> VersaTune
 Old 09-18-2016, 10:05 AM   #1
Fstrnyou's Avatar
Posts: 2,498   (View Stats)
Default Initial Base Tune
Noob question. What tune is initially flashed? 91 base, 93 base, etc? I think I read somewhere that is matches the OE Mazda tune but I don't see a "stock tune" in the tunes list.
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
2008 GSX-R 1000 - Stolen
 Old 09-19-2016, 03:18 AM   #2
Ugnius@VersaTune's Avatar
Posts: 41   (View Stats)
Ugnius@VersaTune is the leader of the worldUgnius@VersaTune is the leader of the worldUgnius@VersaTune is the leader of the worldUgnius@VersaTune is the leader of the worldUgnius@VersaTune is the leader of the worldUgnius@VersaTune is the leader of the worldUgnius@VersaTune is the leader of the worldUgnius@VersaTune is the leader of the worldUgnius@VersaTune is the leader of the worldUgnius@VersaTune is the leader of the worldUgnius@VersaTune is the leader of the world
Initially a special tune is flashed that is identical to OEM in terms of performance, but can accept performance tunes and has launch control, no lift shifting and other special features available. That tune is not in the list, but you can recreate that tune if necessary by clicking "New Tune" and saving the Tune Editor without making any other changes.
Ugnius
Lead Developer
Ugnius@VersaTune is offline   Reply With Quote
The Following 2 Users Say Thank You to Ugnius@VersaTune For This Useful Post:
Enki (09-19-2016), MS3Shadow (09-19-2016)
 Old 09-19-2016, 07:09 AM   #3
Fstrnyou's Avatar
The base tune is already part of the software. Why not just make it visible? I suppose I'm one of the few who want to learn the program before jumping right into an OTS map.
Other rides:
History:
 Old 09-19-2016, 10:55 AM   #4
Enki's Avatar
Posts: 7,541   (View Stats)
Enki has disabled reputation
Groans: 189
...Because it's not something anyone is going to stay on longer than they have to? I mean, nobody buys a tuning solution to stay on the stock map for any real length of time.
 Old 09-19-2016, 12:04 PM   #5
Fstrnyou's Avatar
I don't entirely disagree with you. I do plan to self tune, and I also want to know where I'm starting from and compare it to an OTS tune to see what changed and read about what that change does and how it interacts with other tables, etc. I'm starting from zero instead of being a nice little sheep and jumping into an OTS map that I have no knowledge of how it differs from the previous tune. I'm not trying to take any credit away from the OTS tune developers as I'm sure they know what they're doing. I want to learn, for my own sake, what each thing does. Just clicking download and flash doesn't teach me anything.
Other rides:
History:
Enki (09-19-2016)
 Old 09-19-2016, 01:27 PM   #6
Enki's Avatar
Groans: 189
I'll be redoing the TITS guide in VT, and I'll probably go over the stock vs OTS stuff.
desync0 (09-20-2016), KiwiFlavor (09-20-2016)
 Old 09-20-2016, 02:42 AM   #7
If you want to see what was changed in an OTS tune compared to stock, that can be very easily done with the tune editor. Click "From stock tune" in the "Show changes" panel at the top. All tables that have been changed will be marked in bold.
If you want to start from scratch, just click "New..." in the "My Tunes" area of the "Tunes" tab. The Tune Editor will open with all tables set to stock values. You can then start applying your changes, flashing periodically and checking the effects.
Ugnius
Lead Developer
The Following 4 Users Say Thank You to Ugnius@VersaTune For This Useful Post:
desync0 (09-20-2016), Enki (09-20-2016), Fstrnyou (09-20-2016), WetzMS3 (09-20-2016)
 Old 09-20-2016, 05:05 AM   #8
Fstrnyou's Avatar
Ah, awesome. Thank you very much.
Other rides:
History:
 Old 09-20-2016, 08:17 AM   #9
nindoja's Avatar
Posts: 2,395   (View Stats)
To expand on that, after you do that, you can select a cell/row/table and click the undo button (the circular arrow pointing counter-clockwise) to revert that value to whatever the stock map had.
That feature is also useful to compare changes you made between maps too.
True Red 2009 MS3
Tune: hypnotic tuned
Critical Stats:
// 305whp/352tq
Base tune, what does it do? Kor3y101 Gen2 MS3 General Discussion 4 04-12-2015 02:03 PM
Boost Tune - Only running base WGDC MattJackson86 MazdaSpeed 3/6 - ECU Computer Tuning 10 05-08-2014 05:13 PM
Initial log...how's it look? AKmac11 Mazdaspeed3/6 General Discussion 2 07-31-2013 06:24 PM
In need of BT Base Map Tune myfirstturbo MazdaSpeed 3/6 - ECU Computer Tuning 18 07-28-2013 02:34 PM
Not boosting even on base tune KRheeder MazdaSpeed 3/6 - ECU Computer Tuning 0 02-09-2012 01:27 PM
Page generated in 0.28019 seconds with 24 queries
