| MazdaSpeed 3/6 - E85 Fueling Learn more about feeding your car corn |
![]() Join Date: Apr 2017
Rep Power: 36 ![]() Thanks: 0
(Thread Starter) | Not Ranked : 0 score I have a set of 1 step colder NGKs that I’m now pretty convinced I shouldn’t use. Seems the best E mix option plug is the Denso ITV20? I’m curious to hear if people agree with this?
__________________ 08 MS3 - RMM, AP, Autotech internals, CS TIP/SRI, CS Boost tubes/recirc tube, CS TMIC, CS BPV, DP, DMS OCC Last edited by meekerMS3; 10-24-2017 at 02:01 PM. |
Groans: 211
| Not Ranked : 0 score 50% Ethanol? Hope you did your homework on black death. Stock heat range is fine.
![]() Join Date: May 2016 Location: Sarastoa, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 114
I thought the general consensus was keeping under 50% ethanol significantly reduced the chance of black death, assuming no major oil leaks. I am interested in the spark plug question. I'm using stock Heat Level Iridiums, and will be moving to an Ethanol blend soon, somewhere around E35-E45 or so. Justin with Freektune didn't seem to think cooler plugs were necessary for my application, so I'm sticking with these ATM.
__________________ 2009 Mazdaspeed 3 Sport (Original Owner) - 95k miles on original Motor & Turbo and counting Current Performance Mods: APv3 Freektune 93 & E-30 | JBR 3.0 SRI | ETS TMIC w/JBR Red Tubes | SpeedDaddy TP | AT HPFP | Damond Triple Mounted | Southbend S2 Endurance Clutch/Fly | Stoptech Slotted Rotors | EBC RedStuff Pads | Enkei PF01 18x8.5 +48 | Continental EC Sport 245/40R18 | KWv2 Coilovers | Whiteline LCA Bushings, Anti-Lift, & Bump Steer | Whiteline Endlinks | JBR .125 FSB & RSB w/billet bushings/mounts | CS Lower Tie Bar | DM OCC w/VTA | JBR Shifter Bushings Stereo Mods: Pioneer AVH4100NEX | Phoenix Gold 6.5" Comps Front | Focal 6.5 Coax Rears | Polk 12" in Trunk Floor Enclosure | PPI 4x125W amp driving Fronts & Sub Other Mods: FIAMM 72112 Low Note Horn alongside stock Mods Awaitting Install: Redline Leather Center Armrest & Handbrake Boot Future Mods: Injector Seals | Built Block & BNR S3v2 if ZZB Removed Mods: JBR 70A RMM | Koni STR.T Orange Shocks | |
| The Following User Says Thank You to Carskick For This Useful Post: | Thor Hammer (10-24-2017) |
Yes ~50% e (first post edited to reflect that), and Yes I have done a lot of research, the spark plug preference is what’s least defined and why I asked. Yep, black death prevention was one of the first things I researched.
__________________ 08 MS3 - RMM, AP, Autotech internals, CS TIP/SRI, CS Boost tubes/recirc tube, CS TMIC, CS BPV, DP, DMS OCC Last edited by meekerMS3; 10-24-2017 at 02:03 PM. | |
| The Following User Says Thank You to meekerMS3 For This Useful Post: | Thor Hammer (10-24-2017) |
My apologies, should have been more specific will be aiming for an ethanol/93oct mix that puts me around e48/49 or so. Those running a lower mix (~30%) were usually fine with one step colder. The grey area seems to be the 50% mix; from what I’ve read here it seems people have better luck though in the stock heat range. I was just hoping to get personal confirmation of that. Yep below 50 helps, as well as RP dexos and the SI-1 fix Agreed, from the posts I could find about plugs, it seems people running 100% e have to stay at stock heat range or possibly warmer. Those running
__________________ 08 MS3 - RMM, AP, Autotech internals, CS TIP/SRI, CS Boost tubes/recirc tube, CS TMIC, CS BPV, DP, DMS OCC | |
Groans: 211
| Neutral : -1 score Oh ok, cool. You know what you're getting into with the higher E blend. I would talk to your tuner about their recommendations on heat range.
(Thread Starter) | Not Ranked : 0 score He should be getting off the dyno soon so I will shoot him a message, I just feel like these cars have a mind of their own. I come from the Wrx/STI world, and running step colder plugs was just common practice on pump gas and ethanol tunes (without issue either). The newer wrx’s were also DI.
From what I understand, running an Ethanol blend cools the combustion chamber more so than a purer gas mix. Wouldn't this negate the need for cooler plugs, at least to a point?
Colder plugs help combat preignition, ethanol combustion temps are lower compared to just pump gas (so I think what you said makes sense, hopefully one of the ethanol kings here will lend their knowledge). It seems the temp drops created by the ethanol, and cold weather (which is now upon us) have given a lot of guys running a 50% ethanol blend issues with cold starts and surging, or just overall weird/poor running symptoms. So hopefully someone who has first hand experience will help us out!
(Thread Starter) | Not Ranked : 0 score Well, my tuner said either works but he would lean towards one step colder...so do I use the set of one step colder NGKs or my stock heat range Denso’s? Guess I will just flip a coin...
![]() Join Date: Jun 2016 Location: Washington
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 56
| Not Ranked : 0 score One step colder will be fine, I have been running mine (NGK 6510) from stage 2 pump tune, all the way to stage 3 E30 tune. I just changed mine out around 15k and they weren't fouled, if you like to drive the car hard, just go colder as it will add a margin of safety. Added ethanol like in your case might make the colder plugs not 100% necessary, worst case scenario they foul and you buy new plugs, not exactly hard to change plugs on our cars.
__________________ 2012 Velocity Red Mica MS3 Tech For Powah: JBR Tru 3.5" WP, CP-E TMIC, UR V3 Catless DP/Reso. TP, CS Resonated CBE, CS HPFP Internals, Cobb AP, DM PMM, DM TMM, CS Stg 2 RMM, CS Shifter Bushings, CS Dual VTA BPV, South Bend Stage 3 Endurance clutch, Damond Motorsports SSP, CS 3.5bar MAP, Stratified S-OTS+ Stg 3 E85 tune for summer, Pump S-OTS+ Stage 3 for winter, for now Handling: JBR .250 RSB w/ billet brackets. So I can see/be seen better: DDM LED for Nagare Accent lights, DDM Switchbacks Front turn signals, Osram CBI's, ADVmonster LED Fogs To-do List: BNR S4, maybe S5...bottom end build, probably should do brakes/suspension at some point. Shooting for a 450-500whp daily driver. |
Groans: 211
| Not Ranked : 0 score This thread inspired me to do my own research to learn more on your question. This is an interesting read about ethanol: https://www.6speedonline.com/forums/...-analysis.html The end result is cylinder temps are 4.4% higher on ethanol. And since a colder plug removes more heat from the cylinder this makes sense to run a colder plug on ethanol blend tunes with bolt ons. From NGK's website: When compression is raised, along with the added power comes added heat. Since spark plugs must remove heat and a modified engine makes more heat, the spark plug must remove more heat. A colder heat range spark plug must be selected and plug gaps should be adjusted smaller to ensure proper ignitability in this denser air-fuel mixture. Typically, for every 75-100 hp you add, you should go one step colder on the spark plug's heat range. A hotter heat range is not usually recommended except when severe oil or fuel fouling is occurring.
![]() Join Date: Feb 2012 Location: Li ny
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,290
Groans: 74
| Neutral : +1 score I have always ran stock heat range. Right now i have ngk iridium stock heat range with my mods on a 1:2 mix e:pump. I guess thats e 27? My plugs look great. Before that i was the same mix + meth on the stock turbo and they were fouling slightly. I wouldnt change your gap if it is fine now unless you start getting spark blowout.
__________________ MECP 2012 BM PTE 5858 Vband .82ar // Tial EWG // CPE Mani // 3" Turboback // JBR Under route hot pipe // MD ST mani+spacer with PI // Siemens 60lb Injectors // Splitsecond inj controller // JBR 88 duro RMM/TMM // MD PMM // TWM Full replacement shifter // JBR CC // Autotech FP Internals // SP63 SB/Manley rods SP63 pro pistons // Treadstone FMIC TR824 // FoMoCo Tranny Jizz // South Bend Clutch Stage 3 enduro// GFB Respons // FJ 4" intake // WMI 100% VPM1 // Air Lift 1000 in rear // N2MB WOT BOX Rfinkle tune in progress The Brooklyn beater: 2005 1.8 Auto Sentra |
| The Following User Says Thank You to 5doorsoffury For This Useful Post: | Thor Hammer (10-26-2017) |
| Can someone help me with Spark Plug gap? | Hapa88 | Mazdaspeed3/6 General Discussion | 67 | 10-08-2019 10:22 PM |
| Cylinder One Spark Plug Fouling - Oil on Plug Thread - Slow Start | conrad51 | 2010 MS3 - Troubleshoot/Diagnostics | 8 | 11-15-2016 05:37 AM |
| spark plug how to? | IndianOutlaw | MazdaSpeed 3 - How-To's | 22 | 03-02-2011 06:10 PM |
| best spark plug? | soulefx | 2010 MS3 - Engine, Transmission & Driveline | 12 | 12-22-2009 10:35 PM |
| My personal experience with the K04 | Darksun280 | MazdaSpeed 3/6 - Turbo Induction | 8 | 06-25-2008 12:36 PM |
