Like Tree40Likes
 Old 03-24-2013, 12:15 PM   #81
Wicked's Avatar
Posts: 319   (View Stats)
Wicked is the leader of the worldWicked is the leader of the worldWicked is the leader of the worldWicked is the leader of the worldWicked is the leader of the worldWicked is the leader of the worldWicked is the leader of the worldWicked is the leader of the worldWicked is the leader of the worldWicked is the leader of the worldWicked is the leader of the world
Groaned at 3 Times in 1 Post
I miss having E. My Cobalt was a monster on it. Gonna be making the switch to a 4 gal mix IF THE DAMN SNOW EVER STOPS!
2010 Velocity Red Mica MAZDASPEED3 |E30 self tune|CorkSport SRI/TIP|CorkSport Ice Box|CorkSport TMIC|Forge v2|Autotech Internals|JBR 80a RMM|JBR Shifter Bushings|COBB shift knob|H&R springs|JBR rear camber arms|MOOG end links|
Wicked is offline   Reply With Quote
 Old 03-24-2013, 04:11 PM   #82
navyspeed3's Avatar
Posts: 115   (View Stats)
navyspeed3 has a reputation beyond reputenavyspeed3 has a reputation beyond reputenavyspeed3 has a reputation beyond reputenavyspeed3 has a reputation beyond reputenavyspeed3 has a reputation beyond reputenavyspeed3 has a reputation beyond reputenavyspeed3 has a reputation beyond reputenavyspeed3 has a reputation beyond reputenavyspeed3 has a reputation beyond reputenavyspeed3 has a reputation beyond reputenavyspeed3 has a reputation beyond repute
Originally Posted by ABolewski View Post
@phate; is. And I believe the general consensus was that the E-85 specific pump was bull shit, and you don't need it. Although I have read that even on a k04 you will run out of fuel on 100% E which means you need some form of port injection (5th port or one of the new JMF mani's).
I plan on running strait E pretty soon here myself.
I was just more overall curious to see how many people were running a straight E or had a tune for at the track for it. But thanks for the feedback.
navyspeed3 is offline   Reply With Quote
 Old 05-10-2013, 11:01 AM   #83
ajkulish's Avatar
Posts: 412   (View Stats)
ajkulish is the leader of the worldajkulish is the leader of the worldajkulish is the leader of the worldajkulish is the leader of the worldajkulish is the leader of the worldajkulish is the leader of the worldajkulish is the leader of the worldajkulish is the leader of the worldajkulish is the leader of the worldajkulish is the leader of the worldajkulish is the leader of the world
Groans: 40
to everyone running corn: did your gas mileage get fucked upon switching, or is it similar to just running 93
ajkulish is offline   Reply With Quote
 Old 05-10-2013, 11:06 AM   #84
Mfinlay04's Avatar
Posts: 827   (View Stats)
Who cares. Corn is too much fun to be worried about MPG. Wtf
But yes corn kills, no murders mpg. Between constantly flogging it and corn having less BTU than gasoline
Sent from my Nexus 7 using Tapatalk 2
2006 MS6 Titanium Grey
Tuned with
 Old 05-10-2013, 11:44 AM   #85
Enki's Avatar
Posts: 7,541   (View Stats)
Enki has disabled reputation
Groans: 189
Only if you stomp the fast pedal. I get better mileage than stock on 50/50 mix (~e42)
sarm1084 likes this.
Speed_j23 (05-11-2013)
 Old 05-10-2013, 12:32 PM   #86
ajkulish's Avatar
Groans: 40
thanks, i am hopefully buying an ms3 this week and i am trying to decide my plans with it.
 Old 06-17-2013, 02:05 PM   #87
DumbDave's Avatar
Posts: 57   (View Stats)
DumbDave has a reputation beyond reputeDumbDave has a reputation beyond reputeDumbDave has a reputation beyond reputeDumbDave has a reputation beyond reputeDumbDave has a reputation beyond reputeDumbDave has a reputation beyond reputeDumbDave has a reputation beyond reputeDumbDave has a reputation beyond reputeDumbDave has a reputation beyond reputeDumbDave has a reputation beyond reputeDumbDave has a reputation beyond repute
Anyone notice less NVH switching to E85? At about 10 miles into my first tank I noticed a significant drop in the vibes. My rearview mirror is no longer useless @ speed, and I can start in 2nd gear without the engine bogging. Is that just a side effect of the engine not having to work as hard?
Made me crawl underneath to make sure I didnt snap my JBR wishbone.
Thoughts?
I'm running a 5gal mix of summer blend (E37).
DumbDave is offline   Reply With Quote
The Following User Says Thank You to DumbDave For This Useful Post:
Enki (06-17-2013)
 Old 06-17-2013, 02:58 PM   #88
Enki's Avatar
Groans: 189
It does run smoother, yes. Also, you can shift at about 2500 and it will pull normally. That is what you should do to get better mileage (6th gear @ 45 mph FTW).
sarm1084 and Nel Mazdaspeed like this.
DumbDave (06-17-2013)
 Old 06-17-2013, 04:27 PM   #89
DumbDave's Avatar
Awesome, thanks for the info and piece of mind
 Old 06-19-2013, 03:31 AM   #90
Mfinlay04's Avatar
Not sure if serious nor trolling. 45mph in 6th gear is <2k rpms?!
Tuned with
 Old 06-19-2013, 06:53 AM   #91
Dizzy Turbo's Avatar
Posts: 2,173   (View Stats)
He's serious, I started driving like that on my ethanol map and it helps mpgs a lot.
Edit: as long as your not on a hill haha
The Following User Says Thank You to Dizzy Turbo For This Useful Post:
Enki (06-19-2013)
 Old 06-19-2013, 07:30 AM   #92
Enki's Avatar
Groans: 189
Dead serious. You can't go as low with only 50/50 mix, but these engines on corn love to cruise at 2k rpm.
@phate;
@silvapain;
Back me up gents.
silvapain (06-25-2013)
 Old 06-19-2013, 07:36 AM   #93
silvapain's Avatar
Posts: 6,665   (View Stats)
Groans: 136
He's not saying to floor it at 45 MPH in 6th gear, but the engine has no problem cruising at that low an RPM with E85. I typically try to keep it in the 2K RPM range when cruising at a steady speed, even when on pump gas.
Deldran (06-19-2013)
 Old 06-19-2013, 07:36 AM   #94
Deldran's Avatar
Posts: 3,139   (View Stats)
Groans: 118
Hell i cruze at 40 in 6th on 93. Now if i need to accelerate or anything like that down shift for sure. But keeping a constant speed on the extremely flat road in town on the way to work i see no ill effects
Damond Built Speed 6
The Following 2 Users Say Thank You to Deldran For This Useful Post:
Cheapspeed (09-30-2013), El_Diablo (06-19-2013)
 Old 06-19-2013, 07:53 AM   #95
El_Diablo's Avatar
Posts: 2,770   (View Stats)
Groans: 769
6th gear can be utilized at 35mph as long as you're not attempting to go up a grade or increase speed.
 Old 06-19-2013, 09:43 AM   #96
Ummmm 6th? Haha
 Old 06-19-2013, 10:21 AM   #97
El_Diablo's Avatar
Groans: 769
Originally Posted by Dizzy Turbo View Post
Ummmm 6th? Haha
Fixed, thanks!
Dizzy Turbo (06-19-2013)
 Old 06-20-2013, 01:51 PM   #98
Mfinlay04's Avatar
Well we don't have too many flat roads around here. I typically drive with the rpms between 2.5-3k. Any less would scare the shit out of me.
Tuned with
 Old 06-20-2013, 02:03 PM   #99
specvspeedfreak's Avatar
Posts: 2,371   (View Stats)
Just "tested" this 6th gear thing and I realized I do it all the time without noticing (I try to hypermile since on E as much as I can).. 6th gear at 1.8K-2.2K can get you 35+ mpg easily if you control the throttle correctly.
El_Diablo (06-20-2013)
 Old 06-20-2013, 03:12 PM   #100
El_Diablo's Avatar
Groans: 769
My elevation swing just going to and from work is over 300ft though there are still plenty of places where I can cruise at a low RPM in 6th. Typically, most of my drive is done in 6th with not much time spent in 5th and just one hill in 4th. My speed is usually right around 55-65mph.
 Old 06-20-2013, 08:26 PM   #101
Enki's Avatar
Groans: 189
That should be closer to 40-45 assuming a moderate mix (50/50) and 45-65 mph.
 Old 09-26-2013, 02:30 AM   #102
GeorgeTaper's Avatar
Posts: 74   (View Stats)
GeorgeTaper has a brilliant futureGeorgeTaper has a brilliant futureGeorgeTaper has a brilliant futureGeorgeTaper has a brilliant futureGeorgeTaper has a brilliant futureGeorgeTaper has a brilliant futureGeorgeTaper has a brilliant futureGeorgeTaper has a brilliant futureGeorgeTaper has a brilliant futureGeorgeTaper has a brilliant futureGeorgeTaper has a brilliant future
I have a local E85 pump. A few of them. Based on this. And that my friend runs E85 through his evo and loves it. I would love to get in on it. MAX 50/50 though after reading this. Which tuner would you recommend for 50/50 Ethanol. i need a full tune done anyway and since E85 is so available it would seem right. E50* and 93.
2009 MS3 BLACK MICA GT PACK - Cobb SRI, Autotech HPFP, Cobb AP, JBR TIP, SU TMIC, ATP Catless Longpipe, JBR 88 Duro RMM, JBR EGR block off, JBR thermal gasket, Motorcraft oil, NGK 1 step colder plugs.
GeorgeTaper is offline   Reply With Quote
 Old 09-28-2013, 05:54 AM   #103
Wicked's Avatar
You can drop to 87 when you're running mixes. The E85 more than makes up for it. But many people use Freek tuning or Rich tuning
Mfinlay04 and sarm1084 like this.
The Following 2 Users Say Thank You to Wicked For This Useful Post:
Mfinlay04 (10-03-2013), simply_pandora (10-22-2013)
 Old 10-02-2013, 09:43 PM   #104
Originally Posted by Wicked View Post
You can drop to 87 when you're running mixes. The E85 miss than makes up for it. But many people use Freek tuning or Rich tuning
Next pay check I think I'll give Rich Tune a shout. Thanks for the help my friend
The Following User Says Thank You to GeorgeTaper For This Useful Post:
Wicked (10-05-2013)
 Old 10-16-2013, 04:35 PM   #105
maxspeed's Avatar
Posts: 180   (View Stats)
maxspeed has much to be proud ofmaxspeed has much to be proud ofmaxspeed has much to be proud ofmaxspeed has much to be proud ofmaxspeed has much to be proud ofmaxspeed has much to be proud ofmaxspeed has much to be proud ofmaxspeed has much to be proud ofmaxspeed has much to be proud of
Finishing up my e25 mix base map. I used the mix sheets to get my fsg and scalar numbers. The class 2 and 3 blend numbers are close the scalar is the same and ATR rounds the FSG to the same so I should be fine using both blends? Also lowered boost (17.5) and timing a lot because I am gonna take it little slow. AFR is 11.4 to keep it safe. Anything look wrong with this timing besides being low numbers to start with?
Another question is I am in college so I don't drive that often and my car sits a decent amount. I was planning on do a small fillup 1gallon e85 1 gallon 93 if being on the empty light means 2 gallon left. I did pickup the marine stabilizer though. So has anyone used the sta-bil marine stuff and had sucess or what should I do?
AP|RMM|TP|HPFP|E40
maxspeed is offline   Reply With Quote
 Old 10-16-2013, 05:22 PM   #106
Eth Fiend
phate's Avatar
Posts: 6,947   (View Stats)
That mid range timing isn't really in line with the top end timing. It's WAY aggressive compared to the top end. Quite a bit for a base map.
-06 MS6
-Corn fed 07 MS3 - Sold
maxspeed (10-16-2013)
 Old 10-16-2013, 05:53 PM   #107
maxspeed's Avatar
If the table I posted doesn't look good im just use a ots timing to start with not an expert at atr yet but I think I know enough to try out e85. I haven't had to much experience with changing timing so I will just use that table and do the small increases instead of trying to make my own base.
Jakeypoo likes this.
AP|RMM|TP|HPFP|E40
 Old 10-21-2013, 08:04 AM   #108
sallyspeed3's Avatar
Posts: 638   (View Stats)
sallyspeed3 is the leader of the worldsallyspeed3 is the leader of the worldsallyspeed3 is the leader of the worldsallyspeed3 is the leader of the worldsallyspeed3 is the leader of the worldsallyspeed3 is the leader of the worldsallyspeed3 is the leader of the worldsallyspeed3 is the leader of the worldsallyspeed3 is the leader of the worldsallyspeed3 is the leader of the worldsallyspeed3 is the leader of the world
Closest station for me is about 40 minutes away. So what I do is whenever possible head there on a weekend when I'm able and bring 3 5 gallon containers with me. I put in an ounce or so of the stabil ethanol treatment in each container and fill each one with 4 gallons. Stuff works great, I've had them sit for as long as 2 months and never had any problems.
2008 Cosmic Blue Mazdaspeed 3 GT - COBB AP DIZZYTUNED for 30% E85//JBR Whale Penis//COBB TIP//COBB DP//COBB STS//COBB Knob//COBB shift weight//COBB Piping TR8L Core//Magnaflow CBE//Turbosmart BPV//PTP internals//SU RMM//TRZ tranny mount//Koni + H&R springs//Tinted 35% front, 20% rear//Lamin-X head-light & tail-light film//ASA GT1 18x8//Hankook Ventus V12 225/40//
sallyspeed3 is offline   Reply With Quote
The Following User Says Thank You to sallyspeed3 For This Useful Post:
maxspeed (10-21-2013)
 Old 10-21-2013, 04:54 PM   #109
maxspeed's Avatar
Thanks for the info. How do you determine how many gallons are in the tank when the e light comes on? It seems like most people just put less fuel to make sure there mix is correct and not go for a full tank?
AP|RMM|TP|HPFP|E40
 Old 10-21-2013, 05:18 PM   #110
Exactly right, put in the largest mixture that you think will fit. I do 4 gal of e and 8 of pump when I get just under a quarter tank and that's completely full
 Old 10-21-2013, 05:34 PM   #111
El_Diablo's Avatar
Groans: 769
I take mine down until the gauge reads empty and I can usually fit right at 14 gallons which for me means a 5/9 mix. Your car may be different so keep a spare can of 93 in the trunk until you figure it out.
 Old 10-21-2013, 05:44 PM   #112
maxspeed's Avatar
I will probably fill up with a decent amount less than what would be a full tank then when I figure out what my empty light reads add more. But I still need to decide if I am going to try and tune this or get an e tune. I have been learning a lot last couple months but e85 seems little tougher for me.
AP|RMM|TP|HPFP|E40
 Old 10-21-2013, 05:54 PM   #113
El_Diablo's Avatar
Groans: 769
Best way is to take it all the way down to empty. Fill it to the top with 93 and see what it takes.
 Old 10-21-2013, 05:57 PM   #114
maxspeed's Avatar
Yeah im going to do that soon. Takes me awhile to kill a tank in college I will have to look around for some good driving roads around here to go through my next tank.
AP|RMM|TP|HPFP|E40
 Old 10-21-2013, 06:25 PM   #115
Enki's Avatar
Groans: 189
Take it down to a quarter tank, refill like normal then use that number for your overall fill rate; leave any additional remainder off just to be safe though.
 Old 10-21-2013, 06:31 PM   #116
El_Diablo's Avatar
Groans: 769
I drive way to much for that.
 Old 10-21-2013, 09:08 PM   #117
maxspeed's Avatar
Yeah in the summer that wouldn't be ideal for me but at school not so much of a problem
AP|RMM|TP|HPFP|E40
 Old 10-22-2013, 05:00 AM   #118
Might be different for others, but when my light comes on I put about another 10-15 miles on the car and then head to the gas station. 8 gallons of 93 and I top it off with the 4 gallons of E85, has never been a problem.
 Old 10-22-2013, 02:57 PM   #119
maxspeed's Avatar
I though you put the e85 first but if you know your own tank I guess it doesn't matter.
AP|RMM|TP|HPFP|E40
 Old 10-22-2013, 03:32 PM   #120
silvapain's Avatar
Groans: 136
Remember that the Pu has a 16 gallon tank and the Juan is only 14.5 gallons, so how much you add at what gauge level depends on your MY.
sarm1084 (01-03-2018)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f567/how-e85-98590/
How to e85 mazdaspeed - 1Q5A This thread Refback 10-02-2014 07:27 AM
how to make a mazdaspeed 6 run on E85 This thread Refback 04-23-2013 10:54 AM
Page generated in 0.58206 seconds with 34 queries
