| VersaTune VersaTuner tuning software by VersaTune. Available for Mazdaspeed3, Mazda 3 MPS, Mazdaspeed Axela, Mazdaspeed6, Mazda 6 MPS, Mazdaspeed Atenza. Includes ECU reflashing/remapping, online tune database, custom tune editing ability, virtual dashboard, data logging, diagnostics/DTC code management, Launch Control, No Lift Shift, and stutter-free Smooth Shifting. |
![]() Join Date: Apr 2013 Location: Wilkesboro, North Carolina
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,221
(Thread Starter) | Not Ranked : 0 score maybe I'm missing something, but how do you switch from lambda values to afr values?
__________________ 2013 CWP and Stock |
![]() Join Date: Mar 2011 Location: Cambridge, Ontario, Canada
Rep Power: 221 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 138
| Not Ranked : 0 score In the app... I don't think you can. However, mathematically you can do Lambda x 14.7 and that will give you the AFR for that lambda. If you want to go AFR to Lambda then do AFR / 14.7 and you'll have your lambda value.
__________________ 2011 MAZDASPEED3 Hypnotic Tuned - Rob CPE HPFP - CPE Catted Downpipe - CPE Catback Exhaust - 3" ETS TMIC - Cobb RMM - AEM Boost Gauge & Vent Pod - CANBus Triple - Corksport BPV - Corksport hood strut - Corksport RSB - Corksport Short Shifter - HTP 3.5" Intake - Damond TMM - Damond Vented CC - Vented Oil Cap - Tokay v2 Seals - GTX3067R - Damond PCV Plate - Built Engine (Manley Rods, 88mm Supertech 4032 Piston) - |
Groans: 111
If it's that much of a problem then copy/paste to an excel/openoffice/whatever, multiply everything by 14.7, edit it, divide by 14.7 when you finish, paste back into Versa. You don't need to do this very often but over time I came to "learn" some values so that I don't have to divide/multiply by 14.7 every time.
__________________ 2008 Cosmic Blue Mazda 3MPS Bilstein B12 + CS Camber plates + Eibach camber arms, SSR Type-F, Michelin PS4 225/40/R18, Cobb RMM, StopTech Street Pads + Stoptech Slotted disks, SouthBend Enduro Stage3 clutch, genpu TMM + CS Insert, TheSpeedLine 2X Rear Cross Floor and Rear Middle Lower Strut bars, Tanabe 4 Point Under Brace, Whiteline Bumpsteeer corection kit JBR Tru-3" + CS CAI Box, CP-e TMIC, Cobb XLE, NGK LTR7IX, UR v3 catted DP and res&catted TP, Cobb CatBack, GS EBCS, Autotech internals, GTX3071r gen2, CS 3.5BAR, Guardian Angel, CoolingMist WMI, VCTS Delete, stock ported IM, CorkSport cam shafts Mahle 88mm 4032 9.6:1 pistons, Manley rods, CA625+ head studs, King rod&main bearings, CS seals, DCR VVT, Koyorad radiator. StratiVersaTuned FTW to 28PSI, self-tuned to 32PSI 2008 Icy Blue Mazda CX7 6 Speed Manual SU TMIC, Autotech HPFP internals, Cobb XLE, Cobb EBCS, CorkSport 3.5BAR MAP GTX2867R gen2, stock spark plugs, stock cats and stock exhaust FTW, JBR Tru-3" Silicone intake TheSpeedLine Top and Lower Strut bars self-Versatuned to 22PSI | |
| The Following User Says Thank You to mituc For This Useful Post: | Boost_creep (05-29-2016) |
That's exactly what i done. I just done the entire table in AFR and divided the table by 14.7. Pretty simple to do. I was just hoping there was an easy toggle. I'm not exactly the best at spotting small options.
__________________ 2013 CWP and Stock | |
Groans: 189
| Not Ranked : 0 score There's literally hundreds of pages about this online.
__________________ |
| Approved MSF Vendor ![]() Join Date: Dec 2011
Rep Power: 189 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6
| Not Ranked : 0 score That feature is highly requested and will be incorporated in one of the future releases. Sorry about the inconvenience. |
| The Following 6 Users Say Thank You to Ugnius@VersaTune For This Useful Post: | Boost_creep (05-30-2016), DingoDave (09-27-2016), Enki (05-30-2016), Mazdazilla6 (05-31-2016), mituc (05-30-2016), NCspecV81 (05-30-2016) |
Groans: 111
| Not Ranked : 0 score Incoming WIN! The E85 guys will have to be more careful when working in AFR numbers instead of lambda, but usually at this level people know what they do.
Groans: 189
| Not Ranked : 0 score Shouldn't be much of a change over AFR, since it will still be a direct translation from Lambda. Changing the scalars will change the injection amount so you don't have to fuck with AFRs much.
| ATR Fuel Tables??? (AFR / Lambda?) | GlennMPS | MazdaSpeed 3/6 - ECU Computer Tuning | 5 | 08-05-2013 10:37 AM |
| Downpipe lambda sensor | joey | MazdaSpeed 3/6 - ECU Computer Tuning | 12 | 11-17-2011 01:24 PM |
| Fucking lambda. | ARES28 | MazdaSpeed 3/6 - ECU Computer Tuning | 2 | 09-04-2011 06:46 PM |
| MotorTrend: Next Escalade to go Lambda | Haltech | Automotive News | 0 | 09-08-2008 11:10 AM |
