| VersaTune VersaTuner tuning software by VersaTune. Available for Mazdaspeed3, Mazda 3 MPS, Mazdaspeed Axela, Mazdaspeed6, Mazda 6 MPS, Mazdaspeed Atenza. Includes ECU reflashing/remapping, online tune database, custom tune editing ability, virtual dashboard, data logging, diagnostics/DTC code management, Launch Control, No Lift Shift, and stutter-free Smooth Shifting. |
Groans: 111
| Not Ranked : 0 score I wonder if someone else has any logs with this turbo, I helped a guy in Germany a while ago and found that the boost control with this turbo was very challenging. I got it sorted eventually but I wonder if it was just a particular case due to some wastegate arm preload or other install issue or if they are all the same.
| Cobb AP "stock" tune Turbo PSI | tc0308 | Gen2 MS3 General Discussion | 10 | 03-07-2013 05:09 PM |
| K&N Intake and Sidewinder SURE turbo inlet pipe require tune for speed 3? | jwilson0514 | Mazdaspeed3/6 General Discussion | 17 | 12-04-2012 08:29 PM |
| K&N Typhoon + Turbo Inlet Pipe = safe with no tune? | ChicagoMike | 2010 MS3 - Engine, Transmission & Driveline | 21 | 08-05-2011 11:50 AM |
| Turbo upgrade without a custom tune | ganque | MazdaSpeed 3/6 - Turbo Induction | 6 | 07-30-2010 04:36 PM |
| Anyone fine tune there shifter and tune out a second gear grind? | stevessvt | MazdaSpeed 3 - Engine, Transmission & Driveline | 15 | 10-21-2009 12:06 AM |
