> 2010 MS3 - Appearance > Interior
Like Tree3Likes
  • 2 Post By helmetface
  • 1 Post By xtwoonamatchx
 Old 05-29-2013, 05:29 PM   #1
sparks5314's Avatar
Posts: 74   (View Stats)
sparks5314 is a jewel in the roughsparks5314 is a jewel in the roughsparks5314 is a jewel in the roughsparks5314 is a jewel in the rough
Groaned at 5 Times in 2 Posts
Default Shift knob boot damage after Cobb knob
Installed new Cobb shift knob. How do I fix the boot? It doesn't screw down any more than this.
Sent from my SAMSUNG-SGH-I337 using Tapatalk 2
2011 Mazdaspeed3 W/Tech Package
Cobb Intake, Cobb AP, H&R Springs, Cobb BPV, Corksport Shift Plate, Borla CBE, ATP Downpipe, SURE RMM, Cobb Inlet Hose, KMD Fuel Internals, Tune.
sparks5314 is offline   Reply With Quote
 Old 06-02-2013, 11:11 AM   #2
ahfunaki's Avatar
Posts: 764   (View Stats)
ahfunaki is the leader of the worldahfunaki is the leader of the worldahfunaki is the leader of the worldahfunaki is the leader of the worldahfunaki is the leader of the worldahfunaki is the leader of the worldahfunaki is the leader of the worldahfunaki is the leader of the worldahfunaki is the leader of the worldahfunaki is the leader of the worldahfunaki is the leader of the world
Get a new boot? Try and tuck the torn leather under the knob while screwing it down?
Are you saying the knob is what messed the boot up? I've had probably 5 different knobs on my car and it has never torn like this...
[ 2010 Black Mica Speed3 w/tech package ]
go | COBB AccessPORT | Autotech HPFP Internals | TurboXS Catless Downpipe | TurboXS Race Pipe | Ultimate Racing Catback w/Magnaflow Resonator | Corksport Urethane Exhaust Hangers |
JBR Boost Tubes | cp-e Nviscid Pipe | cp-e XcelNANO SRI | cp-e HeliHose | cp-e Stage 1 xFlex RMM | JBR SSB | RDS-05 Rear Sway Bar |
Torque Solutions Delrin Shift Knob | Block8Head Dual Defrost Pod | Aeroforce Interceptor | Prosport Evo Boost Gauge
show | BC Racing BR Coilovers w/Koyo | SPC Rear Camber Arms | Avid.1 AV-06 18x8 +42 225/40 | 2011+ Tech Headlights | Corksport Tow Plate |
Morimoto 5000k bi-xenon / 3000k fogs | 3BSpec Switchbacks | Corksport LED Rear Bumper Lights | S204 STi Lip
ahfunaki is offline   Reply With Quote
 Old 06-02-2013, 11:12 AM   #3
helmetface's Avatar
Posts: 5,685   (View Stats)
Groans: 219
Neutral  +1 score
You should probably sell your car OP
SpeedThrizzle and jody63 like this.
The Following 9 Users Say Thank You to helmetface For This Useful Post:
ABolewski (06-03-2013), breakfstincluded (06-18-2013), CWP_MS3 (06-18-2013), El_Diablo (06-04-2013), faeker (06-18-2013), Mizzle (06-03-2013), silvapain (06-04-2013), Worbit (06-03-2013), Ziggylittles (07-18-2013)
 Old 06-02-2013, 11:38 AM   #4
xtwoonamatchx's Avatar
Posts: 284   (View Stats)
xtwoonamatchx is the leader of the worldxtwoonamatchx is the leader of the worldxtwoonamatchx is the leader of the worldxtwoonamatchx is the leader of the worldxtwoonamatchx is the leader of the worldxtwoonamatchx is the leader of the worldxtwoonamatchx is the leader of the worldxtwoonamatchx is the leader of the worldxtwoonamatchx is the leader of the worldxtwoonamatchx is the leader of the worldxtwoonamatchx is the leader of the world
same shit happened to me on my stock knob. Take the knob off, go into home depot, buy a washer that isnt bigger than the knob but has a big enough hole. Tuck the fucked leather in under the washer, screw on knob. you could use some glue probably but i just screwed mine on... should help a little bit.
sparks5314 likes this.
xtwoonamatchx is offline   Reply With Quote
 Old 06-03-2013, 11:04 PM   #5
Crarrs's Avatar
Posts: 1,662   (View Stats)
Are you sure? It doesn't look like you used a strap wrench yet. That looks like you could still easily apply up to 150 ft-lbs there.
2004 MSM TiGrey
 Old 06-03-2013, 11:24 PM   #6
breakfstincluded's Avatar
Posts: 3,588   (View Stats)
lose the boot
buy a plate and cut some holes in it
gated shifter ftw
 Old 06-04-2013, 12:10 AM   #7
Pseudonym's Avatar
Posts: 1,429   (View Stats)
That'd be awesome. I wonder if a gate would be possible.
Cobb AP JBR SSP/SSB's
HTP 3 Incher Forge V2 BPV
eBay Test Pipe
SCUBA TUNED
 Old 06-04-2013, 09:52 AM   #8
sparks5314's Avatar
The old knob messed up the boot because i screwed it in too tight. It looks like the glue that held it down from the factory has become undone. So idk what to do at this point. I cant tuck it back in because the new Cobb Knob does not screw down all the way to hold it in place. It just comes out again.
I like the washer home depot idea.
Last edited by sparks5314; 06-04-2013 at 09:52 AM. Reason: MSF Database - Automerged Doublepost
 Old 06-18-2013, 10:05 AM   #9
Mazdaspeed3KHP's Avatar
Posts: 273   (View Stats)
Mazdaspeed3KHP has a reputation beyond reputeMazdaspeed3KHP has a reputation beyond reputeMazdaspeed3KHP has a reputation beyond reputeMazdaspeed3KHP has a reputation beyond reputeMazdaspeed3KHP has a reputation beyond reputeMazdaspeed3KHP has a reputation beyond reputeMazdaspeed3KHP has a reputation beyond reputeMazdaspeed3KHP has a reputation beyond reputeMazdaspeed3KHP has a reputation beyond reputeMazdaspeed3KHP has a reputation beyond reputeMazdaspeed3KHP has a reputation beyond repute
If the glue came un done then simply glue it back into place..
I used gorilla glue when I installed my redline shift boot. It was the biggest pain in the ass.
Put gorilla glue on a tooth pick and put pressure on the spots where the boot tore off. Hold it there for a few mins and let the glue dry. Make sure not to remove that plastic piece that the boot forms around. I had to remove that and install it on my new boot and you have to position it just right so the boot goes onto the shifter assembly even and in the right spots.
Long story short: I didn't glue the black piece onto the boot right so I had to play around with my shift boot to make it look normal when placing it over the shifter assembly, so it wasn't all twisted and jacked up.
I would glue and then use a washer to keep shift knob movement from ripping the boot off again.
Mazdaspeed3KHP is offline   Reply With Quote
 Old 06-18-2013, 11:54 AM   #10
dan7225's Avatar
Posts: 511   (View Stats)
simple fix. big flat washer, preferably black in color
The Following User Says Thank You to dan7225 For This Useful Post:
Redline Shift Boot Bride black leather Ebrake Armrest JBR Knob breakfstincluded Mazdaspeed3/6 General Discussion 36 12-31-2014 01:32 PM
prevent sagging shift boot with new shift knob pinggoy MazdaSpeed 3 - How-To's 18 07-21-2011 09:25 PM
Page generated in 0.30493 seconds with 29 queries
