![]() Join Date: Dec 2009
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6
Groaned at 24 Times in 4 Posts
(Thread Starter) | Not Ranked : 0 score Ok, so I just bought a HID kit and have no clue where to begin and I know others have discussed this before but I need help knowing exactly what I need to do first. How do I remove the old bulbs? I looked at the stock setup last night and it looked complicated. Please help!
__________________ 2010 Celestial Blue Speed3, Corksport SRI w/TIH, Ultimate Racing CBE w/Ti. tips, DDM 6k HID Lows, Cobb AP, AutoTech Internals |
![]() Join Date: Sep 2009 Location: Los Angeles, California
Rep Power: 442 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,334
Groaned at 72 Times in 51 Posts
| Not Ranked : 0 score its in ur manual. |
(Thread Starter) | Not Ranked : 0 score I figured it out. No help needed.
![]() Join Date: Jan 2010
Rep Power: 0 ![]() Thanks: 0
| Not Ranked : 0 score just wondering, when u guys installed your HID's did you have to take off the cover for it or did you guys drill bigger holes in the cover? |
![]() Join Date: Jan 2010 Location: San Antonio TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 43
| Not Ranked : 0 score I didnt drill anything it was pretty easy man to tell you the truth. |
![]() Join Date: Nov 2009 Location: Lacey, WA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,314
Groans: 48
Groaned at 16 Times in 14 Posts
| Not Ranked : 0 score I over thought my install at first.. It came with the wires for the fuses and i was like "wtf??? they said this shit was gonna be easy.." .. after about 30 minutes i realized i didnt need that fucking thing and that the hardest part was tucking the wires so they couldnt be seen that easily.. looks pretty sharp.. just wish i could tick the headlight angle up a couple of degrees.. they shoot straight into the ground like yosemite sam..
__________________ "Pain? I ain't got time for pain.. Only pain I got time for is the pain i put on fools who don't know what time it is." -TTT |
| pewpew ![]() ![]() Join Date: Apr 2008 Location: NoVA
Rep Power: 760 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,124
Groaned at 9 Times in 9 Posts
| The Following User Says Thank You to Sacrilicious For This Useful Post: | Dre (02-11-2010) |
Groans: 48
| Not Ranked : 0 score you spelled caulk wrong sac
| Not Ranked : 0 score maybe i spelled it wrong for YOUR needs... |
![]() Join Date: Feb 2010 Location: Seminole
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 39
| Not Ranked : 0 score So when you upgrade your hids do you have to buy a kit or can you just change bulbs?
__________________ MazdaSpeed6 Cobb CAI : Cobb AP Stage 2 91 : Denso ITV-22 : SU TMIC : SU Testpipe : TS Dualport Bov : SU Boost Tubes : H&R Lowering Springs : Riax 18x9 Wheels : Escta ASX 225/45/18 Still To Come : DevilsOwn Meth Kit : GS BCS |
![]() Join Date: Sep 2008 Location: Tallahassee, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 61
| Not Ranked : 0 score You'll need an entire kit (bulbs, ballasts, plug-n-play wires). |
![]() Join Date: Oct 2009 Location: Andersen AFB, Guam
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 53
| Not Ranked : 0 score actually i have talked to HID sellers before about upgrading to a different K rating and they said all you need is the bulb the ballast doesn't really do anything but help supply the power to the bulb or something like that. the bulb is where the main k rating and all that jazz is at.. who knows though other HID manufacturers may say different to try to get more money out of you |
| Not Ranked : 0 score a different K rating only means that you have a different colored light bulb. HID lights are not the same as regular incandescent lights. incandescents use a standard filament that gets toasted up until it starts glowing...much like your normal household light bulb. an HID light bulb is filled with vapor (xenon) and produces its light via an electric arc between two electrodes...much like street lamps. in order to pull off the arc, the electrodes need to have a massively high voltage difference between them (10s of thousands), which requires a ballast to pull off. K rating really only tells you the color of the light. a real HID light, however, will give you 3x the light of a standard 55w incandescent headlight while only using 35w of power. EDIT: now that i reread, it sounds like both hank3 and i read that 06spped6 was asking about upgrading TO an HID kit from stock incandescents, but bluedmnspeed read that he was asking how to "upgrade" already-HID stock lights to a different color. in that case, a different bulb would work. |
| CP-E SRI Installation Issues | NightFlight | 2010 MS3 - Turbo Induction | 24 | 01-27-2010 05:12 AM |
| CPE HPFP installation | Trader | MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection | 10 | 10-22-2009 01:00 PM |
| Hid Installation help | AmillieMS6 | MazdaSpeed 3/6 - Car Audio & Electronics | 7 | 04-05-2009 10:05 PM |
| H&R Coilover Installation Help | JCMS07 | MazdaSpeed 3/6 - Suspension & Brakes | 23 | 11-29-2008 12:08 PM |
| MBC Installation How To | Ghetto Mods | MazdaSpeed 3/6 - Turbo Induction | 6 | 04-25-2008 07:49 PM |
