> HTP (Hi-Tuned Performance)
Like Tree85Likes
 Old 06-09-2016, 08:11 AM   #81
Matt@HTP's Avatar
Posts: 147   (View Stats)
Matt@HTP is the leader of the worldMatt@HTP is the leader of the worldMatt@HTP is the leader of the worldMatt@HTP is the leader of the worldMatt@HTP is the leader of the worldMatt@HTP is the leader of the worldMatt@HTP is the leader of the worldMatt@HTP is the leader of the worldMatt@HTP is the leader of the worldMatt@HTP is the leader of the worldMatt@HTP is the leader of the world
No reply to an email sent this weekend inquiring about shipping dates.
I do not see an email from you, we got one from Will and Brian both have been replied to.
Next week we will start to see these trickle back from anodizing, so not everyone will get dropped tracking at once.
I will say that anodizing these on the inside with proper coverage has been a tricky. This is due to the smaller holes and making sure that there is no trapped air. We made design changes to aid in this process but it still required more attention on the coaters part and they aren't able to anodize as many at a time as we were quoted. I went and met with them early this week and got them to agree to running these in smaller batches and even 1 at a time if we have to.
I apologize for the wait, and thank you all for being patient.
willix231 and nekret like this.
Manufactured in house...but not in a house.
"Engineered" in an outhouse.
Matt@HTP is offline   Reply With Quote
The Following 8 Users Say Thank You to Matt@HTP For This Useful Post:
Boost_creep (06-13-2016), CMajor (06-11-2016), JSmith (06-09-2016), MS3Shadow (06-09-2016), neganox (06-09-2016), nekret (06-09-2016), Shwaykid (06-09-2016), WetzMS3 (06-09-2016)
 Old 06-20-2016, 12:47 PM   #82
JgamB's Avatar
Posts: 2,566   (View Stats)
I have my tank and it's installed. If you're frustrated with the wait, I can promise you the fit and craftsmanship make it all worthwhile.
Here it is complete with the accessories and hardware
4 studs in the sturdy pump mount plate and some nylock nuts
The grounds are integrated cleanly back to their stock location, and the other 4 bolts are in the frame rail. This isn't going anywhere.
Ahhh, so easy to fill with that convenient neck. I got a tall transmission fill funnel from Napa and it stands in there unsupported. The hose headed off to the right is the ventilation line.
I hacked a 3/4" segment out of my JBR cold pipe and slipped this 3 bung adapter in there (after I ground them down to get a clean spray pattern)
And here you can see blurry in the foreground is the check valve and line headed up to a D12 nozzle. I'll be adding a D10 to that, and expect the pump will be near its limits.
Installation is painless and logical. The welds are works of art. The mounting points align perfectly and are extremely solid. Yes, it was a long wait - but it's worth it.
Edit: DO NOT FORGET IT'S 3/8 NPT COMING FROM THE TANK FEED - if you still want to use your push lock 1/8th npt stuff, you'll need an adapter as pictured above. I ordered one from Summit, then called Napa and they had it in stock - so I've got a spare reducer if anyone needs it.
nekret and MS3Shadow like this.
The Following 13 Users Say Thank You to JgamB For This Useful Post:
Boost_creep (06-21-2016), CMajor (06-20-2016), Code Monkey (06-20-2016), g00s3y (06-20-2016), Hush (06-20-2016), Jester2552 (06-21-2016), JSmith (06-20-2016), Matt@HTP (06-21-2016), MD1032 (06-21-2016), MS3Shadow (06-20-2016), nekret (06-20-2016), nindoja (06-20-2016), Shwaykid (06-20-2016)
 Old 06-21-2016, 01:12 PM   #83
Boost_creep's Avatar
Posts: 829   (View Stats)
No filter?
Are you concerned about possible debris or metal shavings in the tank that might make its way into the pump? Or was the tank clean as a whistle? Lol.
www.dizzytuning.com
www.facebook.com/dizzytuning
 Old 06-21-2016, 02:00 PM   #84
willix231's Avatar
Posts: 1,315   (View Stats)
willix231 has a reputation beyond reputewillix231 has a reputation beyond reputewillix231 has a reputation beyond reputewillix231 has a reputation beyond reputewillix231 has a reputation beyond reputewillix231 has a reputation beyond reputewillix231 has a reputation beyond reputewillix231 has a reputation beyond reputewillix231 has a reputation beyond reputewillix231 has a reputation beyond reputewillix231 has a reputation beyond repute
Nice. Glad to see it came out so clean
Corksport Sri+Tip, Cobb FMIC, Turbosmart BPV, NGK 1 step colder Plugs,Cobb accessport v2,Cobb RMM,cobb shift weight, Megan racing test pipe, Racing beat catback exhaust, Labonte wmi controller with cooling mist pump,stratified 91 octane & e85 ots tunes,Mazdaspeed oem coilovers,CS camber plates,whiteline ALK, whiteline bumpsteer kit, whiteline poly bushings, JBR rear sway bar, SPC rear camber arms,Gtspec mid chassis Aluminum brace, Gt spec rear cross member Brace with V brace addition,Wilwood 4 pot BBk+hawk DTC 60 with DBA 4000 rotors(F),Stoptech high carbon rotor(R), stoptech street performance pads(R), Stoptech stainless steel braided brake line(FxR), Enkei Rpf1 17*8.8 +30, Aluminum hubcentric rings, Work Rs open ended lug nuts, Hankook Rs3 245/40/17
willix231 is offline   Reply With Quote
The Following User Says Thank You to willix231 For This Useful Post:
JgamB (06-22-2016)
 Old 06-21-2016, 04:17 PM   #85
Matt@HTP's Avatar
No filter?
There is no debris in these from the manufacturing process. All holes were laser cut before it was formed. They all were QC & pressure tested for leaks before they went to the anodizer. They also do 2 QC checks at their ISO facility. Any debris will be introduced when filling, so don't eat Taquitos above the funnel when you fill it.
MS3Shadow likes this.
The Following 14 Users Say Thank You to Matt@HTP For This Useful Post:
AwAfrican (07-16-2016), Boost_creep (06-21-2016), CMajor (06-27-2016), g00s3y (06-22-2016), Hush (06-21-2016), Jester2552 (06-21-2016), JgamB (06-22-2016), JSmith (06-21-2016), MD1032 (06-21-2016), MS3Shadow (06-21-2016), neganox (06-22-2016), nekret (06-21-2016), Thepedigree13 (06-22-2016), WetzMS3 (07-01-2016)
 Old 06-22-2016, 05:11 AM   #86
Feline Führer
neganox's Avatar
Posts: 1,790   (View Stats)
Don't tell me how to live.
AwAfrican and riflex like this.
The Following 10 Users Say Thank You to neganox For This Useful Post:
Boost_creep (06-22-2016), CMajor (06-27-2016), JgamB (06-22-2016), JSmith (06-22-2016), Matt@HTP (06-22-2016), MD1032 (06-22-2016), MS3Shadow (06-22-2016), Shwaykid (06-22-2016), Thepedigree13 (06-22-2016), WetzMS3 (07-01-2016)
 Old 06-22-2016, 05:55 AM   #87
He didn't say anything about burritos.
sent from my Nexus 6P
The Following 4 Users Say Thank You to MS3Shadow For This Useful Post:
CMajor (06-27-2016), Matt@HTP (06-22-2016), willix231 (06-22-2016), xorphanx (06-22-2016)
 Old 06-22-2016, 03:05 PM   #88
nindoja's Avatar
Posts: 2,395   (View Stats)
Just so you guys know, you should run solenoids with this tank. Isn't that right @JgamB;?
JgamB likes this.
True Red 2009 MS3
Tune: hypnotic tuned
Critical Stats:
// 305whp/352tq
 Old 06-22-2016, 03:11 PM   #89
MD1032's Avatar
Posts: 2,624   (View Stats)
Groans: 143
Since when was it ever acceptable to not use a solenoid... The problem you described has been around for years now. Check valves don't magically stop methanol flow...they just only allow flow in one direction. Some of them are spring loaded like the DO ones, but this spring is not intended to keep methanol from flowing when the pump is shut off. Dale found this out in his thread recently.
Dale's meth injection fun - pre vs. post TB and dual vs. single nozzle
2007 Mazdaspeed3 GT
 Old 06-22-2016, 03:18 PM   #90
nindoja's Avatar
I'm aware of the thread. Just wanted to poke at Jason some more lol.
True Red 2009 MS3
Critical Stats:
// 305whp/352tq
The Following 2 Users Say Thank You to nindoja For This Useful Post:
JgamB (06-22-2016), MD1032 (06-22-2016)
 Old 06-22-2016, 05:06 PM   #91
Feline Führer
neganox's Avatar
My tank better include a smedium tshirt or some fancy cat laser etching. "Catsensual induction"
HTP likes this.
 Old 06-22-2016, 05:39 PM   #92
Matt@HTP's Avatar
We are working up some more shirts. That is a damn good idear.
The Following 2 Users Say Thank You to Matt@HTP For This Useful Post:
neganox (06-23-2016), WetzMS3 (07-01-2016)
 Old 06-22-2016, 07:00 PM   #93
JgamB's Avatar
No filter?
I have DO nozzles, they have micro mesh screens at the nozzle. But regardless, I filled with water first, primed and flushed the tank. I had no idea HTP went to those lengths to keep it clean. I also don't run 100% meth right off - I make sure my lines aren't leaking, etc.
Too bad I relied on a check valve though.. lol. I would NOT recommend Devil's Own for that. As @MD1032; pointed out, they aren't all made equally.
This is a much better option apparently, but I went with a solenoid
 Old 06-25-2016, 09:34 AM   #94
@Matt@HTP;, any updates on Gen1 ship dates? I received the email that they will be coming back from anodizing soon, so I'm planning a July 11th install. Please tell me I will have it by then
www.dizzytuning.com
 Old 06-25-2016, 10:58 AM   #95
Jester2552's Avatar
Posts: 126   (View Stats)
Jester2552 is the leader of the worldJester2552 is the leader of the worldJester2552 is the leader of the worldJester2552 is the leader of the worldJester2552 is the leader of the worldJester2552 is the leader of the worldJester2552 is the leader of the worldJester2552 is the leader of the worldJester2552 is the leader of the worldJester2552 is the leader of the worldJester2552 is the leader of the world
That's a bold move Cotton
nekret and CMajor like this.
2007 Black MS3
CorkSport Turbocharger, HTP 3" Intake, CorkSport Catless Downpipe, CorkSport Catless Testpipe, CorkSport Catback, Tial 38mm EWG, GrimmSpeed EBCS, Bosch 3 Bar MAP Sensor, Forge V1 BPV, Cobb AcessPort, CP-e Stage 2 RMM, JBR Rear Sway, Moog Endlinks, ETS TMIC, AT Internals, JBR IM/TB TIG, Bilstein B8s, Cobb Springs, Rays Gram Lights 57C6 18X8.5 ET45, 235/40 Ventus RS-3,
Tuned by Nishan
USAF 2W1 "Warheads on Foreheads"
Jester2552 is offline   Reply With Quote
 Old 06-27-2016, 07:53 AM   #96
Jarods7920's Avatar
Posts: 1,415   (View Stats)
CMajor likes this.
 Old 07-01-2016, 08:06 AM   #97
Matt@HTP's Avatar
Got a handful going out today!
nekret and ItsNox like this.
The Following 10 Users Say Thank You to Matt@HTP For This Useful Post:
CMajor (07-01-2016), g00s3y (07-01-2016), Hush (07-01-2016), JgamB (07-01-2016), JSmith (07-01-2016), MS3Shadow (07-01-2016), nekret (07-01-2016), Shwaykid (07-01-2016), therza2169 (07-01-2016), WetzMS3 (07-01-2016)
 Old 07-01-2016, 09:05 AM   #98
willix231's Avatar
Gen 1 or two?
Sent from my LG-H810 using Tapatalk
 Old 07-01-2016, 09:19 AM   #99
Matt@HTP's Avatar
Originally Posted by willix231 View Post
Gen 1 or two?
These are Gen 2's.
We are receiving more back from anodizing on Tuesday.
 Old 07-01-2016, 09:22 AM   #100
i know one of those are mine, i got a email about it shipping soon.
 Old 07-01-2016, 01:24 PM   #101
Feline Führer
neganox's Avatar
None of those boxes contain cat related items or candy with said meth tank. Pass.
 Old 07-11-2016, 09:22 AM   #102
HTP
HTP's Avatar
Posts: 210   (View Stats)
Original post updated with shipped orders.
The Following User Says Thank You to HTP For This Useful Post:
JSmith (07-11-2016)
 Old 07-11-2016, 09:30 AM   #103
willix231's Avatar
Gen 1 not feeling the love
The Following 2 Users Say Thank You to willix231 For This Useful Post:
Jester2552 (07-11-2016), Shwaykid (07-11-2016)
 Old 07-15-2016, 10:38 AM   #104
Daily Driver
Nitr0EngiE's Avatar
Posts: 2,614   (View Stats)
Ill be the first one to buy one of these used when someone decides they dont want.
I want something like this with the fill neck, no paint, and only 2 fittings 1/2 NPT one top one bottom so I can use it as a air to water intercooler tank. I just want plain aluminum.
@HTP; do you have any beta units or incomplete or failures or something that can be made like this cheap ? I dont want all the finishes.
 Old 07-15-2016, 10:47 AM   #105
Matt@HTP's Avatar
For use of an expansion tank? Should be no problem. Our CTSV expansion tank is the same as the Speed but with different mounting brackets and a Jabsco pump flange.
 Old 07-15-2016, 11:20 AM   #106
Daily Driver
Nitr0EngiE's Avatar
Link? I have a bosch cobra water pump so I am not sure about what mounting solution to use.
how affordable can you make it without any finish or anything, my water core has no coating on it either nor the radiator so I see no need to coat the tank. I know its nice, but I need to save cost.
I was going to have one fabbed locally, but if you got something we can work out thats close to the cost then I wont take my car to the shop.
Depending on the capacity of the expansion tank I was even going to go for a second tank on opposite side, but one should be enough. I also though about putting an ice box in the passenger floor board but I already claimed the entire trunk for meth, audio, and battery.
My system barely seems to hold a gallon and I think it heat soaks fast. I would like to add like 3 gal to it, but of course fitment is always a bitch on this car. I have a good spal fan on the heat exchange and the bosch pump with this kit:
Water to Air Intercooler
So im only using the core and heat exchange and hoses everything else i upgraded.
So if you can lead some advice on this, then also i have 2.5" IC pipe feeding the 3" core inlet with 3" out going to stock TB which is smaller than the outlet. Should I reduce the outlet with some sort of weld on aluminum to restrict flow and slow it down? I get boost creep with the new air to water as it steadily climbs from 25 to 26.3+ boost till redline and never stops. I did not have this issue with my CPE Fmic, but now i got like 14 inches of intercooler piping opposed to several feet so I assume I lost pressure drop.
The Following 2 Users Say Thank You to Nitr0EngiE For This Useful Post:
Boost_creep (07-15-2016), WetzMS3 (07-15-2016)
 Old 07-15-2016, 11:23 AM   #107
Daily Driver
Nitr0EngiE's Avatar
here is a picture of the setup
nekret likes this.
The Following 4 Users Say Thank You to Nitr0EngiE For This Useful Post:
Boost_creep (07-15-2016), MD1032 (07-16-2016), nekret (07-15-2016), WetzMS3 (07-15-2016)
 Old 07-15-2016, 01:16 PM   #108
willix231's Avatar
When are rest of us getting our shipment?
 Old 07-15-2016, 02:01 PM   #109
Daily Driver
Nitr0EngiE's Avatar
He just told me on the phone hes going on 2 week vacation and no orders will be filled during that time, so sometimes after that. their website says the same thing, shipping resumes 8/1 (FOR NORMAL ORDERS, not this item)
 Old 07-15-2016, 02:29 PM   #110
Shwaykid's Avatar
Posts: 646   (View Stats)
Makes me not feel so bad about not even having a meth kit yet.
2008 Mazdaspeed3 GT
Jet Black Wax (06/24/2017)
Shwaykid is offline   Reply With Quote
 Old 07-15-2016, 02:48 PM   #111
Daily Driver
Nitr0EngiE's Avatar
lol put the cart before the horse much ?
 Old 07-15-2016, 02:50 PM   #112
Shwaykid's Avatar
Nah. I'm for sure going meth. This tank came around at a damn good price so I jumped on it.
2008 Mazdaspeed3 GT
 Old 07-15-2016, 03:03 PM   #113
i bought this before the meth kit as well. it's a good deal to not pass up.
 Old 07-16-2016, 12:27 PM   #114
Jester2552's Avatar
Won't be shipping anymore Tanks until 8/1? Fack!
2007 Black MS3
Tuned by Nishan
 Old 07-16-2016, 01:19 PM   #115
JSmith's Avatar
Posts: 707   (View Stats)
Groans: 106
If the log jam is the anodizing shop...then this shouldnt slow delivery down too much.
 Old 07-19-2016, 03:28 PM   #116
HTP
HTP's Avatar
Matt is on vacation however I'm here processing all stocking orders and shipping out tanks as they come back. Have no fear. -Katie
The Following 9 Users Say Thank You to HTP For This Useful Post:
Boost_creep (07-19-2016), CMajor (07-19-2016), Dareman (07-19-2016), Jester2552 (07-20-2016), JgamB (07-20-2016), JSmith (07-20-2016), MD1032 (07-19-2016), MS3Shadow (07-19-2016), WetzMS3 (07-20-2016)
 Old 07-19-2016, 04:02 PM   #117
Dareman's Avatar
Posts: 80   (View Stats)
Dareman has much to be proud ofDareman has much to be proud ofDareman has much to be proud ofDareman has much to be proud ofDareman has much to be proud ofDareman has much to be proud ofDareman has much to be proud ofDareman has much to be proud ofDareman has much to be proud ofDareman has much to be proud of
Default Tank Girl
HTP likes this.
2009 Mazdaspeed3 GT - Crystal White Pearl
ETS tmic / CorkSport intake / Synchronic diverter valve / Cobb short shifter / solid shifter bushings / 385gram titanium shift knob / CorkSport interior LEDs / CorkSport LED fog lights / COBB AP / COBB catless DP/ JBR Mounts / CorkSport rear sway bar / NGK 1 step cooler plugs / Autotech HPFP internals / 30% Tint / Dareman Stubby
Dareman is offline   Reply With Quote
The Following User Says Thank You to Dareman For This Useful Post:
JSmith (07-20-2016)
 Old 07-19-2016, 05:10 PM   #118
Matt@HTP's Avatar
"I'll quote you on a custom tank in 2 weeks when I get back from vacation" is what I said. I didn't discuss anything else with you.
The last of the Gen 2 tanks came back from anodizing late on Friday, and Katie (Tank Girl) shipped them out Monday. The delivery driver told me they were racking up the Gen 1 tanks before he left with that delivery.
We are plenty stocked, so I'm not sure why our website would say we aren't shipping. Email me a link where it says that please.
The Following 3 Users Say Thank You to Matt@HTP For This Useful Post:
Dareman (07-20-2016), Nitr0EngiE (07-21-2016), WetzMS3 (07-20-2016)
 Old 07-20-2016, 08:29 AM   #119
Daily Driver
Nitr0EngiE's Avatar
If I am wrong than its irrelevant, sorry for confusion, but i swear I saw on the site where it said closed until 8/1, I guess its possible I had you confused with another site (did not think so but possible). Either way it does not effect me so ill back out of here.
Have a good day all!
EDIT: @Matt@HTP; I apologize, I found what I was talking about and it was JMF, not HTP. so ignore me !
 Old 07-20-2016, 01:24 PM   #120
Jester2552's Avatar
What does racking up mean? Or did you mean wrapping up?
2007 Black MS3
Tuned by Nishan
in tank meth?? david001wj 2010 MS3 - Fuel, Nitrous & Water Injection 7 06-19-2013 07:16 AM
Page generated in 0.64272 seconds with 35 queries
