![]() Join Date: Jul 2019 Location: Virginia
Rep Power: 0 ![]() ![]() Thanks: 5
Groaned at 8 Times in 4 Posts
(Thread Starter) | Neutral : +1 score Driver side headlight lens has moisture in the inside 24/7 even after it's been dry weather for a few days. Gunk is built up by the clasps which has separated the lens from the headlight assembly allowing moisture to get in...I think If I remove the headlight assembly, is it possible for me to remove and clean the lens? Thanks |
Rep Power: 3747 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,744
| Yes. You'll need a heat gun or an oven on low heat to soften the butyl glue that is used to seal the lens to the housing. There are probably some additional clips (including metal clasps) that you'll need to remove or at least "unlock." You'll also have to insert something like a screwdriver, a paint scraper or putty knife, or the like between the lens and the housing to separate them. Be very gentle, and work slowly and methodically. You can easily crack the housing, the lens, or both if you try to force them apart too quickly or aggressively.
| The Following User Says Thank You to Vansquish For This Useful Post: | Noah99 (02-14-2020) |
Before I crack this baby open, do replacement lenses exist or am I just screwed if I break the lens? | |
I'd suggest doing what I did and replacing with an aftermarket lens from China. I've had a set on my car for 2.5 years, and they're clean, clear, and fog-free. I also got a set of them for about $40 USD shipped. Here's what I bought: https://www.ebay.com/itm/Replacement...cAAOSwUM5Z6wvs . . . And here's an option for you, I can't see anything for quite as cheap as the Mazda6 units I bought though. https://www.ebay.com/itm/R-L-Headlig...0AAOSwlf9dhF~W Here's a cheaper option on Aliexpress, if you can bring yourself to trust it. https://www.aliexpress.com/item/3298...archweb201603_ Or, for the cheapest possible solution: https://www.aliexpress.com/item/4000...archweb201603_
__________________ Having trouble finding something on MSF? Use MS3Shadow's search tool:SEARCH MSF HERE! | |
| Not Ranked : 0 score body repair shop may have lens suppliers to propose if needed.
![]() Join Date: Sep 2011 Location: Canada
| Not Ranked : 0 score I also did the ebay china lens. I'd do it again as well. Go to NAPA and get replacement butyl rope to replace what you remove and get it good and warm before putting it back together. I also purchased automotive seam sealer and put a layer around the seam after I had reassembled the lenses.
__________________ SyntheticAtmosphere '06 Speed6 Whitewater Pearl (COBB AP v2, CS s2 SRI/TIP, Autotech HPFP, Cp-e RMM&RDM, Fidanza/LuK, homebrew Testpipe&OCC) next...meth habit If it feels good, do it...Even if you shouldn't! |
| Condensation forming on inside of headlight lens | indianaryan | 2010 MS3 - Troubleshoot/Diagnostics | 31 | 04-20-2015 11:36 AM |
| Clean diesels not so clean, apparently | Haltech | Automotive News | 0 | 04-11-2015 01:10 PM |
| remove or paint orange reflector in headlight | trioskater | Appearance - SILVER | 12 | 05-10-2011 11:50 PM |
