> VersaTune
Like Tree31Likes
 Old 02-03-2016, 06:51 PM   #161
Eth Fiend
phate's Avatar
Posts: 6,947   (View Stats)
Thanks, lol. I didn't try real hard, the floating mode is awesome.
-06 MS6
-Corn fed 07 MS3 - Sold
Micha (02-05-2016)
 Old 02-09-2016, 10:35 AM   #162
aviator79's Avatar
Posts: 3,934   (View Stats)
Planning to make an android app?
 Old 02-11-2016, 07:01 AM   #163
Ugnius@VersaTune's Avatar
Posts: 41   (View Stats)
Ugnius@VersaTune is the leader of the worldUgnius@VersaTune is the leader of the worldUgnius@VersaTune is the leader of the worldUgnius@VersaTune is the leader of the worldUgnius@VersaTune is the leader of the worldUgnius@VersaTune is the leader of the worldUgnius@VersaTune is the leader of the worldUgnius@VersaTune is the leader of the worldUgnius@VersaTune is the leader of the worldUgnius@VersaTune is the leader of the worldUgnius@VersaTune is the leader of the world
This is in our plans.
Ugnius@VersaTune is offline   Reply With Quote
The Following 4 Users Say Thank You to Ugnius@VersaTune For This Useful Post:
aviator79 (02-11-2016), Enki (02-11-2016), Mazdazilla6 (03-03-2016), SpeedRebirth (02-11-2016)
 Old 02-11-2016, 07:12 AM   #164
aviator79's Avatar
I was just kidding but that would be sweet as I just bought a chrombook for garage computer but then realized I could not use it for car.
 Old 03-03-2016, 04:50 PM   #165
Mazdazilla6's Avatar
Posts: 3,657   (View Stats)
I'm so in for an Android app. Gives me an excuse to buy a tablet and run MHD on my 135i too lol.
So there is specific fuel gravity scalars already?
What about real time graphing (historgrams) for monitoring/logging?
VersaTuner = Versatune
PTE = JB 5862
Forge = V2 BPV
Tial = 44mm WG
Autotech = HPFP Internals
Grimmspeed = EBCS
 Old 03-03-2016, 06:39 PM   #166
Enki's Avatar
Posts: 7,541   (View Stats)
Enki has disabled reputation
Groans: 189
Yes, and a built in calculator for it too (it's different from AP).
 Old 03-03-2016, 07:16 PM   #167
I was reading around a bit. So if you change the FSG you don't have to change the MAF curve but you do have to change your load targets?
PTE = JB 5862
Forge = V2 BPV
Tial = 44mm WG
Grimmspeed = EBCS
 Old 03-03-2016, 07:19 PM   #168
Steve@VersaTune's Avatar
Posts: 432   (View Stats)
Steve@VersaTune is the leader of the worldSteve@VersaTune is the leader of the worldSteve@VersaTune is the leader of the worldSteve@VersaTune is the leader of the worldSteve@VersaTune is the leader of the worldSteve@VersaTune is the leader of the worldSteve@VersaTune is the leader of the worldSteve@VersaTune is the leader of the worldSteve@VersaTune is the leader of the worldSteve@VersaTune is the leader of the worldSteve@VersaTune is the leader of the world
There is no reason to run anything but accurate maf scaling and load targets with e85 tuning. Modifying the FSG value based on the e85 calculator output compensates for the e85 specific gravity and afr difference.
Steve
Lead Tuner
Steve@VersaTune is offline   Reply With Quote
The Following 3 Users Say Thank You to Steve@VersaTune For This Useful Post:
Enki (03-03-2016), Mazdazilla6 (03-03-2016), SpeedRebirth (03-03-2016)
 Old 03-03-2016, 07:40 PM   #169
So it's as simple as changing the FSG and then tuning as I normally would?
PTE = JB 5862
Forge = V2 BPV
Tial = 44mm WG
Grimmspeed = EBCS
 Old 03-03-2016, 07:54 PM   #170
edit Correction: You should change AFR targets a bit to compensate for the different ideal max load AFRs.
VersaTuner e85 tuning guide: https://www.versatuner.com/E85TuningGuide.aspx
Mazdazilla6 likes this.
Steve
Lead Tuner
Enki (03-03-2016), Mazdazilla6 (03-03-2016), mituc (03-03-2016)
 Old 03-31-2016, 01:59 PM   #171
flylike2kites's Avatar
Posts: 64   (View Stats)
flylike2kites has much to be proud offlylike2kites has much to be proud offlylike2kites has much to be proud offlylike2kites has much to be proud offlylike2kites has much to be proud offlylike2kites has much to be proud offlylike2kites has much to be proud offlylike2kites has much to be proud offlylike2kites has much to be proud of
-- Live Tuning/Auto Tune (It would be great to be able to make real time changes on the fly. Instead of flashing the entire tune, you can just flash a spark revision without wiping out STFT and/or LTFT data. Or, is it possible to do a quick flash which will only update the cells of the tune which has been revised, or must the entire tune be reflashed each time?)
-- Conditional Statements for Automatic Data-logging (If rpm is above 2500rpm, and load is above 1.025, then datalog the requested parameters until x happens, the load drops below a certain point, or the timer reaches x amount of seconds.)
-- It would be nice if you could read and enter values in kpa instead of load, or 14.68 instead of 1 lambda.
-- It would be more convenient if you could just select your datalog and then export it to excel instead of having to load it just to click the button.
-- It would be great if you could incorporate an Undo button that way if you screw up, you can press the undo button and it'll go back to the last value that you had. It would be different from the restore button which goes back to the default values of the tune.
-- It would be awesome if you could reconfigure the datalogging section to have different skins (i.e. gauges, bars, ect) which move around in real time.
I apologize if anything that I've suggested would be unrealistic. I spent many years tuning from scratch via MegaSquirt on a forgotten platform without any sort of help from vendors.
torquemaniac likes this.
flylike2kites is offline   Reply With Quote
The Following 4 Users Say Thank You to flylike2kites For This Useful Post:
aviator79 (04-01-2016), Jarods7920 (03-31-2016), torquemaniac (03-31-2016), Ugnius@VersaTune (04-01-2016)
 Old 03-31-2016, 03:18 PM   #172
Enki's Avatar
Groans: 189
I think the only thing unrealistic would be the partial flash; I'm probably wrong on this but I think the ECU uses a hash of some sort when powering up to make sure it isn't corrupt before running, which means any changes would alter the match to the hash and thus make it not viable if that makes sense.
 Old 03-31-2016, 03:36 PM   #173
Makes perfect sense, Enki. I didn't think about the possibility of the ECU having a checksum for error detection.
Thank you.
Edit: I was originally under the impression that the ECU's RAM could be rewritten and specific data could be copied over from there.
Meh, I'll leave it to the pros.
Live tuning/Auto-Tune would be a Game Changer for sure.
 Old 03-31-2016, 04:03 PM   #174
Enki's Avatar
Groans: 189
It already flashes faster than AP.
 Old 03-31-2016, 04:11 PM   #175
TiGraySpeed6's Avatar
Posts: 3,981   (View Stats)
You know what feature I want to see- A bounty program on AccessPorts...
I'd switch over in a heartbeat if the cost was easier to deal with. I'd send you my AP hardware if you gave me a discount for making the transition.
Stupid, I know- your customer service and attention to the platform is beyond excellent. Your product is great. The results speak for themselves.
For me, and I suspect many others, the only thing preventing making the jump is simply financial...
340hp / 371tq
meicalnissyen (10-08-2016)
 Old 03-31-2016, 04:32 PM   #176
nindoja's Avatar
Posts: 2,395   (View Stats)
If this is the case, no reason VT couldn't recalculate the hash (it would have to already have the code to do so) and write 1) the table or specific changes and then 2) the new hash.
True Red 2009 MS3
Tune: hypnotic tuned
Critical Stats:
// 305whp/352tq
 Old 03-31-2016, 04:38 PM   #177
Enki's Avatar
Groans: 189
Unless it's encrytped WITH the hash. Then you have to reflash the entire thing anyways.
 Old 03-31-2016, 04:49 PM   #178
This is true, but MegaSquirt spoils you. You're going MS3 Pro with your project. 1 minute is forever in comparison to a few milliseconds.
 Old 03-31-2016, 05:10 PM   #179
nindoja's Avatar
Fair enough. I'm too lazy to go figure out what's actually happening, but you have a point.
True Red 2009 MS3
Critical Stats:
// 305whp/352tq
 Old 03-31-2016, 10:02 PM   #180
jdmage_mx5's Avatar
Posts: 1,877   (View Stats)
My biggest gripe here lately is the data logging text. I'm using an HP stream most of the time but even on my Lenovo Yoga Pro 3 the min and max values are so small and thin it's hard for my old eyes to read. I'd like to see these bold and all of them (even the current data numbers) just a touch bigger or more predominant.
 Old 04-01-2016, 04:57 AM   #181
Thank you for the great ideas, some of them are already on our to-do list.
As for live tuning, this is problematic, because the flash memory of the ECU can only be erased in sectors and those sectors are quite big (up to 256 KB, depending on MCU). So you would still have to reflash a significant portion of the ROM. Add the overhead of setting up the communications and putting the ECU into reflash mode and the gains are not that big. Another problem is that Mazda OEM reflash protocols do not allow specifying the memory area to be erased and always erase everything. So implementing something like that would require significant effort from our side and a lot of custom code in the ECU.
The way they do it when calibrating the ECU in the test cell - they have special development ECUs with lots of RAM and keep all the table data in RAM. That way it can be altered in near real time. Production ECUs, on the other hand, have very small RAM sizes and you could barely fit more than a couple of tables in the free space there.
What concerns measurement units, there is no direct conversion between kPa (manifold pressure) and engine load. Load is calculated as the actual air mass per intake stroke divided by maximum air mass per intake stroke at WOT at 100% volumetric efficiency. Relationship between air mass and pressure depends on many factors.
AFRs instead of lambda are possible, we'll probably add that option in the future, but with the possibility to customize your stoich AFR (some people run ethanol blends that have different stoich AFR).
Ugnius
Lead Developer
The Following 7 Users Say Thank You to Ugnius@VersaTune For This Useful Post:
Enki (04-01-2016), Mazdazilla6 (04-01-2016), meicalnissyen (10-08-2016), Nliiitend1 (04-07-2016), RE-ACTIONENGSPEED3 (10-17-2016), SpeedRebirth (04-02-2016), torquemaniac (04-01-2016)
 Old 04-01-2016, 07:10 AM   #182
cshunter likes this.
 Old 04-01-2016, 05:52 PM   #183
Enki's Avatar
Groans: 189
Nope, not unless you can write good enough code to do all the stock functions on the can bus.
Code Monkey (04-04-2016)
 Old 04-01-2016, 07:54 PM   #184
What number are you looking for? We could do some sort of massive group buy.
nindoja and Mazdazilla6 like this.
Steve
Lead Tuner
Enki (04-01-2016), Mazdazilla6 (04-02-2016), SpeedRebirth (04-02-2016)
 Old 04-02-2016, 11:33 AM   #185
In for GB
PTE = JB 5862
Forge = V2 BPV
Tial = 44mm WG
Grimmspeed = EBCS
 Old 04-02-2016, 03:46 PM   #186
Lol, there would be a group buy a month after I paid full price for the software & cable.
No worries. It's worth every penny. Very happy that I bought VersaTune over Accessport ATR
On a side note, do you guys have recommendation for a lower profile cable for datalogging? I have big feet [Size 12.5], so when I datalog while driving, I hit the cable when I step on the brakes. It's not a big deal, but half an inch would be great!
The Following User Says Thank You to flylike2kites For This Useful Post:
osubeaver (04-02-2016)
 Old 04-02-2016, 03:49 PM   #187
You can get an extension cable on ebay for a few bucks. 90* angle cables too. You can also log with any ELM327 bluetooth just at a lower pid rate.
Steve
Lead Tuner
The Following User Says Thank You to Steve@VersaTune For This Useful Post:
 Old 04-02-2016, 04:45 PM   #188
SpeedRebirth's Avatar
Posts: 685   (View Stats)
Groans: 33
If you have a 6 you can just move the OBDII port to the right and zip tie it there and run the cable along the center console to the logging device
Mazdaspeed6 -06
Tuned with by Alex@Stratified
290 AWHP / K04
370 AWHP / GTX3076 @ 23 psi
 Old 04-02-2016, 06:02 PM   #189
Enki's Avatar
Groans: 189
I pulled the bottom part of my dash out and cut a hole in the back where the plug is, ran the USB cable through there and a hole in the gauge cluster shroud with a grommet. I also use a 90 degree USB adapter to keep it all low profile, as the tablet mounts to my dash as well.
 Old 04-04-2016, 09:36 PM   #190
Eth Fiend
phate's Avatar
Minor issue:
For the data log naming convention, can you change it to a 24 hour format that uses a yyyy_mm_dd_hh_min_sec convention? When you export them, the 12-hour format doesn't arrange in chronological order when you shift from 12 o'clock logs to 1 o'clock logs.
-06 MS6
Enki (04-04-2016)
 Old 04-19-2016, 09:16 PM   #191
I'm almost ready to make the jump, the biggest thing holding me back right now is being too preemptive and missing a GB. Is that still a possibility?
PTE = JB 5862
Forge = V2 BPV
Tial = 44mm WG
Grimmspeed = EBCS
 Old 04-19-2016, 09:46 PM   #192
GB is always an option. We have a standing GB policy 5-9 buyers = $50 off, 10+ = $100 off.
Steve
Lead Tuner
The Following 9 Users Say Thank You to Steve@VersaTune For This Useful Post:
Enki (04-19-2016), Mazdazilla6 (04-19-2016), Micha (04-22-2016), nindoja (04-20-2016), Nliiitend1 (04-22-2016), phate (04-19-2016), SofaKingAwesome (04-20-2016), SpeedRebirth (04-19-2016), TiGraySpeed6 (04-22-2016)
 Old 04-19-2016, 09:53 PM   #193
Well let's get this thing going! Copy and add yourself if interested.
1. Mazdazilla6
PTE = JB 5862
Forge = V2 BPV
Tial = 44mm WG
Grimmspeed = EBCS
Enki (04-19-2016), TiGraySpeed6 (04-22-2016)
 Old 04-20-2016, 08:22 AM   #194
nindoja's Avatar
1. Mazdazilla6
1. Mazdazilla6
2. nindoja
True Red 2009 MS3
Critical Stats:
// 305whp/352tq
Mazdazilla6 (04-20-2016)
 Old 04-20-2016, 09:06 AM   #195
Where should this group buy be posted? Is there a GB forum?
Steve
Lead Tuner
 Old 04-20-2016, 09:09 AM   #196
http://www.mazdaspeedforum.org/forum/forum/f77/
PTE = JB 5862
Forge = V2 BPV
Tial = 44mm WG
Grimmspeed = EBCS
 Old 04-20-2016, 09:25 AM   #197
nindoja's Avatar
@Steve@VersaTune; I've got 2 vehicles. If I buy 2 licenses and 1 cable, is that 1 count towards GB or 2?
Also, I think as a Vendor, you can post GB/GI threads in your own forum. @InkedInspector; @SofaKingAwesome; - what's the rule for vendor-sponsored GBs?
True Red 2009 MS3
Critical Stats:
// 305whp/352tq
The Following 3 Users Say Thank You to nindoja For This Useful Post:
InkedInspector (04-20-2016), Micha (04-22-2016), SofaKingAwesome (04-20-2016)
 Old 04-20-2016, 09:26 AM   #198
Each license counts with or without a cable.
nindoja likes this.
Steve
Lead Tuner
 Old 04-20-2016, 09:37 AM   #199
COCKSTRONG
SofaKingAwesome's Avatar
Posts: 8,447   (View Stats)
Groans: 890
Group buy rules for Vendors
1) Group buy shall have a start date and end date.
2) A list of members will be shown in the GB thread and updated accordingly by the organizer of the GB.
3) Price of the item WILL be posted in the GB post.
4) Organizer of the Group Buy will be responsible for keeping the members up to date.
5) The post of the GB will contain descriptive information pertaining to the sale of that item.
I would suggest that the vendor posts the Group Buy in their section, so as to allow them access to modify thread/posts as needed.
Steve, PM me if you have any questions.
InkedInspector (04-20-2016), Mazdazilla6 (04-20-2016)
 Old 04-21-2016, 02:04 AM   #200
leo766's Avatar
Posts: 300   (View Stats)
leo766 has a reputation beyond reputeleo766 has a reputation beyond reputeleo766 has a reputation beyond reputeleo766 has a reputation beyond reputeleo766 has a reputation beyond reputeleo766 has a reputation beyond reputeleo766 has a reputation beyond reputeleo766 has a reputation beyond reputeleo766 has a reputation beyond reputeleo766 has a reputation beyond reputeleo766 has a reputation beyond repute
Groaned at 93 Times in 33 Posts
may i ask why you say you are "very happy" about VT over AP ATR? i am curious what hte differences are between the two,besides that one is pc based and the other a standalone gadget... the best I can come up with from searching the forums is that VT is specifically for the mazdaspeed platform, but in terms of features I can't tell a lick of difference and from where i stand it seems to be a matter of preferance? since mazda oriented or not if the features are the same, like many others it would be hard to justify a switch, but if there is enough of a diff to be "very happy" about maybe I would switch if I knew what this "delta of difference in ability" actually was.
adnoird app sounds nice tho(AP v3 should of been an andoird app imho, instead of a 700 smartphone gimped down into being an ap with a bigger screen, which is still too damn small imho to be more useful than my DH was, and my plx kiwi2 is)
Fresh to High Rockies Colorado from VA DC area MS6 07 TiGray!
Cpe: FMIC, CAI, TIP, HPFP, bone engine mount
Cobb AP, Test pipe, turbosmart BPV, whitlenine swaybar
Turbine Tech: Extra front motor mount, both diff mounts +bushings
EGR Delete, mini 0803 Dash cam, Prosport Boost guage. Dash Hawk,
AWR: Trans mount with 88 duro bushings, End links front/rear(removed due to them being total garbage and got some moog stock ones for all around on rockauto.
17x7 Kosei K1 TS 15lb rims, goodyear 225/50r17 all season performance tires and RPM springs
Waiting to install: SPC Ball Joints, SS clutch line, lower engine mount bracket local car shop damaged during clutch install and thermal TB gasket and coolant inline plumbing line that can be turned on and off on demand
leo766 is offline   Reply With Quote
The Official AP v3 Landscape Request Thread hnda etr Cobb Tuning 41 03-18-2014 01:19 PM
atr feature request : dual monitor support someguyondrugs
Cobb ATR Support
7 11-26-2013 02:04 PM
Page generated in 0.61193 seconds with 34 queries
