E-Tuners / Custom Hardparts
Like Tree11Likes
 Old 01-13-2014, 05:51 PM   #1
Default AFR targets at loads higher than 2.50 ATR/ATP fix
As the temperatures got colder and people were pushing more and more air with their BT setups we started to notice that the cars were no longer following the target AFRs when loads exceeded 2.50. To properly diagnose this as the problem that is happening to your car, you should see a "step" change in AFRs AND injector duty cycle just as the car hits 2.50 load. See the log attached and highlighted for this and look at how the AFRs jump just as the load gets to 2.50. Make sure the car is leak free on the exhaust and intake and this is the actual reason for incorrect AFR readings
A few of the tuners on here made the same observation so we did some investigation and found that some of the fueling tables in ATP/ATR are actually mislabelled by COBB.
Generally when the AFR targets for normal operation are set, they are set in the No Knock, Base, and Unused (just to be safe) tables.
The knocking tables are generally left untouched at OEM values since they don't come into play until the car knocks - or so everyone thought.
This is actually not the case. When the car knocks the AFRs go 0.5 AFR richer from whatever table and target the car is following at that point.
So what do the knocking tables do??
They are actually tables that are invoked when the car goes above a certain load value. On most of the cars we have seen that load value is 2.50. This value is actually stored in a table that COBB hasn't revealed (yet).
The fix is actually quite simple. Set all the "knocking" tables to match the no knock tables. The "knocking" part of the table name is actually not true, these don't have anything to do with knocking.
The tables are all pretty much the same in all gens and the MS6, I have highlighted these below for a Gen1 Speed3.
EDIT:
This problem seems to potentially have different solutions in different cars. If the above does not fix it, the following should work:
1. When the load goes above 2.5 and the AFRs come off target, calculate a new scalar for the MAF curve. To do this, divide the actual AFRs in the logs by the Requested AFRs in the fuel tables.
2. Multiply the MAF table by this scalar and multiply the load tables by the same amount.
If this still doesn't solve the issue, then there are two more areas to look at:
1. Instead of using an injector scalar for E85, just scale the MAF and set the injector scalar to 1.00
2. If you are using a phasing multiplier, set this to 1.00
The Following 52 Users Say Thank You to Lex For This Useful Post:
2.0t03speed (01-15-2014), 802MS3 (01-13-2014), alexryan (01-20-2014), atvfreek (01-13-2014), beachshoer (01-13-2014), big angry bird (01-14-2014), Boosted Beluga (01-15-2014), Boost_creep (07-08-2015), BrianB6 (01-13-2014), charlesfist (01-14-2014), chaser27 (01-13-2014), DSIT995 (01-18-2014), Enki (01-20-2014), Fjager (03-20-2014), forcedinduktion (01-16-2014), FORZDA 1 (01-13-2014), GabbyChaves (01-14-2014), Hammology (01-22-2014), Hush (01-13-2014), Jansi (01-20-2014), JeffroMS3 (01-16-2014), jseams (01-13-2014), KCi (01-15-2014), King Scumbag (01-15-2014), maisonvi (01-20-2014), meicalnissyen (10-10-2016), Mistersix (04-30-2014), mituc (01-17-2014), Mochi (01-14-2014), ms6mil (01-13-2014), mzr0818 (01-14-2014), nindoja (01-13-2014), Nliiitend1 (01-14-2014), phate (01-14-2014), Pointless (01-13-2014), Pu Manchu (01-13-2014), pwdunmore (01-14-2014), resilientone (01-14-2014), Rich990 (01-15-2014), RichieRichness (08-12-2014), rtabagaboy (01-14-2014), SarcasticOne (01-13-2014), sidekick (01-13-2014), silvapain (01-14-2014), snailD (01-13-2014), SparkySparks (01-20-2014), speed23 (01-13-2014), SpeedRebirth (01-22-2014), taf0422 (01-13-2014), thricestrat (01-14-2014), Tomas (01-18-2014), YABBAMZR (01-13-2014)
 Old 01-13-2014, 06:21 PM   #2
chaser27's Avatar
Posts: 1,276   (View Stats)
Groans: 42
Now I just need to get fast enough to hit 2.5+ loads.
Coming at ya with all 297/359
ECU: self-tuned
RADAR: Passport Escort 9500ci
The Following 6 Users Say Thank You to chaser27 For This Useful Post:
brandonf (01-16-2014), Lex (01-13-2014), mzr0818 (01-14-2014), Nliiitend1 (01-14-2014), rfinkle2 (01-14-2014), Sid3wayS (01-15-2014)
 Old 01-18-2014, 10:55 AM   #3
chaser27's Avatar
Groans: 42
So apparently, this became relevant to me quicker than I had expected. I've been playing with my tune, it was cold this morning and bumped a 2.52 Calc Load today. Just like @superskaterxes; was seeing, my AFR goes rich as hell on a Gen 2 and stays there until it corrects itself. I'm attaching my log for anyone that wants to take a look-see and a graph that shows the ECU going WTF and fixing itself.
ECU: self-tuned
The Following 2 Users Say Thank You to chaser27 For This Useful Post:
Realgib3 (01-18-2014), superskaterxes (01-20-2014)
 Old 01-18-2014, 11:42 AM   #4
Eth Fiend
phate's Avatar
Posts: 6,947   (View Stats)
That looks more like the WOT trims running out of room, then suddenly kicking off (or on, not sure what the target vs actual is. Your axis scaling sucks ).
-06 MS6
-Corn fed 07 MS3 - Sold
rfinkle2 (01-18-2014)
 Old 01-18-2014, 11:45 AM   #5
chaser27's Avatar
Groans: 42
I'm targeting 11.4 for now while I figure out how things play with each other. And they have been hitting almost dead on until the 2.52 today
ECU: self-tuned
 Old 01-18-2014, 02:16 PM   #6
Did you verify that this is not the case when loads are below 2.50 with an A-B-A test? Almost looks like SWAS was involved there.
chaser27 (01-18-2014)
 Old 01-13-2014, 06:24 PM   #7
atvfreek's Avatar
Posts: 7,787   (View Stats)
Thanks Lex, I'm glad I wasn't going crazy in seeing afr's go lean above that specific load point.
2010 Speed3-PTE5858
Freek built/Freektuned
510hp420tq
11.321@129.93
Lex (01-13-2014)
 Old 01-13-2014, 06:25 PM   #8
ms6mil's Avatar
Posts: 4,972   (View Stats)
Groans: 307
Thanks @Lex; I've been having similar issues, I'll give this a shot.
"Here am I. Send me!"
GT3076 - 393/380 3/9 e85
PTE5862 - TBD
The Following User Says Thank You to ms6mil For This Useful Post:
Lex (01-13-2014)
 Old 01-13-2014, 06:56 PM   #9
beachshoer's Avatar
Posts: 2,039   (View Stats)
Good job guys finding a fix and ACTUALLY SHARING it with everyone. That's what this place is all about.
Proud to be Lex tuned.
2010 BM MS3
BNR S3
STRATIFIED TUNED
Other Mazdas in my stable
2010 VR MS3 Wifes Ride
1999 Miata
2001 Miata LS
The Following 5 Users Say Thank You to beachshoer For This Useful Post:
atvfreek (01-13-2014), forcedinduktion (01-16-2014), Lex (01-13-2014), Nliiitend1 (01-14-2014), silvapain (01-14-2014)
 Old 01-13-2014, 07:31 PM   #10
ms6mil's Avatar
Groans: 307
@Lex; once the load goes above 2.5 and transitions into the "knock" table, are we to only likely to see richer AFR's? Will it then remain within that table until the end of the run? Or does it transition back to no knock table at some point.
Reason for asking is because I do notice the richer AFR's to a point but also have seen them go the complete other way and settling towards redline. (Only occurs specific to the 2.5 load) Maybe unrelated
PTE5862 - TBD
 Old 01-13-2014, 07:35 PM   #11
Once it drops below 2.50 it goes back to the normal tables so you might see some oscillation if you're around the 2.50 mark.
Also with the MS6 specifically the VVT VE table has a large effect on fueling as soon as you change the VVT advance table from stock.
The Following 8 Users Say Thank You to Lex For This Useful Post:
Agent_Orange (01-13-2014), charlesfist (01-14-2014), Mistersix (05-16-2015), ms6mil (01-13-2014), Nliiitend1 (01-14-2014), rfinkle2 (01-14-2014), silvapain (01-14-2014), snailD (01-13-2014)
 Old 01-13-2014, 07:50 PM   #12
ms6mil's Avatar
Groans: 307
Haha yeah I found that out the scary way, (trial "with" error). Thanks again for the info Lex.
PTE5862 - TBD
Lex (01-13-2014)
 Old 02-06-2015, 01:19 PM   #13
qkrthnu2's Avatar
Posts: 131   (View Stats)
qkrthnu2 has a reputation beyond reputeqkrthnu2 has a reputation beyond reputeqkrthnu2 has a reputation beyond reputeqkrthnu2 has a reputation beyond reputeqkrthnu2 has a reputation beyond reputeqkrthnu2 has a reputation beyond reputeqkrthnu2 has a reputation beyond reputeqkrthnu2 has a reputation beyond reputeqkrthnu2 has a reputation beyond reputeqkrthnu2 has a reputation beyond reputeqkrthnu2 has a reputation beyond repute
@Lex Does this warning only apply at loads above 2.50?
Looking at the COBB OTS maps, they're making quite a few VVT Advance changes between Stage 0 v233 & Stage 2 v233, however they're not touching the VVT VE comp table. Is that just an omission on COBB's part?
The VVT VE table is hard to interpret, the values sort of correlate with the VVT Advance table as a large pattern, but individual cells are all over the place more like the VE table.
I thought I could make sense of the stock map @ the 2500rpm / 2.00 load.
30 VVT timing x VVT VE comp of 0.0310 = VE of 0.9333
But not everything lines up nice with my assumed math (I'm probably wrong/missing factors). e.g. 2500rpm / 1.00 load
VE of 0.9700 divided by VE Comp of 0.0280 = 34.6, so I would expect to see 35 in the VVT Advance, but it's still 30.
_______________________________________________
Driver Mods - Mid Ohio Three Day Racing School
2006 Mazdaspeed 6 GT - 130k+ miles. Daily driver (Actually my Wife's car)
Shooting for a reliable 350 AWHP.
Surefire Remanufactured Engine Installed @ 135k.
Mods: BNR S3 Turbo \ Grimmspeed EBCS \ Guardian Angel \ Cobb AccessPort \ Bosch 3 Bar MAP sensor \ AWR RMM \ TurbineTech FMM \ Corksport HPFP \ cp-e Injector seals \ Autolite XP5263 plugs \ Ebay Circuit Werks DP \ Stock CBE \ HTP 3" Intake w/ DIY CAI \ cp-e TMIC \ DIY boost tubes \ Primary & Secondary EGR delete \ Bilstein Shocks \ 215/45ZR -18 Continental ExtremeContact DWS
PERM dual PVC plate and two Damond Motorsports catch cans. Full vacuum setup w/ VTA for over pressure.
PERM #1 -> DM OCC V1 -> DM PCV valve -> Check Valve -> Intake Manifold.
PERM #2 -> DM OCC V2 w/ VTA -> Check Valve -> Tee -> Valve Cover & TIP.
The others:
2009 BMW 135i - N54 - JB4 w/ backend flash \ SRI.
1998 VW GTI VR6 - 248k miles (stock clutch!) when wrecked (not my fault)
1995 Jeep XJ - 4.0 - AW4 \ Lift/Tires etc. 230k miles. Rust bucket / winter beater.
1995 Honda del sol VTEC - DIY hodge podge turbo setup \ self tuned w/ Neptune. 2550lbs ~270whp \ 150k+ miles on stock bottom end (4th clutch though) \ knock limited on 93 octane.
Last edited by qkrthnu2; 02-06-2015 at 03:45 PM. Reason: Added COBB OTS observations ; More Running in circles
qkrthnu2 is offline   Reply With Quote
 Old 01-13-2014, 07:43 PM   #14
snailD's Avatar
Posts: 3,039   (View Stats)
thanks for the info Lex! I haven't looked into anyone going over that load yet but its good to know for the future.
Lex (01-13-2014)
 Old 01-13-2014, 07:53 PM   #15
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,163   (View Stats)
Groans: 793
are people at cobb still working on our platform?
"Exclusivity" - CP-enis
Demodded.
The Seals
The Following 8 Users Say Thank You to Tokay444 For This Useful Post:
atvfreek (01-13-2014), blackms3_71 (01-14-2014), Mochi (01-14-2014), ms6mil (01-13-2014), Nliiitend1 (01-14-2014), rfinkle2 (01-14-2014), Sid3wayS (01-15-2014), silvapain (01-14-2014)
 Old 01-13-2014, 07:58 PM   #16
snailD's Avatar
lol good question
The Following 2 Users Say Thank You to snailD For This Useful Post:
chaser27 (01-13-2014), ms6mil (01-13-2014)
 Old 01-14-2014, 05:46 AM   #17
I have seen this on 4-5 gen 2 cars but never on a gen 1. I always set my knock/no knock tables identically along with the rest of my fueling tables and i still see the same thing happening. If you need some evidence/logs i can send over whatever.
atvfreek (01-14-2014), LatinKraze (01-14-2014), Lex (01-14-2014), TiGraySpeed6 (01-15-2014)
 Old 01-14-2014, 09:11 AM   #18
There might be something else going on there. Are the AFRs going lean or rich for you? Also is this only on Gen2 cars?
 Old 01-14-2014, 10:25 AM   #19
thricestrat's Avatar
Posts: 232   (View Stats)
thricestrat is the leader of the worldthricestrat is the leader of the worldthricestrat is the leader of the worldthricestrat is the leader of the worldthricestrat is the leader of the worldthricestrat is the leader of the worldthricestrat is the leader of the worldthricestrat is the leader of the worldthricestrat is the leader of the worldthricestrat is the leader of the worldthricestrat is the leader of the world
Wow... so we dont have the option of setting a full table of knocking values (as we thought we did)? If the commanded fuel (knocking) table is only used by the ecu above load 2.5, 90% of this table is useless. Im assuming this is the case for OL/Part throttle as well?
Awesome find, thanks!
Koni Yellows / Eibach Pro Springs / CX & Treadstone FMIC / HTP 3.5" / PowerSlot Rotors / Moog Rear Endlinks / ProSport Boost Gauge / CP-E Defrost Vent Pod / Autotech HPFP / Cobb AP V3 / BNR S1->S3->Modded S3 / CP-E Stage 2 RMM / JBR Boost Tubes / JBR Recirc Tube / JBR EGR Block Off /
thricestrat is offline   Reply With Quote
 Old 01-14-2014, 10:55 AM   #20
atvfreek's Avatar
Cars I've seen it on actually go lean.
@rfinkle2; I will dig up a log shortly
2010 Speed3-PTE5858
510hp420tq
11.321@129.93
The Following 2 Users Say Thank You to atvfreek For This Useful Post:
resilientone (01-14-2014), rfinkle2 (01-14-2014)
 Old 01-15-2014, 08:22 AM   #21
Dimenus's Avatar
Posts: 2,825   (View Stats)
Groans: 33
Edit: Removed. I'm probably wrong. I threw a system too lean code in the cold when it was ~ -10 degrees here. I've since reflashed the map and my LTFT have shifted almost positive on a 93 map. The code hasn't re-appeared though.
I've definitely seen over 2.5 load on the stock turbo. It's not sustained, but it does happen.
2012 Velocity Red Mica
The Following User Says Thank You to Dimenus For This Useful Post:
rfinkle2 (01-15-2014)
 Old 01-14-2014, 10:30 AM   #22
Have you guys tried scaling the load axis? One thing of note: It seems when scaling the load axis, the ignition AND fuel tables are affected.
Does anyone have a log of this we could look @?
 Old 01-14-2014, 10:36 AM   #23
+1 on log, would be very interesting to see. @Lex; did you find this/verify this with live tracing?
 Old 01-14-2014, 11:14 AM   #24
resilientone's Avatar
Posts: 139   (View Stats)
resilientone has a reputation beyond reputeresilientone has a reputation beyond reputeresilientone has a reputation beyond reputeresilientone has a reputation beyond reputeresilientone has a reputation beyond reputeresilientone has a reputation beyond reputeresilientone has a reputation beyond reputeresilientone has a reputation beyond reputeresilientone has a reputation beyond reputeresilientone has a reputation beyond reputeresilientone has a reputation beyond repute
I'm glad to see some progress being made on this issue. I see a little over 2.50 load pretty often and my AFRs go lean when it happens. It'll be nice when this is ironed out. Thanks again Lex.
resilientone is offline   Reply With Quote
 Old 01-14-2014, 11:27 AM   #25
atvfreek's Avatar
Here are a couple logs to show the lean spot. I would like to mention too, that this never used happen and I have tuned quite a few cars that go over 2.5 load, so something has to have happened in an update along the way
2010 Speed3-PTE5858
510hp420tq
11.321@129.93
The Following 3 Users Say Thank You to atvfreek For This Useful Post:
rfinkle2 (01-14-2014), thricestrat (01-14-2014), TiGraySpeed6 (01-15-2014)
 Old 01-14-2014, 12:02 PM   #26
Thanks for sharing What do you guys suggest moving forward? If we edit our (knocking) fuel table to match (no-knock) fuel tables, and cobb corrects this... we are then essentially tuning out a fail safe. From reading @lex's post, it sounds to me like the (no-knock) table is not used until a calc load of 2.5 is met. So are we stuck with the ecu correcting 0.5AFR if there is knock? Has this issue been seen with the Ignition Tables (@ 2.5)? ATR tables go to a scalable calc load of 2.0, is our ecu being limited therefor searching for a cell to select when hitting a calc load of 2.5? This theory would be in line with @rfinkle2; suggestion of scaling load axis.
 Old 01-14-2014, 12:54 PM   #27
Originally Posted by thricestrat View Post
Thanks for sharing What do you guys suggest moving forward? If we edit our (knocking) fuel table to match (no-knock) fuel tables, and cobb corrects this... we are then essentially tuning out a fail safe. From reading @lex's post, it sounds to me like the (no-knock) table is not used until a calc load of 2.5 is met. So are we stuck with the ecu correcting 0.5AFR if there is knock? Has this issue been seen with the Ignition Tables (@ 2.5)? ATR tables go to a scalable calc load of 2.0, is our ecu being limited therefor searching for a cell to select when hitting a calc load of 2.5? This theory would be in line with @rfinkle2 suggestion of scaling load axis.
If all of the fueling tables are set to the same target, the ecu will inject fuel when it detects knock without regard to the knocking table.
(assuming the tables are still working as they had in the past).
atvfreek (01-14-2014), ge3kspd (11-08-2014), superskaterxes (01-14-2014)
 Old 01-14-2014, 01:19 PM   #28
Right, this is where im lost. If this issue in ATR exists and we cannot tune for knock properly.. we're kind of screwed. If the ecu is bumping the AFR down by 0.5, that's more then sufficient to counter-act knock, but it is tuning around a larger issue. I realize this is a fix and not an "end all be all", just wanted to clarify before running my (knocking) tables the same as (no-knock) tables that there is in deed "something" to deal with knock.
The Following User Says Thank You to thricestrat For This Useful Post:
 Old 01-14-2014, 01:25 PM   #29
Without completely derailing the thread, I have long set all of the fueling tables the same and allowed the ecu to pull timing and inject fuel when KR occurs. Some people use this strategy, other set the knocking table .5 point or so lower.
I wonder if this is what happened to Jeff's car?
@mzr0818;
mzr0818 (01-14-2014), phate (01-14-2014), superskaterxes (01-14-2014)
 Old 01-14-2014, 01:27 PM   #30
The ECU will add fuel when KR occurs regardless of what you set the knocking fuel tables to.
If you don't see above 2.50 load and your car follows the AFRs you are commanding, don't need to change anything.
802MS3 (01-15-2014), chaser27 (01-15-2014), phate (01-14-2014)
 Old 01-14-2014, 12:39 PM   #31
Based on timing I assume that car is on E85? If it is and you are using the fuel scalars this will cause the car to go lean in the midrange. Use MAF scaling instead to avoid the car going lean in the midrange. I highlighted this region below
For the top end ripple, I suspect it is a hardware issue. The car is below 2.50 load at this point and the gen2s use feedback from the WB02. So check for exhaust leaks and I would also look at the intake for leaks, MAF sensor, etc. Some intakes can also cause this kind of effect in the top end.
 Old 01-14-2014, 11:39 AM   #32
Mike@Stratified's Avatar
Posts: 1,119   (View Stats)
@atvfreek; I'd be interested to know if making the knock/no-knock tables match fixes the lean issue for you. I haven't seen what you are seeing, only the rich condition. I wonder if that discrepancy is based on the different model/year versions of ATR.
 Old 01-14-2014, 12:52 PM   #33
atvfreek's Avatar
It is isolated to the load tables and not the scalars. I have a ton of logs from a couple different cars that it is as soon as it goes over 2.5 load, whether on 93 or e85. One of the cars does it if it just goes over the TRL-x gear table at all (not specifically 2.5 load, as his is 2.3 load)
Here is a link to a guy having a similar issue. When he raised his load tables out of reach (ots) his issue went away
Lean at WOT
2010 Speed3-PTE5858
510hp420tq
11.321@129.93
Last edited by atvfreek; 01-14-2014 at 12:52 PM. Reason: MSF Database - Automerged Doublepost
btstarcher (11-13-2014), LatinKraze (01-14-2014), rfinkle2 (01-14-2014)
 Old 01-14-2014, 01:08 PM   #34
Lean at WOT
I haven't seen this issue and I fully load tune so load tables/targets are always in play. I've attached a log for reference. The car follows target AFRs aside from going a tad lean after spool which is fairly normal due to the ECU ending spool enrichment and then starting to lean out up top when his IDCs get above 110.
I have seen the issue when using the injector scalars on the same car and others above certain loads.
atvfreek (01-14-2014), silvapain (01-15-2014)
 Old 01-15-2014, 06:06 AM   #35
ms6mil's Avatar
Groans: 307
Lean at WOT
I am going to get some more logs later today, but was curious if you or anyone has tried this fix to the fuel tables yet with logs to show it working. I don't always hit above 2.5 so haven't been able to verify success. I have been having the same "lean" issue on both 93 and e85 maps as well. Here's my thread started back in August when I first noticed it, along with the recent occurrence. Random Lean @ WOT
PTE5862 - TBD
atvfreek (01-15-2014)
 Old 01-15-2014, 06:39 AM   #36
atvfreek's Avatar
Your log was exactly 2.5 load as well. lol. I haven't seen them go that lean before, but same scenario for sure.
I just sent out a map with the boost toggle unchecked and want to see if that makes any difference.
What are your trl-x tables set to? Are they at 2.5 or above 2.5?
2010 Speed3-PTE5858
510hp420tq
11.321@129.93
ms6mil (01-15-2014), rfinkle2 (01-15-2014)
 Old 01-15-2014, 06:45 AM   #37
How heavily have you tried to correct that portion of the fuel curve freek?
 Old 01-15-2014, 06:50 AM   #38
atvfreek's Avatar
Not heavily because if the log stays at 2.49 the afr is dead on perfect. The second it hits 2.5 on this specific car is goes from 11.8 to 12.2.
Now when it hits the same g/s yet at a higher rpm, that will give less calc load and the afr will still be spot on
2010 Speed3-PTE5858
510hp420tq
11.321@129.93
The Following 4 Users Say Thank You to atvfreek For This Useful Post:
chaser27 (01-15-2014), Jansi (01-20-2014), ms6mil (01-15-2014), rfinkle2 (01-15-2014)
 Old 01-15-2014, 07:31 AM   #39
ms6mil's Avatar
Groans: 307
everything is set above 2.5. (3.0)
PTE5862 - TBD
 Old 01-15-2014, 07:53 AM   #40
Realgib3's Avatar
Posts: 2,443   (View Stats)
I always always always had issues until I set my all my load limits to 5
It was just a weird thing where even when I was under the limits of 3.0, I still saw issues. I feel like I had other issues that showed up too, other than afr, but it's been so damn long I can't remember for sure.
The Following 2 Users Say Thank You to Realgib3 For This Useful Post:
Mazda CEO targets higher sales, upscale brand image Haltech Automotive News 0 12-09-2012 10:20 PM
Bentley targets 'robust' growth, higher profits as wealthy reopen wallets Haltech Automotive News 0 01-03-2012 07:20 AM
U.S. extends concession on trucks to win support for higher mpg targets Haltech Automotive News 0 07-15-2011 08:50 AM
U.S. offers automakers concession on trucks to win support for higher mpg targets Haltech Automotive News 0 07-14-2011 10:00 PM
Report: Morgan hits record sales in 2009, targets even higher for 2010 Haltech Automotive News 0 01-12-2010 07:00 AM
Page generated in 0.75397 seconds with 36 queries
