Closed Thread
 Old 01-26-2016, 01:38 PM   #1
wes3id's Avatar
Posts: 611   (View Stats)
Default odd whining sound near fuel rail
I just went full corn and did some data logs for my freektune map, and there is a high pitched whining coming from somewhere near the middle of the intake manifold...i'm assuming the fuel rail but it sounds pretty close to the throttle body. has anybody else experienced this? the car drives fine...just not sure if i need to be concerned
wes3id is offline
 Old 01-26-2016, 05:44 PM   #2
wes3id's Avatar
Anybody!!???
wes3id is offline
 Old 01-26-2016, 05:56 PM   #3
sheston's Avatar
Posts: 1,847   (View Stats)
You may have to post a video if you can. These cars make way too many "odd" sounds
sheston is offline
 Old 01-26-2016, 06:11 PM   #4
wes3id's Avatar
Here is a shitty video with the whining.
wes3id is offline
 Old 01-26-2016, 06:30 PM   #5
MD1032's Avatar
Posts: 2,624   (View Stats)
Groans: 143
That's really high pitched, almost sounds electronic in nature. Try unplugging the electronic spill valve on the HPFP while the car is idling and see if the sound stops (note: this will cause the car to idle rough). It almost sounds like it's coming from the fuel pump.
2007 Mazdaspeed3 GT
MD1032 is offline
 Old 01-26-2016, 07:09 PM   #6
wes3id's Avatar
when i turn the car off it winds down but if i turn it back over to acc, there is no sound except the normal hpfp priming sound. i try to put my ear down to find exactly where its coming from... sounds like it's coming from lower than the hpfp, like near the throttle body area. i cant feel any air bleeding out anywhere or any leaking fluids.
wes3id is offline
 Old 01-26-2016, 07:18 PM   #7
MD1032's Avatar
Groans: 143
It could be the throttle body motor going bad then.
2007 Mazdaspeed3 GT
MD1032 is offline
 Old 01-27-2016, 07:19 AM   #8
wes3id's Avatar
@atvfreek; any idea's? never heard this before yesterday after i switched over to corn
wes3id is offline
 Old 01-27-2016, 02:09 PM   #9
Enki's Avatar
Posts: 7,541   (View Stats)
Enki has disabled reputation
Groans: 189
Pretty sure the throttle body is PWM, which very well could be the sound you're hearing.
Enki is offline
 Old 01-27-2016, 02:27 PM   #10
wes3id's Avatar
excuse my ignorance, but what is "PWM"?
wes3id is offline
 Old 01-27-2016, 02:30 PM   #11
Pulse width modulation (PWM) is a fancy term for describing a type of digital signal. Pulse width modulation is used in a variety of applications including sophisticated control circuitry. Although this modulation technique can be used to encode information for transmission, its main use is to allow the control of the power supplied to electrical devices, especially to inertial loads such as motors. In addition, PWM is one of the two principal algorithms used in photovoltaic solar battery chargers,the other being maximum power point tracking.
sent from my Nexus 6P
MS3Shadow is offline
WetzMS3 (01-27-2016)
 Old 01-27-2016, 02:53 PM   #12
Enki's Avatar
Groans: 189
PWM on a motor can cause an annoying resonance in some motors. Case in point:
Enki is offline
 Old 01-27-2016, 03:07 PM   #13
wes3id's Avatar
Thanks guys. Why would it start doing that now? it never did before
wes3id is offline
 Old 01-27-2016, 03:17 PM   #14
Enki's Avatar
Groans: 189
What did you change?
Enki is offline
 Old 01-27-2016, 03:28 PM   #15
wes3id's Avatar
installed a JBR BSD kit, changed oil, si-1 hpfp treatment, switched to e85 and loaded first freektune base map for e85 to take some logs. seems a lot hotter in the engine bay as well...coolant and oil temps are in the norm for me, but my once cold pipe is now pretty hot
wes3id is offline
 Old 01-27-2016, 04:05 PM   #16
Enki's Avatar
Groans: 189
Have you checked your oil level?
Enki is offline
 Old 01-27-2016, 04:10 PM   #17
wes3id's Avatar
yes i did.
wes3id is offline
 Old 01-27-2016, 05:54 PM   #18
sheston's Avatar
Are you having any boost issues? Your comment about winding down, could it be the turbo starting to fail? The sound might travel thru the intercooler and sound like it's coming out of the rubber pipe after the cold pipe, before the throttle body.
You could check for shaft play fairly easily
sheston is offline
 Old 01-27-2016, 06:00 PM   #19
wes3id's Avatar
what i meant about winding down was, when i turn the car off..the noise dies off slower than the car (like 2 seconds) I'm fairly certain it is not the turbo as it's a different sound. I did check for shaft play yesterday and sad to say...i have maybe 2mm front to back movement. housing inlet looks good, no oil, barely any scratches, blades are good, no smoking.
wes3id is offline
Closed Thread
Whining sound + no boost (0psi) CombatVet89 MazdaSpeed 3/6 - Turbo Induction 17 05-04-2014 01:09 PM
other cars that share our fuel system (specifically fuel rail) TWOptSL0W MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 1 05-12-2012 09:13 AM
whining sound? analbumcover Gen2 MS3 General Discussion 4 11-02-2011 09:16 AM
Whining Sound At Idle bewsted 2010 MS3 - Troubleshoot/Diagnostics 5 01-09-2011 09:34 PM
Page generated in 0.37350 seconds with 25 queries
