| VersaTune VersaTuner tuning software by VersaTune. Available for Mazdaspeed3, Mazda 3 MPS, Mazdaspeed Axela, Mazdaspeed6, Mazda 6 MPS, Mazdaspeed Atenza. Includes ECU reflashing/remapping, online tune database, custom tune editing ability, virtual dashboard, data logging, diagnostics/DTC code management, Launch Control, No Lift Shift, and stutter-free Smooth Shifting. |
![]() Join Date: Nov 2011 Location: Greece-Athens
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 470
(Thread Starter) | Not Ranked : 0 score But when i try to start the car with LC after i realease the clutch the car is almost switched off ???????I attach logs in vt format and in a ecxel I need help from anyone @Steve@VersaTune; @Ugnius@VersaTune; And anyone else.....
__________________ 2008 speed3 True red. Pte 6466 & AWD Mode on !!!! 11.114@131.04 .........GTX3071.....FWD 10.62@136.64............PTE6466.....AWD [SIGPIC][/SIGPIC] |
| Not Ranked : 0 score Have you ever been able to launch the car with megaspool enabled, but at a different RPM or timing setting? Have you been able to launch the car successfully without megaspool enabled?
__________________ -06 MS6 -Corn fed 07 MS3 - Sold ![]() www.mazdamotorsports.com <<--Mazda racer support program that is free to join and will save you a ton of money. |
| Not Ranked : 0 score From the log, it looks like the car is holding the -7° timing value after the clutch has started to engage. Does your clutch engage early in the pedal travel (close to the floor)? It could be an issue where the clutch switch isn't activating/deactivating at a position that corresponds to where the clutch is actually engaging (car starts to move). Can you grab a log of a launch and include clutch position and vehicle speed? You can take out KR, BAT, Fuel rail pressure, and either of the MAF values to increase resolution slightly.
| The Following User Says Thank You to phate For This Useful Post: | Easter Bunny (07-08-2015) |
(Thread Starter) | Not Ranked : 0 score I have never launch the car with megaspool enabled.without i have not try it now that the car is awd.at the past before the megaspool options the cars was launching perfect ..i will make a log with the values you asked. In my opinion there is a fuel cut but i do not know why.... As for the clutch it is engaged almost in the middle of the pedal route...
| The Following User Says Thank You to RE-ACTIONENGSPEED3 For This Useful Post: | phate (07-08-2015) |
__________________ -06 MS6 -Corn fed 07 MS3 - Sold ![]() www.mazdamotorsports.com <<--Mazda racer support program that is free to join and will save you a ton of money. | |
![]() Join Date: Jul 2008 Location: Imperial MO
Rep Power: 581 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 127
| Not Ranked : 0 score See, i have experienced the same thing. Its like the car falls on its face. I just assumed it was the car bogging down due to low launch RPM...
__________________ 2008 MazdaSpeed 3 AWD big turbo...blah blah blah |
| The Following User Says Thank You to Jarods7920 For This Useful Post: | Enki (07-08-2015) |
I attach one more log i have with 7000rpm and 28psi ....
__________________ 2008 speed3 True red. Pte 6466 & AWD Mode on !!!! 11.114@131.04 .........GTX3071.....FWD 10.62@136.64............PTE6466.....AWD [SIGPIC][/SIGPIC] | |
Groans: 189
| Not Ranked : 0 score So this is apparently what it looks like. I thought I just had too good a traction, even though I wasn't using my LC (never went WOT): Edit: Looking through my track logs, nothing stands out.
__________________ |
| The Following 3 Users Say Thank You to Enki For This Useful Post: |
| The Following 2 Users Say Thank You to RE-ACTIONENGSPEED3 For This Useful Post: | Easter Bunny (07-09-2015), Koke382 (07-08-2015) |
| Not Ranked : 0 score Can you post your open loop ignition timing maps? Screenshots are fine.
| Not Ranked : 0 score This may be a dumb question, but has ANYONE successfully launched the car with megaspool in VT? Or have we Only seen cars making a ton of Boost in 2-step but nobody actually launching. |
| The Following 3 Users Say Thank You to Realgib3 For This Useful Post: |
(Thread Starter) | Not Ranked : 0 score As i understant no one make real launch with megaspool enabled ..the weired thing is that without megaspool stil the same problem(but not so hard)
| The Following User Says Thank You to RE-ACTIONENGSPEED3 For This Useful Post: | Easter Bunny (07-09-2015) |
(Thread Starter) | Not Ranked : 0 score Here is your screenshots...i will also make new logs with the pids you request in about 8 hours..
Groans: 189
| Not Ranked : 0 score Last time I launched with MS enabled, it was on the street and I just blew the tires right off of it.
| The Following User Says Thank You to Enki For This Useful Post: | Easter Bunny (07-09-2015) |
(Thread Starter) | Not Ranked : 0 score If i understand corect the problem is with revs higher than 4500...in the past when i was FWD i have no problem launch the car but when i make a try to start the car with 2nd gear 6000rpm the same bog(always without megaspool)so i estimate the problem is not the megaspool ....
| Not Ranked : 0 score It's pulling timing WAY down after LC deactivates: -13° in a couple spots. Reminds me of shift stutter behavior, which sort of makes sense being immediately after a clutch out action. It's not following your OL timing table. It's not likely, but can you check the timing in the other timing tables around that rpm and load (down to ~1.2 load). Did/does the LC work for you in 1st gear?
| The Following 2 Users Say Thank You to phate For This Useful Post: | Enki (07-09-2015), RE-ACTIONENGSPEED3 (07-10-2015) |
(Thread Starter) | Not Ranked : 0 score i have good news and bad news Bad news are that i check all the ignition realated tables and in that load i found nothing near -13 so i move on and disable the megaspool options for LC & FFS and i make them like i used to have them when i was FWD but i raise the rpms of course......good news i make a try and the car starts like rocket so i will leave it as it is for the moment.....i attach logs and a printscreen of how i set the LC & FFS .... p.s. I`m waiting for Steve & Ugnius response to this?i hope they do not abandon us....
| The Following 2 Users Say Thank You to RE-ACTIONENGSPEED3 For This Useful Post: | Easter Bunny (07-10-2015), phate (07-10-2015) |
Can you take some video of the car ripping off the line with LC? I think @Realgib3; needs some proof, lol. [And we all want to see it, anyway.]
| The Following 5 Users Say Thank You to phate For This Useful Post: | Easter Bunny (07-10-2015), Enki (07-10-2015), RE-ACTIONENGSPEED3 (07-10-2015), Realgib3 (07-10-2015), Vansquish (07-10-2015) |
| The Following User Says Thank You to RE-ACTIONENGSPEED3 For This Useful Post: | phate (07-10-2015) |
| Approved MSF Vendor ![]() Join Date: Nov 2011
Rep Power: 778 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 0
| Not Ranked : 0 score What are the MegaSpool settings that you were using? I'm wondering if you were hitting the NLS limiter. Also, did you have Smooth Shift enabled? It addresses timing retard on high load shifts. Also, what is your mininimum timing set to? |
my megaspool option was for LC 6600rpm -7ign and the NLS 7000rpm -12ign I have not enabled the smooth shift setting for some reason i do not like the way it works when it is enabled As for my minimum spark timing i have it as it is on 4 cylinders -13,5
__________________ 2008 speed3 True red. Pte 6466 & AWD Mode on !!!! 11.114@131.04 .........GTX3071.....FWD 10.62@136.64............PTE6466.....AWD [SIGPIC][/SIGPIC] Last edited by RE-ACTIONENGSPEED3; 07-13-2015 at 12:18 AM. Reason: MSF Database - Automerged Doublepost | |
| Not Ranked : 0 score Looking at the first log, you are seeing fuel cut well before you hit 6600. Are you sure your LC limiter was set at 6600? It looks like 6100 in the logs. Some things to try: enable smooth shift set NLS retard at some extreme value like -30* so it's obvious if you're hitting this. raise LC km/h threshold - it's possible that you're exceeding LC speed threshold before the clutch pedal switch is triggered. You are going from 0 to 12 km/h between the two clutch pedal samples showing disengaged and engaged. I may need to rewrite the LC/NLS speed check to accommodate hard launching cars. |
| The Following 11 Users Say Thank You to Steve@VersaTune For This Useful Post: | Code Monkey (07-13-2015), Dano (11-10-2015), Easter Bunny (07-13-2015), Enki (07-13-2015), Justin@Freektune (07-14-2015), Micha (08-10-2015), phate (07-13-2015), RE-ACTIONENGSPEED3 (07-14-2015), Realgib3 (07-14-2015), TiGraySpeed6 (07-13-2015), xfeejayx (04-27-2017) |
![]() | | #24 | ![]() |
| The Following User Says Thank You to RE-ACTIONENGSPEED3 For This Useful Post: | Realgib3 (11-09-2015) |
![]() | | #25 | ![]() |
| Not Ranked : 0 score We were launching at 4500 rpm the past two events and it works great. I can try bumping it up for testing this issue.
![]() | | #26 | ![]() |
(Thread Starter) | Not Ranked : 0 score At 4500rpm i m sure it launches great, try above 6500rpm.are you using megaspool??
![]() | | #27 | ![]() |
| The Following User Says Thank You to phate For This Useful Post: | Vansquish (04-30-2017) |
![]() | | #28 | ![]() |
| Not Ranked : 0 score Try setting the unk1 and unk2 rev limiters to 7000 or something above what you expect to hit while launching. One of those is the extreme cold operating limiter, the other I suspect may be a neutral rev limiter or something. I will keep looking at the code to see what all the flags are that need to be set to trip it. |
| The Following 6 Users Say Thank You to Steve@VersaTune For This Useful Post: | Code Monkey (11-09-2015), Enki (11-09-2015), Jarods7920 (11-09-2015), phate (11-09-2015), RE-ACTIONENGSPEED3 (11-09-2015), SpeedRebirth (11-10-2015) |
![]() | | #29 | ![]() |
![]() | | #30 | ![]() |
Great track prep, tire heat/pressure, driver control = too much speed = bog. so so track prep, tire heat/pressure, driver control = not enough speed = no bog.
__________________ ![]() 07 Red MS3 GT - E40 - Carrillo Rods - Wiseco Pistons - BSD - JBR 3.5 WidePath - ATP GTX3071 - Forge BPV - GA - Cobb v2 FMIC - CPE EM - CPE DP - CNT CBE - APv3 - Grim EBC - PERM dual port PCV plate - Dano dual OCC - CPE CDFP - Labonte S2 WMI - ACT Street Kit - SUv2 RMM - SU TM - "Stiffy" MM - DG CF wing ext, skirts & front lip - Hotchkis RSB/FSB w PowerGrid Links - Koni FSDs - DBA SX4000 Rotors - Hawk Pads - Silver OZ Ultraleggera - 235/40/18 NT-01 | |
| The Following 2 Users Say Thank You to Dano For This Useful Post: | phate (11-10-2015), RE-ACTIONENGSPEED3 (11-10-2015) |
![]() | | #31 | ![]() |
| Not Ranked : 0 score Looking at this again, it looks like you're hitting the NLS limiter. You launch with LC then quickly exceed the 1.2 mph threshold for LC before the clutch is all the way out and switch to the lower NLS limiter. I suspect others have not hit this because most have a much bigger gap between the LC RPM and NLS RPM or a higher speed threshold for LC. |
| The Following 3 Users Say Thank You to Steve@VersaTune For This Useful Post: |
![]() | | #32 | ![]() |
![]() | | #33 | ![]() |
| Not Ranked : 0 score I am working on a new beta with some new tables exposed. It should be ready early next week. |
| The Following 10 Users Say Thank You to Steve@VersaTune For This Useful Post: | chaser27 (12-18-2015), Code Monkey (12-18-2015), cshunter (12-21-2015), Enki (12-18-2015), Jarods7920 (12-18-2015), Micha (12-19-2015), mituc (12-21-2015), Polish_Eagle (12-19-2015), RE-ACTIONENGSPEED3 (12-19-2015), SpeedRebirth (12-18-2015) |
![]() | | #34 | ![]() |
| Not Ranked : 0 score The new Beta is ready to go. |
| The Following 4 Users Say Thank You to Steve@VersaTune For This Useful Post: |
![]() | | #35 | ![]() |
(Thread Starter) | Not Ranked : 0 score I can not wait to be back to road for testing!!!!!
| The Following 3 Users Say Thank You to RE-ACTIONENGSPEED3 For This Useful Post: |
![]() | | #36 | ![]() |
| Not Ranked : 0 score What was the fix for this? I'm bogging pretty hard using megaspool. LC is 6100 rpm and -20*. NLS is 8000 rpm.
| The Following User Says Thank You to Mazdazilla6 For This Useful Post: | Enki (04-26-2017) |
![]() | | #37 | ![]() |
| Not Ranked : 0 score We added the absolute rev limiters to allow >8000 RPM and exposed all shift related torque limiters. Adjusting the actuation point of the clutch pedal position sensor appears to help too. |
| The Following User Says Thank You to Steve@VersaTune For This Useful Post: | Mazdazilla6 (04-30-2017) |
![]() | | #38 | ![]() |
| Not Ranked : 0 score So you think it's a torque limiter causing the bog?
![]() | | #39 | ![]() |
| Not Ranked : 0 score If you're still in LC mode while the clutch is partially engaged but before the clutch pedal position switch is actuated, it will bog. This is most likely the issue. There is a thread somewhere discussing this. Drill a small hole in the CPP sensor and put a screw in it to allow adjustment of the actuation point. RE-ACTIONENGSPEED3 was also going > 8000 rpm which hit a separate rev limiter. We exposed that limiter as the absolute rev limiter. |
| The Following 2 Users Say Thank You to Steve@VersaTune For This Useful Post: | Enki (05-01-2017), Mazdazilla6 (04-30-2017) |
![]() | | #40 | ![]() |
| Not Ranked : 0 score I'll give it a shot and report back how it goes. Edit: Just to make sure I'm getting this straight. The reason for the screw is to make the car think the clutch is still down (engaged) so it won't shut off megaspool prematurely? @Steve@VersaTune;
__________________ Built 5862: Shootin For The Stars 2006 Mazdaspeed6 GT Crystal White Pearl #07141 Damond Motorsports = PS Cooler - RMM - PMM - OCC VersaTuner = Versatune Clutchmasters = 850 Street Twindisk Corksport = RDM - CBE - RSB - TMM Insert Turbine Tech = Forward Diff Mount - FMM CP-e = Exhaust Manifold - Injector Seals PTE = JB 5862 JMF = Intake Manifold w/Custom PI Kozmic = Downpipe - 6th Port - EGR Delete Forge = V2 BPV Tial = 44mm WG Autotech = HPFP Internals HTP = 4" Intake - Battery Tray Bilstein = B6 Shocks w/Eibach springs Grimmspeed = EBCS Technafit = SS Brake Lines - SS Clutch Line Enkei = EVOX GSR 18x8.5 +38 - NT03+M 17x9.5 +38 Custom = FMIC w/TR1035 - Shifter Cables - Shifter Bushings Last edited by Mazdazilla6; 04-30-2017 at 10:13 AM. |
| KR at WOT issue | 6262ms3 | MazdaSpeed 3/6 - ECU Computer Tuning | 4 | 04-06-2013 08:18 AM |
| DVD Nav Issue | djern | MazdaSpeed 3/6 - Car Audio & Electronics | 5 | 08-18-2012 12:22 AM |
| Report: Toyota confirms Lexus GX handling issue, hoping to isolate issue soon | Haltech | Automotive News | 3 | 04-17-2010 08:40 PM |
| :: new issue :: | :: Gusto :: | MazdaSpeed 6 - Engine, Transmission & Driveline | 10 | 09-14-2009 10:00 PM |
| CPE PNP Issue | Phantom | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 2 | 02-20-2009 03:01 PM |
