> Sonic Tuning
Like Tree3Likes
  • 3 Post By sonic tuning
 Old 10-22-2012, 03:56 PM   #1
sonic tuning's Avatar
Posts: 129   (View Stats)
Lightbulb GB: Cobb AccessPORT + Custom RichTune $699 shipped
We are excited to work with RichTune to bring you this Group Buy.
What's included:
Brand new Cobb AccessPORT for your Mazda.
Custom RichTune for your Mazda
The AccessPORT is the industry leading OEM ECU flashing, managing and monitoring assistant. Unlock power hidden within the ECU by replacing conservative factory settings with more aggressive calibrations. The result is impressive gains in torque and horsepower while maintaining a high degree of safety. The AccessPORT comes with pre-installed maps that are optimized for common performance modifications.
Click here for Cobb AccessPORT Functions
Results from RichTune
Owner: Timothy aka Shadow
Car: 2011 Mazdaspeed 3
Fully Bolted
Stock Turbo
93 Octane
Pre-Tuning
Understand that if we start tuning your car with an existing problem it could cost you more in the end. Make sure your car is running good ie: no boost leaks, fresh oil, no coolant leaks, etc.
We recommend you do a boost leak test, check your spark plug gapping (make sure they are all properly gapped). If you haven’t already I’d suggest buying a set of Denso ITV22 spark plugs. These plugs are 1 step colder which is needed for cars making over 300 hp. They are easy to find online but difficult to find at your local auto store.
Boost leak testing is easy if you have an air compressor. It is extremely important that your car is free of boost leaks because it will allow unmonitored air in/out of the system. The 2.3 MZR is MAF dependent so any air not being seen by the MAF will not be seen by the ECU. This can cause a lean AFR condition and may result in detonation. Also be sure to clean your MAF sensor every 5-10k miles. If you don’t already have an upgraded fuel pump you will need one.
GB Details:
We need 5 people to get this group buy started.
It will be $699 including the custom tune with Cobb AccessPORT shipped to your door.
Once we get to 10+, there would be $20 discount applied to the GB.
We are an authorized Cobb dealer, you will receive the same warranty and tech support as you would buying direct.
Sonic Tuning
18938 Bonanza Way
Gaithersburg, MD 20879
www.sonictuning.com
sonic tuning is offline   Reply With Quote
The Following 9 Users Say Thank You to sonic tuning For This Useful Post:
alphasaur (12-04-2012), Caligula (03-29-2013), CWP_MS3 (11-13-2012), dantes5823 (10-25-2012), jack_hammer (01-17-2013), Menace1 (03-29-2013), RichieRichness (10-25-2012), surebOOst (10-27-2012), Vader (10-26-2012)
 Old 10-22-2012, 03:58 PM   #2
johnredding's Avatar
Posts: 437   (View Stats)
johnredding is the leader of the worldjohnredding is the leader of the worldjohnredding is the leader of the worldjohnredding is the leader of the worldjohnredding is the leader of the worldjohnredding is the leader of the worldjohnredding is the leader of the worldjohnredding is the leader of the worldjohnredding is the leader of the worldjohnredding is the leader of the worldjohnredding is the leader of the world
This is genius.
2007 Mazdaspeed 6 Black Mica
Richtuned
~Some things have been bolted on~
johnredding is offline   Reply With Quote
The Following 2 Users Say Thank You to johnredding For This Useful Post:
RichieRichness (10-25-2012), sonic tuning (10-22-2012)
 Old 10-22-2012, 04:03 PM   #3
Printman's Avatar
Posts: 300   (View Stats)
Printman is the leader of the worldPrintman is the leader of the worldPrintman is the leader of the worldPrintman is the leader of the worldPrintman is the leader of the worldPrintman is the leader of the worldPrintman is the leader of the worldPrintman is the leader of the worldPrintman is the leader of the worldPrintman is the leader of the worldPrintman is the leader of the world
Wish you had of done this 2 weeks ago. GREAT MARKETING!
[SIGPIC]
[/SIGPIC]
2012 Black Mica W/Tech
Cobb AP
AutoTech Internals
JBR 88DM RMM
JBR Heavy Knob
JBR 3" WP
JBR Rear camber arms
UR TP
Ford MOFO Tranny juice
Rotella T6
Self Tune - (Work in Process)
NGK Step 1 colder
5/7 corn fed
Printman is offline   Reply With Quote
The Following User Says Thank You to Printman For This Useful Post:
 Old 10-22-2012, 04:05 PM   #4
Thanks guys, spread the word!
Sonic Tuning
18938 Bonanza Way
www.sonictuning.com
 Old 10-23-2012, 06:28 AM   #5
lets get this going!!!!!!
this is a KILLER deal
RichieRichness (10-25-2012), sonic tuning (10-23-2012)
 Old 10-23-2012, 08:59 AM   #6
leon78's Avatar
Posts: 2,595   (View Stats)
That is a great deal! Get up on this...Richtune FTW!
2013 Scion FR-S (Whiteout)
Less parking more racing
The Following 2 Users Say Thank You to leon78 For This Useful Post:
 Old 10-25-2012, 06:53 AM   #7
RichieRichness's Avatar
Posts: 3,314   (View Stats)
Groans: 35
Lets go people...can't beat this deal anywhere!
RichieRichness is offline   Reply With Quote
The Following User Says Thank You to RichieRichness For This Useful Post:
 Old 10-25-2012, 08:00 AM   #8
dantes5823's Avatar
Posts: 6,576   (View Stats)
dantes5823 is the leader of the worlddantes5823 is the leader of the worlddantes5823 is the leader of the worlddantes5823 is the leader of the worlddantes5823 is the leader of the worlddantes5823 is the leader of the worlddantes5823 is the leader of the worlddantes5823 is the leader of the worlddantes5823 is the leader of the worlddantes5823 is the leader of the worlddantes5823 is the leader of the world
Groaned at 52 Times in 48 Posts
Boom! Let's do this!
dantes5823 is offline   Reply With Quote
 Old 10-26-2012, 08:09 AM   #9
leon78's Avatar
Any bites?
bump
The Following User Says Thank You to leon78 For This Useful Post:
sonic tuning (10-30-2012)
 Old 11-09-2012, 09:19 AM   #10
dantes5823's Avatar
Bump
 Old 11-09-2012, 03:04 PM   #11
surebOOst's Avatar
Posts: 1,795   (View Stats)
surebOOst is the leader of the worldsurebOOst is the leader of the worldsurebOOst is the leader of the worldsurebOOst is the leader of the worldsurebOOst is the leader of the worldsurebOOst is the leader of the worldsurebOOst is the leader of the worldsurebOOst is the leader of the worldsurebOOst is the leader of the worldsurebOOst is the leader of the worldsurebOOst is the leader of the world
Groaned at 61 Times in 40 Posts
Free Bump for good tuning combo!
2006 Evolution IX RS
ER Built 2.3l
On jackstands
awaiting parts
surebOOst is offline   Reply With Quote
The Following 2 Users Say Thank You to surebOOst For This Useful Post:
RichieRichness (11-10-2012), sonic tuning (11-23-2012)
 Old 11-10-2012, 05:04 AM   #12
Shadow's Avatar
Posts: 430   (View Stats)
Shadow is the leader of the worldShadow is the leader of the worldShadow is the leader of the worldShadow is the leader of the worldShadow is the leader of the worldShadow is the leader of the worldShadow is the leader of the worldShadow is the leader of the worldShadow is the leader of the worldShadow is the leader of the worldShadow is the leader of the world
Great tune worth every cent. I got a 2012 ms3 btw
Sent from my ADR6400L using Tapatalk 2
2012 Black Mica MS3 w tech
Cobb AP, CS SRI, CS TIP, Catless DP/TP, Autotech Internals, NGK Plugs 1 colder, Magnaflow CBE, HKS V2 BOV Recirc, ETS TMIC, CS SSP, CS RMM Inserts, CS RSB, CS Springs, Hankook ventus z214 c71 225/45r17 r comp tires for autocross, Stock doneflops for everything else
Shadow is offline   Reply With Quote
The Following 3 Users Say Thank You to Shadow For This Useful Post:
dantes5823 (11-10-2012), RichieRichness (11-10-2012), sonic tuning (11-23-2012)
 Old 11-21-2012, 12:55 PM   #13
dantes5823's Avatar
BUMP!
The Following User Says Thank You to dantes5823 For This Useful Post:
 Old 11-21-2012, 02:32 PM   #14
radbrad's Avatar
Posts: 538   (View Stats)
If i could go back, ap and a tune would be the FIRST mod I would do.
07Speed3
The Following User Says Thank You to radbrad For This Useful Post:
RichieRichness (11-21-2012)
 Old 11-23-2012, 10:43 AM   #15
Bantug's Avatar
Posts: 2   (View Stats)
Bantug will become famous soon enoughBantug will become famous soon enough
I ran into a guy on 495N a few daysa ago. Black MS3. Dropped with black rims. Told him I loved the stance of the car. A couple questions about the tune...
I'm new to this thing so pardon the ignorance but what does the AP and tune entail cuz really, after seeing that Black MS3, I WANT IN!!
BTW, 2009 bonestock Metro Gry MS3
Bantug is offline   Reply With Quote
The Following 2 Users Say Thank You to Bantug For This Useful Post:
playero02 (03-19-2016), RichieRichness (11-24-2012)
 Old 11-23-2012, 10:51 AM   #16
Kdawg207's Avatar
Posts: 2,389   (View Stats)
Kdawg207 is the leader of the worldKdawg207 is the leader of the worldKdawg207 is the leader of the worldKdawg207 is the leader of the worldKdawg207 is the leader of the worldKdawg207 is the leader of the worldKdawg207 is the leader of the worldKdawg207 is the leader of the worldKdawg207 is the leader of the worldKdawg207 is the leader of the worldKdawg207 is the leader of the world
Damn I wish I was ready. Sweet combo here
~~~NJ Nator OG~~~Then AND Now, Just Better~~~
Kdawg207 is offline   Reply With Quote
The Following User Says Thank You to Kdawg207 For This Useful Post:
sonic tuning (12-03-2012)
 Old 12-03-2012, 04:08 PM   #17
Thanks for the support guys!
Sonic Tuning
18938 Bonanza Way
www.sonictuning.com
 Old 12-04-2012, 08:39 AM   #18
BoominChu's Avatar
Posts: 188   (View Stats)
BoominChu has a reputation beyond reputeBoominChu has a reputation beyond reputeBoominChu has a reputation beyond reputeBoominChu has a reputation beyond reputeBoominChu has a reputation beyond reputeBoominChu has a reputation beyond reputeBoominChu has a reputation beyond reputeBoominChu has a reputation beyond reputeBoominChu has a reputation beyond reputeBoominChu has a reputation beyond reputeBoominChu has a reputation beyond repute
Groaned at 7 Times in 5 Posts
nice!!
BoominChu is offline   Reply With Quote
The Following User Says Thank You to BoominChu For This Useful Post:
sonic tuning (04-01-2013)
 Old 03-29-2013, 10:31 AM   #19
5000lbs of voiceless fury
Caligula's Avatar
Posts: 3,140   (View Stats)
Caligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the world
Groans: 185
Groaned at 124 Times in 81 Posts
Brilliant idea!
2015 Telsa Model S 85D - Delivered 10/21/2015 FYEN!
SOLD!!! 2007 Mazda MS6 - //AWD//BNR S3//cp-e TMIC//cp-e CDFP//Cobb AP//Cobb TIH//Cobb EBCS//Bosch 845 3 Bar//MS-CAI//Custom DP//TS Kompact BPV//Magnaflow CBE//AWR RMM//JBR Stage 3 SSP Kit//JBR EGR Delete//H&R Springs//
Caligula is offline   Reply With Quote
The Following 3 Users Say Thank You to Caligula For This Useful Post:
dantes5823 (03-29-2013), RichieRichness (03-29-2013), sonic tuning (04-01-2013)
 Old 04-01-2013, 10:41 PM   #20
Originally Posted by BoominChu View Post
nice!!
Originally Posted by Caligula View Post
Brilliant idea!
Thanks!
Sonic Tuning
18938 Bonanza Way
www.sonictuning.com
 Old 07-05-2013, 10:52 AM   #21
07mica_blk's Avatar
Posts: 77   (View Stats)
07mica_blk is a splendid one to behold07mica_blk is a splendid one to behold07mica_blk is a splendid one to behold07mica_blk is a splendid one to behold07mica_blk is a splendid one to behold07mica_blk is a splendid one to behold07mica_blk is a splendid one to behold07mica_blk is a splendid one to behold
Groaned at 4 Times in 1 Post
I know I am late but is this still going on?
07mica_blk is offline   Reply With Quote
The Following User Says Thank You to 07mica_blk For This Useful Post:
sonic tuning (07-15-2013)
 Old 07-05-2013, 12:51 PM   #22
Groans: 35
I believe so.
Sent from my iPhone using RichieTalk
 Old 07-05-2013, 02:01 PM   #23
07mica_blk's Avatar
The 699 price is only for the group buy right?
CP-E CBE, Injen CAI, HKS BOV, Alpine 1100watt Amp, 10in Rockford Fosgate T1,
 Old 07-06-2013, 09:20 AM   #24
Groans: 35
Just send a PM to Sonic Tuning
 Old 07-15-2013, 09:17 PM   #25
Yes, it is!
Sonic Tuning
18938 Bonanza Way
www.sonictuning.com
Page generated in 0.43651 seconds with 34 queries
