> Sonic Tuning
Like Tree7Likes
Closed Thread
 Old 02-08-2013, 02:29 PM   #41
wolfhawk's Avatar
Posts: 8   (View Stats)
wolfhawk is an unknown quantity at this point
Just curious why the MS6 does not get end links? I am using a set of exposed ball end links, and the MS3 ones pictured look like a much improved closed unit over what I am using.
Thanks!
2007 Mazdaspeed6 GT Titanium #8889
FUN STUFF:
COBB AP | MS CAI | PG TIP | CPE TMIC| TurboSmart BPV |AWR RMM |SURE Anchors | SURE Counter Shift | TWM Short shift stage 1| SURE Charge Tubes| SURE Shortcut | Magnaflow cat back | test pipe | H&R Springs
COOL STUFF:
MP3 integration with Bluetooth | 20% tint | ENKIE 18X8 EKM3's hyper silver | Leather Shift boot | LED Interior and running lights | Sharkfin | The COBB Knob (The name alone sold it LOL).
wolfhawk is offline
 Old 02-08-2013, 03:32 PM   #42
Originally Posted by J.Dy View Post
How much lower would a Gen 2 be with this set of coilovers at maximum height? Thanks.
Both gen MS3's can retain the stock ride height with these
Originally Posted by Karmat View Post
My knowledge of coilovers is non-existent. Please forgive is these questions are stupid as a result.
1. What kind of drop if any are we looking at in the MS6 on the highest setting?
About 1/2", they will also go low enough to make the car undriveable =D
2. I am not too concerned about install difficulty but I see some posts about drilling the strut tower and would like to not have to hack things up.
This only applies to the MS3 because they have camber adjustments in the tophats. The MS6 comes with a double wishbone suspension (as opposed to the macpherson on the MS3) which require you to adjust camber using the upper ball joints.
3. I understand the height adjustments can be made relatively easily after taking off the wheels. How easy is it to adjust the dampening settings in; front and back?
the front dampening adjustments are done on top of the shock tower like this:
and the rear adjustments just require you to each under the car from the back and access the bottom of the shock itself.
4. In the case of a blown shock after the warranty period what is the avenue or option to get these rebuilt as they are clearly a very limited production item?
the cost to rebuild it would be nearly the same as buying a new one which is around $150. now that the MS3/6 coils are getting to be more popular, Sonic Tuning is going to stock a replacement part for every component we sell so there will be no downtime for your car.
Thanks
see answer in red
Originally Posted by magicka View Post
What's the height range for the Gen 1? How close to stock height can they get/what's the min drop?
Taxes will be back soon, and a set of S3s is pretty tempting.
Sent from my DROID RAZR using Forum Runner
they can retain the stock ride height.
Originally Posted by Celestspeed3 View Post
Is the diameter of the perch 2.5"?
Does anyone have any photos of them installed on the car?
Reason being I want to install a set of universal race springs on the car. I have the bottom sorted out I just need the top.
the diameter of the perch is 62mm and the spring is 110mm in diameter
Thanks!
we are looking into including these for the next batch we sell.
superskaterxes is offline
Celestspeed3 (02-08-2013), J.Dy (02-08-2013), Karmat (02-08-2013), magicka (02-08-2013)
 Old 02-08-2013, 03:52 PM   #43
Celestspeed3's Avatar
Posts: 1,136   (View Stats)
I'm not sure how to ask this, so the ID on the rear spring on the small side is what?
I really want to know if I can use a 2.5"ID race spring with that perch.
Fueled by the haters.
Celestspeed3 is offline
 Old 02-08-2013, 04:48 PM   #44
yes the ID of the spring on the small side is 62mm
 Old 02-08-2013, 04:49 PM   #45
Ditto sent you a PM.
 Old 02-08-2013, 05:37 PM   #46
WAHBAM's Avatar
Posts: 283   (View Stats)
WAHBAM is the leader of the worldWAHBAM is the leader of the worldWAHBAM is the leader of the worldWAHBAM is the leader of the worldWAHBAM is the leader of the worldWAHBAM is the leader of the worldWAHBAM is the leader of the worldWAHBAM is the leader of the worldWAHBAM is the leader of the worldWAHBAM is the leader of the worldWAHBAM is the leader of the world
Groans: 47
Groaned at 21 Times in 9 Posts
So in this gb there's no S1 for the MS3? I don't wanna cut holes either. Are the benefits really worth getting the camber plates?
2010 Black Mica Mazdaspeed3
MODS in chronological order of installtion
AEM CAI, JBR SSP Stage 2, JBR Heavy Shift Knob, JBR 80 Duro Billet Rear Motor Mount, CP-E NVISCID Turbo Inlet Pipe. & COBB AP
Debating on Rear Sway Bars, Springs, or internals next...
WAHBAM is offline
 Old 02-08-2013, 06:19 PM   #47
there are no S1's in this GB because we diddent feel it was worth it. you dont have to use the camber plates if you dont want to but its nice to have the adjustment if u need it. you could always just drop the coilover down a little to adjust camber as well its just more of a PITA.
WAHBAM (02-09-2013)
 Old 02-08-2013, 06:40 PM   #48
thatsmrgimp2u's Avatar
Posts: 834   (View Stats)
What was the purpose of the block of wood when using the hole saw in that picture?
Fluids
Rotella T6 A lot
Rislone Engine Treatment
Motorcraft XT-M5-QS(trans)
VP Methanol
~Splash of E85~
thatsmrgimp2u is offline
 Old 02-08-2013, 09:08 PM   #49
magicka's Avatar
Posts: 520   (View Stats)
Cool. Thanks.
2009 CWP MS3 GT
magicka is offline
 Old 02-08-2013, 09:13 PM   #50
BlueDmnSpeed's Avatar
Posts: 1,129   (View Stats)
Interested but won't have the money til tax return check comes in! How Lon this going on for?
RichTuned
BlueDmnSpeed is offline
 Old 02-08-2013, 09:17 PM   #51
it was a guide for the hole saw to help the bit stay centered. if people are interested we can make a few templates for people to pass around and use if they want.
Originally Posted by BlueDmnSpeed View Post
Interested but won't have the money til tax return charcoal comes in! How Lon this going on for?
till they sell out!!!
 Old 02-08-2013, 09:20 PM   #52
K. Hopefully the ms3 s3 kits are still available when I get my money. I think I am gonna replace my HKS suspension instead of getting a Pablo motor.
RichTuned
The Following User Says Thank You to BlueDmnSpeed For This Useful Post:
superskaterxes (02-08-2013)
 Old 02-08-2013, 10:14 PM   #53
xpystchrisx's Avatar
Posts: 81   (View Stats)
xpystchrisx has a reputation beyond reputexpystchrisx has a reputation beyond reputexpystchrisx has a reputation beyond reputexpystchrisx has a reputation beyond reputexpystchrisx has a reputation beyond reputexpystchrisx has a reputation beyond reputexpystchrisx has a reputation beyond reputexpystchrisx has a reputation beyond reputexpystchrisx has a reputation beyond reputexpystchrisx has a reputation beyond reputexpystchrisx has a reputation beyond repute
Are the adjustments on the dampers changing rebound only, or compression and rebound at the same time?
- 2012 MS3 - CS- SRI & TIP - Autotechs - AP v3 - Denso Iridiums - CP-E S2 RMM/TMIC/Catted-DP - 17x9 +45 RPF-1 - 245/40-17 Michelin PSS - Koni Yellows - Whiteline RSB -
- 2011 CX-7 - Soccer mom machine.
xpystchrisx is offline
 Old 02-08-2013, 10:15 PM   #54
both compression and rebound at the same time
xpystchrisx (02-08-2013)
 Old 02-08-2013, 10:27 PM   #55
NICKELL666's Avatar
Posts: 566   (View Stats)
Hmmm.. I was leaning towards corksports... I may go this route..... My bnr build may just have to wait.. I like
NICKELL666 is offline
The Following User Says Thank You to NICKELL666 For This Useful Post:
superskaterxes (02-09-2013)
 Old 02-10-2013, 09:40 PM   #56
pixelNate's Avatar
Posts: 621   (View Stats)
pixelNate is the leader of the worldpixelNate is the leader of the worldpixelNate is the leader of the worldpixelNate is the leader of the worldpixelNate is the leader of the worldpixelNate is the leader of the worldpixelNate is the leader of the worldpixelNate is the leader of the worldpixelNate is the leader of the worldpixelNate is the leader of the worldpixelNate is the leader of the world
Damn, I wish I had the corn for these. Beautiful parts.
Is there a chance of these coming around again?
2008 Cosmic Blue Mica
pixelNate is offline
 Old 02-10-2013, 09:56 PM   #57
Mizzle's Avatar
Posts: 2,829   (View Stats)
Groans: 324
Any spring / damper dynos?
Mizzle is offline
 Old 02-11-2013, 06:27 AM   #58
yes we will most likely do another order once these all sell out
we do have a dyno but the entire sheet is in japanese because it was done by our engineers overseas.l it also only includes 1 or 2 damper settings so we requested they send us a new one with multiple damper settings over the whole range.
Dizzy Turbo likes this.
Boosted Beluga (02-11-2013), Dizzy Turbo (02-11-2013), magicka (02-11-2013), WAHBAM (02-11-2013)
 Old 02-11-2013, 04:02 PM   #59
WAHBAM's Avatar
Groans: 47
What are your opinions on combining the S3 with swift springs? I want these to be the first & last coilovers I buy for my genpu.
WAHBAM is offline
 Old 02-12-2013, 06:51 PM   #60
ARES28's Avatar
Posts: 425   (View Stats)
ARES28 is the leader of the worldARES28 is the leader of the worldARES28 is the leader of the worldARES28 is the leader of the worldARES28 is the leader of the worldARES28 is the leader of the worldARES28 is the leader of the worldARES28 is the leader of the worldARES28 is the leader of the worldARES28 is the leader of the worldARES28 is the leader of the world
Very nice. My stock shits blown at 80k amazingly, and I'm in dire need of some coil-overs.....will order tomorrow if still available......
Mile High. Silver genwon MS3. BNR S3, HTP 3" intake, 3 bar MAP with bit-wise harness, Grimmspeed 3 port ebc, AP with e-85 self tune, Autotech internals, CX racing FMIC, ST coilovers, gutted test, res deletes, turbo XS BPV, TRZ RMM, Jbarone SSP, Jbarone PMM, Moddiction anvil SK, Ultragauge, e-bay oil CC, some ebay drilled rotors, 10k hid kit, washered stock SS, 5MM spacers, Enkei Imola, and other shit i'm forgetting...
Daily driver- Piece of shit 1998 Chevrolet S-10 LS.
ARES28 is offline
 Old 02-12-2013, 06:54 PM   #61
although swift does make a nice product, i would be VERY surprised if you felt the need to change springs after riding on these. Give them a try and you wont be disappointed.
we def have some left in stock!!! just give us a call. the number is in the OP.
ARES28 (02-12-2013), WAHBAM (02-12-2013)
 Old 02-12-2013, 07:28 PM   #62
MS3MYK's Avatar
Posts: 1,967   (View Stats)
Sorry guys I'm gonna have to back out at the moment...
Sent using my EVO LTE on tappy
2008.5 CWP Speed3 GT - SOLD /
1991 Ford Mustang LX 5.0 SSP
MS3MYK is offline
 Old 02-12-2013, 07:30 PM   #63
I'm still dead serious about ordering these just so you know. I'll put a deposit down until next Friday when I have the scrap for them of necessary.
Fluids
Rotella T6 A lot
VP Methanol
~Splash of E85~
 Old 02-12-2013, 07:48 PM   #64
NICKELL666's Avatar
Hope some are left in a week or so!
 Old 02-13-2013, 06:33 AM   #65
Raider's Homie
Wings_Fan_1986's Avatar
Posts: 56   (View Stats)
Wings_Fan_1986 has a brilliant futureWings_Fan_1986 has a brilliant futureWings_Fan_1986 has a brilliant futureWings_Fan_1986 has a brilliant futureWings_Fan_1986 has a brilliant futureWings_Fan_1986 has a brilliant futureWings_Fan_1986 has a brilliant futureWings_Fan_1986 has a brilliant futureWings_Fan_1986 has a brilliant futureWings_Fan_1986 has a brilliant futureWings_Fan_1986 has a brilliant future
I will definitely be getting these closer to the end of this GB, haven't found a negative review on these yet, keep up the great work.
Liquid Silver Metallic 2011 MAZDASPEED 3 Tech
Mods:Cobb Access Port | KMD Internals | Corksport SRI | Corksport TIP | Corksport Racepipe | Corksport Short Shift Plate | Corksport Shifter Bushing Kit | JBR Cylindrical Shift Knob | Sure S3 Torq Driver side motor mount | Sure S3 Torq Passenger side motor mount | JBR 88 RMM | Forged V1 BPV (blue spring)
Looking into: Corksport CBE Exhaust, DownPipe, FMIC
Fuck your piece of shit greddy turbo kit on a stock renesis rotary. Your shit is gonna blow.
I'll fucking rape BOTH of your ricey pieces of shit. Function>form bitch. Bring 'em both down here to FL and I'll show you how a real MZR runs.
By the way. Prepare to get your couch fucked. You just messed with the wrong forum.
EDIT: I see couch fucking has already commenced. Noob, you better back the fuck off before it gets srs in here. This shit is just the beginning. MSF is like the CIA of the internet.
Wings_Fan_1986 is offline
The Following User Says Thank You to Wings_Fan_1986 For This Useful Post:
superskaterxes (02-13-2013)
 Old 02-14-2013, 05:42 AM   #66
ARES28's Avatar
DocuSign complete! Hoping the extra $38 is for shipping?
ARES28 is offline
The Following User Says Thank You to ARES28 For This Useful Post:
superskaterxes (02-14-2013)
 Old 02-14-2013, 08:07 AM   #67
So if we miss the group buy, is the price just 100 more like on the website? Are there more of these actually in inventory apart from what is in this gb?
Fluids
Rotella T6 A lot
VP Methanol
~Splash of E85~
 Old 02-14-2013, 09:12 AM   #68
Pseudonym's Avatar
Posts: 1,429   (View Stats)
interested in a set for an ms6.
Pseudonym is offline
The Following User Says Thank You to Pseudonym For This Useful Post:
 Old 02-14-2013, 09:42 AM   #69
whats in the OP is how many total sets we have in inventory. The price will remain the same regardless of how many sets we have left
thatsmrgimp2u (02-14-2013)
 Old 02-14-2013, 12:07 PM   #70
bislag's Avatar
Posts: 395   (View Stats)
bislag is the leader of the worldbislag is the leader of the worldbislag is the leader of the worldbislag is the leader of the worldbislag is the leader of the worldbislag is the leader of the worldbislag is the leader of the worldbislag is the leader of the worldbislag is the leader of the worldbislag is the leader of the worldbislag is the leader of the world
Quite possibly interested. Gonna think on it more and send a PM if I decide to take the plunge.
Not a question of quality, because these will definitely work just fine, but of the timing.
bislag is offline
 Old 02-14-2013, 01:24 PM   #71
Bobforapples's Avatar
Posts: 219   (View Stats)
Bobforapples has a reputation beyond reputeBobforapples has a reputation beyond reputeBobforapples has a reputation beyond reputeBobforapples has a reputation beyond reputeBobforapples has a reputation beyond reputeBobforapples has a reputation beyond reputeBobforapples has a reputation beyond reputeBobforapples has a reputation beyond reputeBobforapples has a reputation beyond reputeBobforapples has a reputation beyond reputeBobforapples has a reputation beyond repute
YOU STAY AWAY YOU. Damn you Tire Rack for making my wheels so cheap at the same time as a GB on coilovers.
Cobb AP // JBR 88d Trilogy // JBR 3.5" WP // JBR RSB // MS Coils // SPC Camber Arms // Autotech Internals // eBay Catless DP // ACT-ZX5-HDSS // TRM C3 17x9 +48 // 255/40/17 NT05
Bobforapples is offline
The Following User Says Thank You to Bobforapples For This Useful Post:
bislag (02-14-2013)
 Old 02-14-2013, 01:35 PM   #72
sonic tuning's Avatar
Posts: 129   (View Stats)
Yes, it is.
Your coil is going out today!
Last set of the S3 Gen1 left.
Sonic Tuning
18938 Bonanza Way
Gaithersburg, MD 20879
www.sonictuning.com
sonic tuning is offline
The Following User Says Thank You to sonic tuning For This Useful Post:
ARES28 (02-14-2013)
 Old 02-14-2013, 01:46 PM   #73
So what are we looking at time wise for them to be back in inventory??
Fluids
Rotella T6 A lot
VP Methanol
~Splash of E85~
 Old 02-14-2013, 06:21 PM   #74
ARES28's Avatar
Originally Posted by sonic tuning View Post
Yes, it is.
Excellent Customer service!
ARES28 is offline
sonic tuning (02-14-2013)
 Old 02-14-2013, 07:26 PM   #75
h.h.sk1nny's Avatar
Posts: 1,392   (View Stats)
Just got my sweet Sonic Tuning CO's from UPS today. Everything looks very nice. Great customer service and quick shipment of item. If today weren't Valentines Day, they would be installed on my car tonight. Guess tomorrow night will do
h.h.sk1nny is offline
The Following User Says Thank You to h.h.sk1nny For This Useful Post:
 Old 02-14-2013, 09:18 PM   #76
We have another shipment May~June.
Sonic Tuning
18938 Bonanza Way
www.sonictuning.com
 Old 02-15-2013, 04:30 AM   #77
PapaSmurf's Avatar
Posts: 8,236   (View Stats)
How many S3 genpus left Anthony?
Sent from my flying tapadildo
860whp/677wtq
2.7 V6 Ecoboost
PapaSmurf is offline
 Old 02-15-2013, 05:54 AM   #78
i believe 4-5 sets
ill make sure to update the OP today.
 Old 02-15-2013, 06:06 AM   #79
PapaSmurf's Avatar
should be getting my reenlistment bonus on the 1st of March, hopefully there is a gen2 S3 set left for me.
860whp/677wtq
2.7 V6 Ecoboost
 Old 02-15-2013, 06:21 AM   #80
KRheeder's Avatar
Posts: 140   (View Stats)
KRheeder has much to be proud ofKRheeder has much to be proud ofKRheeder has much to be proud ofKRheeder has much to be proud ofKRheeder has much to be proud ofKRheeder has much to be proud ofKRheeder has much to be proud ofKRheeder has much to be proud ofKRheeder has much to be proud ofKRheeder has much to be proud of
Dont know if im just retarded but i dont see a price... Can anyone maybe help me wit a price plz
KRheeder is offline
Closed Thread
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f596/gb-v2-sonic-tuning-coilovers-137331/
GB V2: Sonic Tuning Coilovers!!! - Mazdaspeed Forums This thread Refback 01-17-2014 10:27 AM
If interested. Coil overs GB available at MSF - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Pingback 02-05-2013 08:58 PM
GB: Sonic Tuning Coilovers!!! sonic tuning Sonic Tuning 142 03-03-2014 03:55 AM
Anyone in Wilmington, DE area with Sonic Tuning Coilovers? MPSpd3 MazdaSpeed 3/6 - Suspension & Brakes 5 11-05-2012 06:51 PM
Sonic Tuning Coilovers superskaterxes MazdaSpeed 3/6 - Suspension & Brakes 181 07-17-2012 06:08 AM
Sonic Tuning ST8s MS3inDC Wheels & Tires - BLACK 7 09-07-2011 09:50 AM
Page generated in 0.60483 seconds with 41 queries
