| VersaTune VersaTuner tuning software by VersaTune. Available for Mazdaspeed3, Mazda 3 MPS, Mazdaspeed Axela, Mazdaspeed6, Mazda 6 MPS, Mazdaspeed Atenza. Includes ECU reflashing/remapping, online tune database, custom tune editing ability, virtual dashboard, data logging, diagnostics/DTC code management, Launch Control, No Lift Shift, and stutter-free Smooth Shifting. |
![]() Join Date: Dec 2014 Location: Paducah, KY
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 18
(Thread Starter) | Not Ranked : 0 score I'm making this thread to figure out how I missed this information, and to help anyone else who may miss it in the future. About 3 weeks ago, I installed many parts, including a 3 bar map sensor. I informed my tuner, and he sent me a tune that had the proper numbers in the MAP scale tables to work with the 3 Bar. No matter what we tried, the dashboard and logs were showing a -2 psi with engine off and a peak boost of 9 psi on spring, which is supposed to be 14. I thought maybe the map sensor or adapter was bad, because the tune was fine, but it turned out to be this. This is the configuration of the Intake Manifold Absolute Pressure parameter on the dashboard. This is completely separate from the tune. Changing the drop down from Stock to Bosch 3 Bar completely fixed my problem. It only took me 3 weeks to find this. Probably because we were monitoring with the Boost Pressure parameter, not this one. Did I miss something? Is there anywhere that this has been stated, other than a brief mention in the suggestions thread? I know plenty have had success with Versatune, did everyone else just figure this out, and I'm the dummy? Why is this essential setting buried into a parameter that isn't necessary for tuning? Maybe a setting on the tune customizer would be better. I'm not being critical, just curious to see if others struggled like me, and where I could have found this information. ---
__________________ 2007 Mazdaspeed 6 Liquid Silver // BNR S3 V1 // JBR 3" Intake // Grimmspeed 3 port // 3 Bar MAP // Autotechs // DM OCC // Magnaflow CBE // OBX Test Pipe // Custom Shift Cables |
![]() Join Date: Mar 2011 Location: Cambridge, Ontario, Canada
Rep Power: 221 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 138
| Not Ranked : 0 score It was mentioned in their release notes: VersaTuner 1.12.0 released : Software Support
__________________ 2011 MAZDASPEED3 Hypnotic Tuned - Rob CPE HPFP - CPE Catted Downpipe - CPE Catback Exhaust - 3" ETS TMIC - Cobb RMM - AEM Boost Gauge & Vent Pod - CANBus Triple - Corksport BPV - Corksport hood strut - Corksport RSB - Corksport Short Shifter - HTP 3.5" Intake - Damond TMM - Damond Vented CC - Vented Oil Cap - Tokay v2 Seals - GTX3067R - Damond PCV Plate - Built Engine (Manley Rods, 88mm Supertech 4032 Piston) - |
| The Following User Says Thank You to Polish_Eagle For This Useful Post: | Trithemius (03-10-2017) |
__________________ 2007 Mazdaspeed 6 Liquid Silver // BNR S3 V1 // JBR 3" Intake // Grimmspeed 3 port // 3 Bar MAP // Autotechs // DM OCC // Magnaflow CBE // OBX Test Pipe // Custom Shift Cables | |
| Not Ranked : 0 score I made this same mistake earlier this week. I've always used boost pressure before, for some reason decided to use manifold pressure instead.
| The Following User Says Thank You to Mazdazilla6 For This Useful Post: | Trithemius (03-10-2017) |
| Setting The Pressure Threshold on your TPMS | RichB | MazdaSpeed 3 - How-To's | 12 | 09-18-2012 10:08 PM |
| Absolute Load vs Mods | quad4svtspeed6 | MazdaSpeed 3/6 - ECU Computer Tuning | 7 | 05-16-2011 08:22 PM |
| Amp setting/Line out converter setting? | 2k6speed6 | MazdaSpeed 3/6 - Car Audio & Electronics | 0 | 07-31-2009 12:10 PM |
| Absolute beefyness, you can't get any better than this | steven88 | Custom Performance Engineering (cp-e.com) | 10 | 04-19-2009 08:36 PM |
