> 2010 MS3 - Appearance > Exterior
  • 1 Post By DukeBlox
 Old 06-16-2016, 12:26 AM   #1
mazdaspeedtree's Avatar
Posts: 4   (View Stats)
mazdaspeedtree has a little shameless behaviour in the past
Default Orange oxidized specs on pearl white paint
My car keeps having more and more orange oxidized specs all over it. Any recommendations on exterior cleaning products to prevent this? I've been using turtle wax compound to buff them off, but it takes a lot of time. Wondering if there are any products to prevent them rather than just buffing them out consistently.
mazdaspeedtree is offline   Reply With Quote
 Old 06-16-2016, 05:01 AM   #2
KiwiFlavor's Avatar
Posts: 2,447   (View Stats)
It's not just you. That also happens to my car but since yours is white, it shows more. Clay bar should help. We did this to my friend's white speed. It does take quite a bit of time before you can get rid of it.
2012 NASA Spaceship Gray MS3
 Old 06-16-2016, 05:53 AM   #3
TiGraySpeed6's Avatar
Posts: 3,981   (View Stats)
I got one of these nanoskin pads last year, and honest to god I'll never use a clay bar again. These things are outstanding...
This is what I've got, but there are many variations now- sponges, mitts etc...
Nanoskin Autoscrub Medium Foam Pad
340hp / 371tq
CWP_MS3 (06-16-2016), KiwiFlavor (06-16-2016)
 Old 06-16-2016, 06:01 AM   #4
KiwiFlavor's Avatar
Interesting. You sir, piqued my Interest.
 Old 06-16-2016, 06:12 AM   #5
hidin in yo bushes
CWP_MS3's Avatar
Groans: 122
Hm... Going to have to go find this. I too was going to say clay bar. Spray waxing your car after you wash it makes everything come off so much easier, but yes it is a pain in the ass.
Rich Tuned
330WHP and 363TQ
10-19-13 Moore Automotive
 Old 09-04-2016, 07:24 PM   #6
DukeBlox's Avatar
Posts: 1   (View Stats)
DukeBlox will become famous soon enough
I've used Iron X Iron X Iron Remover, CQuartz IronX, Paint Cleaner, paint decontamination with great results on my CWP. Those orange flecks were everywhere on my car before.
N26B44 likes this.
DukeBlox is offline   Reply With Quote
The Following User Says Thank You to DukeBlox For This Useful Post:
N26B44 (04-19-2017)
 Old 02-02-2017, 06:41 AM   #7
Kellrell's Avatar
Posts: 13   (View Stats)
Kellrell will become famous soon enough
Didn't look at the date on this prior but I also just used Iron X on my entire car to remove the iron stains. wish I would have waited until spring because now I have to buy another bottle.
Kellrell is offline   Reply With Quote
 Old 02-02-2017, 10:43 AM   #8
Omega's Avatar
Posts: 441   (View Stats)
Yes I pointed these out some time ago I absolutely LOVE these.
If you're sealing the paint (most waxes today over the counter are sealants unless carnauba) you really shouldn't be getting these.... You're either waiting too long between waxes or it's something picked up from the surface.
I seal my car twice a year (garaged) with high quality sealant, never had any issues even when I owned a white miata which did not have clear coats. Seal the paint more often, if you're compounding or doing ANYTHING to the surface, you need to immediately put wax back on the areas you worked.
I also agree 100% with spray waxing the entire car after wash, it picks a lot of stuff up and brings up the sheen. But it's not really necessary (great for removing water spots) if the wax is in good shape below, just helps to extend the life.
EDIT: OMFG just realized it was an old ass thread revived by a noob after posting.
2006 Super Clean BCM MS6
Last edited by Omega; 02-02-2017 at 10:44 AM. Reason: MSF Database - Automerged Doublepost
 Old 02-02-2017, 11:03 AM   #9
GroceryGtr's Avatar
Posts: 472   (View Stats)
Industrial fallout is a pita....everytime we visit the inlaws in orchard park I notice crap on my paint. Best thing to do is use a really good wax or paint sealer. That way all the metal gets caught in the sacrificial layer instead of burning into your clear coat. then remove with a good cleaner wax and reapply once or twice a year. You can buff it out of the clearcoat a few times, but at some point you run out of clearcoat.
'13 Pearl White MS3 HiFiSpeed 2010 MS3 - Build Diaries 84 05-25-2015 02:39 AM
my 08 white pearl :) dbeotee Appearance - WHITE 9 05-18-2014 12:30 PM
VRM paint turning orange?? jguthrie03 Gen2 MS3 General Discussion 10 08-04-2013 08:57 PM
Page generated in 0.32338 seconds with 27 queries
