Other Platforms
> Ford Focus ST Ecoboost - General Discussion
Ford Focus ST Ecoboost - General Discussion Discussion of Ford Ecoboost Engines
 Old 07-03-2014, 07:19 AM   #1
shadow102's Avatar
Posts: 971   (View Stats)
Default Modding a Focus ST
Well i have a focus ST in the drive way now that it looks like i will start modding in the near future (not mine, the speed is not going anywhere). Before i have to go suffer an join a ST forum of some sort i was just wondering if, like the speeds, there is a set upgrade path to follow in order to prevent a block ventilation or turbo blow up.
Right now the idea is just to follow the speed3 path, RMM, Intake, cobb ap, ect. I have also been asked to look into the boomba bov (yes i know it makes noise whoopie)
2013 CWP MS3 w/tech package
 Old 07-03-2014, 07:31 AM   #2
jseams's Avatar
Posts: 1,414   (View Stats)
jseams is the leader of the worldjseams is the leader of the worldjseams is the leader of the worldjseams is the leader of the worldjseams is the leader of the worldjseams is the leader of the worldjseams is the leader of the worldjseams is the leader of the worldjseams is the leader of the worldjseams is the leader of the worldjseams is the leader of the world
The factory airbox on the ST is not nearly as restrictive as the one on the MS3... however, their FMIC is crap. I'd make replacing the intercooler a priority over the intake and the BOV... you can expect about 260-270whp with a mostly fully bolted ST on pump gas and a tune. They really don't take to mods the same way the MS3 does; mostly because the k03 is fairly maxed from the factory.
Justin and Alex both offer e85 tuning and the cars seem to respond well to this... so another option for cheap HP.
CRMetallic 2019 Mercedes C43 AMG
SOLD MNBlue 2012 S4 Prestige... a few mods
SOLD IB 2015 3.8 Gencoupe Ultimate
BLOWED UP DIB 2014 Mustang 5.0... a few mods
SOLD - LS 2012 MS3
Cobb AP//SF//CAB
Autotech HPFP
Corksport TMIC//BPV//TIP//BTbs
JBR 88a RMM
Sure M3 TP
OBX CBE
Tanabe NF210's
ADVAN RG-D 18x8 +38
Freektuned 50/50 E85
jseams is offline   Reply With Quote
The Following 2 Users Say Thank You to jseams For This Useful Post:
predapio (07-03-2014), shadow102 (07-03-2014)
 Old 07-03-2014, 07:41 AM   #3
MazdaBoy2.3's Avatar
Posts: 5,797   (View Stats)
Groans: 51
But day make piles of tq!
 Old 07-03-2014, 07:44 AM   #4
chrisjnas's Avatar
Posts: 354   (View Stats)
chrisjnas is the leader of the worldchrisjnas is the leader of the worldchrisjnas is the leader of the worldchrisjnas is the leader of the worldchrisjnas is the leader of the worldchrisjnas is the leader of the worldchrisjnas is the leader of the worldchrisjnas is the leader of the worldchrisjnas is the leader of the worldchrisjnas is the leader of the worldchrisjnas is the leader of the world
Wow. That's it? I expected a lot more out of the ST.
chrisjnas is offline   Reply With Quote
 Old 07-03-2014, 07:46 AM   #5
twenty5psi's Avatar
Posts: 213   (View Stats)
twenty5psi is the leader of the worldtwenty5psi is the leader of the worldtwenty5psi is the leader of the worldtwenty5psi is the leader of the worldtwenty5psi is the leader of the worldtwenty5psi is the leader of the worldtwenty5psi is the leader of the worldtwenty5psi is the leader of the worldtwenty5psi is the leader of the worldtwenty5psi is the leader of the worldtwenty5psi is the leader of the world
They seem to be doing fairly well with 2867's(mid 300's whp/wtq) and most are just on pump gas......a bigger turbo really opens up the powerband and they rev clean to 7000.
A 400whp ST with the gearing and powerband they have would be a quick car from a roll.
2013 MS3 VRM w/Tech
-unSure Track RMM//Cobb AP//AT HPFP Internals//HTP 3" Intake//UR Resonated TP//UR CBE//JBR Weighted Shift Knob//JBR Shifter Cage Bushings
FlowTuned 2 Gallon E85 blend 307whp/336wtq
twenty5psi is offline   Reply With Quote
 Old 07-03-2014, 07:55 AM   #6
lug
lug's Avatar
Posts: 315   (View Stats)
lug is the leader of the worldlug is the leader of the worldlug is the leader of the worldlug is the leader of the worldlug is the leader of the worldlug is the leader of the worldlug is the leader of the worldlug is the leader of the worldlug is the leader of the worldlug is the leader of the worldlug is the leader of the world
This^^^. FMIC now and save up for a BT (kits are running about 2K now). Fuel system is a bit better so you won't have to mess with it unless you want high300's/400 hp.
lug is offline   Reply With Quote
 Old 07-03-2014, 09:33 AM   #7
predapio's Avatar
Posts: 8,939   (View Stats)
Groans: 309
FMIC and tune are the first things.
That's what I'll be doing.
What a lovable bunch we are!!
 Old 07-07-2014, 12:13 PM   #8
BigJimMs3's Avatar
Posts: 4,859   (View Stats)
BigJimMs3 is the leader of the worldBigJimMs3 is the leader of the worldBigJimMs3 is the leader of the worldBigJimMs3 is the leader of the worldBigJimMs3 is the leader of the worldBigJimMs3 is the leader of the worldBigJimMs3 is the leader of the worldBigJimMs3 is the leader of the worldBigJimMs3 is the leader of the worldBigJimMs3 is the leader of the worldBigJimMs3 is the leader of the world
Groans: 76
Groaned at 22 Times in 20 Posts
Yea intake/muffler delete/freektune(e30) Im seeing 274hp-350tq. Intercooler SUCKS and mine finally came in today! hoping for 280-285ish hp.
2006 Mazdaspeed 6
BNR S4 and supporting mods
2007 Mazdaspeed 3
Bolt on's and tune
2015 Taurus S.H.O
Intake/Tune
2016 Ford Explorer Sport
Stock
BigJimMs3 is offline   Reply With Quote
 Old 07-09-2014, 07:33 AM   #9
LOL MS3's Avatar
Posts: 67   (View Stats)
LOL MS3 has a reputation beyond reputeLOL MS3 has a reputation beyond reputeLOL MS3 has a reputation beyond reputeLOL MS3 has a reputation beyond reputeLOL MS3 has a reputation beyond reputeLOL MS3 has a reputation beyond reputeLOL MS3 has a reputation beyond reputeLOL MS3 has a reputation beyond reputeLOL MS3 has a reputation beyond reputeLOL MS3 has a reputation beyond reputeLOL MS3 has a reputation beyond repute
Pretty much what every one has said. Intercooler and AP should be high on the list. RMM should be up there too. Intake and exhaust is just a noise maker. Shifter bushings and stuff like that... tune with either alex or justin. Youll be impressed. e30 really wakes the car up. People are pushing 290-297whp with corn and full bolt ons.
'13 Focus ST
Current Modifications:
Freektune 93 oct|Boomba BOV|Res and Mufler Delete|CXR FMIC - Installed by Relentless Customs
- @lolms3
LOL MS3 is offline   Reply With Quote
HELP WITH MODDING! Crasth 2010 MS3 - ECU Computer Tuning 27 04-12-2014 10:30 AM
Official: Ford reveals production 2012 Focus ST, shows off Euro-only Focus ST Wagon Haltech Automotive News 4 09-14-2011 09:31 PM
MS 6 modding giordanos4 MazdaSpeed 6 - How-To's 22 01-21-2011 05:37 PM
Old to the MS3, New to modding it Jasonstiller MazdaSpeed 3 - Engine, Transmission & Driveline 17 03-07-2009 07:15 AM
Page generated in 0.29333 seconds with 28 queries
