> VersaTune
Like Tree31Likes
 Old 12-02-2014, 06:23 AM   #1
Steve@VersaTune's Avatar
Posts: 432   (View Stats)
Steve@VersaTune is the leader of the worldSteve@VersaTune is the leader of the worldSteve@VersaTune is the leader of the worldSteve@VersaTune is the leader of the worldSteve@VersaTune is the leader of the worldSteve@VersaTune is the leader of the worldSteve@VersaTune is the leader of the worldSteve@VersaTune is the leader of the worldSteve@VersaTune is the leader of the worldSteve@VersaTune is the leader of the worldSteve@VersaTune is the leader of the world
Default Official VersaTuner Feature Request Thread
Please post your feature requests here. If your request is platform specific, please indicate what platform you are referring to. I will aggregate the requests up to this first post.
Code:
Platform        Request
All             High speed logging/greater number of concurrent PIDs
All             Hotkeys in Tune Editor for interpolation, write value, multiply, add, and subtract.
MS3/MS6         Rolling MegaSpool
MS3/MS6         Make axes scalable to 8500 or 9000 RPM
MS3/MS6         Timing retard traction control
All             4 Bar MAP Logging PID
Made sticky.
Steve
Lead Tuner
Last edited by Steve@VersaTune; 12-09-2014 at 01:31 PM. Reason: MSF Database - Automerged Doublepost
Steve@VersaTune is offline   Reply With Quote
The Following 15 Users Say Thank You to Steve@VersaTune For This Useful Post:
CWP_MS3 (12-03-2014), Deldran (12-03-2014), Easter Bunny (12-07-2014), Enki (12-07-2014), keridil (12-08-2014), kgb (03-24-2015), littleloogy (12-07-2014), Micha (12-04-2014), phate (12-02-2014), RE-ACTIONENGSPEED3 (12-09-2014), Roddiy (12-08-2014), shadesofgray19 (12-03-2014), SparkySparks (12-09-2014), SpeedRebirth (12-02-2014), TiGraySpeed6 (12-02-2014)
 Old 12-02-2014, 10:20 AM   #2
Eth Fiend
phate's Avatar
Posts: 6,947   (View Stats)
Steve, are there tables related to dbw response and/or decay in relation to APP position/rate of change? I'm not sure what they would actually be called, but something related to the hysteresis between APP input and actual throttle movement. When I moved to the MS6 from my MS3, it it seemed like there was a big difference in response even though they were tuned similarly, and how the revs hang seems different also. [Hopefully that makes sense.]
-06 MS6
-Corn fed 07 MS3 - Sold
 Old 12-02-2014, 01:12 PM   #3
Based on what I have seen, the APP - DBW smoothing is hard coded and not a table. Based on the code, MS6 should be more responsive than MS3. Is that your experience?
Steve
Lead Tuner
The Following 3 Users Say Thank You to Steve@VersaTune For This Useful Post:
phate (12-02-2014), Roddiy (12-08-2014), shadesofgray19 (12-03-2014)
 Old 12-02-2014, 01:54 PM   #4
Eth Fiend
phate's Avatar
Yep. Sometimes it's difficult to pinpoint exactly why they feel so different because of the differences in drivetrain and weight, but I notice the biggest difference in throttle close response. The MS6 can be pretty abrupt.
-06 MS6
 Old 12-02-2014, 02:40 PM   #5
Deldran's Avatar
Posts: 3,139   (View Stats)
Groans: 118
I have a couple Features requests.
1.) Keyboard shortcut keys in tune editor.
a.) h to horizontally interpolate
b.) v to vertically interpolate
c.) e to edit selected cells. As in if you have a group of cells selected you can just click e to write the same value into all of them
d.) m to multiply selected cells by whatever number you input.
Also where would you like bugs reported. in this thread or a separate one. Hope we are not overwhelming you
Damond Built Speed 6
 Old 12-03-2014, 12:07 PM   #6
Enki's Avatar
Posts: 7,541   (View Stats)
Enki has disabled reputation
Groans: 189
Ethanol content % (table lookup to FSG/Scalar, see cheat sheets) with advanced setting for manual configuration of FSG and scalar would be awesome.
Roddiy likes this.
phate (12-09-2014), Roddiy (12-08-2014), shadesofgray19 (12-03-2014)
 Old 12-07-2014, 05:55 PM   #7
Enki's Avatar
Groans: 189
Keyboard shortcut on Dashboard view for logging: Space bar to start/stop recording.
Is there any way to improve the PID rate for logging?
 Old 12-07-2014, 06:00 PM   #8
Deldran's Avatar
Groans: 118
Enki, you can already use space bar to start and stop recording
 Old 12-07-2014, 06:04 PM   #9
Enki's Avatar
Groans: 189
Really? Didn't seem to work for me.
 Old 12-07-2014, 06:16 PM   #10
Enter key toggles logging on/off too.
The pane with the active PIDs and the log data needs to be the focused pane for spacebar and enter to work. Click anywhere in the logging pane to make it the focused pane. I think by default, the master PID list is the active pane.
The PID rate is limited by the ECU. We may add high speed logging in the future. It's on the to-do list.
Steve
Lead Tuner
The Following User Says Thank You to Steve@VersaTune For This Useful Post:
Enki (12-07-2014)
 Old 12-07-2014, 06:21 PM   #11
Deldran's Avatar
Groans: 118
Steve I'm note sure if the limitation is only ECU. the AP had much more resolution. I am not sure how it's resolution on the 6 was. Maybe @phate; can chime in on the difference between logging resolution for the 6.
I will say it really needs to be higher, I would but that toward the top of the list personally
Enki (12-07-2014)
 Old 12-07-2014, 06:51 PM   #12
Enki's Avatar
Groans: 189
Thanks, I'll give this a shot next time I'm out.
I agree, the difference between my AP logs and my VT logs is...well, massive. See attached.
Edit: For the TLDR inclined:
Versatune:
11 PIDs
22.018 seconds
103 rows
4.677 rows per second
Accessport:
17 PIDs
12.336 seconds
104 rows
8.430 rows per second @ +54% PIDs per row
keridil likes this.
 Old 12-07-2014, 06:54 PM   #13
High speed logging with AP is implemented with custom code. The stock logging is limited by the ECU. It's on our list. Please see the first post.
Steve
Lead Tuner
The Following 2 Users Say Thank You to Steve@VersaTune For This Useful Post:
keridil (12-08-2014), Micha (12-10-2014)
 Old 12-07-2014, 06:55 PM   #14
Eth Fiend
phate's Avatar
VT's a little bit slower, but not by much. Between 6 and 7 rows per second in VT, compared to the AP's ~8 rows per second. [This is in reference to the MS6 and my AP V2B.]
Edit: Remove all the logging parameters you don't really need to increase resolution.
-06 MS6
 Old 12-07-2014, 08:20 PM   #15
Putin 2.3T's Avatar
Posts: 1,040   (View Stats)
Rolling anti-lag. Now.
2011 Mazdaspeed 3 [Sold]
 Old 12-08-2014, 12:05 AM   #16
Please elaborate.
Steve
Lead Tuner
 Old 12-08-2014, 12:08 AM   #17
Enki's Avatar
Groans: 189
Please elaborate.
IF brake = depressed
AND Accel Pedal Position > 90% (configurable)
ENABLE Launch Control
...If that makes sense.
Roddiy (12-08-2014)
 Old 12-08-2014, 12:35 AM   #18
OK. Sort of like Launch Control and NLS, but with the brake pedal in stead of the clutch pedal?
Steve
Lead Tuner
 Old 12-08-2014, 12:52 AM   #19
Enki's Avatar
Groans: 189
Basically brake boosting without the brake; just some sort of trigger. If a slight touch on the clutch can be used, that might work as well.
I'm not entirely sure how it can be done, and that was just an example.
If you need a test subject for this, I'm game.
 Old 12-08-2014, 01:04 AM   #20
Define the conditions under which you want retard applied.
APP > 98%
Brake = on
Any others?
You could probably use NLS to accomplish this. The clutch pedal sensor triggers long before the clutch disengages. I often get hit by this with my sloppy clutch work when I mash the gas before I finish letting the clutch out.
Steve
Lead Tuner
Enki (12-08-2014)
 Old 12-08-2014, 01:10 AM   #21
Enki's Avatar
Groans: 189
How should I test this? Set NLS to MegaSpool = True + RPM = 3000?
 Old 12-08-2014, 01:21 AM   #22
You can probably leave the NLS limiter at whatever RPM you want to hit your next gear at.
I assume you're using this at lower RPMs where the turbo is not prone to rapid spooling. If the clutch is engaged, you won't hit the limiter in any hurry.
Steve
Lead Tuner
Enki (12-08-2014)
 Old 12-08-2014, 01:36 AM   #23
RE-ACTIONENGSPEED3's Avatar
Posts: 401   (View Stats)
APP > 98%
Brake = on
Any others?
Maybe it can starts by a button and app>98 (thats the way syvecs ecu works with rolling launch) and when you realesa the button the car just take off ...
Also it will be nice to have pid with injectors flow % and i think it is time to make the scalars up to 8500rpm...
2008 speed3
True red.
Pte 6466 & AWD Mode on !!!!
 Old 12-08-2014, 11:02 AM   #24
Putin 2.3T's Avatar
Please elaborate.
Yummy!
Sounds wicked from the outside.
The Following User Says Thank You to Putin 2.3T For This Useful Post:
Roddiy (12-08-2014)
 Old 12-08-2014, 11:06 AM   #25
OK. So the use case is racing from a roll. I get it.
Steve
Lead Tuner
Putin 2.3T (12-09-2014), RE-ACTIONENGSPEED3 (12-08-2014)
 Old 12-08-2014, 11:08 AM   #26
Enki's Avatar
Groans: 189
I think he means how it works.
@Steve@VersaTune; is there a clutch position sensor thats fairly sensitive? I know the clutch has to be depressed fully for the car to start, but is there a way to have it see if its just barely depressed like when the cruise control kicks off to act as the trigger? That would probably be best, as I'm not sure how many people want to do antilag followed by a clutch dump.
 Old 12-08-2014, 11:10 AM   #27
Data log the clutch pedal position with the key on and engine off and see where it triggers.
Steve
Lead Tuner
Enki (12-08-2014)
 Old 12-08-2014, 11:21 AM   #28
Enki's Avatar
Groans: 189
Will do. *Adds it to list*
 Old 12-08-2014, 12:49 PM   #29
Eth Fiend
phate's Avatar
Steve, is there any way to implement functions based on the rate of change of certain parameters? As an example - rate of change of RPM could pull timing or BCS DC as it deviated from expected (a type of traction control, in other words).
-06 MS6
RE-ACTIONENGSPEED3 (12-08-2014), Roddiy (12-08-2014)
 Old 12-08-2014, 12:57 PM   #30
That could be done. In fact that's how older MegaSquirt software implemented basic traction control.
Steve
Lead Tuner
The Following 5 Users Say Thank You to Steve@VersaTune For This Useful Post:
Enki (12-08-2014), phate (12-08-2014), RE-ACTIONENGSPEED3 (12-08-2014), Roddiy (12-08-2014), TiGraySpeed6 (12-08-2014)
 Old 12-08-2014, 04:19 PM   #31
Enki's Avatar
Groans: 189
Pull WOT load when HPFP pressure drops.
Engine saver v1.0
Roddiy likes this.
The Following 6 Users Say Thank You to Enki For This Useful Post:
JSmith (12-09-2014), Micha (12-10-2014), phate (12-08-2014), Putin 2.3T (12-09-2014), Roddiy (12-08-2014), TiGraySpeed6 (12-08-2014)
 Old 12-09-2014, 07:15 AM   #32
one more request , add a log pid for the bosch 4 bar map sensor...
2008 speed3
True red.
 Old 12-09-2014, 07:19 AM   #33
What are the scaling and offset values?
Steve
Lead Tuner
 Old 12-09-2014, 07:36 AM   #34
I pm`ed you...
2008 speed3
True red.
 Old 12-09-2014, 09:30 AM   #35
Enki's Avatar
Groans: 189
Feels like it's a binary on/off type of sensor and it hits on right as the clutch would be near disengagement...making it not ideal for rolling LC.
 Old 12-09-2014, 11:37 AM   #36
I do not know if it is possible to use a button from the steering wheel...
2008 speed3
True red.
 Old 12-09-2014, 11:46 AM   #37
If the button goes direct to the ECU, it should be possible.
Steve
Lead Tuner
 Old 12-09-2014, 11:51 AM   #38
Putin 2.3T's Avatar
Well MoTEC and the ProEFI live both use the cruise control button/stock. But I don't know if that's possible with the MS3.
 Old 12-09-2014, 11:53 AM   #39
Eth Fiend
phate's Avatar
How high do you currently rev?
-06 MS6
 Old 12-09-2014, 11:58 AM   #40
Enki's Avatar
Groans: 189
If it's going to be increased, might as well go to 10k.
SpeedRebirth (12-09-2014)
The Official AP v3 Landscape Request Thread hnda etr Cobb Tuning 41 03-18-2014 01:19 PM
atr feature request : dual monitor support someguyondrugs
Cobb ATR Support
7 11-26-2013 02:04 PM
Page generated in 0.60568 seconds with 26 queries
