> HTP (Hi-Tuned Performance)
Like Tree47Likes
 Old 01-24-2013, 02:24 PM   #161
Volcom8190's Avatar
Posts: 448   (View Stats)
Volcom8190 is the leader of the worldVolcom8190 is the leader of the worldVolcom8190 is the leader of the worldVolcom8190 is the leader of the worldVolcom8190 is the leader of the worldVolcom8190 is the leader of the worldVolcom8190 is the leader of the worldVolcom8190 is the leader of the worldVolcom8190 is the leader of the worldVolcom8190 is the leader of the worldVolcom8190 is the leader of the world
Have you guys considered using a larger diameter honeycomb style straightener, the holes seem quite small. I bet your losing a good chunk of space for air to flow because of this. It might be necessary to use a honeycomb that small on the larger intakes, but on the smaller one, im sure exceptions can be made.
2010 - BMW 335i M-Sport - Lemans Blue Metallic
2005 - Kawasaki ZX-6R 636 - Magma Red
Volcom8190 is offline   Reply With Quote
 Old 01-24-2013, 06:33 PM   #162
sidekick's Avatar
Posts: 3,093   (View Stats)
Groans: 47
Originally Posted by Dr. Speed View Post
~2.8" isn't even that much bigger than the stock MAF housing is it? I know this is kind of the general trend (doesn't the JBR 3.5" have an ACTUAL ID of 3.3-something?)... but it still is a bit disappointing. Intake diameter should definitely be advertised using ID numbers.
Well part of the problem is that the bare pipe they are using is probably sold by the OD, not the ID. So it is a 3" pipe, but the ID is 2.87". I really doubt that .130" is going to make a very big difference in air flow or power output.
This is probably why people going from a Stock size MAF to the 3.5" are seeing pretty big gains. That's a jump of about .7", where as the jump from stock to 2.87" is only about .2".
The MAF size isn't the only thing that matters here though. The whole entire intake is a larger diameter surely flows more than stock and most SRI+TIP combos. The MAF really only needs to be larger if you've maxed out your current MAF housing in terms of flow.
Has anyone measured the ID of the SURE ID300? It is made from solid chunk of billet as far as I know, so it probably has an ID of 3.00".
Dr. Speed (01-24-2013)
 Old 01-24-2013, 07:10 PM   #163
faeker's Avatar
Posts: 5,091   (View Stats)
Groans: 731
They post the MAF housing being ID of 3" but it looks like everything behind it goes down to stock size.
Mods: stock
 Old 01-24-2013, 07:28 PM   #164
DamagedGoods's Avatar
Posts: 304   (View Stats)
DamagedGoods is the leader of the worldDamagedGoods is the leader of the worldDamagedGoods is the leader of the worldDamagedGoods is the leader of the worldDamagedGoods is the leader of the worldDamagedGoods is the leader of the worldDamagedGoods is the leader of the worldDamagedGoods is the leader of the worldDamagedGoods is the leader of the worldDamagedGoods is the leader of the worldDamagedGoods is the leader of the world
This is SURE's stand alone 3" MAF, where it connects to TIP is more like 2.75 (taken from other thread).
Tappin
2007 Mazdaspeed 6 - Bolted, Methed, Tuned
DamagedGoods is offline   Reply With Quote
The Following User Says Thank You to DamagedGoods For This Useful Post:
 Old 01-24-2013, 07:46 PM   #165
Assuming the I.D. of the 3" HTP is 2.8", the area of the HTP housing is about 14% larger than stock.
On the stock maf curve, that buys you about 45 g/s more mass airflow before pegging the maf sensor.
(some rough assumptions made to arrive @ this #, but a good estimate).
The Following 5 Users Say Thank You to rfinkle2 For This Useful Post:
Dr. Speed (01-25-2013), faeker (01-24-2013), Lex (01-24-2013), Micha (11-03-2013), Voltwings (01-25-2013)
 Old 01-24-2013, 10:42 PM   #166
Increasing the piping diameter all the way to the turbo will certainly help. There is no questioning that here.
What is going on here however is that the MAF curve itself does not match other MAF curves in the voltage -> mass airflow relationship.
Ideally you can scale any MAF housing to any other MAF housing by knowing both their diameters. All that the MAF sensor does is "sample" a part of the airstream. So the percentage that it samples is proportional to the cross sectional area of the pipe.
When scaling an existing MAF table to the HTP intake (whether using 3" or 2.87" as the diameter) it becomes clear that the scaling factor is not the same across the board. This means that the voltage -> mass airflow relationship is different with these intakes and it is likely related to the honeycomb and pieces in place to hold it in like the glue and pipe bead.
I am personally not a fan of hacking MAF curves too much on a vehicle simply because you can run yourself into tuning something really wacky that can backfire (tuning around a leak or some other issue). On top of this we get such few breakpoints in the car with trims acting all the time that it really is hacking up the curve in a piecewise fashion and this is where a lot of people have become stumped with this intake.
However, if the curve has to be piecewise scaled, this can still be done as long as it is consistent from one intake to the next. This has not come out of the woodwork just yet because we don't know if people were having leaks or if it was the MAF cal - this is why I must go back on the importance of a solid MAF cal that is scalable because then you can properly diagnose other issues such as leaks.
It would be good to hear back from HTP with some of their own in-house MAF cals so that we can compare and see if we find something that consistently works well on their intakes.
sidekick likes this.
The Following 9 Users Say Thank You to Lex For This Useful Post:
beachshoer (01-25-2013), faeker (01-25-2013), JDW1 (01-25-2013), magicka (01-25-2013), Mike@Stratified (01-25-2013), ms3blackmica (01-25-2013), rfinkle2 (01-25-2013), sidekick (01-25-2013), TiGraySpeed6 (01-25-2013)
 Old 01-25-2013, 08:20 AM   #167
faeker's Avatar
Groans: 731
Sigh. Intake just arrived. Sad I cannot put it on. Hope this gets figured out soon.
tappy-tap-tappytalk
Mods: stock
 Old 01-25-2013, 08:32 AM   #168
beachshoer's Avatar
Posts: 2,039   (View Stats)
And THIS my friend is why I am ecstatic you are tuning my car.
tappy-tap-tappytalk
Why not? I've been going back and forth with Lex tuning my car with this intake and there's no reason why you can't run it. Im even racing with mine this weekend.
2010 BM MS3
BNR S3
STRATIFIED TUNED
Other Mazdas in my stable
2010 VR MS3 Wifes Ride
1999 Miata
2001 Miata LS
The Following User Says Thank You to beachshoer For This Useful Post:
Lex (01-25-2013)
 Old 01-25-2013, 08:59 AM   #169
faeker's Avatar
Groans: 731
My tune is being worked on as this plays out. I don't usually go full on with a part unless I know for sure I wont an issue.
tappy-tap-tappytalk
Mods: stock
 Old 01-25-2013, 09:03 AM   #170
This is odd to hear. If Faeker was going racing, I would not want him to run an intake on which I wasn't 100% sure he was not running rich and I knew his car was 100% dialed in.
I don't know the entire story (and respect Lex's decision), nor do I want to turn this into "tuner wars", but I asked Faeker to wait to install the intake until Godspeed7 gives me some data from his.
 Old 01-25-2013, 09:08 AM   #171
I posted a beta CAL for the HTP 3" here if you want to try it or take a look.
MAF calibrations for bigger intakes
Rob, I've had quite a few cars that I've tuned with this intake and I am using data from several - both gen1 and gen2. If the datalogs look good (the due diligence is there) there's no reason to not drive the car.
aldekei (01-25-2013), beachshoer (01-25-2013), rfinkle2 (01-25-2013), TiGraySpeed6 (01-25-2013)
 Old 01-25-2013, 09:23 AM   #172
TBH, I know your data to be 100% reliable, but have not looked @ that thread until yesterday.
I sometimes feel as if I should put in the work rather than gank an maf curve from you.
Seems a little "hackish" to me, but I guess I need to get over that.
@faeker; if you'd like, I can insert Lex's values into your map and you can install your intake.
100% up to you.
 Old 01-25-2013, 09:28 AM   #173
KevMS6's Avatar
Posts: 316   (View Stats)
My Cpe nano intake measured in at 2.72" ID, my HTP tip measured 2.83" ID
Tuned with by
The Following 2 Users Say Thank You to KevMS6 For This Useful Post:
Lex (01-25-2013), rfinkle2 (01-25-2013)
 Old 01-25-2013, 09:29 AM   #174
100% up to you.
Rob, still plenty of work to do. That's a starting point and tweaks here and there may be needed. It's just a reasonable starting point and if the intakes are consistent this should be safe to run the car on.
Micha (11-03-2013), rfinkle2 (01-25-2013)
 Old 01-25-2013, 09:34 AM   #175
faeker's Avatar
Groans: 731
Let's do it up rob. I'm down for guinea pigging today.
tappy-tap-tappytalk
Mods: stock
 Old 01-25-2013, 09:36 AM   #176
Voltwings's Avatar
Posts: 3,713   (View Stats)
@Lex; i remember you saying you had a curve that worked perfect on a BNR spd6 with this intake, but that same curve didnt work on a BNR spd3 or something like that. Are there drastic inconsistancies between different vehicles running these same intakes? Honey combs are not exactly rigid, they're quite fragile. Is it possible that the honey combs are getting bent / mishaped somehow during production / shipping / instillation, whichever and thats whats causing these weird readings since basically no two intakes would flow the same?
for instance, say my intake has a perfect ideal honeycomb, and you base a maf cal off my car. You then take that same MAF cal and put it on someones car with janky fins, and their computer thinks they are getting more air flow than they actually are which explains why they're getting High g/s readings but not making the equivilant power?
Past:
-Sold-
-Sold-
Current:
2012 Loaded Speed3 - Stock
2001 Miata - Basically stock
 Old 01-25-2013, 09:38 AM   #177
HTP
HTP's Avatar
Posts: 210   (View Stats)
Since we outsource our tuning, and will not have him available to us until Monday, I need as much info from you as possible. Who are the customers that are having issues? I know of 3 that you are tuning (1 local to us), please PM me this. Since you say that there are inconsistencies between our intakes, I need to know exactly what data leads you to that conclusion (logs please) so that our tuner can address it. If there is a problem with one of our products, we want to get to the bottom of it immediately. On Monday we will be using our original test intake as well as several others from the shelf to verify whether there are any inconsistencies or not. This will take out the differences from one cars setup to another, and focus on the whether every intake is performing the same as it did during testing.
Per my conversation with our tuner this morning, he scales the maf, then tunes any points that don't fall in line. He didn't have much time to talk since they have a subaru dyno day in full swing. Though, he said it was completely crazy to just scale across the board and expect for everything to be perfect, which I am sure you just aren't doing with your tunes. He also said that our intakes are reading the airflow differently due to the honeycomb and he adjusts the tunes accordingly. It was a lengthy process to dial in at first, but its not expected that this product will be a drop in. I will post up a calibration as soon as possible, and go one further. We will start posting all data from development from our products including dyno results (not virtual dyno). I await your pm.
Matt
The Following 12 Users Say Thank You to HTP For This Useful Post:
aldekei (01-25-2013), beachshoer (01-25-2013), Code Monkey (01-25-2013), faeker (01-25-2013), Hush (01-25-2013), Lex (01-25-2013), magicka (01-25-2013), memin (01-25-2013), ms3blackmica (01-25-2013), rfinkle2 (01-25-2013), sidekick (01-25-2013), speed_freak91 (01-26-2013)
 Old 01-25-2013, 09:41 AM   #178
Yes there can be some inconsistencies there for sure. However I don't know how large these can be until we see lots of cars. For now, I'd use what I posted as a starting point and make some tweaks if needed. I consider a MAF cal that keeps LTFTs withing +/-8% and WOT +/-0.2AFR decent on a gen1. On a gen2 the ECU will adjust at WOT so you will hit targets until you are more than 10% off at WOT.
Pointless (01-25-2013), Voltwings (01-25-2013)
 Old 01-25-2013, 09:47 AM   #179
Matt
Matt I don't have the time to get all this data and logs to you. I have posted a MAF cal that seems to be close and that I have derived from several vehicles.
If you have your own MAF cal or want to use what I posted you can check for consistency (ie swap several intakes on the same car), learn trims, verify WOT if a gen1, then this would be a good check and something you can post. The consistency data is very important.
Also be aware even the air filter will affect MAF calibration - especially at low airflow rates.
Also, don't take this as a criticism. I am helping you and the users of these intakes have an easier time with the tune and install.
 Old 01-25-2013, 09:53 AM   #180
JDW1's Avatar
Posts: 486   (View Stats)
JDW1 is the leader of the worldJDW1 is the leader of the worldJDW1 is the leader of the worldJDW1 is the leader of the worldJDW1 is the leader of the worldJDW1 is the leader of the worldJDW1 is the leader of the worldJDW1 is the leader of the worldJDW1 is the leader of the worldJDW1 is the leader of the worldJDW1 is the leader of the world
Since this is about mine I'm curious about this as well. I was apparently flowing above average with my Cobb SF on there as well, seeing ~25-40 more g/s with the HTP
My LTFT and WOT AFR's are in those ranges with some revisions I made on my own from your Sure cal (guys scared to put an intake on make me chuckle a bit, MAF cal is tuning 101). I'm almost curious enough to reset the ecu and flash your beta values and cross my fingers.
07 Liquid Plat Silver W/BNR S3 ~325/340 Pump gas AlphaTuned. Parting out.
11 Mustang GT current.
JDW1 is offline   Reply With Quote
 Old 01-25-2013, 09:55 AM   #181
Originally Posted by JDW1 View Post
Since this is about mine I'm surious about this as well. I was apparently flowing above average with my Cobb SF on there as well, seeing ~25-40 more g/s with the HTP
My LTFT and WOT AFR's are in those ranges with some revisions I made on my own from your Sure cal. I'm almost curious enough to reset the ecu and flash your beta values and cross my fingers.
Don't cross your fingers - it's easy to monitor this. Just watch AFRs as you're getting into WOT. If they are within 0.2 of your targets they are safe. At low loads and idle you need to put some miles on the car to learn LTFTs.
 Old 01-25-2013, 10:00 AM   #182
JDW1's Avatar
I know I can monitor it but I compared your beta scale to the one I revised and there was a good bit less g/s at the top of it and like I said, my WOT AFR's are already ~11.7 +/- .2.
 Old 01-25-2013, 10:05 AM   #183
sidekick's Avatar
Groans: 47
Wouldn't setting up a FTCL map be a pretty good way to figure something like this out? You'll be able to see trims for every breakpoint/MAF reading and adjust accordingly. It'll probably give us a better look into what is going on with this intake. Has anyone tried that yet?
 Old 01-25-2013, 10:08 AM   #184
I have a gen2 running ftcl now (the equivalent of full time closed loop / as good as it gets on a gen2 LOL).
As soon as he gets me the data, I will be happy to post it.
Micha (11-03-2013), sidekick (01-25-2013)
 Old 01-25-2013, 10:09 AM   #185
A European MS6 was spot on with those values at WOT and that's as close as I can get to your particular car/setup. Up to you if you want to try.
 Old 01-25-2013, 10:53 AM   #186
fredricktsang's Avatar
Posts: 459   (View Stats)
fredricktsang is the leader of the worldfredricktsang is the leader of the worldfredricktsang is the leader of the worldfredricktsang is the leader of the worldfredricktsang is the leader of the worldfredricktsang is the leader of the worldfredricktsang is the leader of the worldfredricktsang is the leader of the worldfredricktsang is the leader of the worldfredricktsang is the leader of the worldfredricktsang is the leader of the world
Hopefully it gets all sorted soon! Intake coming tomorrow
fredricktsang is offline   Reply With Quote
The Following User Says Thank You to fredricktsang For This Useful Post:
 Old 01-25-2013, 11:21 AM   #187
GODspeed7's Avatar
Posts: 3,456   (View Stats)
I'm trying rob! You sent me the map the morning of my off day! Lol so I haven't driven to work or anywhere for that matter. Should have the miles done by today or tomorrow!
Tapatalk LIKE A BOSS!
2012 Mazdaspeed3 Black Mica
The Following User Says Thank You to GODspeed7 For This Useful Post:
 Old 01-25-2013, 11:25 AM   #188
sidekick's Avatar
Groans: 47
I'm going to be installing mine today, assuming it stops raining, so I'll post some logs later. I'll be using a MAF cal scaled for a 2.8" MAF housing, so hopefully that works out.
The Following 2 Users Say Thank You to sidekick For This Useful Post:
rfinkle2 (01-25-2013), Voltwings (01-25-2013)
 Old 01-25-2013, 11:29 AM   #189
No problem. It really is not a HUGE rush.
 Old 01-25-2013, 11:44 AM   #190
GODspeed7's Avatar
Just a little rush? Lol
 Old 01-25-2013, 12:06 PM   #191
What is your starting MAF cal that you are scaling?
 Old 01-25-2013, 12:25 PM   #192
faeker's Avatar
Groans: 731
almost done installing mine. I'll load up the map after I'm done and get some miles on it. I'll post the logs I pull later today. FWIW, I'm sick as shit. I've been sick all week with what may have been the flu. It's also colder than my wife's shoulder today. I'm getting this done though because I want to lend a hand in regards to getting this intake calibration solid. I'm no tuner for sure, but I'll put some manual labor in to help get this right.
Mods: stock
The Following 3 Users Say Thank You to faeker For This Useful Post:
KevMS6 (01-25-2013), Lex (01-25-2013), rfinkle2 (01-25-2013)
 Old 01-25-2013, 12:39 PM   #193
sidekick's Avatar
Groans: 47
I'll post it up when I get to my house. I'll post the scaled one as well.
 Old 01-25-2013, 01:42 PM   #194
jdmage_mx5's Avatar
Posts: 1,877   (View Stats)
I don't know a whole lot about tuning but I have a 3.5" coming for my Pu next week. I have a test pipe plus the mods in my sig. Would I be safe to start off with the usual MAF CAL scaling process? If I can help in any way to get data for the 3.5" on a gen 2 let me know. ( Side note: I'm hoping to sign up for a Stratified Tune in a month or so, should I just wait to install the intake then?)
 Old 01-25-2013, 02:34 PM   #195
faeker's Avatar
Groans: 731
Well the weather did me in. It started snowing as I finished up the work. If the roads are clear tomorrow I'll get a couple logs done.
tappy-tap-tappytalk
I would suggest waiting until you can get tuned for it. This isn't a plug and play part.
tappy-tap-tappytalk
Mods: stock
Last edited by faeker; 01-25-2013 at 02:34 PM. Reason: MSF Database - Automerged Doublepost
jdmage_mx5 (01-25-2013), rfinkle2 (01-25-2013)
 Old 01-25-2013, 03:17 PM   #196
sidekick's Avatar
Groans: 47
@HTP; already posted the actual ID of the 3.5" intake, so now we have a better starting point. I'd scale the MAF for the ID they posted and then continue with normal a MAF Cal process. Just be sure to keep an eye on AFRs during WOT runs, as that seems to be the place where people are having problems. A WOT MAF Cal will probably be necessary, based on what @Lex; has been saying.
3.5" - 3.37"
tappy-tap-tappytalk
That isn't really true. You can throw it on and tune for it just like any other intake. It may take a little more work and require a little more caution, but it really isn't that big of a deal.
 Old 01-25-2013, 03:41 PM   #197
faeker's Avatar
Groans: 731
if it takes any work, then it's not plug and play. Cobb, Sure, CS, K&N all make intakes that are plug and play. When we have to tune for a bigger diameter, then it goes beyond the pnp namesake. Me personally, I love having to tune for my parts. It makes my car feel more personal. BTW, did you get your logs loaded up yet? I'm curious to see how things came out.
Mods: stock
 Old 01-25-2013, 03:41 PM   #198
jdmage_mx5's Avatar
^^^^What are your thoughts @Lex; about waiting until I start my tune or just dive in and watch my parameters as I go?
 Old 01-25-2013, 03:57 PM   #199
FWIW, Smoogs12 is running a 4" version of this intake, which was easy enough to dial in.
Personally, if you aren't self tuning, I would always wait to install a different diameter intake until the person creating your maps is ready.
Changing the maf diameter and mass airflow readings has an effect on calculated load and of course, fueling in general.
Micha (11-03-2013), ms3blackmica (01-25-2013), sidekick (01-25-2013), TiGraySpeed6 (01-25-2013)
 Old 01-25-2013, 04:10 PM   #200
sidekick's Avatar
Groans: 47
If that last part was directed at me, then no. I'm at work until 5:30 today. Then I'll be throwing on my intake and doing some logging. The WOT pulls will probably be very late tonight, as the area I do them dies down around 12-1AM.
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f579/intakes-now-available-134325/
JBR Wide path VS Cobb SRI+TIP? This thread Refback 01-28-2013 08:55 AM
Out of stock intakes!!!!!! Toymachinespeed 2010 MS3 - Turbo Induction 26 07-30-2011 06:34 AM
CorkSport SRI Intakes CorkSport CorkSport 3 08-04-2010 03:54 PM
Page generated in 0.65705 seconds with 34 queries
