 - Grim EBC - PERM dual port PCV plate - Dano dual OCC - CPE CDFP - Labonte S2 WMI - ACT Street Kit - SUv2 RMM - SU TM - "Stiffy" MM - DG CF wing ext, skirts & front lip - Hotchkis RSB/FSB w PowerGrid Links - Koni FSDs - DBA SX4000 Rotors - Hawk Pads - Silver OZ Ultraleggera - 235/40/18 NT-01 |
| The Following User Says Thank You to Dano For This Useful Post: | Enki (02-29-2012) |
![]() Join Date: Jul 2009 Location: Keene, NH
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 53
| Not Ranked : 0 score I might help to change your vocabulary in the first post a little to specify "by volume" as opposed to "by ratio of ethanol to gas". Otherwise, very helpful, thanks!
__________________ 08.5 Mazdaspeed 3 - Cobb AP w/ Boost Targetting at 17psi, CP-E Nano SRI, ETS 3.25" TMIC, SU Test Pipe, CP-E RMM, Bilstein Sports, Cobb Springs, Progress RSB, Short Shift Plate, SU Solid Shifter Bushings, Dashhawk, Gold 18x8.5 Rota G-Force's, 235/40/18 Hankook Ventus V12's 253WHP/274WTQ on a Mustang Dyno before tune, 282WHP/318WTQ in VD after tune 97 Suzuki TL1000S Naked - LeoVince Slip-Ons, K&N Filter, PCII, fully custom naked setup 89 Kawasaki 650SX Stand-Up Jetski |
| The Following User Says Thank You to SRTie4k For This Useful Post: | Enki (03-20-2012) |
| Not Ranked : 0 score stuck
| The Following 4 Users Say Thank You to superskaterxes For This Useful Post: |
Groans: 189
(Thread Starter) | Not Ranked : 0 score Updated OP with link to seasonal blends by region information for more accurate calculation of mixes based on date.
![]() Join Date: May 2009 Location: Memphis, IN
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,249
| Not Ranked : 0 score Great thread. This shit is priceless.
__________________ 2006 MS6 Titanium Grey BSD, Custom 3" SRI, 3" HTP TIP, Custom 2.5" Single Exit Exhaust, Nator Sytle Downpipe, E40 Selftune, AutoTechs, Ghetto Mod'ed Stock BPV, VTCS Delete, IM PnP & AWR RMM3 Tuned with Last edited by Mfinlay04; 07-19-2012 at 11:54 AM. |
| The Following User Says NO Thank You to Mfinlay04 For This Un-useful Post: | RichieRichness (07-19-2012) |
![]() Join Date: Mar 2010 Location: Manassas, VA
Rep Power: 2313 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,791
Groans: 35
__________________ CP-e Atmosphere GTX3076r w1.06 Tial | JMF IM | NATOR D.C. FMIC | JBR Wide Path | Autotech Internals | HKS SSQV2 | Ebay DP | Denso ITV24 | CP-e RDM | AutoExe Strut Tower Bar | Whiteline RSB | Sonic Tuning Coils | DSS Driver Side Axle | JMF OCC BT - 395 awhp 345 awtq @ Moore Automotive 4/12/2014 on 93 octane Stock Turbo - 331 awhp 397 awtq @ Moore Automotive 11/10/2012 on ~e48 12.263 @ 111.75 mph 1.669 60' 11/17/2012 | |
Groans: 189
(Thread Starter) | Not Ranked : 0 score ![]()
__________________ 2006 MS6 Titanium Grey BSD, Custom 3" SRI, 3" HTP TIP, Custom 2.5" Single Exit Exhaust, Nator Sytle Downpipe, E40 Selftune, AutoTechs, Ghetto Mod'ed Stock BPV, VTCS Delete, IM PnP & AWR RMM3 Tuned with | |
| The Following User Says Thank You to Mfinlay04 For This Useful Post: | RichieRichness (07-19-2012) |
![]() Join Date: Jun 2012 Location: San Jose, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,963
Groans: 47
| Not Ranked : 0 score Some people may also find THIS calculator helpful.
__________________ 2006 Mazdaspeed6 FreekTune | 91 | JBR 3", PMM & RMM | CS Racepipe, TMIC & TMM Inserts | Autotechs ![]() |
Groans: 189
(Thread Starter) | Not Ranked : 0 score Unfortunately, that site won't tell you the scalars for the AP, and the mileage shit doesn't apply because we can tune for MUCH better mileage on e85 than a normal, un-tuned flex-fuel vehicle can get (basically close to stock mileage if you keep your foot out of it).
| The Following 2 Users Say Thank You to Enki For This Useful Post: | Bucker (08-15-2012), RichieRichness (08-15-2012) |
Groans: 47
| Not Ranked : 0 score It's very useful for figuring out your ethanol mix though.
Groans: 189
(Thread Starter) | Not Ranked : 0 score Ok... But the screenshots up top are pretty much laid out so you don't have to type anything into a calculator.
| The Following User Says Thank You to Enki For This Useful Post: | Bucker (08-15-2012) |
Groans: 189
(Thread Starter) | Not Ranked : 0 score Cheat sheets version 2! Those of you with Google Drive can save this document locally, export it, or run it directly on your Android device! I've tested this from my Android phone and it does work, though you do have to manually refresh so the calculated values update. My requirements: 1. If you go to use it and see someone else is changing values, please let them finish before you input your own. There is an integrated chat for Google Docs so you can find out how much longer the other person(s) will be. 2. Don't fuck up the maths on this thing or deface it with ascii cocks or anything. I may not be available to fix or reload it; if this gets to be a consistent problem, I'll probably wind up taking it down. With that out of the way, on to the good shit! Here is what it looks like: Some quick notes: 1. The seasonal blend information is editable in the table to the right, and is also included as images embedded directly into the file; these images are also embedded at the end of this post. 2. The manual mix output uses the %Ethanol values you specify in the sheet up top; the seasonal mix output uses the lookup table at the right for minimum ethanol content in said e85 (instead of using the %E value in B1). 3. The "Reblend gallons" value is for when you have a partial tank of mix and have to get fuel from some place that doesn't have corn available. Specify your remaining fuel quantity using the E85 and Pump gallons sections (make sure the manual mix value matches what you are running) and then play with the reblend gallons value to see how much adding pump gas to your existing mix will change your overall percentage. 4. That is all.Here's the link to the spreadsheet; try not to fuck it up: https://docs.google.com/spreadsheet/...0lmUjcwR3R2Ync Seasonal blend information: This version replaces the older one, still available here: Fuel mix cheat sheets
| 5000lbs of voiceless fury ![]() Join Date: May 2012 Location: San Diego, CA
Rep Power: 2530 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,855
Groans: 185
Groaned at 124 Times in 81 Posts
| Not Ranked : 0 score good deal.
__________________ 2015 Telsa Model S 85D - Delivered 10/21/2015 FYEN! SOLD!!! 2007 Mazda MS6 - //AWD//BNR S3//cp-e TMIC//cp-e CDFP//Cobb AP//Cobb TIH//Cobb EBCS//Bosch 845 3 Bar//MS-CAI//Custom DP//TS Kompact BPV//Magnaflow CBE//AWR RMM//JBR Stage 3 SSP Kit//JBR EGR Delete//H&R Springs// |
![]() | | #24 | ![]() |
Groans: 189
(Thread Starter) | Not Ranked : 0 score Mods please un-sticky; has been replaced by new version: Fuel Mix Cheat Sheets v.2
![]() | | #25 | ![]() |
| Not Ranked : 0 score I think the original thread is too valuable to un-sticky, so they're merged ![]() The cheat sheets are a seriously nice quick reference. I use them often when I'm out and don't want to calc this stuff, haha.
__________________ -06 MS6 -Corn fed 07 MS3 - Sold ![]() www.mazdamotorsports.com <<--Mazda racer support program that is free to join and will save you a ton of money. |
| The Following 3 Users Say Thank You to phate For This Useful Post: |
![]() | | #26 | ![]() |
![]() Join Date: Sep 2011 Location: Rockville, MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,554
Groans: 130
Groaned at 8 Times in 7 Posts
| Not Ranked : 0 score What I don't get about this is that even though the MS6 has a 16 gallon tank, it never will fill up 16 gals at the pump. The charts are all based on if you literally put 16 gallons in the tank which I think is impossible. Unless I'm doing something wrong I don't think I've ever filled up past 14 gallons when I take the car till the gas light comes on. and I have everyone telling me that 3 gallons of E85 is all I will ever need. Ok thats great. The problem is partial fill ups. There are going to be times where I can't wait to take the car down till the gas light comes on to fill up. So how do I know for sure what of each type of fuel to put in when I go to the station to partially fill up?
__________________ 06 Black Cherry Mica MS6 GT: Speed Perf6rmanc3 built motor, GT3076r EWG, ACT 6 puck Clutch kit, HTP 3.5" full intake, M2 downpipe, XS Power Exhaust Manifold, CP-E austenite 3" exhaust, Whiteline 24mm rear sway bar, Injector RX Cleaned injectors, JBR trilogy motor mounts, JBR EGR Block off plate, Ported and ceramic coated intake manifold, 3 bar MAP, 3 port EBCS, Cobb AP, CX racing piping with Treadstone TR8, CP-E SAFEseals, MD OCC, Step Colder spark plugs, Turbo XS RFL BOV, AT fp internals, CP-E rear diff mount, Turbine Tech Front rear diff mount, DSS 500hp rear drivers side axle, Wilwood 4 Pot Calipers, Team Dynamics 18"x8" Pro Race 1.2s +38, SPC front ball joints, H&R springs, Morimoto clear projector retrofits. |
![]() | | #27 | ![]() |
| Banned ![]() Join Date: Aug 2011 Location: Springfield/Union NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,560
Groaned at 52 Times in 48 Posts
| The Following 2 Users Say Thank You to dantes5823 For This Useful Post: | Jh8909 (12-18-2012), RichieRichness (12-19-2012) |
![]() | | #28 | ![]() |
Groans: 35
| Not Ranked : 0 score Just eye ball it dude. This shit is not an exact science. Sent from my iPhone using Tapatalk
![]() | | #29 | ![]() |
| Not Ranked : 0 score Just remember to err on the high side of ethanol. The little bit of leanness you mightbutprobablywont encounter will be offset by the increase in effective octane. Sent from my Galaxy Nexus using Tapatalk 2
![]() | | #30 | ![]() |
Groans: 189
(Thread Starter) | Not Ranked : 0 score Or if you know how many gallons actually fit, you could always *use the cheatsheets* to figure out how much to use for the mix.
![]() | | #31 | ![]() |
![]() Join Date: Aug 2011 Location: Miami, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 13,355
Groans: 279
The Injector Scalar table in AP is rounding my value of 1.0266 to 1.03, is that ok?
__________________ 2010 LSM Speed3 Bolted + Corn + Meth + ACT 6-Puck #BakeryTuned | |
![]() | | #32 | ![]() |
| Not Ranked : 0 score What you don't want to do is continue to use the "top off" method. Your E concentration will continue to move one way or another depending on which fuel you top off with. Tappin
| The Following 2 Users Say Thank You to Dano For This Useful Post: | Enki (12-19-2012), polishlanman (01-27-2013) |
![]() | | #33 | ![]() |
Groans: 189
(Thread Starter) | Not Ranked : 0 score Yeah.
![]() | | #34 | ![]() |
![]() Join Date: Jan 2011 Location: Tulsa, OK
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 24
| Not Ranked : 0 score Good stuff. I should be going BNR S3 soon and have one gas station 2 miles away with 100% pure gas (91 octane) and another 2 miles away currently with E70 (E85 Winter blend.) Mixing 5.25 gal of E70 and 7 gallons of pure gas should give me an E30 mix!
__________________ Need a way to mount your Devil's Own methanol kit? Find my F/S thread for a custom made mount kit with all hardware included! |
![]() | | #35 | ![]() |
Groans: 189
(Thread Starter) | Not Ranked : 0 score I've added a secondary tab to the Google Docs spreadsheet calc which has the lambda/afr/max power (lean and rich) info in it across a very wide range; hopefully someone finds it useful, though it isn't specifically required for tuning our cars.
| The Following User Says Thank You to Enki For This Useful Post: | El_Diablo (08-26-2013) |
![]() | | #36 | ![]() |
Groans: 189
(Thread Starter) | Neutral : +1 score Third tab added for new version of the calculator which makes for easier blending math: https://docs.google.com/spreadsheet/...nc&usp=sharing
![]() | | #37 | ![]() |
Groans: 189
(Thread Starter) | Not Ranked : 0 score Whoever the stupid shit(s) is(are) that keeps editing cells they shouldn't is going to get the spreadsheet taken down. Just sayin.
![]() | | #38 | ![]() |
![]() Join Date: Mar 2014 Location: ardmore, ok
Rep Power: 0 ![]() ![]() ![]() ![]() Thanks: 12
| Not Ranked : 0 score wow, Im gunna make some print outs of this and hand them out at the next meet after choppin' some heads. Awesome thread enki! |
![]() | | #39 | ![]() |
![]() Join Date: Aug 2012 Location: Ripon, CA
Rep Power: 2958 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,390
Sent from a Galaxy far far away... | |
![]() | | #40 | ![]() |
| Not Ranked : 0 score trust me, they know im far to old and tarded to figure this kind of stuff out on my own. ENKI will get full credit for sure... |
| The Following User Says Thank You to Mulenax For This Useful Post: | littleloogy (03-29-2014) |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f567/fuel-mix-cheat-sheets-102438/ | ||||
| E70 | This thread | Refback | 12-30-2015 12:28 PM | |
| b00stedmica93's Tuning - Page 5 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum | This thread | Refback | 03-04-2014 01:35 PM | |
| Going to try E30 today | This thread | Pingback | 01-20-2014 09:40 AM | |
| What happened to the e85 blend thread? - Page 4 | This thread | Refback | 01-08-2014 06:44 PM | |
| What happened to the e85 blend thread? - Page 3 | This thread | Pingback | 01-08-2014 11:28 AM | |
| 93 GMC Typhoon - Page 16 - Motorgen - Automotive Events, Meets, Cruises and Forums | This thread | Refback | 03-19-2012 09:16 AM | |
| Mazda whips the sheets off of MX-5 Miata Miyako for UK market | Haltech | Automotive News | 0 | 06-30-2010 08:00 AM |
| 18 psi DynoJet Dyno Sheets | 18psiWhiteMS3 | MazdaSpeed 3/6 - Big Turbo Builds | 13 | 04-08-2010 09:59 AM |
| Overstock. com - 5% Off Storewide & Free Shipping on Sheets at Overstock.com | Haltech | Hot Deals Section | 0 | 04-15-2008 07:40 AM |
| New SmartBargains Coupon Codes - Extra 25% Off Select Luxury Sheets at SmartBargains | Haltech | Hot Deals Section | 0 | 04-14-2008 01:50 PM |
