> HTP (Hi-Tuned Performance)
Like Tree6Likes
 Old 12-17-2012, 08:16 PM   #1
Deldran's Avatar
Posts: 3,139   (View Stats)
Groans: 118
Default HTP 3.5 full intake installed
So after about 2 hours I finally got the 3.5 inch full intake installed.
The quality is great as well as the price.
As far as installation goes it was pretty straight forward. I highly recommend picking up @HTP; small battery tray and installing it all at the same time. I did not do this and it is a tight fit.
One recommendation I have is it get an angled fitting for the small house as well I am not sure what this goes to off the top of my head. Also so clamps for the valve cover vent hose would be nice. The vc vent hose was a bit to long cut it like three times but that's not a bad thing per say.
I will update this later with power and airflow gains once I get the maf dialed in. As far as what I did to get the car started I just multiplied both maf cal tables by 1.66. It stuttered for about a minute initially but then ran smooth
Sent from my Nexus 10 using Tapatalk HD
Damond Built Speed 6
The Following 13 Users Say Thank You to Deldran For This Useful Post:
anavrinIV (12-19-2012), AZSPEED3 (12-17-2012), CrawlingMS3 (04-27-2013), DingoDave (01-02-2013), El_Diablo (12-22-2012), magicka (12-18-2012), Ms3_Miami (12-19-2012), Pointless (12-18-2012), SKiZZ (02-28-2014), SLOWHATCH (12-17-2012), speed_freak91 (01-11-2013), Todd98SE (12-18-2012), xdm88 (12-19-2012)
 Old 12-17-2012, 08:21 PM   #2
Jhornbrook's Avatar
Posts: 708   (View Stats)
Jhornbrook is the leader of the worldJhornbrook is the leader of the worldJhornbrook is the leader of the worldJhornbrook is the leader of the worldJhornbrook is the leader of the worldJhornbrook is the leader of the worldJhornbrook is the leader of the worldJhornbrook is the leader of the worldJhornbrook is the leader of the worldJhornbrook is the leader of the worldJhornbrook is the leader of the world
Groaned at 6 Times in 4 Posts
Subbin for gains.
Ultimate Racing // testpipe, catback // TWM // Full Replacement Shifter, Short Shift Boot // Cobb// AP // Sure aeros, sidewinder, shortcut, ags SS knob, return, chargetubes, countershift // Corksport // License Plate Relocate, Fog Light LED's, Interior LED's, Poly Exhaust Hangers, Oil Catch Can // PTP// HPFP Upgrade, 2150 rail valve // H&R // SS Coilovers // SPC// Adjustable Camber Arms // Hawk// HPS Brake Pads // Ebay Chargespeed Lip 06-07 STI Lip // DDM 8K 55W HIDs // JBR// Rear Sway Bar, 88D RMM, AP Mount //WHITELINE// Front End Links // ETS// TMIC//
Jhornbrook is offline   Reply With Quote
The Following User Says Thank You to Jhornbrook For This Useful Post:
boostdmazda3 (12-17-2012)
 Old 12-17-2012, 11:16 PM   #3
specvspeedfreak's Avatar
Posts: 2,371   (View Stats)
Nice.. Looks like the fitment is better than the JBR (from pics at least)... what is the price on these?
Tokay444 (12-18-2012)
 Old 12-18-2012, 04:25 AM   #4
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,163   (View Stats)
Groans: 793
If it fits, it's better than some other 3.5" intakes
"Exclusivity" - CP-enis
Demodded.
The Seals
 Old 12-18-2012, 05:59 AM   #5
Deldran's Avatar
Groans: 118
It's about the same as the JBR.
It does fit well my battery box is a bit distorted though won't snap back together just right but I believe that is because of my positive wire not being in just right.
It makes your car so much louder though. I no reason to run vta with this thing stock bpv sounds like a bov with it
 Old 12-18-2012, 06:34 AM   #6
BigRedSpecial's Avatar
Posts: 1,436   (View Stats)
Groans: 56
What are you comparing the sound to? I'm replacing my corksport with the JBR and my inner ricer wonders if I'll lose any noise
Needed: Driver mod
The Following User Says Thank You to BigRedSpecial For This Useful Post:
ricknm (12-18-2012)
 Old 12-18-2012, 06:44 AM   #7
Deldran's Avatar
Groans: 118
To stock intake. You can also here the turbo spool this thing gives me ear gasms at part throttle haven't even went woot yet
 Old 12-18-2012, 06:51 AM   #8
Groans: 56
Gotcha... I noticed the same thing when I put the CS on. Couldn't believe how much the stocker muffled things.
Needed: Driver mod
moomooz12 (12-18-2012)
 Old 12-18-2012, 07:26 AM   #9
maisonvi's Avatar
Posts: 3,490   (View Stats)
Groans: 75
Also interested in price and gains.
Didnt see anything on HTPs site about this.
 Old 12-18-2012, 08:17 AM   #10
Deldran's Avatar
Groans: 118
Yea not sure why it's not up on @HTP; site yet. I think only me and one other msf member has one of these atm I saw him talk about it then I pm htp and said I wanted one lol.
The way the got the air straightener built in is awesome
 Old 12-18-2012, 08:18 AM   #11
yeah.. fitment looks a lot better.. the filter end of the pipe is angled better (a lot further from the bpv.) and the intake is not pushing against the tray nearly as much.. My battery tray is way more distorted than that, and I couldn't even use all 3 bolts to the tray.I struggled for 2 days to get the fitment the way I would like but still not happy... Now I will need to make the holes in the battery tray bigger and slide the box some to clear the pipe better...At the end, I'm sure I can make it work... Just sucks how much work it needs to be done for it.
 Old 12-18-2012, 08:42 AM   #12
dereeek's Avatar
Posts: 2,053   (View Stats)
Groans: 386
Very nice. @HTP; is there any discount if we buy this intake and your battery box at the same time? Like a combo package.
BNR3-FREEK-PU-398HP
The Following 2 Users Say Thank You to dereeek For This Useful Post:
El_Diablo (12-19-2012), Ms3_Miami (12-19-2012)
 Old 12-18-2012, 08:46 AM   #13
Deldran's Avatar
Groans: 118
The only really hard part I had with the whole install was getting the intake by that stupid coolant line, another TIP for people installing something like this might be to grease that pipe up a bit with some oil or something, it grabs the intake pretty good, had to try and get my giant ass hands below the intake to push that hose down while pushing the intake onto the coupler.
I would still say using @HTP; battery tray would give you the best fitment possible
 Old 12-19-2012, 01:41 PM   #14
Deldran's Avatar
Groans: 118
Well i got some preliminary results in.
Obviously my tune needs some work still. The larger intake has caused me to start overboosting again, i had the majority of the worked out before i put the intake on.
My maf cal is still way off so dont be alarmed by the AFR's it was a cool enough day I felt i could do a couple woot pulls without getting in trouble.
Comparing the two attached logs i picked up 25 HP and 9 torque. I am curious to see how much of that is because of the over boosting i have at the moment, but thought i would post this up anyway. Also these are on different roads on different days so its hard to tell. The gain could also be from lower BATS.
The Following 3 Users Say Thank You to Deldran For This Useful Post:
BigjohnB20 (12-20-2012), Ms3_Miami (12-19-2012), xdm88 (12-19-2012)
 Old 12-19-2012, 02:25 PM   #15
Boostman07's Avatar
Posts: 229   (View Stats)
Boostman07 has a reputation beyond reputeBoostman07 has a reputation beyond reputeBoostman07 has a reputation beyond reputeBoostman07 has a reputation beyond reputeBoostman07 has a reputation beyond reputeBoostman07 has a reputation beyond reputeBoostman07 has a reputation beyond reputeBoostman07 has a reputation beyond reputeBoostman07 has a reputation beyond reputeBoostman07 has a reputation beyond reputeBoostman07 has a reputation beyond repute
Is it a custom order kinda thing? Im not seeing it on their website.
tappy tap
09 MS3 GT
Fully Bolted
50/50 e85 Richtune
Boostman07 is offline   Reply With Quote
 Old 12-19-2012, 02:31 PM   #16
Deldran's Avatar
Groans: 118
tappy tap
Call them up I think there adding it soon. But if u call you can order one
The Following 2 Users Say Thank You to Deldran For This Useful Post:
Boostman07 (12-19-2012), Ms3_Miami (12-19-2012)
 Old 12-19-2012, 03:51 PM   #17
Ms3_Miami's Avatar
Posts: 3,185   (View Stats)
Ms3_Miami is the leader of the worldMs3_Miami is the leader of the worldMs3_Miami is the leader of the worldMs3_Miami is the leader of the worldMs3_Miami is the leader of the worldMs3_Miami is the leader of the worldMs3_Miami is the leader of the worldMs3_Miami is the leader of the worldMs3_Miami is the leader of the worldMs3_Miami is the leader of the worldMs3_Miami is the leader of the world
Groans: 55
+1
08 Black Mica Ms3~full bolt ons/Nishan Tuned-Sold
NATOR FL
Ms3_Miami is offline   Reply With Quote
 Old 12-20-2012, 08:38 AM   #18
HTP
HTP's Avatar
Posts: 210   (View Stats)
Yes! When we officially release these and the 4" intakes shortly, we will have a discounted package option available with the battery trays for sure!
Katie
The Following 13 Users Say Thank You to HTP For This Useful Post:
asall667 (05-10-2013), Deldran (12-20-2012), dereeek (12-20-2012), DingoDave (01-02-2013), Dream20b (01-05-2013), El_Diablo (12-20-2012), maisonvi (12-20-2012), Micha (12-31-2012), Ms3_Miami (12-20-2012), Pointless (01-02-2013), RichieRichness (12-20-2012), senor blanco ms3 (12-22-2012), speed_freak91 (12-21-2012)
 Old 01-03-2013, 07:09 PM   #19
HTP
HTP's Avatar
tappy tap
Our 3.5" and 3.0" Full Intakes are now available:
Check them out here
Thanks!
Katie
Boostman07 likes this.
The Following 7 Users Say Thank You to HTP For This Useful Post:
ASHMS3 (01-03-2013), Boostman07 (01-03-2013), El_Diablo (01-04-2013), Micha (01-08-2013), Ms3_Miami (01-03-2013), Pointless (01-10-2013), Pseud0logik (01-03-2013)
 Old 01-10-2013, 10:10 PM   #20
reko's Avatar
Posts: 26   (View Stats)
reko is a glorious beacon of lightreko is a glorious beacon of lightreko is a glorious beacon of lightreko is a glorious beacon of lightreko is a glorious beacon of lightreko is a glorious beacon of light
@Deldran the fact that it's a 1 piece thing, does it cause any troubles with the engine movement? That's my only concern...
reko is offline   Reply With Quote
 Old 01-11-2013, 05:18 AM   #21
Deldran's Avatar
Groans: 118
What exactly do you mean. I pretty much have this dialed in now and I drive it like I stole it. No issues at all
 Old 01-11-2013, 03:16 PM   #22
reko's Avatar
@Deldran Well with the engine movement....
If you were to have a TIP in silicone + an elbow along with the maf housing, the silicone could "absorb" some of the movement. And if you had an aluminum TIP + a silicone elbow that connects to the maf housing, once again, the silicone could absorb a portion of the movement since silicone is flexible
Now since it's a one piece all the way, the only part that could absorb some of the engine movement is the coupling to the turbo; therefore **it could** create tension to it and it would be easier to disconnect from it.
Sorry if my explanation sucks, english isn't my native language.... Hope you get my point / question anyway!
The Following User Says Thank You to reko For This Useful Post:
Micha (07-10-2013)
 Old 01-11-2013, 04:49 PM   #23
El_Diablo's Avatar
Posts: 2,770   (View Stats)
Groans: 769
Its attached to the engine, it moves with the engine, its not attached to the body in any way so there is not need to worry about energy absorbtion... and even if it was, that just means you need to drop some cash on mounts.
 Old 01-11-2013, 05:01 PM   #24
J.Dy's Avatar
Posts: 109   (View Stats)
J.Dy has a reputation beyond reputeJ.Dy has a reputation beyond reputeJ.Dy has a reputation beyond reputeJ.Dy has a reputation beyond reputeJ.Dy has a reputation beyond reputeJ.Dy has a reputation beyond reputeJ.Dy has a reputation beyond reputeJ.Dy has a reputation beyond reputeJ.Dy has a reputation beyond reputeJ.Dy has a reputation beyond reputeJ.Dy has a reputation beyond repute
The intake moves with the engine and it looks like it's only attached at the turbo so there shouldn't be a problem. I think you're describing an issue where the filter end of the intake is also attached to the chassis.
edit: El_Diablo beat me to it!
J.Dy is offline   Reply With Quote
The Following User Says Thank You to J.Dy For This Useful Post:
El_Diablo (01-11-2013)
 Old 01-11-2013, 05:48 PM   #25
reko's Avatar
Yeah that's what I was thinking too; just that someone on another forum pointed this out... and I do have a 2.5 TIP from HTP and it is connected onto the engine about halfway with the inlet bracket. So the one piece intake system should be the same....
I used to have a CAI on my old celica 6th gen and it was only "secured" by the coupler that connects to the TB. It was always moving and disconnecting... 'had to ty-wrap tuning style that shit
magicka (01-11-2013)
 Old 01-11-2013, 09:46 PM   #26
magicka's Avatar
Posts: 520   (View Stats)
In the pics on HTPs site, the 3" intakes have a bracket, but from what I've seen the 3.5 s don't. I'd prefer a mounting point in addition to the turbo. It seems like a lot to ask a single coupler to support the whole length of the intake. I understand the decision to leave the bracket off, though, given that the larger intakes will often be used on BT setups where things don't quite line up.
2009 CWP MS3 GT
 Old 01-12-2013, 07:04 AM   #27
El_Diablo's Avatar
Groans: 769
If one silicone coupler can hold over 30psi, I think you'll be fine with it supporting a lb or two.
 Old 01-12-2013, 06:10 PM   #28
Volcom8190's Avatar
Posts: 448   (View Stats)
Volcom8190 is the leader of the worldVolcom8190 is the leader of the worldVolcom8190 is the leader of the worldVolcom8190 is the leader of the worldVolcom8190 is the leader of the worldVolcom8190 is the leader of the worldVolcom8190 is the leader of the worldVolcom8190 is the leader of the worldVolcom8190 is the leader of the worldVolcom8190 is the leader of the worldVolcom8190 is the leader of the world
you can always fit it and then have a muffler shop tack on a strip of metal for you to use as a bracket
2010 - BMW 335i M-Sport - Lemans Blue Metallic
2005 - Kawasaki ZX-6R 636 - Magma Red
Volcom8190 is offline   Reply With Quote
 Old 01-12-2013, 06:44 PM   #29
magicka's Avatar
Yeah, that's an option. I'm sure it's fine without the bracket, and I wouldn't want to dick up the finish.
2009 CWP MS3 GT
 Old 01-12-2013, 08:13 PM   #30
Deldran's Avatar
Groans: 118
Got my HTP battery tray and picked up a battery today. It looks sexy should be able to put it in tomorrow
IshiKage (01-13-2013), Ms3_Miami (01-15-2013)
 Old 01-12-2013, 08:43 PM   #31
Eth/Meth Junkie
cld12pk2go's Avatar
Posts: 2,998   (View Stats)
Katie
Will 4'' fit with relocated ECU and stock Battery Tray?
 Old 01-12-2013, 10:19 PM   #32
Deldran's Avatar
Groans: 118
I am sure @HTP; will chime in on that but with out tight my 3.5 is I highly doubt it. Look up a few post the pick of my intake installed I don't think there is another .5 inches of room to be had
 Old 01-13-2013, 12:26 AM   #33
Etipp98's Avatar
Posts: 1,947   (View Stats)
Groaned at 7 Times in 4 Posts
Ive got my car torn apart and can throw my 4" on with stock tray tomorrow.
The Following User Says Thank You to Etipp98 For This Useful Post:
cld12pk2go (01-13-2013)
 Old 01-15-2013, 11:16 AM   #34
speed_freak91's Avatar
Posts: 1,189   (View Stats)
Groans: 34
Installed a JBR 3.5" onto a local Nator members car and it was rubbing his battery box with the ECU relocated. Its a tight fit.
 Old 04-05-2013, 05:41 PM   #35
SLOWHATCH's Avatar
Posts: 2,461   (View Stats)
Groans: 274
How did you guys get around the coolant line in front of turbo? Over or under? Did you push it back any off the connection at the block? Or left it be? I noticed I can get it to slide off nearly 1/4" for a bit of added room.
 Old 04-05-2013, 06:52 PM   #36
HTP
HTP's Avatar
That heater core line is a pain in the ass. Keep it under the intake. Some people slide the hose back on the fitting, some setups its not a problem and they leave it alone. On our test cars I install a Gates 28604 ($2.99) coolant hose connector and a few inches of 5/8" hose to give the proper clearance.
Matt
SLOWHATCH likes this.
The Following 5 Users Say Thank You to HTP For This Useful Post:
Micha (07-10-2013), MS3G35 (04-23-2013), Nel Mazdaspeed (11-25-2014), SKiZZ (03-13-2014), SLOWHATCH (04-05-2013)
 Old 04-05-2013, 07:23 PM   #37
SLOWHATCH's Avatar
Groans: 274
Matt
Thanks, I was just coming in here to edit post and say I got it. It actually fits better than I thought it would. The way you mentioned would make it even better. But seems to be ok without it. I'll post up some pics in another thread when I have it all buttoned up.
The Following User Says Thank You to SLOWHATCH For This Useful Post:
rfinkle2 (04-23-2013)
 Old 04-23-2013, 11:06 AM   #38
manila's Avatar
Posts: 1,767   (View Stats)
@Deldran; Any word on the gains from the 3.5"? Do you have any issues with intake movement, I ask because I noticed the 3.0" has a bracket and the 3."5 does not.
@HTP; Is there a way we can get the bracket for the 3.5" as an option?
'12 MS3 Black Mica w/ Tech
 Old 04-23-2013, 11:20 AM   #39
SLOWHATCH's Avatar
Groans: 274
Imo, the bpv hose does a good job of holding the intake "up". Not much movement between it and the valve cover breather hose.
manila (04-23-2013)
 Old 04-23-2013, 11:34 AM   #40
SparkySparks's Avatar
Posts: 1,314   (View Stats)
Just contact HTP and ask about the bracket, they welded one on for me.
On Order:
Coming Soon:
DIY Projects:
The Following 4 Users Say Thank You to SparkySparks For This Useful Post:
El_Diablo (04-27-2013), magicka (04-23-2013), Pointless (04-27-2013), rfinkle2 (04-23-2013)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f579/htp-3-5-full-intake-installed-133129/
For Sale: HTP 3.5" Intake This thread Refback 05-19-2014 04:52 AM
Sure Aeros 3 full intake Moreira 2010 MS3 - Turbo Induction 72 07-28-2013 12:28 PM
Installed SURE Full 3 Aeros with 3" MAF (k04) dale_gribble Mazdaspeed3/6 General Discussion 33 01-20-2013 07:50 PM
installed corksport intake, not hitting full boost. azer 2010 MS3 - Turbo Induction 13 08-09-2012 06:24 PM
Full GT Spec Underbracing Installed & Review ElBartoRex MazdaSpeed 3/6 - Suspension & Brakes 48 04-28-2009 08:32 PM
Page generated in 0.60227 seconds with 41 queries
