> HTP (Hi-Tuned Performance)
Like Tree110Likes
 Old 11-30-2014, 02:04 PM   #121
speed3sailor's Avatar
Posts: 835   (View Stats)
speed3sailor is the leader of the worldspeed3sailor is the leader of the worldspeed3sailor is the leader of the worldspeed3sailor is the leader of the worldspeed3sailor is the leader of the worldspeed3sailor is the leader of the worldspeed3sailor is the leader of the worldspeed3sailor is the leader of the worldspeed3sailor is the leader of the worldspeed3sailor is the leader of the worldspeed3sailor is the leader of the world
well I am out, I had one made for me to fit in a stock location
Pictures?
07 SILVER Speed3 , BNR S3- Tial 38mm EWG w/ stock mani- COBB AP- Ebay catless Downpipe- HTP 3in intake- Devils Own WMI (D10)- CX Racing FMIC- Autotech internals- Grimmspeed 3P EBCS- Denso ITV22- HKS super SQV- Bosch 3 bar - Damon PMM- JBR RMM- shift weight- EGR delete- TIGs- JBR RSB- Eibach springs- TR Motorsports 17x9- Hankook RS-3 255/40/17
speed3sailor is offline   Reply With Quote
The Following User Says Thank You to speed3sailor For This Useful Post:
CFI2008 (04-02-2015)
 Old 11-30-2014, 05:21 PM   #122
NCspecV81's Avatar
Posts: 2,867   (View Stats)
Originally Posted by speed3sailor View Post
Pictures?
Gettin' ready to have these remade in complete stainless. I have a company willing to do it. I need my car back to get it done tho. Will not be cheap. I measured around 7 quarts of total volume.
2013 CWP and Stock
The Following 8 Users Say Thank You to NCspecV81 For This Useful Post:
09TrueRedGTX (12-11-2014), Boostin'likeAboss (12-16-2014), breakfstincluded (01-07-2015), He Hate Me (04-05-2015), hnda etr (12-05-2014), jdmage_mx5 (11-30-2014), magicka (12-01-2014), speed3sailor (12-01-2014)
 Old 11-30-2014, 06:12 PM   #123
HTP
HTP's Avatar
Posts: 210   (View Stats)
Looks good! Location and fill neck wise this is very close to our design. Ours is much larger volume and incorporates a pump mount. (make sure you keep anti-seize on those threads or you will find that lid impossible to remove)
Stainless isn't necessary. We were very gung-ho about releasing these tanks until we talked to every meth injection manufacturer and they were very adamant about corrosion. It will corrode over night they said. Well it doesn't.
I will go into more detail as we set to finally release these. We will have an initial number of these available and if the interest is there, we will do a nice group buy.
Matt
SparkySparks likes this.
The Following 12 Users Say Thank You to HTP For This Useful Post:
09TrueRedGTX (12-11-2014), breakfstincluded (01-07-2015), cshunter (11-30-2014), faeker (01-03-2015), hnda etr (12-05-2014), jdmage_mx5 (11-30-2014), Mauro_Penguin (12-02-2014), Micha (12-14-2014), NCspecV81 (12-10-2014), neganox (12-10-2014), SparkySparks (12-10-2014), trancehead (01-22-2015)
 Old 11-30-2014, 08:23 PM   #124
NCspecV81's Avatar
What gauge aluminum are you using? No fear of the pump jolting around on hard launches screwing up the tank? That's the only reason a mount wasn't incorporated into this one. Did not want the that stress from hanging the pump off the side of it.
2013 CWP and Stock
motherfnmonsta (12-02-2014)
 Old 12-10-2014, 04:52 PM   #125
Feline Führer
neganox's Avatar
Posts: 1,790   (View Stats)
I'll take one. That tank looks aces man. I'm currently utilizing my WW reservoir as my meth tank. Is there truth to tanks having to be vented? Is that tank vented?
 Old 12-10-2014, 05:20 PM   #126
SparkySparks's Avatar
Posts: 1,314   (View Stats)
Matt
Looks like I might hold off a little longer on installing my meth kit.
On Order:
Coming Soon:
DIY Projects:
 Old 12-10-2014, 05:34 PM   #127
NCspecV81's Avatar
I dunno about HTP's, but I'm sure it likely does. Here's mine
2013 CWP and Stock
09TrueRedGTX (12-11-2014), neganox (12-10-2014)
 Old 12-20-2014, 02:18 PM   #128
msantana101's Avatar
Posts: 1,517   (View Stats)
Subbed
FreekTuned
 Old 12-29-2014, 04:09 PM   #129
Oni
Oni's Avatar
Posts: 565   (View Stats)
Matt
Any teaser pics available yet?
'12 Velocity Red Mica MS3
Cobb AP V3 // Autotech Fuel Pump Internals // HTP 3" // UR Catted V2 DP // UR Resonated TP // UR Resonated CBE // GrimmSpeed EBCS // CP-E TMIC // GFB Respons BPV // JBR Trilogy 88/80/80 // Corksport Hood Struts // Prosport EVO Boost Gauge w/ block8head vent pod // E30 Freektune
Installing Soon : Stratified GA // Bosch 3 Bar Map w/ PNP Harness
Oni is offline   Reply With Quote
 Old 01-03-2015, 11:16 AM   #130
faeker's Avatar
Posts: 5,091   (View Stats)
Groans: 731
3 quarts is not going to be enough for me so I'm very interested in this. Glad I finally found the subsection Matt haha.
Mods: stock
 Old 01-04-2015, 10:57 AM   #131
Matt@HTP's Avatar
Posts: 147   (View Stats)
Matt@HTP is the leader of the worldMatt@HTP is the leader of the worldMatt@HTP is the leader of the worldMatt@HTP is the leader of the worldMatt@HTP is the leader of the worldMatt@HTP is the leader of the worldMatt@HTP is the leader of the worldMatt@HTP is the leader of the worldMatt@HTP is the leader of the worldMatt@HTP is the leader of the worldMatt@HTP is the leader of the world
Just to add a little more info on our methanol testing and its corrosive effects.
It is true that 100% methanol is corrosive to aluminum, but for it to take effect, it takes a very, very long time. We have conducted a long term test because this face value claim pops up immediately when discussing it. We have tested this on cast alum, 3003 alum, 5352 alum (what we use for tanks), 6061 alum, & anodized alum (5352 & 6061). Due to the protective oxide layer that forms on the surface of alum when exposed to air, it is protected from corrosion for the most part.
Where we saw any type of corrosion was on cast, and over the length of 2 years, it was very minimal. All types of alum did surprisingly well over this period, the only spots that we saw signs of any type of etching is where we had put a scratch through the oxide layer and the HAZ area around a weld. Even this was very minimal and would have no effect on a methanol injection system. Anodized alum had zero effects.
This was all tested with 99.999% meth. Keep in mind that Methanol is hydrophilic, meaning that it attracts water and will absorb it, self diluting. So fresh methanol was constantly changed to keep the purity levels up. As I have studied these results and researched findings from corrosion engineers, I'm a little let down by this claim that everyone spouts so freely. Just as little as a couple percent of dilution of water, and the corrosive effects are gone.
What does this all mean? Maybe its time to finally release these tanks.
Got Meth?
Mauro_Penguin likes this.
Manufactured in house...but not in a house.
"Engineered" in an outhouse.
Matt@HTP is offline   Reply With Quote
The Following 23 Users Say Thank You to Matt@HTP For This Useful Post:
865ms3 (01-04-2015), BigRedSpecial (04-27-2015), Boostin'likeAboss (02-10-2015), breakfstincluded (01-07-2015), England15j (01-04-2015), faeker (01-04-2015), hnda etr (01-22-2015), Hush (01-04-2015), jdmage_mx5 (01-04-2015), John@RPM (01-07-2015), Koke382 (01-04-2015), levon.mark (01-04-2015), Mauro_Penguin (01-05-2015), msantana101 (01-04-2015), neganox (01-04-2015), smoogs12 (01-22-2015), speed3sailor (01-04-2015), SpeedRebirth (01-04-2015), Tomas (01-04-2015), trancehead (01-22-2015), UnknownSuperhero (01-06-2015), WetzMS3 (02-25-2015), YABBAMZR (01-23-2015)
 Old 01-04-2015, 12:03 PM   #132
2 weeks?
Seriously though, using the stock WWF tank is getting pretty old. I'm ready for this release.
 Old 01-04-2015, 05:20 PM   #133
Feline Führer
neganox's Avatar
My body is ready.
 Old 01-21-2015, 09:25 PM   #134
865ms3's Avatar
Posts: 2,602   (View Stats)
Bump
Brent
-Built Block-5858-Meth
Dragon Slayer Setup
FreekTuned
 Old 01-22-2015, 05:26 AM   #135
youngwonder's Avatar
youngwonder has a reputation beyond reputeyoungwonder has a reputation beyond reputeyoungwonder has a reputation beyond reputeyoungwonder has a reputation beyond reputeyoungwonder has a reputation beyond reputeyoungwonder has a reputation beyond reputeyoungwonder has a reputation beyond reputeyoungwonder has a reputation beyond reputeyoungwonder has a reputation beyond reputeyoungwonder has a reputation beyond reputeyoungwonder has a reputation beyond repute
I will be looking out for the release. I'm in the market to get another tank.
08 Mazdaspeed3
Hypnotic Tuned: e85
BNR s3 v2
AEM Meth Kit 100% Meth w/ DO10 (not using now)
Accessport V3
DNP Exhaust Manifold
Corksport Exhaust
JBR OCC s2
TR8 FMIC
CPE RMM Stage 2
HTP 3" Full Intake
Autotech Internals
CP-E downpipe - Catless
JBR short throw shifter
JBR shift knob
Corksport short shift plate
SS brakelines
Koni Yellow
H&R Springs
Low beam headlights - HID 6000k
Fog lights - HID 6000k
youngwonder is offline   Reply With Quote
 Old 01-22-2015, 07:04 AM   #136
faeker's Avatar
Groans: 731
I needs this right meow
Mods: stock
 Old 01-27-2015, 06:44 AM   #137
865ms3's Avatar
Bump @Matt@HTP; I need this! Preorder???
Brent
Dragon Slayer Setup
FreekTuned
 Old 01-27-2015, 07:53 AM   #138
chrisjnas's Avatar
Posts: 354   (View Stats)
chrisjnas is the leader of the worldchrisjnas is the leader of the worldchrisjnas is the leader of the worldchrisjnas is the leader of the worldchrisjnas is the leader of the worldchrisjnas is the leader of the worldchrisjnas is the leader of the worldchrisjnas is the leader of the worldchrisjnas is the leader of the worldchrisjnas is the leader of the worldchrisjnas is the leader of the world
@Matt@HTP; I'd be in.
chrisjnas is offline   Reply With Quote
 Old 02-10-2015, 06:09 AM   #139
@Matt@HTP; any update? I'm ready to spend money.
08 Mazdaspeed3
Hypnotic Tuned: e85
BNR s3 v2
Accessport V3
Corksport Exhaust
JBR OCC s2
TR8 FMIC
CPE RMM Stage 2
HTP 3" Full Intake
Autotech Internals
JBR shift knob
SS brakelines
Koni Yellow
H&R Springs
The Following User Says Thank You to youngwonder For This Useful Post:
865ms3 (02-10-2015)
 Old 02-10-2015, 09:47 AM   #140
865ms3's Avatar
Same! I need this and your hot pipe.
Brent
Dragon Slayer Setup
FreekTuned
 Old 02-10-2015, 06:13 PM   #141
Feline Führer
neganox's Avatar
I know of a few locals that would want in on this as well.
 Old 02-24-2015, 01:45 PM   #142
865ms3's Avatar
@Matt@HTP; any news??!!!?!
Brent
Dragon Slayer Setup
FreekTuned
 Old 02-24-2015, 09:35 PM   #143
Matt@HTP's Avatar
All I'm gonna say is it IS in the lineup to release real soon. We have received a lot of support lately, and we would like to support your meth habit in return.
WetzMS3 likes this.
The Following 5 Users Say Thank You to Matt@HTP For This Useful Post:
865ms3 (02-25-2015), ASHMS3 (02-25-2015), Mauro_Penguin (02-25-2015), WetzMS3 (02-25-2015), xfeejayx (03-02-2015)
 Old 02-25-2015, 06:16 AM   #144
My decals add horsepower
TJM216's Avatar
Posts: 72   (View Stats)
TJM216 has much to be proud ofTJM216 has much to be proud ofTJM216 has much to be proud ofTJM216 has much to be proud ofTJM216 has much to be proud ofTJM216 has much to be proud ofTJM216 has much to be proud ofTJM216 has much to be proud of
Finally!!! Been waiting for this!
2008.5 Mazdaspeed 3 Built Block
Power
Cobb APv3, CPE HPFP, Cobb Intake, JBR FMIC with TR8, JBR Shifter, JBR Passenger & Transmission Mounts, CPE Stage2 RMM, Turboxs Downpipe, CNT Exhaust, EGR Delete, JBR TIGS/Coolant Bypass, JBR OCC
BT build coming soon!
Mark Gibson Tune (in progress)
TJM216 is offline   Reply With Quote
 Old 02-25-2015, 08:25 AM   #145
I could use more HTP sexiness in my car! This included.
 Old 03-10-2015, 04:00 PM   #146
England15j's Avatar
Posts: 1,910   (View Stats)
Any Update?
The Following User Says Thank You to England15j For This Useful Post:
865ms3 (03-10-2015)
 Old 03-31-2015, 08:26 AM   #147
865ms3's Avatar
Sigh........bump
@Matt@HTP;
Brent
Dragon Slayer Setup
FreekTuned
 Old 03-31-2015, 08:42 AM   #148
Yatta's Avatar
Posts: 1,862   (View Stats)
I’ve had a devils own kit waiting for install mostly because I wanted to upgrade the stock WWF tank to Canadian spec before doing so... this would eliminate that requirement and it has been more than 2 weeks...
 Old 03-31-2015, 08:47 AM   #149
I cannot wait to get my hands on this and see what HTP has come up with. Sounds like the mad scientist will want my new meth setup active this week, so soon I'll need that extra capacity and sexy welds behind my bumper.
 Old 03-31-2015, 10:55 AM   #150
Putin 2.3T's Avatar
Posts: 1,040   (View Stats)
@Matt@HTP; yup.. I'm back. This time I'm here to bug you until you release this meth tank. I have two options right now. I either run your tank or I run trunk-mount. Now since I own a MS3, that would put the methanol right in the cabin. Imagine if I were to get in a roll-over crash and I'm smoking. I'd be lit up in invisible flames and the firefighters wouldn't even know that i'm burning alive. Would you want that on your conscience?! WOULD YOU?!
I hope you can sleep at night knowing that there's the possibility that somebody out there could be risking their lives right now running a trunk-mount meth tank when they could be running your meth tank instead. Think of the children when they come home to find out that their parents died in a horrific crash that they could have survived had they not used an in-trunk meth tank. Then they'll look at you with tears in their eyes and ask "Why Matt, why didn't you release the meth tank soon enough? My mommy and daddy would still be alive." You heartless bastard..
Think of the children..
I love your under-route piping by the way.
2011 Mazdaspeed 3 [Sold]
The Following 10 Users Say Thank You to Putin 2.3T For This Useful Post:
BigRedSpecial (04-27-2015), Code Monkey (03-31-2015), dan7225 (03-31-2015), England15j (03-31-2015), Hush (03-31-2015), JSmith (03-31-2015), Mauro_Penguin (03-31-2015), SpeedRebirth (03-31-2015), WetzMS3 (03-31-2015), Yatta (03-31-2015)
 Old 03-31-2015, 10:59 AM   #151
HTP products are proudly made in the U.S.A. @Matt@HTP; doesn't give a damn about your commie ass!
However, I am a red blooded American, who fears the same fate. Please help Matt!!!
 Old 03-31-2015, 11:07 AM   #152
865ms3's Avatar
Mines already in the hatch....it's a ticking time bomb!
Brent
Dragon Slayer Setup
FreekTuned
 Old 03-31-2015, 11:16 AM   #153
Yatta's Avatar
Will Vodka work in lieu of meth? having that in cabin, no, wrong...
 Old 03-31-2015, 11:46 AM   #154
smckenzie04's Avatar
Posts: 24   (View Stats)
smckenzie04 is just really nicesmckenzie04 is just really nicesmckenzie04 is just really nicesmckenzie04 is just really nicesmckenzie04 is just really nice
I'n for a MS6 version in the same location!
smckenzie04 is offline   Reply With Quote
The Following 2 Users Say Thank You to smckenzie04 For This Useful Post:
PhillyCheese (04-01-2015), wwpms6 (04-01-2015)
 Old 03-31-2015, 08:48 PM   #155
Matt@HTP's Avatar
Sheesh @Putin 2.3T; I'm all teary-eyed now. That was heart felt.
The meth tank will be making an appearance at ENM.......for the children.
xfeejayx, neganox and WetzMS3 like this.
The Following 7 Users Say Thank You to Matt@HTP For This Useful Post:
865ms3 (04-01-2015), He Hate Me (04-05-2015), jdmage_mx5 (03-31-2015), neganox (04-01-2015), Putin 2.3T (04-01-2015), rymanmazda (04-01-2015), WetzMS3 (03-31-2015)
 Old 04-01-2015, 07:42 AM   #156
Feline Führer
neganox's Avatar
fap fap fap fap fap fap
 Old 04-01-2015, 11:11 AM   #157
865ms3's Avatar
Bring me one. I'll buy it.
Brent
Dragon Slayer Setup
FreekTuned
 Old 04-01-2015, 11:18 AM   #158
Do you have a price on it? Are you going to sell them at ENM or it's just being shown?
08 Mazdaspeed3
Hypnotic Tuned: e85
BNR s3 v2
Accessport V3
Corksport Exhaust
JBR OCC s2
TR8 FMIC
CPE RMM Stage 2
HTP 3" Full Intake
Autotech Internals
JBR shift knob
SS brakelines
Koni Yellow
H&R Springs
 Old 04-01-2015, 11:36 AM   #159
rymanmazda's Avatar
Posts: 1,531   (View Stats)
Groans: 122
Also, sidenote, when is the under routed fmic piping coming out? I have a TR8 that I won from you guys and it needs a buddy so I can install them.
Freektune: 400whp/387awtq
-Autocross Setup-
Other Rides:
 Old 04-01-2015, 03:34 PM   #160
PhillyCheese's Avatar
Posts: 226   (View Stats)
in for a ms6 version also
MOD LIST
UNDER CONSTRUCTION
The Following User Says Thank You to PhillyCheese For This Useful Post:
wwpms6 (04-01-2015)
Page generated in 0.57108 seconds with 40 queries
