| MazdaSpeed 3/6 - E85 Fueling Learn more about feeding your car corn |
![]() | | #81 | ![]() |
| Not Ranked : 0 score we are, and always be, the bastard step children of the performance world. It's just our fate. That said, I love a dark horse project and a 20-30% increase, that doesn't cost an arm and a leg, would be a very nice option. Just not sure its attainable. my thoughts on what's required (criteria): 1) injectors that are electrically similar to ours. 2) injectors that are the same dims or smaller than ours. (fab a seal, head, and o-ring. rail, that makes up the difference because you are buying seals anyway and o-rings are plentiful) * machining the head is out of the question IMO. go PI. 3) along the dim subject, injectors that are not too much taller, if at all, than ours (rail height) 4) injectors that can be controlled via the OEM ECU. 5) injectors that can be controlled via tables already exposed by Cobb. (cuz let's face it, Cobb is done with Mazda...yes this may come as a surprise and break the hearts of some, but it's a fact and a matter of economics for Cobb, and I don't blame them one bit, blame Mazda) the rest would be relative gravy (hardline to rail, harness, etc.) That's all I can think of at the moment, because....
__________________ ![]() 07 Red MS3 GT - E40 - Carrillo Rods - Wiseco Pistons - BSD - JBR 3.5 WidePath - ATP GTX3071 - Forge BPV - GA - Cobb v2 FMIC - CPE EM - CPE DP - CNT CBE - APv3 - Grim EBC - PERM dual port PCV plate - Dano dual OCC - CPE CDFP - Labonte S2 WMI - ACT Street Kit - SUv2 RMM - SU TM - "Stiffy" MM - DG CF wing ext, skirts & front lip - Hotchkis RSB/FSB w PowerGrid Links - Koni FSDs - DBA SX4000 Rotors - Hawk Pads - Silver OZ Ultraleggera - 235/40/18 NT-01 |
| The Following 8 Users Say Thank You to Dano For This Useful Post: | biscuit003 (11-07-2015), Easter Bunny (11-06-2015), Enki (11-06-2015), Mauro_Penguin (11-13-2015), MD1032 (11-06-2015), Micha (11-07-2015), neganox (11-06-2015), WetzMS3 (11-06-2015) |
![]() | | #82 | ![]() |
Groans: 189
(Thread Starter) | Not Ranked : 0 score If electrical is the same, control should be doable via scalar and pressure tables alone I would think. (lower pressure on pump gas, default scalars for corn).
__________________ |
![]() | | #83 | ![]() |
| Not Ranked : 0 score @Dano; I agree with everything save one. Versatune.
| The Following 3 Users Say Thank You to Easter Bunny For This Useful Post: |
![]() | | #84 | ![]() |
![]() Join Date: Dec 2013 Location: Plainfield, IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,712
| Not Ranked : 0 score has anyone looked into the HDEV-5 injectors? I'm still learning about injectors and spray patterns and operating pressures so bare with me here but from what I'm reading on these injectors it seems that they can flow for what we are looking for and can keep a proper spray pattern. Maybe theres a possibility we can retrofit their guts in our injectors? just a thought. P.S My buddy got back to me with what his connection at ford said. "He said the only way is to buy one to see. No one will lend any out. Its a new car so they wont be laying around and if they are they have to be sent back for warranty." I attached a photo of a couple injectors retrofitted with a HDEV-5 guts
__________________ 2010 black mica speed3 The go: Depo racing: downpipe (100 cell count), custom: FMIC. HTP: 3.5" intake, under route piping. JBR: shortshifter, RSB. Autotech: HPFP internals. Go fast bits: hybrid BPV, VMR: 18x8.5 V710s, Bridgestone: potenza re760 245/40/18, KW: v3 coilovers,SPC: camber arms, freektuned, Damond Motorsports: dual OCC, PMM, PCV plate, RMM, TMM, EGR delete, FoSt mani, Corksport: battery box(fuck this thing), injector seals, Cobb: EBCS, AP v3. AEM: methanol. Seibon: carbon fiber hood. UR: catback. Bosch: 3bar. BNR: s4, DNP: EWG manifold, Tial: 38mm mvs EWG. The show: 5% tint all around, 50% tint windshield, rally armor mudflaps, Sony XAV64BT touchscreen headunit, katskin leather interior, CPE relocation plate, Maisonvi weighted shift knob, Corksport hoodscoop, black housing headlights. Soon:built motor |
| The Following 3 Users Say Thank You to Djohns For This Useful Post: |
![]() | | #85 | ![]() |
![]() Join Date: Oct 2013 Location: Raleigh, Charlotte NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 812
Otto Cycle Simulation Parameters: Bore = 87.5mm Stroke = 94.0 mm CR = 9.5 Speed = 5500 RPM Start of Combustion = 350 CA (-10 bTDC) Equivalence Ratio = 0.78912 Temp1 = 125 *F Pressure1 = 2.4 bars Density Air = 2.7 kg/m3 Fuel = Gasoline Engine Wall Temp = 500 K Burning Time = Variable (because I don't know) Take it for what it's worth, results from a program written in fortran. Doesn't take into account energy transfer from fuel vaporization and thus in-cylinder pressure drop, but gives you ballpark.
__________________ 2013 Liquid Silver Metallic MS3 GTX2867 ; Cobb AP v3 ; Cobb Turboback Exhaust ; Cobb EBCS ; Swift Springs ; Koni Yellows ; SPC Camber Arms ; Aquamist HFS-4 WMI ; Relentless Customs PNP IM ; ETS TMIC ; HTP Full 3.5" Intake ; HTP Battery Tray ; CS BPV ; CS Mid-Chassis Brace ; CS TMM Insert ; AT Internals ; JBR 88 Duro RMM ; DM PMM ; JBR OCC ; JBR IM & TB TIGs ; JBR EGR Blockoff Plate ; JBR 0.125 RSB & Tru-Torsion RSB Billet Brackets ; NGK Step Colder Plugs ; Bosch 3 Bar Map ; Block8head Dual Gauge Vent Pod ; Dual Aeroforce Interceptors ; Stoptech SS Brake Lines & Centric Blanks ; EBC Yellowstuff ; MOOG Endlinks TunedbyNishan | |
| The Following 7 Users Say Thank You to mize13 For This Useful Post: | Easter Bunny (11-07-2015), Enki (11-07-2015), Mauro_Penguin (11-13-2015), Mazdazilla6 (11-07-2015), Micha (11-07-2015), Tokay444 (11-09-2015), zenit (11-07-2015) |
![]() | | #86 | ![]() |
| Not Ranked : 0 score Assuming we can get LNF/Opel injectors to fit with some ease, they are totally proper electrically, offer 25% more flow than we have now and a whole set with a fuel rail costs $350 brand new. As it's been stated we are well aware there are meth systems and 5/6th and PI. But frankly I don't want to run a second fuel tank, a standalone controller or both. It's not appealing, plain and simple. My car is driven daily (when it works) and the less I have to think about the better. I want my fuel from one tank and my electronics controlled by one computer. Part of why I'm helping do this, even if it fails, is because I'd rather attempt and fail than sit behind my computer and say, "oh this platform is dead there's nothing new to do" FUCK THAT. Look at every other community out there, they are always making improvements and taking more steps. We already know our platform can make good power, we're approaching 900whp, but that's the .01%. This is something that could help tons of builds, and allow greater power at a much more simple package. Frankly, I'd rather do something that helps 100 people get to 400hp than 1 person to 1000hp.
| The Following 18 Users Say Thank You to Mazdazilla6 For This Useful Post: | broda (11-07-2015), ButtholeRedMS3 (11-18-2015), cocoanton (11-07-2015), Djohns (11-07-2015), Easter Bunny (11-07-2015), Enki (11-07-2015), Hammology (11-07-2015), ItsNox (11-08-2015), JgamB (11-13-2015), lolwrx (11-08-2015), Mauro_Penguin (11-13-2015), Micha (11-07-2015), nojjy (11-07-2015), Ozynigma (11-13-2015), speed3 britz (11-13-2015), SpeedRebirth (11-07-2015), Thepedigree13 (11-07-2015), WetzMS3 (11-09-2015) |
![]() | | #87 | ![]() |
Groans: 189
__________________ | |
| The Following User Says Thank You to Enki For This Useful Post: | Micha (11-07-2015) |
![]() | | #88 | ![]() |
Obviously with more E, it's gonna drop more.
![]() | | #89 | ![]() |
![]() Join Date: Nov 2010 Location: South Haven, MI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,824
Groans: 75
| Not Ranked : 0 score While I have seen these threads come and go, and I think it's most likely something that is out of reach for us I'm willing to help where I can. I have a spare head, an injector or 2 and a machine shop. If things need to be made I can probably help there. Electrically and tuning wise, I'm usless. But other than than let me know if I can help. Sent from my SM-G900V using Tapatalk
__________________ Franken Turbo, built motor, meth. DIY parts: Shift Knob, Shift Plate, Shift Bushings, Battery Tray, EBCS, RSB, probably more. "Your signature should just say, I'm the shit." -LynzeC |
| The Following 8 Users Say Thank You to maisonvi For This Useful Post: | biscuit003 (11-07-2015), cocoanton (11-07-2015), ItsNox (11-08-2015), Mauro_Penguin (11-13-2015), Mazdazilla6 (11-07-2015), MD1032 (11-07-2015), Micha (11-07-2015), WetzMS3 (11-09-2015) |
![]() | | #90 | ![]() |
![]() Join Date: Apr 2013 Location: Evanston, IL
Rep Power: 1329 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 938
Groans: 57
| Not Ranked : 0 score Lord master supreme @Enki; Helpers @davychronic; contacting GDI companies @Mazdazilla6; independent projects @HawkeyeGeoff; inside track @ bosch @Djohns; independent projects @Vansquish; independent projects @mize13; injection simulation @maisonvi; machinework @ mockup Companies to contact: Deatschwerks Bosch inquiry@service-solutions.com Bosch sent @Enki; to redirected to a local company @HawkeyeGeoff; offered to reachout to bosch contacts APR Injectors made by bosch? Additional Companies? @davychronic; Independent projects @Mazdazilla6; buying LNF injectors and swapping guts Buying LNF injector next week 11/9-11/13 @Djohns; Ecoboost injector compatibility with friend @ ford; Looking into HDEV-5 injectors? Resistance from Ford on injectors - anyone else? @CorkSport; Corksport injectors? Manufacts suck eggs. Stalled out. @Vansquish; finding company that’s adapting skyactive injectors for l3vdt @mize13; injection simulation @maisonvi; head machine work and mockup We've got some good tech talk in here, but we could use a little project management to keep this on track. @Enki; feel free to steal this and put it in top post if you want. |
| The Following 14 Users Say Thank You to zenit For This Useful Post: | cocoanton (11-08-2015), Code Monkey (11-07-2015), dan7225 (11-09-2015), Djohns (11-07-2015), Hammology (11-07-2015), ItsNox (11-08-2015), magicka (11-09-2015), maisonvi (11-07-2015), Mauro_Penguin (11-13-2015), Mazdazilla6 (11-07-2015), MD1032 (11-07-2015), Micha (11-07-2015), Thepedigree13 (11-07-2015), WetzMS3 (11-09-2015) |
![]() | | #91 | ![]() |
| Not Ranked : 0 score People need to be completely honest about what they are willing to pay for a solution so those driving towards a solution will have a basic understanding cost metrics/parameters. What are YOU willing to pay right now to have a high flow injector bolt on solution? EDIT: I would probably be willing to pay around $1k for a solution.
__________________ 2006 MS6 WWP Sport - 340whp/350wtq JBR 3"- BNRS3V2 - GS EBCS - CUSTOM FMIC - CS IM - LTR7IX - CMGS WMI & D07 GA - TURBOXS HEADER - FIDANZA FW - CP-E CATTED DP - 3" CATBACK BILSTEIN - H&R SPRINGS - 18x8.5 +48 ROTA SVN - 265/35R18 HTR ZIII MINI H1 6.0 - CAR LED TAILS SEE MORE USING !SHOUTTAG.COM - ENTER: !6SPEED6 |
| The Following User Says Thank You to dale_gribble For This Useful Post: | breakfstincluded (11-08-2015) |
![]() | | #92 | ![]() |
Groans: 189
(Thread Starter) | Not Ranked : 0 score Fixed.
| The Following 7 Users Say Thank You to Enki For This Useful Post: | ItsNox (11-08-2015), magicka (11-09-2015), maisonvi (11-07-2015), Mauro_Penguin (11-13-2015), Mazdazilla6 (11-07-2015), Micha (11-07-2015), Vansquish (11-07-2015) |
![]() | | #93 | ![]() |
| Feline Führer ![]() Join Date: Feb 2013 Location: Jacksonville, FL
Rep Power: 2280 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,422
| Not Ranked : 0 score I can only offer jokes, jokes with cats, pictures with cats, and cash in order to purchase donor injectors in which to experiment with / dissect. I said injectors not hookers. Maybe hookers... but injectors first.
__________________ Official CatDickRacing Sales Rep - All products backordered. |
| The Following 5 Users Say Thank You to neganox For This Useful Post: | ItsNox (11-08-2015), Mauro_Penguin (11-13-2015), Micha (11-07-2015), monkey.bones.007 (11-07-2015), WetzMS3 (11-09-2015) |
![]() | | #94 | ![]() |
![]() Join Date: Oct 2015 Location: Windsor, ON
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 44
| Not Ranked : 0 score Delphi Multec(r) GDi Multi-Hole Fuel Injectors Would the delphi's be a better internals swap then the HDEV5's? The delphi's are good for up to 260 or 300 bar max. If I did the conversion right the HDEV5's are good to 200 bar. Just using my googlefu and talking out my ass, figured I throw a suggestion in the ring. |
![]() | | #95 | ![]() |
Groans: 189
(Thread Starter) | Not Ranked : 0 score Considering our equipment currently peaks at 138 BAR, I'd say the benefit of rocking significantly higher pressures probably isn't worth whatever the cost would be (especially since we can't really get aftermarket rail pressure sensors working properly).
![]() | | #96 | ![]() |
__________________ 2010 black mica speed3 The go: Depo racing: downpipe (100 cell count), custom: FMIC. HTP: 3.5" intake, under route piping. JBR: shortshifter, RSB. Autotech: HPFP internals. Go fast bits: hybrid BPV, VMR: 18x8.5 V710s, Bridgestone: potenza re760 245/40/18, KW: v3 coilovers,SPC: camber arms, freektuned, Damond Motorsports: dual OCC, PMM, PCV plate, RMM, TMM, EGR delete, FoSt mani, Corksport: battery box(fuck this thing), injector seals, Cobb: EBCS, AP v3. AEM: methanol. Seibon: carbon fiber hood. UR: catback. Bosch: 3bar. BNR: s4, DNP: EWG manifold, Tial: 38mm mvs EWG. The show: 5% tint all around, 50% tint windshield, rally armor mudflaps, Sony XAV64BT touchscreen headunit, katskin leather interior, CPE relocation plate, Maisonvi weighted shift knob, Corksport hoodscoop, black housing headlights. Soon:built motor | |
![]() | | #97 | ![]() |
| Not Ranked : 0 score That'd be awesome. One small problem, I'm doing all my testing up at school 4 hours away in MI. If I bring anything home though and need a hand I'll hit you up.
| The Following 5 Users Say Thank You to Mazdazilla6 For This Useful Post: | Djohns (11-07-2015), Enki (11-07-2015), HawkeyeGeoff (11-08-2015), Mauro_Penguin (11-13-2015), WetzMS3 (11-09-2015) |
![]() | | #98 | ![]() |
| Not Ranked : 0 score Ah damn. Well let me know when you come back and we can meet up. I've got tools I can bring. Plus if swapping actually works and they fit, since your speed is down for the count currently, I can be the test mule.
| The Following 2 Users Say Thank You to Djohns For This Useful Post: | Jh8909 (11-08-2015), Mazdazilla6 (11-07-2015) |
![]() | | #99 | ![]() |
![]() Join Date: Sep 2011 Location: Rockville, MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,554
Groans: 130
Groaned at 8 Times in 7 Posts
| Not Ranked : 0 score I would be willing to pay $1k for injectors considering 6th port is around that price anyway. And I don't need full port injection for my goals so no need in spending over $2k for that. I'm all for the furthering and development of our platform, as "dead" as it is. I would rather at least try and get something going rather then just sitting back and not doing anything about it.
__________________ 06 Black Cherry Mica MS6 GT: Speed Perf6rmanc3 built motor, GT3076r EWG, ACT 6 puck Clutch kit, HTP 3.5" full intake, M2 downpipe, XS Power Exhaust Manifold, CP-E austenite 3" exhaust, Whiteline 24mm rear sway bar, Injector RX Cleaned injectors, JBR trilogy motor mounts, JBR EGR Block off plate, Ported and ceramic coated intake manifold, 3 bar MAP, 3 port EBCS, Cobb AP, CX racing piping with Treadstone TR8, CP-E SAFEseals, MD OCC, Step Colder spark plugs, Turbo XS RFL BOV, AT fp internals, CP-E rear diff mount, Turbine Tech Front rear diff mount, DSS 500hp rear drivers side axle, Wilwood 4 Pot Calipers, Team Dynamics 18"x8" Pro Race 1.2s +38, SPC front ball joints, H&R springs, Morimoto clear projector retrofits. |
| The Following 5 Users Say Thank You to Jh8909 For This Useful Post: | Easter Bunny (11-08-2015), magicka (11-09-2015), Mauro_Penguin (11-13-2015), Mazdazilla6 (11-08-2015), Micha (11-08-2015) |
![]() | | #100 | ![]() |
| Enter the 36 Chambers ![]() Join Date: May 2009 Location: Beverly Hills, FL
Rep Power: 1632 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,746
| Not Ranked : 0 score I'm in the same boat. I would rather spend $1k for an upgraded injector set up vs a more difficult (more shit to go wrong) 5th/6th port injection set up. This platform might be so called dead, but I've seen otherwise. With new members popping up, and old ones pushing it to new heights of higher HP and faster track times. I still see where there would be a market for a more simpler fueling solution.
GTX3071r : Tial MV-S 38mm ewg : COBB AP : Stratified ebc : CP-E HPFP : CP-E Safe seals : COBB fmic v2 : HKS bov : HTP 4" intake w/battery tray : DNP turbo mani : ATP catless dp : Mazdaspeed cbe : JBR trilogy : TWM sts : MattDamond occ v2 : NGK6510's : Eibach Prokit : Koni Yellow's : Corksport front endlinks : Corksport RSB : JBR EGR Delete : Kozmic Motorsports Primary EGR Delete : TB coolant bypass : Relentless Customs PnP intake mani : Bosch 3 Bar Map Sensor : Bitwise Motorsports Bosch MAP Sensor Connector : South Bend stg3 endurance clutch : 17x8 Enkei TSP5 : Hankook v12 245/45 SP63 Longblock Head= Mild bowl work as well as mild porting on intake/exhaust. Bottom end= SP63 Weisco 9.5:1 - 87.5mm : Head Studs 10mm L19 : Manley H-Beam : Rod Bolts ARP Custom Age 625 : Coated Clevite Main & Rod Bearings | |
| The Following 3 Users Say Thank You to NoRegrets For This Useful Post: |
![]() | | #101 | ![]() |
Groans: 57
| The Following User Says Thank You to zenit For This Useful Post: | Jh8909 (11-08-2015) |
![]() | | #102 | ![]() |
Groans: 189
(Thread Starter) | Not Ranked : 0 score The more diversity we have as far as trying to get something to work, the more likely we (as a community) will be to succeed. Pick something no-one else is doing, and chip in (keeping thread up to date with your progress of course). If it helps, I can keep OP up to date with who is doing what and what their progress is.
| The Following 7 Users Say Thank You to Enki For This Useful Post: | breakfstincluded (11-08-2015), Djohns (11-08-2015), HawkeyeGeoff (11-08-2015), ItsNox (11-08-2015), Jh8909 (11-08-2015), Mauro_Penguin (11-13-2015), WetzMS3 (11-09-2015) |
![]() | | #103 | ![]() |
![]() Join Date: Mar 2012 Location: Waterford, MI - America's High Five
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,451
__________________ Silver 2007 Speed3 GT Xona Rotor 6156, Port Injection w/ E85...Bunch of other stuff. I make some power. Titanium Grey Mazdaspeed6 GTX3071, DD | |
| The Following 3 Users Say Thank You to HawkeyeGeoff For This Useful Post: |
![]() | | #104 | ![]() |
Groans: 189
(Thread Starter) | Not Ranked : 0 score Op fully updated. Please mention me directly when you have an update for your section for me to add. Upgraded injectors (because aux fuel is for losers)
| The Following User Says Thank You to Enki For This Useful Post: | Mauro_Penguin (11-13-2015) |
![]() | | #105 | ![]() |
Groans: 130
__________________ 06 Black Cherry Mica MS6 GT: Speed Perf6rmanc3 built motor, GT3076r EWG, ACT 6 puck Clutch kit, HTP 3.5" full intake, M2 downpipe, XS Power Exhaust Manifold, CP-E austenite 3" exhaust, Whiteline 24mm rear sway bar, Injector RX Cleaned injectors, JBR trilogy motor mounts, JBR EGR Block off plate, Ported and ceramic coated intake manifold, 3 bar MAP, 3 port EBCS, Cobb AP, CX racing piping with Treadstone TR8, CP-E SAFEseals, MD OCC, Step Colder spark plugs, Turbo XS RFL BOV, AT fp internals, CP-E rear diff mount, Turbine Tech Front rear diff mount, DSS 500hp rear drivers side axle, Wilwood 4 Pot Calipers, Team Dynamics 18"x8" Pro Race 1.2s +38, SPC front ball joints, H&R springs, Morimoto clear projector retrofits. | |
| The Following 5 Users Say Thank You to Jh8909 For This Useful Post: | Easter Bunny (11-09-2015), Enki (11-08-2015), Mauro_Penguin (11-13-2015), NoRegrets (11-09-2015), sho (11-09-2015) |
![]() | | #106 | ![]() |
Groans: 57
Let's keep this rolling guys. | |
| The Following 8 Users Say Thank You to zenit For This Useful Post: | Easter Bunny (11-09-2015), Enki (11-08-2015), Jh8909 (11-08-2015), Mauro_Penguin (11-13-2015), neganox (11-09-2015), NoRegrets (11-09-2015), Tokay444 (11-09-2015), WetzMS3 (11-09-2015) |
![]() | | #107 | ![]() |
Groans: 189
(Thread Starter) | Not Ranked : 0 score Updated.
| The Following 3 Users Say Thank You to Enki For This Useful Post: |
![]() | | #108 | ![]() |
![]() Join Date: Nov 2011 Location: Clarksville, Tn
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,001
| Not Ranked : 0 score I have a spare injector harness, if someone would need it for this.
__________________ 2013 CWP That's slow ![]() 2012 LSM Totaled by an asshole red light runner Previous: Freekbuilt & Freektuned 5858 (only made it to 93 tune )Previous: MILTUNED E85 K04 |
| The Following 5 Users Say Thank You to cshunter For This Useful Post: | Djohns (11-09-2015), Easter Bunny (11-09-2015), Enki (11-08-2015), Mauro_Penguin (11-13-2015), NoRegrets (11-09-2015) |
![]() | | #109 | ![]() |
![]() Join Date: Feb 2015 Location: Palmer, Iowa
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 152
| Not Ranked : 0 score Sorry guys been busy af bout to be a dad any day now. I contacted both companies by phone and both told be no go on increasing flow on our stock injectors. One company, AUS Injection, told me that it could not be done and maintain the same spray pattern. So im curious how and where this one guy had it done. @Enki; Ill keep inquiring about it as i find companies that work on gdi injectors. Interesting video I found on modified gdi injectors... https://www.youtube.com/watch?v=JZmV10pFsCM
__________________ 06 MS6 GT Titanium Gray II Metallic Last edited by davychronic; 11-09-2015 at 06:17 PM. |
| The Following 3 Users Say Thank You to davychronic For This Useful Post: |
![]() | | #110 | ![]() |
![]() Join Date: Feb 2011 Location: Goldsboro, NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 34,434
I have a few injectors laying around that I bought to have cleaned and flow matched. I'd be more than happy to donate one or two plus some cash to the cause when the time comes.
__________________ 2009 CWP MS3 GT Rally Armor Flaps | Gen Pu Wheels | JBR 80d v1 RMM/RSB/TIGs/Boost & Bypass Tubes TWM Full Replacement Shifter | CS SRI/TIP/Skid Plate | Koni FSD 4045 | Matt Damon OCC | Cobb DP/AP | CP-e TMIC/HPFP PTP VVT Actuator/Injector Seals & Studs | Samco Rad Hoses | Redline Leather Shift & E-Brake Boot BNR S3 | Stratified Boost Dial | ||
| The Following 5 Users Say Thank You to magicka For This Useful Post: | Easter Bunny (11-10-2015), Enki (11-09-2015), Jh8909 (11-09-2015), Mauro_Penguin (11-13-2015), NoRegrets (11-10-2015) |
![]() | | #111 | ![]() |
| Not Ranked : 0 score This looks promising... email sent Gdi Injectors | Magneti Marelli
__________________ 06 MS6 GT Titanium Gray II Metallic |
| The Following 8 Users Say Thank You to davychronic For This Useful Post: | Djohns (11-10-2015), Enki (11-10-2015), Mauro_Penguin (11-13-2015), Mazdazilla6 (11-11-2015), Micha (11-12-2015), NoRegrets (11-10-2015), Turbo_Steve (11-18-2015), zenit (11-10-2015) |
![]() | | #112 | ![]() |
![]() Join Date: Aug 2012 Location: Auburn, MI
| Not Ranked : 0 score @Mazdazilla6; isn't the graph of VW injector voltage similar to how you said ours work (in below article). If so we may be able to adapt a GTI/Golf R injector. They have some 500 hp capable ones out now. http://opensiuc.lib.siu.edu/cgi/view...text=auto_pres Maybe the University guy that wrote this knows which is most electrically similar. He calls our mazdaspeed in that link so he obviously looked at them in his study. Might be worth an email to him. I can check if you want.
__________________ '12 Velocity Red Mica MS3 Cobb AP V3 // Autotech Fuel Pump Internals // HTP 3" // UR Catted V2 DP // UR Resonated TP // UR Resonated CBE // GrimmSpeed EBCS // CP-E TMIC // GFB Respons BPV // JBR Trilogy 88/80/80 // Corksport Hood Struts // Prosport EVO Boost Gauge w/ block8head vent pod // E30 Freektune Installing Soon : Stratified GA // Bosch 3 Bar Map w/ PNP Harness [SIGPIC][/SIGPIC] |
| The Following 7 Users Say Thank You to Oni For This Useful Post: | Djohns (11-11-2015), Easter Bunny (11-12-2015), Enki (11-12-2015), maisonvi (11-12-2015), Mauro_Penguin (11-13-2015), Micha (11-12-2015), NoRegrets (11-11-2015) |
![]() | | #113 | ![]() |
Groans: 57
| Not Ranked : 0 score @phate; FYI link above @ SIU |
| The Following 3 Users Say Thank You to zenit For This Useful Post: |
![]() | | #114 | ![]() |
The issue is still with the resistances. Even if VW uses a peak and hold style system, their injectors still have x10+ the resistance. There's no way around that unless we make some sort of amplifier to the injectors. That's not something I have any interest in doing but someone else is more than welcome to try. I just got paid so I should be picking up an LNF injector soon.
__________________ Built 5862: Shootin For The Stars 2006 Mazdaspeed6 GT Crystal White Pearl #07141 Damond Motorsports = PS Cooler - RMM - PMM - OCC VersaTuner = Versatune Clutchmasters = 850 Street Twindisk Corksport = RDM - CBE - RSB - TMM Insert Turbine Tech = Forward Diff Mount - FMM CP-e = Exhaust Manifold - Injector Seals PTE = JB 5862 JMF = Intake Manifold w/Custom PI Kozmic = Downpipe - 6th Port - EGR Delete Forge = V2 BPV Tial = 44mm WG Autotech = HPFP Internals HTP = 4" Intake - Battery Tray Bilstein = B6 Shocks w/Eibach springs Grimmspeed = EBCS Technafit = SS Brake Lines - SS Clutch Line Enkei = EVOX GSR 18x8.5 +38 - NT03+M 17x9.5 +38 Custom = FMIC w/TR1035 - Shifter Cables - Shifter Bushings | |
| The Following 7 Users Say Thank You to Mazdazilla6 For This Useful Post: | Easter Bunny (11-12-2015), Enki (11-12-2015), Mauro_Penguin (11-13-2015), Micha (11-12-2015), NoRegrets (11-12-2015), WetzMS3 (11-12-2015), zenit (11-12-2015) |
![]() | | #115 | ![]() |
| Not Ranked : 0 score Ordered. Shipping says the 19th for delivery.
| The Following 9 Users Say Thank You to Mazdazilla6 For This Useful Post: | Easter Bunny (11-12-2015), Enki (11-12-2015), HawkeyeGeoff (11-13-2015), ItsNox (11-13-2015), maisonvi (11-12-2015), Mauro_Penguin (11-13-2015), Micha (11-12-2015), NoRegrets (11-12-2015), zenit (11-12-2015) |
![]() | | #116 | ![]() |
![]() Join Date: Dec 2013 Location: Tampa, Florida
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 462
| Not Ranked : 0 score Do we know exactly where our injectors spray? Can not be the cylinder walls must be directly toward the piston top? I need to read up on the different spray patterns I guess because this part is what is confusing me. The electrical portion can always be worked around so long as flow and pattern are correct. Off to the webz before posting anything else Edit: is this relevant to those just catching up? http://www.consulab.com/files/gdiHandoutrev20147e.pdf
__________________ The line up: 2013 G37 loaded...not stock for long 2013 MS3...stock to midturbo back to stock (traded) 2009 Nissan Frontier LE loaded...big stereo system (traded) 2009 Cadillac CTS sport package...stock (blown and traded piece of shit) 1994 Integra RS built all motor (sold) 1990 Civic EF nitrous turbo motor swapped beast (sold) 1987 Dodge pick up...jacked up (sold) Last edited by speedfreak44; 11-12-2015 at 05:09 PM. |
![]() | | #117 | ![]() |
| Not Ranked : 0 score The electrical portion cannot be *easily* worked around if it isn't similar to our injectors from the get go. Spray pattern shouldn't matter a whole lot. If the fuel injector atomizes fuel just fine on the engine it came in it will do the same for us. Multiport units or ones with a pattern are mostly there for atomization reasons related to emissions etc. Spray angle between our injectors and should be fairly similar to other options that use an injector in the side of the head (most DI cars on the market). Some info I've found that I saved a while ago about our injectors says our spray angle is between 30* and 75* degrees. I imagine other injectors work in a similar window, the only thing that would change that would be if the angle of other platforms' injectors were more acute (parallel to head gasket) or obtuse (perpendicular to head gasket). I don't think they will vary greatly much at all.
__________________ Built 5862: Shootin For The Stars 2006 Mazdaspeed6 GT Crystal White Pearl #07141 Damond Motorsports = PS Cooler - RMM - PMM - OCC VersaTuner = Versatune Clutchmasters = 850 Street Twindisk Corksport = RDM - CBE - RSB - TMM Insert Turbine Tech = Forward Diff Mount - FMM CP-e = Exhaust Manifold - Injector Seals PTE = JB 5862 JMF = Intake Manifold w/Custom PI Kozmic = Downpipe - 6th Port - EGR Delete Forge = V2 BPV Tial = 44mm WG Autotech = HPFP Internals HTP = 4" Intake - Battery Tray Bilstein = B6 Shocks w/Eibach springs Grimmspeed = EBCS Technafit = SS Brake Lines - SS Clutch Line Enkei = EVOX GSR 18x8.5 +38 - NT03+M 17x9.5 +38 Custom = FMIC w/TR1035 - Shifter Cables - Shifter Bushings Last edited by Mazdazilla6; 11-12-2015 at 08:10 PM. |
| The Following User Says Thank You to Mazdazilla6 For This Useful Post: | Easter Bunny (11-12-2015) |
![]() | | #118 | ![]() |
| Not Ranked : 0 score Inwas confused in regards to the spray patterns but I also was assuming them to be similar to PI injectors in that they spray forward and not at a particular angle until I read how some are directed toward the cylinder walls in different fashions. The electrical portion I was referring to is building some type of plug in box or whatever to go between the injectors and the harness that will adjust resistance. Again however I am just now reading into this stuff I was waiting a little to see where you guys were heading with it
__________________ The line up: 2013 G37 loaded...not stock for long 2013 MS3...stock to midturbo back to stock (traded) 2009 Nissan Frontier LE loaded...big stereo system (traded) 2009 Cadillac CTS sport package...stock (blown and traded piece of shit) 1994 Integra RS built all motor (sold) 1990 Civic EF nitrous turbo motor swapped beast (sold) 1987 Dodge pick up...jacked up (sold) |
![]() | | #119 | ![]() |
| Not Ranked : 0 score As far as a pnp electrical solution we cannot use injectors that have a higher resistance than ours. There is no way to lower the resistance in an injector without opening it up and chopping out parts of it. I'm still hoping we will hear back from a GDI company in regards to making us a solution. Everything else that we are working on is an alternative.
![]() | | #120 | ![]() |
| Not Ranked : 0 score Has anyone here opened up a DI more specifically one from our motor? I am curious what they look like internally. Off to google again...
