E-Tuners / Custom Hardparts
Like Tree11Likes
 Old 12-22-2014, 09:16 AM   #81
The MAF sensor reading is all over the place in the log. That's the first thing I would look at addressing.
Did you change the fuel scalar for E25? If not, the ethanol itself will make the AFRs leaner.
 Old 12-22-2014, 01:37 PM   #82
ledfootrob's Avatar
Posts: 195   (View Stats)
ledfootrob is the leader of the worldledfootrob is the leader of the worldledfootrob is the leader of the worldledfootrob is the leader of the worldledfootrob is the leader of the worldledfootrob is the leader of the worldledfootrob is the leader of the worldledfootrob is the leader of the worldledfootrob is the leader of the worldledfootrob is the leader of the worldledfootrob is the leader of the world
Yes fuel scalar is changed for that tune. Its a bad log to show as my boost dial was setup up for a lower boost tune but I was just using it too show that at 2.5 load AFR remained on target, but using pump fuel with a stock fuel scalar the AFR goes into the 9's using the same maf cal.
2012 Black Mazda 3 MPS
CP-E Stage 2 Pistons - Manley Rods - BNR S3 - HTP 3" TIP + 3" BTM - Corksport Airbox - Cobb FMIC
2XS Exhaust Manifold - Snow Performance Meth Kit - HKS SSQIV - HPFP Internals - CPE Catted Downpipe - Perm PCV Plate
OBX Catback - CPE Stage 2 RMM - JBR Side Mounts - SURE AGS Shiftknob + Shortcut + Anchors
Cobb Accessport V3 - Saikou Michi OCC - Damond OCC - Corksport Springs - Bilstein B8 Shocks
Versus Eurolace 19 x 8 +45 - Hankook RS3
Built & Tuned by Rob
Track Setup - 18 x 8.5 Lenso Spec E - Nitto NT-01 245/40/18
DBA T3 Rotors - Carbotech XP10 Brake Pads
ledfootrob is offline   Reply With Quote
 Old 02-06-2015, 01:19 PM   #83
qkrthnu2's Avatar
Posts: 131   (View Stats)
qkrthnu2 has a reputation beyond reputeqkrthnu2 has a reputation beyond reputeqkrthnu2 has a reputation beyond reputeqkrthnu2 has a reputation beyond reputeqkrthnu2 has a reputation beyond reputeqkrthnu2 has a reputation beyond reputeqkrthnu2 has a reputation beyond reputeqkrthnu2 has a reputation beyond reputeqkrthnu2 has a reputation beyond reputeqkrthnu2 has a reputation beyond reputeqkrthnu2 has a reputation beyond repute
Once it drops below 2.50 it goes back to the normal tables so you might see some oscillation if you're around the 2.50 mark.
Also with the MS6 specifically the VVT VE table has a large effect on fueling as soon as you change the VVT advance table from stock.
@Lex Does this warning only apply at loads above 2.50?
Looking at the COBB OTS maps, they're making quite a few VVT Advance changes between Stage 0 v233 & Stage 2 v233, however they're not touching the VVT VE comp table. Is that just an omission on COBB's part?
The VVT VE table is hard to interpret, the values sort of correlate with the VVT Advance table as a large pattern, but individual cells are all over the place more like the VE table.
I thought I could make sense of the stock map @ the 2500rpm / 2.00 load.
30 VVT timing x VVT VE comp of 0.0310 = VE of 0.9333
But not everything lines up nice with my assumed math (I'm probably wrong/missing factors). e.g. 2500rpm / 1.00 load
VE of 0.9700 divided by VE Comp of 0.0280 = 34.6, so I would expect to see 35 in the VVT Advance, but it's still 30.
_______________________________________________
Driver Mods - Mid Ohio Three Day Racing School
2006 Mazdaspeed 6 GT - 130k+ miles. Daily driver (Actually my Wife's car)
Shooting for a reliable 350 AWHP.
Surefire Remanufactured Engine Installed @ 135k.
Mods: BNR S3 Turbo \ Grimmspeed EBCS \ Guardian Angel \ Cobb AccessPort \ Bosch 3 Bar MAP sensor \ AWR RMM \ TurbineTech FMM \ Corksport HPFP \ cp-e Injector seals \ Autolite XP5263 plugs \ Ebay Circuit Werks DP \ Stock CBE \ HTP 3" Intake w/ DIY CAI \ cp-e TMIC \ DIY boost tubes \ Primary & Secondary EGR delete \ Bilstein Shocks \ 215/45ZR -18 Continental ExtremeContact DWS
PERM dual PVC plate and two Damond Motorsports catch cans. Full vacuum setup w/ VTA for over pressure.
PERM #1 -> DM OCC V1 -> DM PCV valve -> Check Valve -> Intake Manifold.
PERM #2 -> DM OCC V2 w/ VTA -> Check Valve -> Tee -> Valve Cover & TIP.
The others:
2009 BMW 135i - N54 - JB4 w/ backend flash \ SRI.
1998 VW GTI VR6 - 248k miles (stock clutch!) when wrecked (not my fault)
1995 Jeep XJ - 4.0 - AW4 \ Lift/Tires etc. 230k miles. Rust bucket / winter beater.
1995 Honda del sol VTEC - DIY hodge podge turbo setup \ self tuned w/ Neptune. 2550lbs ~270whp \ 150k+ miles on stock bottom end (4th clutch though) \ knock limited on 93 octane.
Last edited by qkrthnu2; 02-06-2015 at 03:45 PM. Reason: Added COBB OTS observations ; More Running in circles
qkrthnu2 is offline   Reply With Quote
 Old 02-07-2015, 02:20 PM   #84
The VE table is most likely experimentally determined and not mathematically. In other words they put the engine on the dyno and after choosing the VVT advance desired and adjust final trims via the VE table. Even if it was a mathematical model we won't be able to use our current data for making calculated adjustments.
From what I've seen the most affected car is the MS6 and the effects are most visible under steady WOT.
chaser27 (02-09-2015)
Mazda CEO targets higher sales, upscale brand image Haltech Automotive News 0 12-09-2012 10:20 PM
Bentley targets 'robust' growth, higher profits as wealthy reopen wallets Haltech Automotive News 0 01-03-2012 07:20 AM
U.S. extends concession on trucks to win support for higher mpg targets Haltech Automotive News 0 07-15-2011 08:50 AM
U.S. offers automakers concession on trucks to win support for higher mpg targets Haltech Automotive News 0 07-14-2011 10:00 PM
Report: Morgan hits record sales in 2009, targets even higher for 2010 Haltech Automotive News 0 01-12-2010 07:00 AM
Page generated in 0.25260 seconds with 23 queries
