> 2010 MS3 - Appearance > Exterior
 Old 03-03-2018, 09:18 PM   #1
tmaiorca's Avatar
Posts: 193   (View Stats)
tmaiorca is a glorious beacon of lighttmaiorca is a glorious beacon of lighttmaiorca is a glorious beacon of lighttmaiorca is a glorious beacon of lighttmaiorca is a glorious beacon of lighttmaiorca is a glorious beacon of light
Default Wind Took Roof Rack Strip Off
Hey guys,
Anyone have a part number or name for the attached item? I tried searching OEM parts diagram but couldn't find anything.
This past storm in NJ had some pretty strong winds and it took the strip that goes from the front of the roof to the back clean off. Since I'm not infront of the car atm, google images will have to suffice. Thanks guys
RIP 2006 MS6:: CP-E CAI // 3" CP-E TIP // SU Turbosmart BPV // M2 3" Catless DP // Cobb AP v2 //CP-E Rear Motor Mount // JBR SSP //JBR OCC // 1" Springs // EGR Unplugged // JBR Coolant Bypass // JBR TIG
2010 Genpu:: JBR SRI // JBR TIH // SU Turbosmart Full Recirc BPV // Cobb AP v2 // S-OTS Tuned // RallyArmor UR
tmaiorca is offline   Reply With Quote
 Old 03-04-2018, 06:16 AM   #2
kTaLgsTo's Avatar
Posts: 566   (View Stats)
Those are called roof rails, I do not know the factory number, but maybe knowing what they are called will help you out. I did a quick google search but came up with nothing in my 10 second attention deficit window...
Last edited by kTaLgsTo; 03-04-2018 at 06:17 AM. Reason: I don't feel like I should have to explain this again, but I'm in my mid thirties and cannot type...
 Old 03-04-2018, 09:46 AM   #3
g00s3y's Avatar
Posts: 2,127   (View Stats)
Groans: 438
Find a mazda at the local junkyard and take one from there. Probably cheaper.
 Old 03-05-2018, 01:50 PM   #4
6kipps's Avatar
Posts: 86   (View Stats)
6kipps is a name known to all6kipps is a name known to all6kipps is a name known to all6kipps is a name known to all6kipps is a name known to all6kipps is a name known to all
I believe what you are looking for is a "roof molding" (either left or right), part number BBN7509L0 (left) or BBN7509H0 (right). I would suggest bouncing the part numbers with your VIN to verify.
2013 MS3: COBB AP v3, CS SRI/TIP, CP-E TMIC, UR TP, CS HPFP, CS BPV, JBR OCC, COBB shift weight, Conti DWS, some rice...
6kipps is offline   Reply With Quote
MGM MS3 with RX-8's and a roof rack luckylad82 Appearance - METRO GREY 7 07-17-2012 05:46 PM
How to replace your roof rails (for roof rack use.) ncpaladin MazdaSpeed 3 - How-To's 7 11-30-2010 12:36 PM
Page generated in 0.27576 seconds with 24 queries
