E-Tuners / Custom Hardparts
  • 2 Post By Lex
 Old 09-03-2014, 12:05 PM   #1
Default The anatomy of a WMI failure
Currently tuning a customer with a Water-Methanol Injection (WMI) system and a big turbo. It's a 2010 MS3 with a GTX3071 and a D10 nozzle running a 50/50 mix.
In the middle of a 2-3-4 gear run his WMI system failed and it's interesting to have a look at the data before and during the failure. It also shows that it's not all sunshine and rainbows and a WMI failure can ruin your day. In this case the failure was the tank running low.
The graphs below show normal WMI operation during a 4th gear pull. Notice that the Boosted Air Temperatures (BAT) don't rise during the pull more than 10F.
Also note the injector duty cycle. The car has WOT fueling trims that are compensating for the extra fuel supplied by the WMI system. His duty cycle stays around 90%.
Now here the failure happens half way through the 4th gear pull in this 2-3-4 pull. First notice the big rise in BATs during the 4th gear section and the Knock Retard (KR) of 4*.
A second piece of data confirming WMI has stopped spraying is the injector duty cycle that is now over 100%. You can see the jump in duty cycle associated with the knock just as the system fails.
Moral of the story is that if you are pushing the car on WMI, a failsafe is a great idea. You can couple any of the existing failsafe devices from WMI kit manufacturers with the GA. We are also working on a failsafe system that can be setup to catch these scenarios with any WMI kit but unfortunately it is still under development.
Lacey28 and trancehead like this.
The Following 24 Users Say Thank You to Lex For This Useful Post:
Axela_EN (09-03-2014), bigspender (09-09-2014), chaser27 (09-05-2014), Code Monkey (09-03-2014), CrawlingMS3 (09-06-2014), CWP_MS3 (09-17-2014), doctavus (10-03-2014), Hush (09-03-2014), IMASA (09-03-2014), jack_hammer (09-05-2014), Jonathanhair07 (09-05-2014), kish89 (09-05-2014), Mauro_Penguin (10-18-2014), mituc (10-18-2014), ms6mil (09-17-2014), MTLspeed6 (09-03-2014), Pointless (09-06-2014), rymanmazda (09-03-2014), speed23 (09-04-2014), Swinger13 (09-05-2014), trancehead (09-03-2014), YABBAMZR (09-06-2014), Z32_MS3 (09-03-2014), [R]usty (09-03-2014)
 Old 09-03-2014, 12:23 PM   #2
dale_gribble's Avatar
Posts: 4,720   (View Stats)
Wait, guardian angel works with existing WMI failsafes? Please elaborate.
EDIT: I am a retard. I definitely overlooked that. I was looking for this exact function yesterday. Badass...
The AEM has a 12V+ trigger, so I am pretty much on it.
MINI H1 6.0 - CAR LED TAILS
Lex (09-03-2014)
 Old 09-03-2014, 12:28 PM   #3
Yes and if the failsafe has a trigger to ground, a very simple relay will trigger the GA. I have schematics for this if anyone has a failsafe with a trigger to ground.
dale_gribble (09-03-2014)
 Old 09-03-2014, 12:44 PM   #4
The AEM 30-3020 failsafe/gauge setup looks like a great pairing for this as a WMI failsafe (on top of GA boost control). It has a high side +12V trigger line and a low side trigger also.
This is exactly what I was looking for and it was under my nose this whole time.
Lex (09-03-2014), neganox (09-18-2014)
 Old 09-04-2014, 05:27 AM   #5
dev
dev's Avatar
Posts: 325   (View Stats)
dev is the leader of the worlddev is the leader of the worlddev is the leader of the worlddev is the leader of the worlddev is the leader of the worlddev is the leader of the worlddev is the leader of the worlddev is the leader of the worlddev is the leader of the worlddev is the leader of the worlddev is the leader of the world
@mize13; Glad you bought the failsafe?
Stock as Fuck
dev is offline   Reply With Quote
 Old 09-05-2014, 06:38 AM   #6
Jonathanhair07's Avatar
Posts: 1,601   (View Stats)
Jonathanhair07 is the leader of the worldJonathanhair07 is the leader of the worldJonathanhair07 is the leader of the worldJonathanhair07 is the leader of the worldJonathanhair07 is the leader of the worldJonathanhair07 is the leader of the worldJonathanhair07 is the leader of the worldJonathanhair07 is the leader of the worldJonathanhair07 is the leader of the worldJonathanhair07 is the leader of the worldJonathanhair07 is the leader of the world
Groaned at 8 Times in 4 Posts
@ms6mil; I been reading up on failsafe/Guage setups since I bought my meth kit. AEM makes a good one. Figured I would tag you in this. this would ease the fear if anything was to fail.
2012 Mazdaspeed3
Columbus, Ga
FJ Performance Built Block/GTX3582r
Jonathanhair07 is offline   Reply With Quote
The Following User Says Thank You to Jonathanhair07 For This Useful Post:
ms6mil (09-17-2014)
 Old 09-05-2014, 12:48 PM   #7
Jpspeedthree's Avatar
Posts: 250   (View Stats)
Jpspeedthree is the leader of the worldJpspeedthree is the leader of the worldJpspeedthree is the leader of the worldJpspeedthree is the leader of the worldJpspeedthree is the leader of the worldJpspeedthree is the leader of the worldJpspeedthree is the leader of the worldJpspeedthree is the leader of the worldJpspeedthree is the leader of the worldJpspeedthree is the leader of the worldJpspeedthree is the leader of the world
Not sure how you head out to do some logs and you decide to do them without checking how much meth you have in the tank. Good info though and Failsafe is a good idea.
Corksport SRI - TIP - Vibrant TBE - Turbo XS FMIC - Autotech FP Internals - Ebay Downpipe - Eibach Springs - JBR RMM - Turbosmart DualPort BPV - Cobb Accessport - Tork Upgraded VVT - Grimmspeed EBCS - Snow Performance Stage 2 Meth Kit - Tuned by Tork Motorsports.
Jpspeedthree is offline   Reply With Quote
The Following 2 Users Say Thank You to Jpspeedthree For This Useful Post:
mr.speedy3 (11-09-2014), WetzMS3 (09-05-2014)
 Old 09-06-2014, 11:38 AM   #8
There are a large number of reason for a system to fail. Whether its low fluid, a seized pump, wiring connection or a leaky fitting.
The important thing to take away is that - should there be a failure, can you catch it and do something about it? If you can't, how high is the risk?
If you're running a smallish D07 and lower nozzle and a 50/50 mix the methanol won't affect your fueling and timing increases due to meth will be small. So a failure is not as risky. For people relying on meth for fuel and significant timing increases on stock motors it is much more critical.
mituc (10-18-2014)
 Old 09-17-2014, 12:37 AM   #9
KCi
KCi's Avatar
Posts: 93   (View Stats)
Great info Lex! GA will be my next shopping list. I have AEM kit as well.
The Following User Says Thank You to KCi For This Useful Post:
Lex (09-17-2014)
 Old 09-17-2014, 01:02 AM   #10
btstarcher's Avatar
Posts: 4,852   (View Stats)
@mazdafreak;
SnailTune in progress
Lex (09-17-2014)
Video: Watch the anatomy of a road washing out Haltech Automotive News 0 04-17-2013 11:00 AM
anatomy of OEM fuel pump failure jack_hammer MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 11 02-01-2012 12:45 PM
Anatomy of a Top-Fuel Dragster Haltech Automotive News 1 01-24-2011 06:39 AM
Anatomy of a race driver proves hardcore required Haltech Automotive News 0 05-01-2008 05:41 PM
Page generated in 0.31163 seconds with 27 queries
