> 2010 MS3 - Appearance > Exterior
  • 1 Post By Kellrell
 Old 02-02-2017, 07:09 AM   #1
Kellrell's Avatar
Posts: 13   (View Stats)
Kellrell will become famous soon enough
Default engine bay corrosion
any else Genpu valve cover and intake manifold corroding and weathered looking. I looked at 2 other Genpu's other than mine and they were worse. Its not happening on my brother in law's genjuan or my previous juan. I'll post a pic here soon.
Kellrell is offline   Reply With Quote
 Old 02-02-2017, 07:17 AM   #2
SoyBean's Avatar
Posts: 176   (View Stats)
SoyBean has a reputation beyond reputeSoyBean has a reputation beyond reputeSoyBean has a reputation beyond reputeSoyBean has a reputation beyond reputeSoyBean has a reputation beyond reputeSoyBean has a reputation beyond reputeSoyBean has a reputation beyond reputeSoyBean has a reputation beyond reputeSoyBean has a reputation beyond reputeSoyBean has a reputation beyond reputeSoyBean has a reputation beyond repute
Have you taken into account where/when the vehicles have been driven (snow salt/sand) and whether they have the under tray. I have a GenJuan with not under tray, snow salt for three winters; I have light corrosion on the engine cover and surface rust on the rear suspension assembly.
2008.5 Black MS3 "Wednesday"
PWR: HTP 3.5, CPe Catless DP, CX FMIC, HKS (VTA), PTP HPFP Internals, TRZ MM, AWR PMM
SUSP: Drag DR31 18x8 +35, MonoSS Coilovers/Endlinks, Racing Beat Sway Bars, Drilled Rotors, Green Brake Pads
MISC: AP v3 Self-Tuned, 6LB Battery, Braided Brake Lines, NRG Steering Wheel, Partial Gutted Interior
SoyBean is offline   Reply With Quote
 Old 02-02-2017, 07:17 AM   #3
Kellrell's Avatar
It just seems like it shouldn't be so bad. Bolts/nuts rusted and all the corrosion. 2011 with only 40K miles. any advice on cleaning; would rather not have to change each bolt or have one break one day down the road when I'm changing something.
 Old 02-02-2017, 07:20 AM   #4
Kellrell's Avatar
I live here in Germany but so does my brother in law with his Genjuan without the issue. Underside of my car is fine aside from exhaust bolts. Mostly centralized rusted bolts and corrosion to the engine bay. Under tray is in good working order. None of my other vehicles had the issue but both of the other genpus I looked at had it. One guy told me its because "its jdm" lol
 Old 02-02-2017, 07:20 AM   #5
sharksinspace's Avatar
Posts: 766   (View Stats)
Groans: 126
Should put your tray back on...aside from the protective aspect, it's designed to help engine cooling by affecting where and how air flows through the bay.
Genpoo stuff
 Old 02-02-2017, 07:24 AM   #6
Kellrell's Avatar
my undertray is and has been on.
....not talking to me...sorry ha
sharksinspace likes this.
The Following User Says Thank You to Kellrell For This Useful Post:
KiwiFlavor (02-02-2017)
 Old 02-02-2017, 10:37 AM   #7
Omega's Avatar
Posts: 441   (View Stats)
Heat is a catalyst for oxidation, heat + oxygen = oxidation, therefore it rusts more easily and quickly. Light coats of oil/grease/wd40 on metal parts would prevent air contact and resist corrosion....
Edit: There's also things in your engine bay (fluids) that can cause some level of oxidation, if you've ever had a fluid leak that's probably not very useful for avoiding oxidation either.
2006 Super Clean BCM MS6
Kellrell (02-02-2017)
 Old 02-02-2017, 11:02 AM   #8
Kellrell's Avatar
Yeah after posting this I cleaned the entire engine bay and then went over it with wd40 and cleaned again.
 Old 02-19-2017, 01:02 PM   #9
andale927's Avatar
Posts: 193   (View Stats)
andale927 has a brilliant futureandale927 has a brilliant futureandale927 has a brilliant futureandale927 has a brilliant futureandale927 has a brilliant futureandale927 has a brilliant futureandale927 has a brilliant futureandale927 has a brilliant futureandale927 has a brilliant futureandale927 has a brilliant futureandale927 has a brilliant future
Mine looks about the same and I only have 27k miles.
andale927 is offline   Reply With Quote
Protect your PCM the Wiring Harness from Corrosion Lex2007 Mazdaspeed3/6 General Discussion 55 03-22-2016 01:08 PM
Help!!! ECU Corrosion on pins and CPE PNP Harness btkrausen MazdaSpeed 3/6 - ECU Computer Tuning 73 07-23-2014 12:53 PM
TMIC corrosion sidekick CorkSport 13 09-15-2012 12:19 AM
Toyota faces possible recall for corrosion on Tundras Haltech Automotive News 0 10-07-2009 08:00 AM
Toyota faces possible recall for corrosion on Tundras Haltech Automotive News 0 10-06-2009 07:00 PM
Page generated in 0.31221 seconds with 25 queries
