> VersaTune
Like Tree5Likes
 Old 07-07-2015, 11:05 AM   #1
RE-ACTIONENGSPEED3's Avatar
Posts: 401   (View Stats)
Default LC issue??
Hi to all,i have make some progress with tuning my car.So i try to make some Launches i have enabled Megaspool i set the LC limit to 6200 and retard -7 , great results 6200 almost 26psi...
But when i try to start the car with LC after i realease the clutch the car is almost switched off ???????I attach logs in vt format and in a ecxel
I need help from anyone
@Steve@VersaTune;
@Ugnius@VersaTune;
And anyone else.....
2008 speed3
True red.
Pte 6466 & AWD Mode on !!!!
 Old 07-08-2015, 07:17 AM   #2
Eth Fiend
phate's Avatar
Posts: 6,947   (View Stats)
Have you ever been able to launch the car with megaspool enabled, but at a different RPM or timing setting? Have you been able to launch the car successfully without megaspool enabled?
-06 MS6
-Corn fed 07 MS3 - Sold
 Old 07-08-2015, 07:24 AM   #3
Eth Fiend
phate's Avatar
From the log, it looks like the car is holding the -7° timing value after the clutch has started to engage. Does your clutch engage early in the pedal travel (close to the floor)? It could be an issue where the clutch switch isn't activating/deactivating at a position that corresponds to where the clutch is actually engaging (car starts to move).
Can you grab a log of a launch and include clutch position and vehicle speed? You can take out KR, BAT, Fuel rail pressure, and either of the MAF values to increase resolution slightly.
-06 MS6
Easter Bunny (07-08-2015)
 Old 07-08-2015, 07:40 AM   #4
I have never launch the car with megaspool enabled.without i have not try it now that the car is awd.at the past before the megaspool options the cars was launching perfect ..i will make a log with the values you asked.
In my opinion there is a fuel cut but i do not know why....
As for the clutch it is engaged almost in the middle of the pedal route...
2008 speed3
True red.
The Following User Says Thank You to RE-ACTIONENGSPEED3 For This Useful Post:
phate (07-08-2015)
 Old 07-08-2015, 07:51 AM   #5
Eth Fiend
phate's Avatar
It doesn't look like fuel cut, but it's pretty low logging resolution. AFR looks good, and IPW doesn't go to 0 after what looks like the clutch engaging. There is a dip in IPW at 5.944s that could indicate it pulling fuel, but the resolution isn't high enough to tell for sure.
-06 MS6
 Old 07-08-2015, 08:20 AM   #6
Jarods7920's Avatar
Posts: 1,415   (View Stats)
See, i have experienced the same thing. Its like the car falls on its face. I just assumed it was the car bogging down due to low launch RPM...
The Following User Says Thank You to Jarods7920 For This Useful Post:
Enki (07-08-2015)
 Old 07-08-2015, 12:27 PM   #7
I thought the same think the first time i experienced it.But then i raise rpm and boost and still the same reaction i even make a try with 7200rpm and 32psi still the same results. I even make a try launching the car with FWD and 6200rpm and 26psi same result again...
I attach one more log i have with 7000rpm and 28psi ....
2008 speed3
True red.
 Old 07-08-2015, 01:01 PM   #8
Enki's Avatar
Posts: 7,541   (View Stats)
Enki has disabled reputation
Groans: 189
So this is apparently what it looks like. I thought I just had too good a traction, even though I wasn't using my LC (never went WOT):
Edit:
Looking through my track logs, nothing stands out.
Easter Bunny (07-09-2015), Micha (08-10-2015), Scare Dem (07-11-2015)
 Old 07-08-2015, 01:08 PM   #9
http://www.youtube.com/watch?v=4BCWl3kM48I
Edit:
Especially at last try thats exactly the bog i get ....
2008 speed3
True red.
The Following 2 Users Say Thank You to RE-ACTIONENGSPEED3 For This Useful Post:
Easter Bunny (07-09-2015), Koke382 (07-08-2015)
 Old 07-08-2015, 01:46 PM   #10
Eth Fiend
phate's Avatar
Can you post your open loop ignition timing maps? Screenshots are fine.
-06 MS6
 Old 07-08-2015, 09:11 PM   #11
Realgib3's Avatar
Posts: 2,443   (View Stats)
This may be a dumb question, but has ANYONE successfully launched the car with megaspool in VT? Or have we Only seen cars making a ton of
Boost in 2-step but nobody actually launching.
Jackis likes this.
The Following 3 Users Say Thank You to Realgib3 For This Useful Post:
Easter Bunny (07-09-2015), Jackis (11-09-2015), phate (07-10-2015)
 Old 07-09-2015, 12:00 AM   #12
As i understant no one make real launch with megaspool enabled ..the weired thing is that without megaspool stil the same problem(but not so hard)
2008 speed3
True red.
 Old 07-09-2015, 12:09 AM   #13
Here is your screenshots...i will also make new logs with the pids you request in about 8 hours..
2008 speed3
True red.
 Old 07-09-2015, 02:12 AM   #14
Enki's Avatar
Groans: 189
Last time I launched with MS enabled, it was on the street and I just blew the tires right off of it.
 Old 07-09-2015, 02:56 AM   #15
If i understand corect the problem is with revs higher than 4500...in the past when i was FWD i have no problem launch the car but when i make a try to start the car with 2nd gear 6000rpm the same bog(always without megaspool)so i estimate the problem is not the megaspool ....
2008 speed3
True red.
 Old 07-09-2015, 09:05 AM   #16
i attach logs as requested...
2008 speed3
True red.
 Old 07-09-2015, 12:01 PM   #17
Eth Fiend
phate's Avatar
It's pulling timing WAY down after LC deactivates: -13° in a couple spots. Reminds me of shift stutter behavior, which sort of makes sense being immediately after a clutch out action. It's not following your OL timing table. It's not likely, but can you check the timing in the other timing tables around that rpm and load (down to ~1.2 load).
Did/does the LC work for you in 1st gear?
-06 MS6
Enki (07-09-2015), RE-ACTIONENGSPEED3 (07-10-2015)
 Old 07-10-2015, 12:40 AM   #18
i have good news and bad news
Bad news are that i check all the ignition realated tables and in that load i found nothing near -13 so i move on and disable the megaspool options for LC & FFS and i make them like i used to have them when i was FWD but i raise the rpms of course......good news i make a try and the car starts like rocket so i will leave it as it is for the moment.....i attach logs and a printscreen of how i set the LC & FFS ....
p.s. I`m waiting for Steve & Ugnius response to this?i hope they do not abandon us....
2008 speed3
True red.
Easter Bunny (07-10-2015), phate (07-10-2015)
 Old 07-10-2015, 07:08 AM   #19
Eth Fiend
phate's Avatar
Good to hear you're able to launch it. My only other suggestion, since it looks like a shift related issue, is to try it with the 'smooth shift' toggle enabled. I believe it does some things to shift related timing tables, so there's a small chance it could fix this.
Can you take some video of the car ripping off the line with LC? I think @Realgib3; needs some proof, lol. [And we all want to see it, anyway.]
cshunter likes this.
-06 MS6
The Following 5 Users Say Thank You to phate For This Useful Post:
Easter Bunny (07-10-2015), Enki (07-10-2015), RE-ACTIONENGSPEED3 (07-10-2015), Realgib3 (07-10-2015), Vansquish (07-10-2015)
 Old 07-10-2015, 10:04 AM   #20
i will, next time i will be out to make some tuning i guess next Tuesday ......
2008 speed3
True red.
phate (07-10-2015)
 Old 07-11-2015, 07:37 AM   #21
Steve@VersaTune's Avatar
Posts: 432   (View Stats)
Steve@VersaTune is the leader of the worldSteve@VersaTune is the leader of the worldSteve@VersaTune is the leader of the worldSteve@VersaTune is the leader of the worldSteve@VersaTune is the leader of the worldSteve@VersaTune is the leader of the worldSteve@VersaTune is the leader of the worldSteve@VersaTune is the leader of the worldSteve@VersaTune is the leader of the worldSteve@VersaTune is the leader of the worldSteve@VersaTune is the leader of the world
What are the MegaSpool settings that you were using? I'm wondering if you were hitting the NLS limiter. Also, did you have Smooth Shift enabled? It addresses timing retard on high load shifts.
Also, what is your mininimum timing set to?
Steve
Lead Tuner
Steve@VersaTune is offline   Reply With Quote
 Old 07-13-2015, 12:17 AM   #22
hi,
my megaspool option was for LC 6600rpm -7ign and the NLS 7000rpm -12ign
I have not enabled the smooth shift setting for some reason i do not like the way it works when it is enabled
As for my minimum spark timing i have it as it is on 4 cylinders -13,5
2008 speed3
True red.
Last edited by RE-ACTIONENGSPEED3; 07-13-2015 at 12:18 AM. Reason: MSF Database - Automerged Doublepost
 Old 07-13-2015, 07:28 PM   #23
Looking at the first log, you are seeing fuel cut well before you hit 6600. Are you sure your LC limiter was set at 6600? It looks like 6100 in the logs.
Some things to try:
enable smooth shift
set NLS retard at some extreme value like -30* so it's obvious if you're hitting this.
raise LC km/h threshold - it's possible that you're exceeding LC speed threshold before the clutch pedal switch is triggered. You are going from 0 to 12 km/h between the two clutch pedal samples showing disengaged and engaged.
I may need to rewrite the LC/NLS speed check to accommodate hard launching cars.
Steve
Lead Tuner
The Following 11 Users Say Thank You to Steve@VersaTune For This Useful Post:
Code Monkey (07-13-2015), Dano (11-10-2015), Easter Bunny (07-13-2015), Enki (07-13-2015), Justin@Freektune (07-14-2015), Micha (08-10-2015), phate (07-13-2015), RE-ACTIONENGSPEED3 (07-14-2015), Realgib3 (07-14-2015), TiGraySpeed6 (07-13-2015), xfeejayx (04-27-2017)
 Old 11-09-2015, 04:36 AM   #24
Some things to try:
enable smooth shift
I have tried all these options nothing worked.I also try to launch without megaspool option enabled and i some times was able to launch some other the same bog(nothiing changed between the 2 tries).So i think you should deffinetlly check what is going on with the high revs and launch control i think that there might be some issue...Especially for my car that it is launching hard is a very big problem ,because after every bog i really stress my t-case.
2008 speed3
True red.
Realgib3 (11-09-2015)
 Old 11-09-2015, 07:47 AM   #25
Eth Fiend
phate's Avatar
We were launching at 4500 rpm the past two events and it works great. I can try bumping it up for testing this issue.
-06 MS6
 Old 11-09-2015, 07:55 AM   #26
At 4500rpm i m sure it launches great, try above 6500rpm.are you using megaspool??
2008 speed3
True red.
 Old 11-09-2015, 08:19 AM   #27
Eth Fiend
phate's Avatar
Megaspool @ 4500 rpm, yes. We haven't gone up with it because it just blows the tires off if we try hitting it too hard
-06 MS6
Vansquish (04-30-2017)
 Old 11-09-2015, 06:06 PM   #28
Try setting the unk1 and unk2 rev limiters to 7000 or something above what you expect to hit while launching. One of those is the extreme cold operating limiter, the other I suspect may be a neutral rev limiter or something. I will keep looking at the code to see what all the flags are that need to be set to trip it.
Steve
Lead Tuner
The Following 6 Users Say Thank You to Steve@VersaTune For This Useful Post:
Code Monkey (11-09-2015), Enki (11-09-2015), Jarods7920 (11-09-2015), phate (11-09-2015), RE-ACTIONENGSPEED3 (11-09-2015), SpeedRebirth (11-10-2015)
 Old 11-09-2015, 11:46 PM   #29
I have set them always to 8000rpm...If you want i can send you my tune just in case i miss something.
2008 speed3
True red.
 Old 11-10-2015, 09:12 AM   #30
Trail of Fail
Dano's Avatar
Posts: 9,484   (View Stats)
Some things to try:
enable smooth shift
Considering that it looks like he has the LC RPM limiters set above required values this seems the most promising place to look. LC speed threshold. I believe he says the bog only happens sometimes so he may be right on the LC speed logic bubble so to speak.
Great track prep, tire heat/pressure, driver control = too much speed = bog. so so track prep, tire heat/pressure, driver control = not enough speed = no bog.
phate (11-10-2015), RE-ACTIONENGSPEED3 (11-10-2015)
 Old 12-11-2015, 08:40 PM   #31
Looking at this again, it looks like you're hitting the NLS limiter. You launch with LC then quickly exceed the 1.2 mph threshold for LC before the clutch is all the way out and switch to the lower NLS limiter. I suspect others have not hit this because most have a much bigger gap between the LC RPM and NLS RPM or a higher speed threshold for LC.
Steve
Lead Tuner
The Following 3 Users Say Thank You to Steve@VersaTune For This Useful Post:
phate (12-11-2015), RE-ACTIONENGSPEED3 (12-13-2015), SpeedRebirth (12-11-2015)
 Old 12-18-2015, 04:06 AM   #32
So Steve what you thing will be the solution for that problem.I have set the LC mp/h thresold to 10mp/h but nothing changed
2008 speed3
True red.
 Old 12-18-2015, 05:26 AM   #33
I am working on a new beta with some new tables exposed. It should be ready early next week.
Micha likes this.
Steve
Lead Tuner
The Following 10 Users Say Thank You to Steve@VersaTune For This Useful Post:
chaser27 (12-18-2015), Code Monkey (12-18-2015), cshunter (12-21-2015), Enki (12-18-2015), Jarods7920 (12-18-2015), Micha (12-19-2015), mituc (12-21-2015), Polish_Eagle (12-19-2015), RE-ACTIONENGSPEED3 (12-19-2015), SpeedRebirth (12-18-2015)
 Old 12-21-2015, 10:48 PM   #34
The new Beta is ready to go.
RE-ACTIONENGSPEED3 likes this.
Steve
Lead Tuner
The Following 4 Users Say Thank You to Steve@VersaTune For This Useful Post:
Code Monkey (12-22-2015), Enki (12-21-2015), Jarods7920 (12-22-2015), SpeedRebirth (12-22-2015)
 Old 12-24-2015, 01:25 AM   #35
I can not wait to be back to road for testing!!!!!
2008 speed3
True red.
The Following 3 Users Say Thank You to RE-ACTIONENGSPEED3 For This Useful Post:
Jarods7920 (12-28-2015), maisonvi (12-24-2015), mazdakaps (12-29-2015)
 Old 04-26-2017, 04:38 PM   #36
Mazdazilla6's Avatar
Posts: 3,657   (View Stats)
What was the fix for this? I'm bogging pretty hard using megaspool. LC is 6100 rpm and -20*. NLS is 8000 rpm.
VersaTuner = Versatune
PTE = JB 5862
Forge = V2 BPV
Tial = 44mm WG
Autotech = HPFP Internals
Grimmspeed = EBCS
Enki (04-26-2017)
 Old 04-28-2017, 09:55 PM   #37
We added the absolute rev limiters to allow >8000 RPM and exposed all shift related torque limiters.
Adjusting the actuation point of the clutch pedal position sensor appears to help too.
Steve
Lead Tuner
The Following User Says Thank You to Steve@VersaTune For This Useful Post:
Mazdazilla6 (04-30-2017)
 Old 04-30-2017, 09:46 AM   #38
So you think it's a torque limiter causing the bog?
PTE = JB 5862
Forge = V2 BPV
Tial = 44mm WG
Grimmspeed = EBCS
 Old 04-30-2017, 09:53 AM   #39
If you're still in LC mode while the clutch is partially engaged but before the clutch pedal position switch is actuated, it will bog. This is most likely the issue. There is a thread somewhere discussing this. Drill a small hole in the CPP sensor and put a screw in it to allow adjustment of the actuation point.
RE-ACTIONENGSPEED3 was also going > 8000 rpm which hit a separate rev limiter. We exposed that limiter as the absolute rev limiter.
Mazdazilla6 likes this.
Steve
Lead Tuner
The Following 2 Users Say Thank You to Steve@VersaTune For This Useful Post:
Enki (05-01-2017), Mazdazilla6 (04-30-2017)
 Old 04-30-2017, 09:57 AM   #40
I'll give it a shot and report back how it goes.
Edit: Just to make sure I'm getting this straight. The reason for the screw is to make the car think the clutch is still down (engaged) so it won't shut off megaspool prematurely? @Steve@VersaTune;
PTE = JB 5862
Forge = V2 BPV
Tial = 44mm WG
Grimmspeed = EBCS
KR at WOT issue 6262ms3 MazdaSpeed 3/6 - ECU Computer Tuning 4 04-06-2013 08:18 AM
DVD Nav Issue djern MazdaSpeed 3/6 - Car Audio & Electronics 5 08-18-2012 12:22 AM
:: new issue :: :: Gusto :: MazdaSpeed 6 - Engine, Transmission & Driveline 10 09-14-2009 10:00 PM
CPE PNP Issue Phantom MazdaSpeed 3/6 - Troubleshoot/Diagnostics 2 02-20-2009 03:01 PM
Page generated in 0.61198 seconds with 28 queries
