| VersaTune VersaTuner tuning software by VersaTune. Available for Mazdaspeed3, Mazda 3 MPS, Mazdaspeed Axela, Mazdaspeed6, Mazda 6 MPS, Mazdaspeed Atenza. Includes ECU reflashing/remapping, online tune database, custom tune editing ability, virtual dashboard, data logging, diagnostics/DTC code management, Launch Control, No Lift Shift, and stutter-free Smooth Shifting. |
![]() Join Date: Apr 2013 Location: Wilkesboro, North Carolina
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,221
__________________ 2013 CWP and Stock |
Rep Power: 1237 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,288
Groans: 111
| Not Ranked : 0 score Fixed.
| The Following User Says Thank You to mituc For This Useful Post: | NCspecV81 (02-13-2016) |
![]() ![]() Join Date: Jun 2010 Location: Morton Grove, il
Rep Power: 1485 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 16,886
Groans: 78
| Not Ranked : 0 score @Steve@VersaTune; I'll gladly send my copy of VT around if that isn't a problem for you guys. They can't put it on their car, but even using the software was an eye opener for me.
__________________ "Well, Racecar=Broke. Other kinds of awesome may not, but racecar does. But racecar=best kind of awesome." -Wetz QFT |
| The Following User Says Thank You to xfeejayx For This Useful Post: | Enki (02-23-2016) |
![]() Join Date: Mar 2011 Location: Cambridge, Ontario, Canada
Rep Power: 221 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 138
| Not Ranked : 0 score Honestly just buy VersaTuner, you won't be disappointed. I've been running it for about 2 years I believe and it's been excellent and the support from the VT guys is amazing. VT is there for their customers.
__________________ 2011 MAZDASPEED3 Hypnotic Tuned - Rob CPE HPFP - CPE Catted Downpipe - CPE Catback Exhaust - 3" ETS TMIC - Cobb RMM - AEM Boost Gauge & Vent Pod - CANBus Triple - Corksport BPV - Corksport hood strut - Corksport RSB - Corksport Short Shifter - HTP 3.5" Intake - Damond TMM - Damond Vented CC - Vented Oil Cap - Tokay v2 Seals - GTX3067R - Damond PCV Plate - Built Engine (Manley Rods, 88mm Supertech 4032 Piston) - |
| The Following User Says Thank You to Polish_Eagle For This Useful Post: | xfeejayx (02-23-2016) |
| Approved MSF Vendor ![]() Join Date: Nov 2011
Rep Power: 778 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 0
| Not Ranked : 0 score Here is a video showing the flashing process. It's a slightly older version of VersaTuner, but the process is the same. Screen shots of the UI are here on our website https://www.versatuner.com/Screenshots.aspx We are working on a demo, but it's not our top priority right now. |
| The Following User Says Thank You to Steve@VersaTune For This Useful Post: | SpeedRebirth (02-27-2016) |
![]() Join Date: Jun 2011 Location: australia
Rep Power: 1125 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,310
Groaned at 8 Times in 4 Posts
Even getting to play with basic functions is interesting!
__________________ OLD: GT3071 IWG | Autotech HPFP | Cobb AP | tune | Catted DP |HDi FMIC | CPE 4" TIP + 3.25" MAF | Grimmspeed EBCS | RX8 S2 Rims | JBR 80a Trilogy | Forge V2 BPVNEW: HTP full 3" | catted DP | Autotech HPFP | COBB AP | |
Groans: 189
| Not Ranked : 0 score @Steve@VersaTune; maybe it would be possible to get a copy of the software locked to a bullshit, impossible vin for sharing/demo work? Or are you planning on removing the flashing functionality altogether for demo purposes?
__________________ |
Groans: 78
| Not Ranked : 0 score I have a copy of my wrecked car. I guarantee that's not running... Sent from my Nexus 5 using Tapatalk
| The Following User Says Thank You to xfeejayx For This Useful Post: | Micha (02-24-2016) |
| Not Ranked : 0 score |
Groans: 111
__________________ 2008 Cosmic Blue Mazda 3MPS Bilstein B12 + CS Camber plates + Eibach camber arms, SSR Type-F, Michelin PS4 225/40/R18, Cobb RMM, StopTech Street Pads + Stoptech Slotted disks, SouthBend Enduro Stage3 clutch, genpu TMM + CS Insert, TheSpeedLine 2X Rear Cross Floor and Rear Middle Lower Strut bars, Tanabe 4 Point Under Brace, Whiteline Bumpsteeer corection kit JBR Tru-3" + CS CAI Box, CP-e TMIC, Cobb XLE, NGK LTR7IX, UR v3 catted DP and res&catted TP, Cobb CatBack, GS EBCS, Autotech internals, GTX3071r gen2, CS 3.5BAR, Guardian Angel, CoolingMist WMI, VCTS Delete, stock ported IM, CorkSport cam shafts Mahle 88mm 4032 9.6:1 pistons, Manley rods, CA625+ head studs, King rod&main bearings, CS seals, DCR VVT, Koyorad radiator. StratiVersaTuned FTW to 28PSI, self-tuned to 32PSI 2008 Icy Blue Mazda CX7 6 Speed Manual SU TMIC, Autotech HPFP internals, Cobb XLE, Cobb EBCS, CorkSport 3.5BAR MAP GTX2867R gen2, stock spark plugs, stock cats and stock exhaust FTW, JBR Tru-3" Silicone intake TheSpeedLine Top and Lower Strut bars self-Versatuned to 22PSI | |
| Not Ranked : 0 score The only difference is the tables, logging pids, and available tunes in the database. |
| dashhawk software interfering with other software? | builthatch | Mazdaspeed3/6 General Discussion | 3 | 07-09-2012 06:26 AM |
| EdgeAutosport.com Demo Car | JP@edgeautosport.com | EdgeAutosport.com | 44 | 04-30-2012 12:40 PM |
| Standback Tuning Software, Drivers, and Logging Software | www.cp-e.com | Custom Performance Engineering (cp-e.com) | 24 | 04-24-2011 11:49 AM |
