E-Tuners / Custom Hardparts
Like Tree11Likes
 Old 01-15-2014, 07:58 AM   #41
chaser27's Avatar
Posts: 1,276   (View Stats)
Groans: 42
I always always always had issues until I set my all my load limits to 5
It was just a weird thing where even when I was under the limits of 3.0, I still saw issues. I feel like I had other issues that showed up too, other than afr, but it's been so damn long I can't remember for sure.
Load based? Could it maybe have something to do with the table that tells the ECU how much to correct based on how far off it is from target? (can't remember name right now)
Sent from the lead
Coming at ya with all 297/359
ECU: self-tuned
RADAR: Passport Escort 9500ci
 Old 01-15-2014, 08:00 AM   #42
the following logs are of the problem im seeing. I have seen this in 2 other cars besides these and they were all gen 2. The earlier revision letter log is the one where it barely kisses 2.5 and doesent have the problem while the later revision is with the AFR drop.
Car 1 is BT MS3
Car 2 is stock turbo factory freak.
i have not seen any correlation to fuel used or targets and all of my fuel tables are set identically. I also dont see the AFR always recover when it comes back down below 2.5.
atvfreek (01-15-2014), rfinkle2 (01-15-2014)
 Old 01-15-2014, 08:10 AM   #43
atvfreek's Avatar
Posts: 7,787   (View Stats)
Car 1 is BT MS3
You know, I had a car do something similar to that and said fuck it and scaled the maf. Which fixed it going rich... Maybe @rfinkle2; hit it on the head, and it's the same scenario going lean. I may try scaling the maf on the car with the lean condition.
I wonder if some ecu's lose their OL fuel correction when over 2.5 load.
Gonna play around a little today once I get some logs from @resilientonel;
2010 Speed3-PTE5858
Freek built/Freektuned
510hp420tq
11.321@129.93
The Following 5 Users Say Thank You to atvfreek For This Useful Post:
chaser27 (01-18-2014), Realgib3 (01-15-2014), resilientone (01-15-2014), rfinkle2 (01-15-2014), superskaterxes (01-20-2014)
 Old 01-15-2014, 08:22 AM   #44
Dimenus's Avatar
Posts: 2,825   (View Stats)
Groans: 33
Cars I've seen it on actually go lean.
@rfinkle2; I will dig up a log shortly
Edit: Removed. I'm probably wrong. I threw a system too lean code in the cold when it was ~ -10 degrees here. I've since reflashed the map and my LTFT have shifted almost positive on a 93 map. The code hasn't re-appeared though.
I've definitely seen over 2.5 load on the stock turbo. It's not sustained, but it does happen.
2012 Velocity Red Mica
The Following User Says Thank You to Dimenus For This Useful Post:
 Old 01-15-2014, 08:42 AM   #45
Guys, are you using the load target comp / injector base offset fix?
Realgib3 (01-15-2014), superskaterxes (01-20-2014)
 Old 01-15-2014, 12:19 PM   #46
Been using that for a long time and it's related to WGDC.
The injector phasing multiplier also has similar results if used.
@atvfreek; are you using this to gain some headroom?
Another note. The ECU will scale AFRs at WOT up to +/-12-15% which you will not be able to see since these trims are not logged.
If you go "outside" this range, the ECU may actually give up on using the trims.
Everything has to be more or less in range for the tune to work well. Moving load tables, compensation tables, etc. "out of the way" often has unpredictable effects.
Last edited by Lex; 01-15-2014 at 12:20 PM. Reason: MSF Database - Automerged Doublepost
 Old 01-15-2014, 12:44 PM   #47
Yes Lex, I understand that that fix is related to wgdc. Thank you.
I'll be tuning cars with no pride and continue flying by night.
2.0t03speed likes this.
The Following 5 Users Say Thank You to rfinkle2 For This Useful Post:
2.0t03speed (01-15-2014), Agent_Orange (01-18-2014), atvfreek (01-15-2014), sho (05-12-2014), superdave2335 (04-16-2014)
 Old 01-15-2014, 02:35 PM   #48
atvfreek's Avatar
Yes I do use those.
No I do not use the phasing injector multiplier
2010 Speed3-PTE5858
510hp420tq
11.321@129.93
Lex (01-15-2014)
 Old 01-18-2014, 10:55 AM   #49
chaser27's Avatar
Groans: 42
Originally Posted by chaser27 View Post
Now I just need to get fast enough to hit 2.5+ loads.
So apparently, this became relevant to me quicker than I had expected. I've been playing with my tune, it was cold this morning and bumped a 2.52 Calc Load today. Just like @superskaterxes; was seeing, my AFR goes rich as hell on a Gen 2 and stays there until it corrects itself. I'm attaching my log for anyone that wants to take a look-see and a graph that shows the ECU going WTF and fixing itself.
ECU: self-tuned
The Following 2 Users Say Thank You to chaser27 For This Useful Post:
Realgib3 (01-18-2014), superskaterxes (01-20-2014)
 Old 01-18-2014, 11:39 AM   #50
related thread:
Random Lean @ WOT
 Old 01-18-2014, 11:42 AM   #51
Eth Fiend
phate's Avatar
Posts: 6,947   (View Stats)
That looks more like the WOT trims running out of room, then suddenly kicking off (or on, not sure what the target vs actual is. Your axis scaling sucks ).
-06 MS6
-Corn fed 07 MS3 - Sold
rfinkle2 (01-18-2014)
 Old 01-18-2014, 11:45 AM   #52
chaser27's Avatar
Groans: 42
I'm targeting 11.4 for now while I figure out how things play with each other. And they have been hitting almost dead on until the 2.52 today
ECU: self-tuned
 Old 01-18-2014, 02:16 PM   #53
Did you verify that this is not the case when loads are below 2.50 with an A-B-A test? Almost looks like SWAS was involved there.
 Old 01-18-2014, 02:22 PM   #54
chaser27's Avatar
Groans: 42
Yes, I was actually just looking at it. Temp rose almost 20 degrees between logs and I only hit like 2.4 or so. AFR's are rock steady.
I can't wrap my head around it... maybe the phantom OL fuel trims @atvfreek; (I think it was) was talking about?
I don't want to do a MAF adjustment like @ms6mil; is doing, because I don't really hit 2.5 ever
Concerning SWAS, only if my sensor is acting up, dead straight road and slight uphill. Not really getting torque steer
Attaching log.
ECU: self-tuned
The Following User Says Thank You to chaser27 For This Useful Post:
ms6mil (01-20-2014)
 Old 01-18-2014, 02:32 PM   #55
Start with the basics of setting your fuel tables all the same.
After this remove the injector scalars and phasers if they are not OEM.
 Old 01-18-2014, 02:36 PM   #56
chaser27's Avatar
Groans: 42
I actually just did that. I only had the OL/WOT no knock tables adjusted in the above logs. If I hit 2.5+ anytime soon. I'll report back. Thank you.
Sent from the lead
ECU: self-tuned
Lex (01-18-2014)
 Old 01-20-2014, 06:22 AM   #57
mghtymouse380's Avatar
Posts: 1,182   (View Stats)
mghtymouse380 is the leader of the worldmghtymouse380 is the leader of the worldmghtymouse380 is the leader of the worldmghtymouse380 is the leader of the worldmghtymouse380 is the leader of the worldmghtymouse380 is the leader of the worldmghtymouse380 is the leader of the worldmghtymouse380 is the leader of the worldmghtymouse380 is the leader of the worldmghtymouse380 is the leader of the worldmghtymouse380 is the leader of the world
Groans: 58
So to bring this back up. I was wondering if anyone had any insight into this. I have problems dipping way rich once it gets over 2.5 load but the tables that are in question are fixed.
Here are a 3rd gear and a 4th gear back to back (within five mins). And here is the map that I am currently running. Thanks for all your help
2013 CWP (DD)
COBB AP| JBR HSK| JBR RSB| JBR SSP| JBR Shifter Bushings| AT Internals| Ksport Kontrol Pro Coilovers| 3.5 MAF HOUSING| 3' HTP TIP| UR FMIC| TIGS| GTX2867| EBAY 3' DP
TUNE IN PROGRESS (RFINKLE2)
1999 Mazda Miata (PROJECT) (blown motor)
BEGI Cast Manifold| BEGI DP| SR20 Turbo (GT2554)| Flying Miata Silicone IC Piping| Cx Racing IC| HKS BOV| TEIN SA| Harddog Rollbar|Sparco Spint V| TRmotorsports C1 15x8
mghtymouse380 is offline   Reply With Quote
The Following User Says Thank You to mghtymouse380 For This Useful Post:
rfinkle2 (01-20-2014)
 Old 01-20-2014, 06:44 AM   #58
I didn't know you were home.
I can continue to work on this for you if you want Cody. If you see the link above, it can be corrected by massaging the maf curve.
atvfreek (01-20-2014), chaser27 (01-20-2014), ms6mil (01-20-2014)
 Old 01-20-2014, 06:55 AM   #59
Groans: 58
Yeah I have been home for a bit just been busy with other things. Seeing family and things over the holidays and haven't really been doing much with the car.
2013 CWP (DD)
 Old 01-20-2014, 08:33 AM   #60
chaser27's Avatar
Groans: 42
I forgot to report back in this thread, but @Lex; after adjusting my MAF curve as if the area where it went rich were the fuel trims as if all OL fuel trimming went away, my AFRs were still spot on (I dropped my MAF ~13%). Another thing I noticed after the change was that I no longer went rich on tip in, but rather when I let off. I adjusted back the other way and it seems to be better on both ends now. However, my calc loads are now lower (where they should be, cause I'm slow) so I won't be able to see what happens over 2.5
Sent from the lead
ECU: self-tuned
Lex (01-20-2014), ms6mil (01-20-2014)
 Old 01-20-2014, 02:41 PM   #61
Sent from the lead
The ECU has somewhere around 12-15% authority over fueling under WOT. So yes, it will adjust to meet the AFR targets even if your MAF cal is off based on the wideband feedback.
You can use this to drop yourself lower in load. if issues persist.
I think there are more than a single issue here and it might differ from one generation car to another.
Mazdaspeed3GT (11-10-2015)
 Old 01-20-2014, 07:52 PM   #62
Jansi's Avatar
Posts: 729   (View Stats)
Jansi is the leader of the worldJansi is the leader of the worldJansi is the leader of the worldJansi is the leader of the worldJansi is the leader of the worldJansi is the leader of the worldJansi is the leader of the worldJansi is the leader of the worldJansi is the leader of the worldJansi is the leader of the worldJansi is the leader of the world
Been talking with @ms6mil; I've seen the same trend with my AFR's. Here's a screen shot of of a log right at the verge of hitting 2.5. I know I have a lot more logs around but this is what I found so far.
File Type: png Screen Shot 2014-01-20 at 9.51.35 PM.png (345.4 KB, 56 views)
"That Other's May Live"
SELF TUNED
380WHP/372WTQ Dyno Jet @SL E85 mix
ENGINE
GTX3071r // CUSTOM exMANI // CUSTOM DP // TAIL 38mm WG // NGK 1 STEP COLDER PLUGS (6510) // HTP 3.5" WP+BATT TRAY // GRIMSPEED 3 PORT EBCS // BOSCH 3 BAR+HARNESS // JBR BYPASS HOSE // GUARDIAN ANGEL // CX PIPING+TR8 CORE // V3 ACCESSPORT // JBR 88a RMM // JBR 88 duro TRANNY // JBR OCC Stg 2 // SYNAPSE DV
SUSPENSION
CorkSport Coils // SPC REAR CAMBER ARMS @-1.5 // 17x9 RPF01's- 255/40/18 FEDERAL RS-R // 5mm(front) EIBACH SPACERS+STUDS
OTHER SHIT
JBR SSP // RALCO RZ SS // DEFI RED RACER BOOST GUAGE // BLOCK8HEAD VENT POD // KENWOOD DDX419 // KICKER ZX300.1 // DX200.4 // KICKER CVR 12" IN PORTED BOX // KICKER MIDS+HIGHS
Jansi is offline   Reply With Quote
 Old 01-20-2014, 07:59 PM   #63
ms6mil's Avatar
Posts: 4,972   (View Stats)
Groans: 307
Yeah Jean those are pretty negligible compared to mine, but you see what I was talkin about
"Here am I. Send me!"
GT3076 - 393/380 3/9 e85
PTE5862 - TBD
The Following User Says Thank You to ms6mil For This Useful Post:
Jansi (01-20-2014)
 Old 01-20-2014, 08:16 PM   #64
Jansi's Avatar
Yea I'm not too worried about them as my AFR's deviate at a minuscule amount compared to yours. At first I really thought maybe my calc'd % of E was jacked up but I'm glad you mentioned this thread and makes perfect sense now!
SELF TUNED
ENGINE
SUSPENSION
OTHER SHIT
The Following User Says Thank You to Jansi For This Useful Post:
ms6mil (01-20-2014)
 Old 01-20-2014, 11:07 PM   #65
It is common to see some AFR deviation during spool and I don't think this is the same issue. You can tell your injector duty continues to climb. In the cases where the cars go rich or lean there is a step change in injector duty where it either drops or increases.
 Old 01-20-2014, 11:24 PM   #66
Enki's Avatar
Posts: 7,541   (View Stats)
Enki has disabled reputation
Groans: 189
I'm still using OTS values in those tables myself (if memory serves, I'll check tomorrow), and my fueling was almost 100% dead on balls accurate; now though, it starts to go rich above a certain RPM (note that I'm also using a reverse-taper boost curve, so airflow increases as RPM increases); I'm almost certain, though, that this is a result of me going from VTA to pulling inert gasses from the crankcase back into the inlet.
 Old 01-21-2014, 06:19 PM   #67
ledfootrob's Avatar
Posts: 195   (View Stats)
ledfootrob is the leader of the worldledfootrob is the leader of the worldledfootrob is the leader of the worldledfootrob is the leader of the worldledfootrob is the leader of the worldledfootrob is the leader of the worldledfootrob is the leader of the worldledfootrob is the leader of the worldledfootrob is the leader of the worldledfootrob is the leader of the worldledfootrob is the leader of the world
Im getting the same problem on a Gen 2. As soon as I hit 2.5 load my AFR goes rich to the low 10's and stays there for the rest of the pull. 3rd Gear is fine as it only hits 2.4~ max but 4th gear is a different story.
All my fueling tables are set the same. And SWAS disabled. Im gonna try a E85 tune without meth on and see if I still get it to rule out meth enrichment.
2012 Black Mazda 3 MPS
CP-E Stage 2 Pistons - Manley Rods - BNR S3 - HTP 3" TIP + 3" BTM - Corksport Airbox - Cobb FMIC
2XS Exhaust Manifold - Snow Performance Meth Kit - HKS SSQIV - HPFP Internals - CPE Catted Downpipe - Perm PCV Plate
OBX Catback - CPE Stage 2 RMM - JBR Side Mounts - SURE AGS Shiftknob + Shortcut + Anchors
Cobb Accessport V3 - Saikou Michi OCC - Damond OCC - Corksport Springs - Bilstein B8 Shocks
Versus Eurolace 19 x 8 +45 - Hankook RS3
Built & Tuned by Rob
Track Setup - 18 x 8.5 Lenso Spec E - Nitto NT-01 245/40/18
DBA T3 Rotors - Carbotech XP10 Brake Pads
ledfootrob is offline   Reply With Quote
The Following User Says Thank You to ledfootrob For This Useful Post:
SarcasticOne (01-21-2014)
 Old 01-21-2014, 07:11 PM   #68
Enki's Avatar
Groans: 189
Just confirmed that all my tables except for OL/WOT Commanded EQ (Knocking) are set to match (targeting 12:1 AFR). This table is set to 11.5:1 AFR, but the AFR doesn't start to go rich until after I drop back below 2.5 load:
http://www.mazdaspeedforum.org/forum/foru...ordeal-4th.csv
 Old 01-22-2014, 01:11 AM   #69
SarcasticOne's Avatar
Posts: 1,013   (View Stats)
Groaned at 8 Times in 4 Posts
Mine starts doing it when i hit 2.4 (goes a bit leaner, just to 12.05 or 12.2 from 11.8 )
am targeting 2.35... was much cooler the other night than it has been recently... so i noticed it more...
will implement the fuel table changes and report back
The Following User Says Thank You to SarcasticOne For This Useful Post:
atvfreek (01-22-2014)
 Old 01-22-2014, 08:45 AM   #70
atvfreek's Avatar
The fuel table change isn't going to fix it. What is happening is there is OL afr correction and once it gets above a certain load target, the ECU gives up on it and the afr's either go lean or rich depending which way the maf cal is slightly off. Basically the maf cal has to be spot on when these higher loads are reached.
In your log, I see a +5.3 LTFT from 30g/s up. I would add 5% fuel to your maf curve starting at 30g/s all the way to the end of the maf scale. That is what I ended up doing on the couple of cars I've seen it on and it has worked great.
2010 Speed3-PTE5858
510hp420tq
11.321@129.93
The Following 9 Users Say Thank You to atvfreek For This Useful Post:
chaser27 (01-22-2014), Lex (01-22-2014), nindoja (01-22-2014), phate (01-22-2014), rfinkle2 (01-22-2014), RichieRichness (08-12-2014), SarcasticOne (01-22-2014), snailD (01-22-2014), Tokay444 (01-22-2014)
 Old 01-22-2014, 04:35 PM   #71
In certain cars this has fixed it so I think the ECU IS looking at different tables.
But I think you're correct as well regarding the MAF calibration and the car stopping to use the OL fuel corrections past 2.50 load in a lot of cases.
atvfreek (01-22-2014), snailD (01-22-2014)
 Old 01-22-2014, 05:23 PM   #72
snailD's Avatar
Posts: 3,039   (View Stats)
good discussion guys, sorry i have nothing to contribute. Utah loads are significantly less. I remember having issues tuning 801ms3's car however with fueling (pretty sure it went over 2.5 load) and just did maf scaling to get it dialed in, this was over a year ago now.
The Following 2 Users Say Thank You to snailD For This Useful Post:
atvfreek (01-22-2014), rfinkle2 (01-22-2014)
 Old 01-22-2014, 05:39 PM   #73
Also remember that tuners use different strategies to tune and this does affect how the logic plays out especially since we don't get visibility to the logic and don't see all the tables so there's a lot of interpretation that happens. The only time I have seen cars with consistent step changes in AFRs it has been fixed through these tables and more commonly through the use of MAF scaling instead of using the injector scalars.
The gen2 car I posted a log earlier from exhibited these issues and they were fixed by not using the scalars and loads actually went UP. However the MAF calibrations I am also quite careful with when scaling so the issue may not present itself because of this.
It is likely that the problem has several potential sources.
atvfreek (01-22-2014), SarcasticOne (01-22-2014), snailD (01-22-2014)
 Old 01-28-2014, 12:31 PM   #74
Just had a car exhibit this problem. It is a gen1.
The solution in this case was scaling the MAF to account for both E85 and then further scaling it to make AFRs be on target for above 2.50 load.
The procedure was simple since in this case the MAF curve was not piecewise scaled. So I had to scale the entire curve by ~8% and the AFRs are consistent above and below 2.50 load.
Attached a before scaling and after scaling log for reference. I have also updated the OP with this as a fix as well. Thanks for hints and insight on this everyone.
atvfreek (01-28-2014), Enki (01-28-2014), RichieRichness (08-12-2014)
 Old 04-16-2014, 08:52 PM   #75
superdave2335's Avatar
Posts: 924   (View Stats)
superdave2335 is the leader of the worldsuperdave2335 is the leader of the worldsuperdave2335 is the leader of the worldsuperdave2335 is the leader of the worldsuperdave2335 is the leader of the worldsuperdave2335 is the leader of the worldsuperdave2335 is the leader of the worldsuperdave2335 is the leader of the worldsuperdave2335 is the leader of the worldsuperdave2335 is the leader of the worldsuperdave2335 is the leader of the world
Groaned at 9 Times in 6 Posts
Shouldn't the OP be corrected since what you stated about correcting the issue was false?
08' MS3 ESK-EMO Tuned!!!
GT3076r EWG
Manley rods, cp-e stage 2 pistons, arp studs, fullRace exhaust mani,PNP stock IM, TurboXS catless DP/TP/CBE, TurboXS FMIC, hybrid boost control setup using MBC/EBCS, HTP 4" intake system w/MAF block off plate, 3.5" blow thru system fabbed by me,3 bar map, SNOW Stage 2 W/Direct port meth, HKS SSQV4 full vta, JBR 80duro RMM/TMM/PMM, JBR Stage2 OCC, EGR delete, TWM Full Replacement, perm butt plug knob, JBR SB, KMD V2, NGK's, perm pcv plate.
shout outs to -Rob, DJ, Nishan, William, John. couldn't have done it with out your guys advice and assistance. thanks.
superdave2335 is offline   Reply With Quote
 Old 04-16-2014, 09:16 PM   #76
All the solutions are listed in the OP sir.
 Old 04-16-2014, 09:18 PM   #77
If you say so. :-)
sent from the igloo.
GT3076r EWG
 Old 12-21-2014, 02:20 PM   #78
ledfootrob's Avatar
Thread revival time. I just noticed in my latest 25% E mix tune when my car hit 2.5 load and over my AFR's remained on target. This tune uses the the same maf cal from my other tunes which at 2.5 load will drop into the mid 9's AFR. Has anybody changed there Fuel Scalar on a pump gas tune minimally to see the effect.
 Old 12-21-2014, 07:39 PM   #79
chaser27's Avatar
Groans: 42
Logs?
ECU: self-tuned
ms6mil (12-21-2014)
 Old 12-22-2014, 02:06 AM   #80
ledfootrob's Avatar
Damn I don't have a log from a pump tune which hits 2.5 to show it going rich but here is my E tune where it doesn't.
Mazda CEO targets higher sales, upscale brand image Haltech Automotive News 0 12-09-2012 10:20 PM
Bentley targets 'robust' growth, higher profits as wealthy reopen wallets Haltech Automotive News 0 01-03-2012 07:20 AM
U.S. extends concession on trucks to win support for higher mpg targets Haltech Automotive News 0 07-15-2011 08:50 AM
U.S. offers automakers concession on trucks to win support for higher mpg targets Haltech Automotive News 0 07-14-2011 10:00 PM
Report: Morgan hits record sales in 2009, targets even higher for 2010 Haltech Automotive News 0 01-12-2010 07:00 AM
Page generated in 0.61768 seconds with 35 queries
