![]() Join Date: Mar 2011 Location: Ottawa
Rep Power: 0 ![]() ![]() ![]() ![]() Thanks: 0
Groaned at 7 Times in 1 Post
(Thread Starter) | Not Ranked : 0 score hello. the Canadian Gen2 Speed3 has ugly halogen DRL's in the headlight housing. I pulled the bulb but can't get a number from it. Can someone confirm it's a 9006? and has anyone upgraded to an LED 9006? problems in the cluster? do you need to add a resistor like you do with the LED turn bulbs? I've found this: LED FOG LAMP HID 7000K WHITE COLOR HB4 / 9006 Surface M | eBay if anyone has a better suggestion, I'm open to it. cheers |
