> VersaTune
  • 1 Post By Fstrnyou
 Old 09-18-2016, 04:47 PM   #1
Fstrnyou's Avatar
Posts: 2,498   (View Stats)
Default First Log Stock MS6 - high KR?
I occasionally get a rather large stutter but hadn't felt it in quite a while. Installed VT yesterday evening and did some driving last night and today to get the fuel trims settled. Came across a good stretch of straight and flat road and did a 4th gear log for the first time. Low and behold, I caught the stutter/hesitation in the log. On the way home, I look over to the KR field and see nearly 6KR max!!! Got home, opened up the log and BAM, the insane KR is where I feel the hesitation. WTF is happening? Car is stock with exception of a new CS BPV, but this exact hesitation has been happening for quite a while, like I said earlier. Fuel rail pressure is all over the place, but always above 1600.
The only thing I see relating to the KR is that the AFR's might not have come down fast enough after peak load, but once KR hit, the AFR dropped quickly.
And for the hell of it, added VD of the log.
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
2008 GSX-R 1000 - Stolen
 Old 09-18-2016, 06:46 PM   #2
sheston's Avatar
Posts: 1,847   (View Stats)
Looks like you had one big KR event, and it's just decaying the rest of the time. If you are going to self tune, I would decrease the decay value so you can see separate events. Also, you need to log several other parameters, throttle position (to see if the throttle is being closed by the ECU), Ignition advance (to see how the ECU is controlling timing), and various others that you can find in logging threads.
As far as this log, did you hit anything in the road? hear any noises from the engine suspension? If you log more, see if the KR happens as the same rpm, etc. I can't really see anything in the log that would explain the KR. Add some of the other parameters and try logging again.
As far as helping your engine (I assume you don't know how it was taken care of), I would change your plugs, gap them to 0.026 or so, stretch your ignition coils, change your oil and the other maintenance stuff. Good Luck
The Following 2 Users Say Thank You to sheston For This Useful Post:
DingoDave (09-18-2016), Pu Manchu (09-19-2016)
 Old 09-18-2016, 07:06 PM   #3
DingoDave's Avatar
Posts: 764   (View Stats)
DingoDave is the leader of the worldDingoDave is the leader of the worldDingoDave is the leader of the worldDingoDave is the leader of the worldDingoDave is the leader of the worldDingoDave is the leader of the worldDingoDave is the leader of the worldDingoDave is the leader of the worldDingoDave is the leader of the worldDingoDave is the leader of the worldDingoDave is the leader of the world
Groans: 43
Groaned at 8 Times in 4 Posts
I would also do a compression check when you change your plugs. You can rent one at Autozone/Oreilly's. Check for anything loose or unbolted that could be banging against the engine.
2013 Black Mica Mazdaspeed 3 - Current daily
2006 WWP Mazdaspeed 6 - Soon to be daily
2006 BCM Mazdaspeed 6 - Project
Tuned with by
DingoDave is offline   Reply With Quote
 Old 09-18-2016, 07:10 PM   #4
Fstrnyou's Avatar
Replaced plugs with OE back in Feb maybe. Gapped to .030. Springs are stretched. Regularly change oil. Air filter good. MAF sensor clean. Did a coolant flush. JBR boost tubes and recirc hose. Replaced original BPV w/ CS BPV a few days ago, but first noticed this exact event about 6 or so months ago, so I'm ruling that out. From what I can recall, it's always around the same RPM, 2700-2800.
As for the log, I just picked general parameters for curiosity sake for my first log but had no expectations of capturing the knock event as it hadn't happened like that for about 2 months. Even after repeated attempts to replicate it. Sometimes it's a barely noticeable stumble and other times I feel no stumble at all. There will certainly be more logs, but it could be a month before it happens again and there's no guarantee I'll be logging at the time. What PID's should I drop? I don't want to log too many and sacrifice resolution.
On a side note, what's up with those BAT's? 140's while cruising and the BAT's drop drastically under boost until it can't keep up with the hair dryer and it climbs back up. Ambient temps were around 85F.
Did a compression check a few months ago. If I recall correctly, they were 180, 180, 180, 185.
Other rides:
History:
Last edited by Fstrnyou; 09-18-2016 at 07:18 PM. Reason: MSF Database - Automerged Doublepost
 Old 09-19-2016, 10:38 AM   #5
r3d
r3d's Avatar
Posts: 182   (View Stats)
r3d has a reputation beyond reputer3d has a reputation beyond reputer3d has a reputation beyond reputer3d has a reputation beyond reputer3d has a reputation beyond reputer3d has a reputation beyond reputer3d has a reputation beyond reputer3d has a reputation beyond reputer3d has a reputation beyond reputer3d has a reputation beyond reputer3d has a reputation beyond repute
Prob need to get your injectors cleaned, at that mileage they are caked.
Building it from ground up:
r3d is offline   Reply With Quote
 Old 09-19-2016, 06:07 PM   #6
Fstrnyou's Avatar
Good call. I'll scope out an injector set from a part-out and have them cleaned so I'm not immobilized for a week or so.
It was also suggested that a new O2 might be a good idea.
As sheston stated above, I don't know the history of this car. It had 115k miles when I got my hands on it. I've fixed/replaced/checked a lot of things but still have much more to do.
I don't intend to tune for performance/power until this engine is back in tip-top. Aside from a rebuild...
Other rides:
History:
 Old 09-19-2016, 06:29 PM   #7
sheston's Avatar
I would think at that mileage your valves and pistons are the things that would be caked. The EGR totally ruins these cars if your not spraying Meth to keep things clean. You might think about looking at those
 Old 09-19-2016, 07:48 PM   #8
Fstrnyou's Avatar
I have an EGR delete kit on my kitchen table. OCC kit to follow. And I would like to add a water/meth kit primarily for cleaning purposes as I don't intend to go past about 350whp. I don't have the money or resources for an engine rebuild...right now.
Other rides:
History:
 Old 09-19-2016, 08:18 PM   #9
djern's Avatar
Posts: 1,139   (View Stats)
Groans: 27
you have plenty of nator at your disposal in charlotte time to meet them guys bro..we can get ur car straightened out!
06 VRM Speed 6 W/Navi
05 Mazda Family Truckster
twitter.com/djern
instagram.com/djern
facebook.com/djern
 Old 09-19-2016, 09:05 PM   #10
Fstrnyou's Avatar
What's up Ern? I knew you'd find me eventually.
I occasionally check for updates on the next cars and coffee, or was it mugs n mufflers? Beer n boost? Tea n turbochargers? Eh whatever.
I'm way down in Rock Hill. Seen a few MS3's in the area. Heading up your way, I'm limited to weekend trips and I have my daughter half of those weekends. You won't want me around if I have her. Lol. She's 3.
Other rides:
History:
 Old 09-19-2016, 09:44 PM   #11
MSF's Punishing Member
Pu Manchu's Avatar
Posts: 2,992   (View Stats)
Groans: 546
or maybe he will.
94 M
MS6
IS350
 Old 09-19-2016, 10:01 PM   #12
Fstrnyou's Avatar
Hmm..
/Google search "sketchy gun shop with no background check"
Click - buy now.
Okay, I'm ready.
Other rides:
History:
djern (09-20-2016)
 Old 09-25-2016, 07:44 PM   #13
Fstrnyou's Avatar
Two more logs in the books but still haven't been able to capture the big KR like the first log. It has done it again, but not while logging. oh well.
2nd log - added the stock TMIC shroud. Thanks @HaXiR; Made little more power from the lower BATs.
3rd log - short 4th gear run on the interstate (4200-5700). leaned out the WOT target AFR's to 0.8 lambda up to 5.5k, 0.75 @ 6k, 0.7 after that. I don't think I've ever ran it to 6k before. Obviously, running leaner made more power. Got a few ticks of 0.7 KR up top.
File Type: csv 9-25-16 Stock Tune leaner afr targets.csv (3.5 KB, 3 views)
HaXiR likes this.
Other rides:
History:
HaXiR (09-25-2016)
Report: GM stock hits all-time high above $40 Haltech Automotive News 0 12-08-2013 12:30 PM
Help! High BATs or do all the stock intake manifolds flow about the same? paveltol MazdaSpeed 6 - Engine, Transmission & Driveline 7 11-11-2013 08:46 AM
Tesla stock reaches record high, brushes $53 Haltech Automotive News 0 04-23-2013 05:50 PM
High GM stock price aids workers, UAW's King says Haltech Automotive News 0 11-17-2010 10:20 PM
Page generated in 0.33741 seconds with 26 queries
