 Old 10-14-2015, 10:31 AM   #1
qkrthnu2's Avatar
Posts: 131   (View Stats)
qkrthnu2 has a reputation beyond reputeqkrthnu2 has a reputation beyond reputeqkrthnu2 has a reputation beyond reputeqkrthnu2 has a reputation beyond reputeqkrthnu2 has a reputation beyond reputeqkrthnu2 has a reputation beyond reputeqkrthnu2 has a reputation beyond reputeqkrthnu2 has a reputation beyond reputeqkrthnu2 has a reputation beyond reputeqkrthnu2 has a reputation beyond reputeqkrthnu2 has a reputation beyond repute
Default Low-Ethanol Fail Safe
Anyone here ever used one of these? Zeitronix ECA : SEMA Award Winning Ethanol Content Analyzer and Flex Fuel Sensor for E-85 and E-85/gasoline Blends
This thing looks pretty badass, realtime Ethanol content analyzer. Not cheap ($379 for Sensor/Analyzer/Guage combo), but would pay for itself if you ever ended up with a low-E fill.
It has analog outputs so it could even be made into an automatic fail-safe device. I'm picturing a little Arduino project that would read the analog Ethanol content signal as input and then output to the GuardianAngel trigger if Ethanol content is too low. @Lex
_______________________________________________
Driver Mods - Mid Ohio Three Day Racing School
2006 Mazdaspeed 6 GT - 130k+ miles. Daily driver (Actually my Wife's car)
Shooting for a reliable 350 AWHP.
Surefire Remanufactured Engine Installed @ 135k.
Mods: BNR S3 Turbo \ Grimmspeed EBCS \ Guardian Angel \ Cobb AccessPort \ Bosch 3 Bar MAP sensor \ AWR RMM \ TurbineTech FMM \ Corksport HPFP \ cp-e Injector seals \ Autolite XP5263 plugs \ Ebay Circuit Werks DP \ Stock CBE \ HTP 3" Intake w/ DIY CAI \ cp-e TMIC \ DIY boost tubes \ Primary & Secondary EGR delete \ Bilstein Shocks \ 215/45ZR -18 Continental ExtremeContact DWS
PERM dual PVC plate and two Damond Motorsports catch cans. Full vacuum setup w/ VTA for over pressure.
PERM #1 -> DM OCC V1 -> DM PCV valve -> Check Valve -> Intake Manifold.
PERM #2 -> DM OCC V2 w/ VTA -> Check Valve -> Tee -> Valve Cover & TIP.
The others:
2009 BMW 135i - N54 - JB4 w/ backend flash \ SRI.
1998 VW GTI VR6 - 248k miles (stock clutch!) when wrecked (not my fault)
1995 Jeep XJ - 4.0 - AW4 \ Lift/Tires etc. 230k miles. Rust bucket / winter beater.
1995 Honda del sol VTEC - DIY hodge podge turbo setup \ self tuned w/ Neptune. 2550lbs ~270whp \ 150k+ miles on stock bottom end (4th clutch though) \ knock limited on 93 octane.
qkrthnu2 is offline   Reply With Quote
 Old 10-14-2015, 11:59 AM   #2
Enki's Avatar
Posts: 7,541   (View Stats)
Enki has disabled reputation
Groans: 189
There are minimum content standards based on seasons, in which you could tune for the minimum and use the cheat sheets while watching the trims.
In the case of E70 pump, 4/8 mix would result in E30; with the same mix in the summer (assuming full E85), the mix would jump to E35.
 Old 10-14-2015, 02:03 PM   #3
qkrthnu2's Avatar
Yeah it's definitely easy enough to calculate the mix.
I was thinking this could be an engine saver for a scenario along the lines of a bad fill (i.e. Ethanol content is not what is claimed), or someone accidentally filling the tank with all gas on an E tune (e.g. multi-driver vehicles). The latter is a scenario which would likely result in timing advance so high that it is outside the range of Knock Retard coming to the rescue.
The others:
Honda recalls 6,800 Accord hybrids for switching to fail-safe mode Haltech Automotive News 0 10-06-2015 08:30 AM
DIY WMI Fail Safe? ms6_nate MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 4 07-25-2013 09:51 PM
Ethanol from almost anything? Coskata opens Lighthouse cellulosic ethanol plant Haltech Automotive News 0 10-18-2009 11:20 AM
Page generated in 0.23660 seconds with 21 queries
