| HTP (Hi-Tuned Performance) HTP (Hi-Tuned Performance) is dedicated to providing the automotive community with quality performance products and the highest level of customer service and support. Whether you're local or overseas, we like to approach each customer as though they're sitting right in front of us at the shop. Whether you're a long time customer or if you're new to HTP, we look forward to having the opportunity to prove our commitment to quality and service. |
![]() | | #321 | ![]() |
![]() Join Date: May 2013 Location: CO
Rep Power: 2407 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,487
| Not Ranked : 0 score ![]() tapatalk, it sucks |
| The Following 2 Users Say Thank You to monkey.bones.007 For This Useful Post: | aromig (07-20-2015), PhillyCheese (07-20-2015) |
![]() | | #322 | ![]() |
| Not Ranked : 0 score |
| The Following 5 Users Say Thank You to Raider For This Useful Post: | adamizme (07-21-2015), aromig (07-20-2015), Easter Bunny (07-21-2015), Mauro_Penguin (07-22-2015), WetzMS3 (12-08-2015) |
![]() | | #323 | ![]() |
![]() Join Date: Aug 2011 Location: Fuckin Topeka, Kansas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,200
__________________ "I apologize for nothing!" - Hedonismbot ![]() Last edited by aromig; 07-20-2015 at 10:08 PM. Reason: MSF Database - Automerged Doublepost |
| The Following User Says Thank You to aromig For This Useful Post: | Easter Bunny (07-21-2015) |
![]() | | #324 | ![]() |
__________________ "I apologize for nothing!" - Hedonismbot ![]() |
![]() | | #325 | ![]() |
| The Following User Says Thank You to MS3Shadow For This Useful Post: | Easter Bunny (07-21-2015) |
![]() | | #326 | ![]() |
![]() | | #327 | ![]() |
![]() | | #328 | ![]() |
![]() | | #329 | ![]() |
| The Following User Says Thank You to MS3Shadow For This Useful Post: | Code Monkey (07-25-2015) |
![]() | | #330 | ![]() |
![]() Join Date: Aug 2013 Location: St. Louis, MO
Rep Power: 0 ![]() ![]() ![]() ![]() Thanks: 32
| Not Ranked : 0 score @Matt@HTP; stop horseplaying on vacation! |
![]() | | #331 | ![]() |
![]() Join Date: Oct 2012 Location: Colorado Springs, CO
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 757
| Not Ranked : 0 score As to interest, I have a DVC30 kit waiting for a 'real' bracket/tank solution.... On a genpu...how soon is meow? But it isn't respectable. It's mildly terrifying. And that actually makes it quite appealing. - Mazda 3 MPS review, Matthew Jones, Top Gear.
__________________ mods: \\// AT HPFP // AccessPort // CS S2 TIP, SRI and TMIC // CPe S2 RMM // Synapse BPV // Mazda gutted secondary cat // S-OTS+ 91S2 // HKS TP DLi II // Wilwood DP6 13” brakes // TCE 2 piece rear rotors // Maxwell SuperCap/LiFePO4 cell \\// waiting for install: \\// CPE Catted DP // CS Battery Box // Devils Own Meth kit // H&R Coilovers \\// |
![]() | | #332 | ![]() |
![]() Join Date: Sep 2011 Location: Jacksonville, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 402
| Not Ranked : 0 score It's been almost a full 3 years since Matt started this thread. I wouldn't wait to install install your kit. Tap your washer fluid tank for now. If you want a level sensor, install one of the self sealing deals or get the mz5/Canadian tank assembly.
__________________ 2012 Mazdaspeed 3 w/ tech package CS LED Kit & Fogs - *painted* CF hood - VG Sharkfin antenna - CS TMM insert - DM PMM - CPe S2 RMM - Cobb AP - JBR True 3" intake - Autotech FP Internals - JBR RSB - CS Racepipe - CS SSB - JBR Short Shifter - CS SSP & weight - Motocraft tranny fluid - CS TMIC - NGK plugs - modified CS Cold Air Box - JBR EGR delete - CS OCC - DO WMI kit w/ d05 - DM TB spacer - CS BPV - KW v1 Coilovers - Whiteline adjustable endlinks - SPC camber arms - tons of GTSpec braces - Whiteline bump steer kit - Wilwood 6 pot front calipers w/ Wilwood slotted rotors - mz5 rear slotted rotors & brackets - front & rear SS brake lines - Freek tune |
![]() | | #333 | ![]() |
![]() Join Date: Aug 2012 Location: Auburn, MI
Still waiting ... ![]() ![]() ![]() ![]() ![]()
__________________ '12 Velocity Red Mica MS3 Cobb AP V3 // Autotech Fuel Pump Internals // HTP 3" // UR Catted V2 DP // UR Resonated TP // UR Resonated CBE // GrimmSpeed EBCS // CP-E TMIC // GFB Respons BPV // JBR Trilogy 88/80/80 // Corksport Hood Struts // Prosport EVO Boost Gauge w/ block8head vent pod // E30 Freektune Installing Soon : Stratified GA // Bosch 3 Bar Map w/ PNP Harness [SIGPIC][/SIGPIC] | |
| The Following 2 Users Say Thank You to Oni For This Useful Post: | adamizme (08-13-2015), Mauro_Penguin (08-13-2015) |
![]() | | #334 | ![]() |
| Might need more cats. Sent from my HTC M9
| The Following User Says Thank You to MS3Shadow For This Useful Post: | aromig (08-13-2015) |
![]() | | #335 | ![]() |
| The Following 2 Users Say Thank You to aromig For This Useful Post: | adamizme (08-14-2015), Code Monkey (08-13-2015) |
![]() | | #336 | ![]() |
| Sent from my HTC M9
![]() | | #337 | ![]() |
| The Following User Says Thank You to Code Monkey For This Useful Post: | aromig (08-13-2015) |
![]() | | #338 | ![]() |
| The Following 2 Users Say Thank You to MS3Shadow For This Useful Post: | aromig (08-13-2015), Easter Bunny (08-14-2015) |
![]() | | #339 | ![]() |
__________________ "I apologize for nothing!" - Hedonismbot ![]() Last edited by aromig; 08-13-2015 at 10:29 PM. Reason: derp |
| The Following User Says Thank You to aromig For This Useful Post: | Easter Bunny (08-14-2015) |
![]() | | #340 | ![]() |
| The Following 3 Users Say Thank You to MS3Shadow For This Useful Post: |
![]() | | #341 | ![]() |
| Not Ranked : 0 score Because boobytrap
| The Following 3 Users Say Thank You to aromig For This Useful Post: |
![]() | | #342 | ![]() |
| The Following 2 Users Say Thank You to aromig For This Useful Post: | Code Monkey (08-16-2015), MS3Shadow (08-16-2015) |
![]() | | #343 | ![]() |
| Sent from my HTC M9
| The Following 2 Users Say Thank You to MS3Shadow For This Useful Post: | aromig (08-16-2015), Code Monkey (08-16-2015) |
![]() | | #344 | ![]() |
![]() | | #345 | ![]() |
| The Following User Says Thank You to MS3Shadow For This Useful Post: | aromig (08-18-2015) |
![]() | | #346 | ![]() |
| Not Ranked : 0 score Getting multiple requests from multiple members for multiple vendor pages, to please chill out with the cat pics, as it derails the threads and pollutes them to the point the real information when posted, is likely to be unseen. So I am asking to stop the derailing. Or as the other crowd informs me I am doing, is making MSF boring and push old members away or something. Here is the official "discussion section" http://www.mazdaspeedforum.org/forum/foru...nifold-192475/ Last edited by Raider; 08-25-2015 at 01:43 PM. |
| The Following User Says Thank You to Raider For This Useful Post: | motherfnmonsta (08-25-2015) |
![]() | | #347 | ![]() |
__________________ 2012 Mazdaspeed 3 w/ tech package CS LED Kit & Fogs - *painted* CF hood - VG Sharkfin antenna - CS TMM insert - DM PMM - CPe S2 RMM - Cobb AP - JBR True 3" intake - Autotech FP Internals - JBR RSB - CS Racepipe - CS SSB - JBR Short Shifter - CS SSP & weight - Motocraft tranny fluid - CS TMIC - NGK plugs - modified CS Cold Air Box - JBR EGR delete - CS OCC - DO WMI kit w/ d05 - DM TB spacer - CS BPV - KW v1 Coilovers - Whiteline adjustable endlinks - SPC camber arms - tons of GTSpec braces - Whiteline bump steer kit - Wilwood 6 pot front calipers w/ Wilwood slotted rotors - mz5 rear slotted rotors & brackets - front & rear SS brake lines - Freek tune | |
| The Following 3 Users Say Thank You to adamizme For This Useful Post: |
![]() | | #348 | ![]() |
| Not Ranked : 0 score I thought we were striving to become the number one cat gif forum.
![]() | | #349 | ![]() |
![]() Join Date: Dec 2013 Location: Mountain House, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 596
| Not Ranked : 0 score @HTP; is this your meth tank?
__________________ 2013 Mazdaspeed3 Crystal White Pearl [Damond Motorsports RMM & SSP] [Maisonvi Grooved Dessert Beagle Knob] [COBB AP V3] [CorkSport HPFP Internals, SRI, TIP, TMIC & LEDs] [Sure M3 TP] [cp-e Triton CBE] [GFB BOV] [91 Octane Purple Drank Tuned - 260whp/290wtq - VDyno] Parts to Install: [JBR 3" TRU-3" Intake & Solid Shifter Bushings] [DDM HID Kit] |
![]() | | #350 | ![]() |
| Approved MSF Vendor ![]() Join Date: Dec 2014 Location: In full orbit.
Rep Power: 489 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 24
| The Following User Says Thank You to Matt@HTP For This Useful Post: | Micha (12-08-2015) |
![]() | | #351 | ![]() |
![]() Join Date: Nov 2010 Location: Reading, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 23,158
Groans: 731
| Not Ranked : 0 score Is it in production, if not when, and at what price point.
__________________ Mods: stock Eventually I'll pay for how I am....but it won't be by the hand of any of you faggot fucks here. |
| The Following 3 Users Say Thank You to faeker For This Useful Post: |
![]() | | #352 | ![]() |
| Not Ranked : 0 score Is this 100% going into production? If yes I'm going to wait it out to go meth... Sent from my iPhone using Tapatalk
![]() | | #353 | ![]() |
| Not Ranked : 0 score Yes, 100%. Introductory offer/price point will be posted. |
| The Following 10 Users Say Thank You to Matt@HTP For This Useful Post: | Easter Bunny (12-08-2015), faeker (12-07-2015), jdmage_mx5 (12-07-2015), littleloogy (12-07-2015), magicka (12-08-2015), Mauro_Penguin (12-08-2015), Micha (12-08-2015), MS3Shadow (12-08-2015), neganox (12-08-2015), NoRegrets (12-08-2015) |
![]() | | #354 | ![]() |
| Feline Führer ![]() Join Date: Feb 2013 Location: Jacksonville, FL
Rep Power: 2280 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,422
| Not Ranked : 0 score I peed a little.
__________________ Official CatDickRacing Sales Rep - All products backordered. |
| The Following 4 Users Say Thank You to neganox For This Useful Post: |
![]() | | #355 | ![]() |
![]() | | #356 | ![]() |
![]() Join Date: Aug 2012 Location: Ripon, CA
Rep Power: 2958 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,390
| Not Ranked : 0 score I'm going to need a tank eventually, might as well get in on some of this action. |
![]() | | #357 | ![]() |
I'm thinking the same thing... Don't want a tank in my trunk and don't want to half ass rig something with a standard plastic tank Sent from my iPhone using Tapatalk
__________________ 2013 Mazdaspeed3 Crystal White Pearl [Damond Motorsports RMM & SSP] [Maisonvi Grooved Dessert Beagle Knob] [COBB AP V3] [CorkSport HPFP Internals, SRI, TIP, TMIC & LEDs] [Sure M3 TP] [cp-e Triton CBE] [GFB BOV] [91 Octane Purple Drank Tuned - 260whp/290wtq - VDyno] Parts to Install: [JBR 3" TRU-3" Intake & Solid Shifter Bushings] [DDM HID Kit] | |
![]() | | #358 | ![]() |
| Not Ranked : 0 score 2.5 gallons eh @Matt@HTP;?! You all grew it up a little.
![]() | | #359 | ![]() |
| The Following 6 Users Say Thank You to Matt@HTP For This Useful Post: | Hush (12-08-2015), littleloogy (12-08-2015), Mauro_Penguin (12-08-2015), Micha (12-08-2015), MS3Shadow (12-08-2015), neganox (12-08-2015) |
![]() | | #360 | ![]() |
![]() Join Date: Jun 2012 Location: Asia
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 112
| Not Ranked : 0 score Just an idea, the tank location (just behind the bumper) may be risky if involve in a nasty accident. It might be worst case scenario which it could ignite and blow up and whole engine is on flame. What about some crash bar or some reinforcement in front of the tank? |
| Venting meth tank | f-castrillo | 2010 MS3 - Fuel, Nitrous & Water Injection | 17 | 04-19-2012 01:49 AM |
| best way to seal 100% meth tank?? | seanmiller09 | MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection | 0 | 08-04-2010 08:17 PM |
