| VersaTune VersaTuner tuning software by VersaTune. Available for Mazdaspeed3, Mazda 3 MPS, Mazdaspeed Axela, Mazdaspeed6, Mazda 6 MPS, Mazdaspeed Atenza. Includes ECU reflashing/remapping, online tune database, custom tune editing ability, virtual dashboard, data logging, diagnostics/DTC code management, Launch Control, No Lift Shift, and stutter-free Smooth Shifting. |
![]() Join Date: Apr 2016 Location: Clarksville, Tennessee
Rep Power: 0 ![]() ![]() ![]() Thanks: 3
(Thread Starter) | Not Ranked : 0 score Wondering how to use the tune sharing option with VT. And If someone would be kind enough to share a tune with me that I can use/build upon. Trying to learn the ropes and would love some tunes to study and build my own with. |
![]() Join Date: Oct 2016 Location: Mi
Rep Power: 0 ![]() ![]() Thanks: 10
| Not Ranked : 0 score What do you drive for starters? |
(Thread Starter) | Not Ranked : 0 score 2013 MS3 |
![]() Join Date: Apr 2013 Location: Evanston, IL
Rep Power: 1329 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 938
Groans: 57
| Not Ranked : 0 score There is a stock tune and numerous off the shelf tunes for you to play with. What are you planning on getting from other users tunes that isn't already available from existing resources?
__________________ "you, sir, are the most knowledge slow guy I know. Stop fucking around and drive faster." -feejay "if anyone else acts a fool, we'll punish them to Roberts oil hut to discuss string alignment technique" -wetzel |
(Thread Starter) | Not Ranked : 0 score I guess I'm just looking to learn from others as well. It would be nice to see what others use to be safe/reliable. Also I hadn't mentioned this in the beginning but I'm also looking for e85 advice. Looking to do a 30%e 70% 93 mix maybe 50/50. So I guess seeing what others have used would be helpful. |
| Not Ranked : 0 score No mods in sig. Start with the stock tune. Lol. That's what I did. Don't forget to do a lot of reading. I'm still mostly stock and I think I have about 40 different tune revisions that have accumulated by just playing with the software.
| Not Ranked : 0 score Same I've probably made about 100+ revisions but mines is for my RX8 |
(Thread Starter) | Not Ranked : 0 score I haven't updated anything in my signature or profile. My bad. Hpfp internals. SRI/TIP. JBR RMM 88 duro. Corksport Injector seals. JBR OCC. Corksport TMIC |
| Not Ranked : 0 score Start with a stock tune, use the comparison feature and compare it to one of the maps that VT offers to see what would be appropriate changes. If you are stuck on something, chances are it's been covered here before at some point.
(Thread Starter) | Not Ranked : 0 score Alright Cool. Thanks guys.
__________________ 2013 Speed3. Corksport SRI/TIP. Corksport HPFP internals. Corksport TMIC. Corksport BeCuse Injector seals. JBR RMM 88 Duro. JBR short shift plate and counter weight. JBR OCC. Custom 3" straightpipe exhaust with HKS muffler. Versa tune 93 octane. Going to corn soon. KO4 on 19lbs. |
Groans: 189
| Not Ranked : 0 score Directly copying someones tune is a bad idea for multiple reasons. You're better off starting from scratch (stock tune) and slowly working your way up to where you want to be.
__________________ |
| Not Ranked : 0 score I've been taking baby steps increasing my load targets. I'm lucky I did it that way because even a slight increase threw my knock sensor in a bitch fit. I'd be all kinds of messed up if I jumped right into an OTS tune.
| local tune or inet tune | RACER_X | Gen2 MS3 General Discussion | 19 | 11-13-2014 02:05 PM |
| cobb ap: is safe tune quicker than stage 0 tune? | Fusion_MS3 | 2010 MS3 - ECU Computer Tuning | 14 | 12-16-2012 02:27 AM |
| Anyone fine tune there shifter and tune out a second gear grind? | stevessvt | MazdaSpeed 3 - Engine, Transmission & Driveline | 15 | 10-21-2009 12:06 AM |
