> 2010 MS3 - Appearance > Exterior
Like Tree4Likes
 Old 12-26-2016, 07:39 AM   #41
Dropen's Avatar
Posts: 46   (View Stats)
Dropen will become famous soon enoughDropen will become famous soon enough
In my CX7 i put LED in almost all the lights to LED.
I had some issues with the brake lights so i had to get "canbus" LED bulbs (it has a resistor to add more ohms and delete the ABS error)
For the turn signal is the same, i got yellow LED with "canbus" too, or the speed of the turn light shine weird.
I got all that LEDs in aliexpress, for the cheapest price i bought more for stock just in case.
Dropen is offline   Reply With Quote
 Old 12-27-2016, 06:44 AM   #42
Mazduhspeed6's Avatar
Posts: 157   (View Stats)
Mazduhspeed6 is a name known to allMazduhspeed6 is a name known to allMazduhspeed6 is a name known to allMazduhspeed6 is a name known to allMazduhspeed6 is a name known to allMazduhspeed6 is a name known to all
Yea i would never use ebay bulbs thats just me. My question was for the vled v3 triton bulbs, so they do fit into our housings? And my other question is these stuff im seeing with the switchbacks looks really cool, do they have be hooked some kind if special way, any kind of wiring that needs done or is it all plug and play, if it isnt, is there a clear and illustrated version of instructions...thanks for any and all help given guys, later
...and on price they are very expensive but ill be buying them with my tax return money...my favorite time of the year!
2007 Mazda Speed6 GT
Power: rebuilt stock motor*
JBR full power path stage II intake w/JBR TIP*
ATP catted downpipe w/ second cat delete*
Corksport HPFP internals*
Corksport BeCuse injector seals*
Corksport Turbo*
Corksport 3.5 Bar MAP sensor*
Corksport EBCS*
Treadstone Tr8 w/ RPM CX racing piping kit*
Suspension: Corksport Lowering Springs
Brakes: Still stock
Driveline: Sure Motorsports R6*
Sure Motorsports Juggernaut*
Sure Motorsports Dreadnaught*
Sure Motorsports shifter bushings*
Corksport weighted Black shift knob
Electronics: Cobb Accessport V3 w/ tune by Will at PD tuning*Purple Drank Tuning*
Mazduhspeed6 is offline   Reply With Quote
 Old 12-27-2016, 09:18 AM   #43
RazoE's Avatar
Posts: 181   (View Stats)
RazoE has a reputation beyond reputeRazoE has a reputation beyond reputeRazoE has a reputation beyond reputeRazoE has a reputation beyond reputeRazoE has a reputation beyond reputeRazoE has a reputation beyond reputeRazoE has a reputation beyond reputeRazoE has a reputation beyond reputeRazoE has a reputation beyond reputeRazoE has a reputation beyond reputeRazoE has a reputation beyond repute
The V3 tritons are universal. They come with multiple gaskets and screws and spacers to fit basically any housing. The wiring is plug and play, no extra wiring needed (unless you chose to dim your lights at night, as they are BRIGHT).
They come with a harness for a resistor if you should choose to run them.
Their 6 ohm resistors are recommended if running only signals on the front OR back. 3 ohms for those running front AND back. I personally run 4 6ohms, 1 per bulb because I didn't plan it out too well.
-2008 Mazdaspeed3
Corksport Stage II SRI - boost tubes - Dual VTA BPV / CP-E TMIC / HKS 3" CBE / JBR shifter bushings - Reverse gate - Modified Raider air dam for TMIC / COBB cold air box - AP V3 / Autotech HPFP / Damond short shift plate / Optima yellow top / Mazdaspeed lowering springs and camber arms / Black Gen Pu wheels
RazoE is offline   Reply With Quote
 Old 12-27-2016, 09:48 AM   #44
g00s3y's Avatar
Posts: 2,127   (View Stats)
Groans: 438
Spending tax return money on turn signal bulbs... Because they are so expensive...
MS3Shadow (12-27-2016)
 Old 12-27-2016, 01:15 PM   #45
ToyCop's Avatar
Posts: 237   (View Stats)
ToyCop has a reputation beyond reputeToyCop has a reputation beyond reputeToyCop has a reputation beyond reputeToyCop has a reputation beyond reputeToyCop has a reputation beyond reputeToyCop has a reputation beyond reputeToyCop has a reputation beyond reputeToyCop has a reputation beyond reputeToyCop has a reputation beyond reputeToyCop has a reputation beyond reputeToyCop has a reputation beyond repute
Says the guy with the carbon fiber "performance" parts.
2011 Mazdaspeed 3 VRM W/Tech
CorkSport: 3" Power Series SRI, BPV & hose, Boost tubes, Battery box, HPFP internals, Short shifter and bushings.
ETS TMIC, Ultimate Racing test pipe, Damond dual OCCs, Damond TMM, CP-E S2 RMM, COBB APv3, Freektune OTS+ 93 Oct.
Rice: RallyArmor, Morimoto XB LED Fogs, VLeds Triton Reverse Lights, Redline boots and armrest cover, Maisonvi shift knob.
Audio: Pioneer AVIC-7100NEX
ToyCop is offline   Reply With Quote
Led Turn Signal Question Feargod69 MazdaSpeed 3/6 - Appearance 10 12-31-2010 11:47 PM
Followup: Toyota bomb scares due to... Nigerian turn signal inventor? Haltech Automotive News 0 05-20-2010 08:50 AM
Changing front turn signal bulbs with stock HID's (GT) 802MS3 MazdaSpeed 3/6 - Car Audio & Electronics 7 04-06-2010 04:26 PM
Squealing Sound in Cold Weather, Cars With Polymer Bodies, Heater and Horn Not Working, How To Replace Turn Signal, Mech Haltech Automotive News 0 01-09-2009 12:50 PM
Page generated in 0.26535 seconds with 24 queries
