> HTP (Hi-Tuned Performance)
 Old 06-16-2013, 04:23 PM   #1
soul.survivor's Avatar
Posts: 335   (View Stats)
soul.survivor is the leader of the worldsoul.survivor is the leader of the worldsoul.survivor is the leader of the worldsoul.survivor is the leader of the worldsoul.survivor is the leader of the worldsoul.survivor is the leader of the worldsoul.survivor is the leader of the worldsoul.survivor is the leader of the worldsoul.survivor is the leader of the worldsoul.survivor is the leader of the worldsoul.survivor is the leader of the world
Default TIP with bracket doesn't fit
I got the TIP with the bracket on top for the stock grommet/spacer. It does not fit. The bracket ends up rubbing the threads on the stud where it's supposed to bolt up. I installed it without the spacer because there's no way it was going to get close enough to bolt it down. The bracket should be offset toward the engine, not sitting on top of the TIP.
2008 CBM MS3
CP-E RMM | JBR 3.5" WP | GTX3071R | JBR OCC + IM TIG | SU TMIC | Turbosmart Compact BPV | Autotech Internals | Cobb AP + TBE + EBCS | NGK 1 Step Colder | TWM Shifter | Hotchkis Sways | Bilstein Sports | Swift SPEC-Rs | SPC Camber Arms | Freektune
soul.survivor is offline   Reply With Quote
 Old 06-16-2013, 08:41 PM   #2
MZRSPEED's Avatar
Posts: 550   (View Stats)
Did you email them about it first? They have awesome customer service, no doubt they would have taken care of you.
The Following User Says Thank You to MZRSPEED For This Useful Post:
HTP (06-17-2013)
 Old 06-17-2013, 07:14 AM   #3
HTP
HTP's Avatar
Posts: 210   (View Stats)
Line up the mounting tab and then rotate the inlet into the turbo coupler. If you install the inlet into the turbo coupler and clamp it first then it may not line up.
Matt
The Following 2 Users Say Thank You to HTP For This Useful Post:
3starmagnum (06-17-2013), deadlandxtreme (06-17-2013)
 Old 06-17-2013, 09:31 AM   #4
Thanks for the reply.
I placed the inlet into the coupler without clamping it and rotated it all around. The bpv and intake pipes were up against the radiator hoses and other stuff before the tab was even close to being correct.
2008 CBM MS3
NEW Cp-E complete RMM with BRACKET J-Liss MazdaSpeed 3 - Engine, Transmission & Driveline 47 11-29-2011 12:36 AM
IWG Bracket manelscout4life MazdaSpeed 3/6 - Big Turbo Builds 20 07-15-2011 09:57 PM
AP mounting bracket seanmiller09 MazdaSpeed 3 - How-To's 0 05-30-2010 09:58 PM
Page generated in 0.24162 seconds with 23 queries
