> VersaTune
Like Tree31Likes
 Old 03-23-2015, 05:18 AM   #1
Mfinlay04's Avatar
Posts: 827   (View Stats)
Originally Posted by Steve@VersaTune View Post
From the main screen, go to settings, Edit Tune Customizer Profile, then in the Tune Customizer window, go to the Disabling DTCs tab, then hit the Advanced button. All available DTCs on the vehicle should be listed there. If P2096 is not on the list there, and the ECU is throwing that code, let me know.
here is a screenshot of the CEL in VT just for verificication too
2006 MS6 Titanium Grey
Tuned with
 Old 03-06-2015, 10:23 AM   #2
Enki's Avatar
Posts: 7,541   (View Stats)
Enki has disabled reputation
Groans: 189
The ECU is tied in to the cruise control system, I'm sure (these cars are drive by wire, after all). Maybe holding down the cancel button or something is an option.
RE-ACTIONENGSPEED3 (03-07-2015)
 Old 03-11-2015, 01:31 AM   #3
Enki's Avatar
Groans: 189
I think you can just disable the codes for the secondary O2 and that should do it.
 Old 03-11-2015, 05:52 AM   #4
Deldran's Avatar
Posts: 3,139   (View Stats)
Groans: 118
I think this has been brought up, but any way to increase logging resolution. I know turning more Parameters of helps, but it still seems like the resolution of the AP is higher with similar numbers of parameters logged
Damond Built Speed 6
 Old 03-11-2015, 06:18 AM   #5
Steve@VersaTune's Avatar
Posts: 432   (View Stats)
Steve@VersaTune is the leader of the worldSteve@VersaTune is the leader of the worldSteve@VersaTune is the leader of the worldSteve@VersaTune is the leader of the worldSteve@VersaTune is the leader of the worldSteve@VersaTune is the leader of the worldSteve@VersaTune is the leader of the worldSteve@VersaTune is the leader of the worldSteve@VersaTune is the leader of the worldSteve@VersaTune is the leader of the worldSteve@VersaTune is the leader of the world
High speed logging is definitely on the list.
Mfinlay04 and SpeedRebirth like this.
Steve
Lead Tuner
Steve@VersaTune is offline   Reply With Quote
The Following 2 Users Say Thank You to Steve@VersaTune For This Useful Post:
Mfinlay04 (03-12-2015), SpeedRebirth (03-11-2015)
 Old 03-23-2015, 05:20 AM   #6
There are some DTCS that are handled differently in the rom. We are working on masking them.
Mfinlay04 likes this.
Steve
Lead Tuner
Mfinlay04 (04-07-2015), SpeedRebirth (03-23-2015)
 Old 03-24-2015, 09:41 AM   #7
Polish_Eagle's Avatar
Posts: 408   (View Stats)
How exactly do the Warmup Enrichment tables work? The reason I ask is because I set the decrement for them to 0 (up to 60 F) so it won't remove enrichment until my car is at 60 degrees fahrenheit (I run lean AFR).
Thing that has me confused is that at idle it works fine and the AFR is richer to where I set it, but as soon as I start driving the AFR targets my values from the closed loop table (no enrichment applied). Is there anything I can do to make it target the closed loop value and then apply the given enrichment at all times until the required temperature is reached?
 Old 03-24-2015, 11:49 AM   #8
That would require custom ECU code to change the logic.
Steve
Lead Tuner
 Old 03-24-2015, 12:32 PM   #9
So are the enrichment tables meant only for idle? I thought this was a global percentage of fuel increase until the decrement removes all the additional fueling.
 Old 03-24-2015, 12:42 PM   #10
EmPeEs6's Avatar
Posts: 642   (View Stats)
EmPeEs6 is the leader of the worldEmPeEs6 is the leader of the worldEmPeEs6 is the leader of the worldEmPeEs6 is the leader of the worldEmPeEs6 is the leader of the worldEmPeEs6 is the leader of the worldEmPeEs6 is the leader of the worldEmPeEs6 is the leader of the worldEmPeEs6 is the leader of the worldEmPeEs6 is the leader of the worldEmPeEs6 is the leader of the world
So, where is the great (announced) benefit of these tables if they only come into play at idle (which is less than 1% of all driving conditions)?!?
Mods: BNR S4, 3" Ray cb, CP-E catted dp, CS 3" intake, CP-E tmic, D06-wmi, itv22/NGK IX plugs, Forge bov, hpfp-upgrade, JBR ebcs, 3 bar map sensor, egr block off kit, ACT 6 pad clutch with SL flywheel, Wiseco oem compression pistons, Manley H-Beam connecting rods, reworked head, CP-E SafeSeal injector seals, no E85, Cosworth thermostat
EmPeEs6 is offline   Reply With Quote
 Old 03-24-2015, 12:49 PM   #11
Enki's Avatar
Groans: 189
It makes starting cars on full corn MUCH easier.
Mfinlay04 (04-07-2015), phate (03-24-2015)
 Old 03-24-2015, 12:57 PM   #12
EmPeEs6's Avatar
Pity, since I could need some enrichment during warmup phase for my E-mix, too...
Gesendet von meinem HUAWEI Y300-0100 mit Tapatalk
 Old 03-24-2015, 12:59 PM   #13
EmPeEs6's Avatar
Since my engine runs noticeably unsmooth during the first few minutes but not directly after startup, when enrichment is max.
 Old 03-24-2015, 12:59 PM   #14
Eth Fiend
phate's Avatar
Posts: 6,947   (View Stats)
Why?
-06 MS6
-Corn fed 07 MS3 - Sold
 Old 03-24-2015, 01:56 PM   #15
I personally find when running lean cruise my car runs really rough until the engine coolant temperature reaches approximately 55 - 60 degrees Fahrenheit, that's why I was hoping I could apply the warm up enrichment values to my requested AFR until the car is warmed up to the right temp.
 Old 03-24-2015, 02:03 PM   #16
These tables are meant to be used for cranking and afterstart until the chambers get warmed up enough to get good atomization. It's not for long term warm-up running. Once closed loop operation starts, trims are based on O2 sensor feedback.
Steve
Lead Tuner
The Following 4 Users Say Thank You to Steve@VersaTune For This Useful Post:
Enki (03-24-2015), phate (03-24-2015), Polish_Eagle (03-24-2015), RE-ACTIONENGSPEED3 (03-24-2015)
 Old 03-24-2015, 02:55 PM   #17
Enki's Avatar
Groans: 189
^^^ This is what I thought it was for too, not warming up the car faster. Yeah, it's annoying driving the car around when it sputters like that, but it also shouldn't take long to get to a temperature where it starts to run good again.
 Old 03-24-2015, 05:22 PM   #18
Maybe in Arizona it doesn't take too long, but during cold Canadian winters it can be a fare amount of time.. Lol.
Thanks for clearing that up Steve, I guess I'll stop with the madness..
 Old 03-24-2015, 05:30 PM   #19
Enki's Avatar
Groans: 189
Maybe leave the heater off for a little while until the car heats up? Should warm up faster that way.
 Old 03-24-2015, 07:34 PM   #20
I use the auto climate control and it does that already
 Old 03-25-2015, 09:35 AM   #21
Jarods7920's Avatar
Posts: 1,415   (View Stats)
Steve i think you and i have discussed before, but what about actual AFR and PSI values as apposed to KPA and lambda?
Also when i was playing with my tune last night, i noticed something about boost based logic in there but wasnt used. Whats the deal with that?
 Old 03-25-2015, 11:38 AM   #22
RE-ACTIONENGSPEED3's Avatar
Posts: 401   (View Stats)
They have found some tables for boost based tuning and they just have them avaliable(for now it is useless unless they make an option for boost logik tuning)
2008 speed3
True red.
Pte 6466 & AWD Mode on !!!!
 Old 03-25-2015, 11:53 AM   #23
The ECU has native boost tuning capability. It is disabled by default and load based tuning is used. Some people prefer the simplicity of boost tuning. If you fully understand how load based tuning works, it is very powerful. We exposed the boost tuning tables for reference. They are not used in any way when the ECU is in load based tuning mode.
Steve
Lead Tuner
kgb (03-25-2015), Nliiitend1 (03-26-2015), RE-ACTIONENGSPEED3 (03-25-2015), SpeedRebirth (03-26-2015)
 Old 03-25-2015, 12:05 PM   #24
Enki's Avatar
Groans: 189
Personally I prefer load based tuning; it's way more reliable and consistent.
The Following 5 Users Say Thank You to Enki For This Useful Post:
Mfinlay04 (04-07-2015), Nliiitend1 (03-26-2015), RE-ACTIONENGSPEED3 (03-25-2015), SarcasticOne (03-25-2015), SpeedRebirth (03-26-2015)
 Old 03-26-2015, 07:04 AM   #25
Jarods7920's Avatar
I have no issues with load tuning at this time, but i was just curious as to what it was is all. They arent set to any relevant values right now. More just informational.
 Old 04-01-2015, 03:00 PM   #26
@Steve@VersaTune; @Ugnius@VersaTune;
Any estimation about when the Versatuner 2.0 will be released?
p.s. I really need the rolling megaspool & the revlimit above 8000rpm...
2008 speed3
True red.
The Following User Says Thank You to RE-ACTIONENGSPEED3 For This Useful Post:
Enki (04-01-2015)
 Old 04-02-2015, 08:08 AM   #27
torquemaniac's Avatar
Posts: 733   (View Stats)
...and I need access to the transmission tables
2011 CX-7 AWD 2.3 turbo
 Old 04-24-2015, 05:22 PM   #28
SpeedRebirth's Avatar
Posts: 685   (View Stats)
Groans: 33
Tested my win 8.1 tablet for the first time today. Works good so far.
Encountered a small issue though. When trying to save a log with the preselected filename it fails because of the timestamp includes a : between hour/minutes/seconds. Get a Invalid filename error
Example: 22:55:35
Mazdaspeed6 -06
Tuned with by Alex@Stratified
290 AWHP / K04
370 AWHP / GTX3076 @ 23 psi
Enki (04-24-2015)
 Old 04-24-2015, 07:41 PM   #29
Enki's Avatar
Groans: 189
Example: 22:55:35
It also fails because of slashes in the file name. Bit of a pain.
How long until the next update, @Steve@VersaTune;?
 Old 05-03-2015, 08:44 PM   #30
Mfinlay04's Avatar
-Anyway to incorporate a way to see what tune is currently flashed on the car? Or perhaps adding a line on the individual map with a flash date.
More than once I've mad revisions to a map in the middle of the night and then forgot to flash it the next time i went to my car. And then days/weeks go by and then I can't remember which revision is actually on the car. Shit I'm getting too old.
-Also, I've noticed when exporting a datalog to CSV it seems to cut off some of the parameters. I'd have to actually look and count but for example there are 10 slots to live datalog but when exporting them to CSV form it only exports 8/10.
@Steve@VersaTune;
Tuned with
 Old 05-08-2015, 12:00 AM   #31
Enki's Avatar
Groans: 189
Originally Posted by Mfinlay04 View Post
...I've noticed when exporting a datalog to CSV it seems to cut off some of the parameters. I'd have to actually look and count but for example there are 10 slots to live datalog but when exporting them to CSV form it only exports 8/10.
I took a bunch of short logs today and did not have this issue with 12 parameters.
Mfinlay04 (05-08-2015)
 Old 05-03-2015, 08:53 PM   #32
Enki's Avatar
Groans: 189
I've only been monitoring 8 but I'll try 10 tomorrow and see if I can replicate.
 Old 05-03-2015, 10:46 PM   #33
Mfinlay04's Avatar
I don't remember the exact # without doing it myself. But if your going to test it load up as many parameters you can and see if they all export to CSV.
Tuned with
The Following User Says Thank You to Mfinlay04 For This Useful Post:
Enki (05-03-2015)
 Old 05-03-2015, 10:48 PM   #34
Enki's Avatar
Groans: 189
I vaguely recall not being able to monitor more than 8...
 Old 05-04-2015, 03:43 AM   #35
Groans: 33
12 is max number of logged/monitored parameters
15 would be much better so we could include coolant temp and a few other usefull parameters
Mazdaspeed6 -06
290 AWHP / K04
The Following 2 Users Say Thank You to SpeedRebirth For This Useful Post:
Enki (05-04-2015), Mfinlay04 (05-08-2015)
 Old 05-04-2015, 10:20 AM   #36
Enki's Avatar
Groans: 189
Maybe I went with 8 due to logging frequency. Don't remember
 Old 05-07-2015, 06:04 PM   #37
Eth Fiend
phate's Avatar
Not sure if it's been requested yet - Would it be possible to log the steering angle?
-06 MS6
aviator79 (03-04-2016), Enki (05-07-2015), Micha (08-15-2015)
 Old 05-09-2015, 02:36 AM   #38
Enki's Avatar
Groans: 189
Confirmed not an issue for me.
Attached is a significantly longer log; wholly untainted.
 Old 05-12-2015, 02:46 PM   #39
Posts: 2,826   (View Stats)
Question: Can anyone help me generate a logcfg.txt file for gen 1 MS3? It is the logging file needed to run Tactrix Open Port 2.0 on-board stand alone SD card data logging.
I am data logging my gen 1 MS3 with a laptop software program called ScanXL Pro with Mazda PIDs. It has very low resolution via USB dongle.
I recently purchased a Tactrix Open Port 2.0 which operates with a J2534 interface and has an internal SD card for stand alone direct data logging that can then be later downloaded as a complete csv file. No conversion needed.
To activate the data logging it has to have a logcfg.txt file loaded on the SD card.
I am ignorant of how to write the script for that file to log our engine parameters.
I did find a file out there on the 'net, where someone developed a log file for a N/A Mazda. It is attached. It is configured to start logging at a certain pedal position reflective of WOT and stop when the pedal is lifted.
The file runs, but most of the data other than time, rpm, LTFT and AFR is either irrelevant or is reported inaccurately from our ECU, or is reported in metric units.
I'm looking for someone who can write a logcfg.txt file that would activate the particular corresponding PIDs for our cars.
Ideally, I'd like to have a logcfg.txt file that would log the parameters that would work with Virtual Dyno.
I don't know if anyone here uses Tactrix Open Port 2.0 for direct SD card logging, but it is very fast and convenient, and seems to be supported by VersaTune.
If anyone can offer assistance, it would be appreciated.
phate (05-12-2015)
 Old 05-12-2015, 03:16 PM   #40
Eth Fiend
phate's Avatar
If available, a complete list of parameter names would be more useful. That looks like a pretty simple config file. Sweet find. Can you post one of the data logs that you took with it?
-06 MS6
The Official AP v3 Landscape Request Thread hnda etr Cobb Tuning 41 03-18-2014 01:19 PM
atr feature request : dual monitor support someguyondrugs
Cobb ATR Support
7 11-26-2013 02:04 PM
Page generated in 0.69055 seconds with 32 queries
